View Full Version : Generation III Internal Engine
  1. biggest cam with stock tc
  2. LS1 Hone
  3. Ever use longer rods?
  4. Lq4 parts interchange.....
  5. Lq4 swap please help....eek...Advice please...
  6. Forged 347
  7. 5.3 or ls6 with torquer v3
  8. Bent pushrods
  9. 4.8l cam?
  10. horse and torque question
  11. 408 CR Help please
  12. Location of Spark Plug on 4.8 vs. 5.7 Heads?
  13. WooHoooo! Heads and cam are in!!!!!!!!!!
  14. Best place to get pistons coated, and should ring lands get coated?
  15. LS1 forge rebuild
  16. Exhaust flow cfm
  17. engine noise on an 01 ws6
  18. adjustable timing gearset needed for cam install in LS6?
  19. Heads and T-Rex cam ?
  20. dyno numbers
  21. LS1 Head Help CFM (PRC Heads)
  22. Flat Spotted Roller Lifter???
  23. remote start?
  24. Questions About Water Methanol Alcohol Injection - Post Them Here
  25. TSPs 5.3 stg 2.5 w/228Rcam anyone running this?
  26. I'm about to replace my head gaskets..........
  27. car wont stay running. electrical im sure. help diagnose?
  28. fowler db guage
  29. Livernois Head, opinion needed
  30. Livernois head, opinion needed
  31. Stock LS1, Put 5.3 Heads On? Which Casting?
  32. MTI r1 cam ?'s
  33. Where can I find oil pan with good price?
  34. Just installed Prothane Motor Mounts
  35. New block or re-line?
  36. How much can a 6.0 Iron block be bored
  37. 55k miles...cam?
  38. 248/248 .590/.590 106???
  39. Would LOVE to hear clips of diff cams on stock heads
  40. lifter advice with h/c swap
  41. Did a Compression test..think i gotta problem
  42. Need Help With Rebuild Parts
  43. milling heads with an ASA
  44. Are BBK intakes any good?
  45. h/c setup
  46. Ls1 tear down
  47. 6.0L or 5.3L for 56 chevy
  48. Trex and heads
  49. Who has the best deal on a long block or crate motor?
  50. fixed knock sensors still read code?
  51. Best head & cam package
  52. Unknown cam?
  53. Help! Lost 10-15 lbs of oil pressure
  54. Need H/C swap advice
  55. Ls1 Noise 99 Camaro Please Help
  56. Poor Dyno #s
  57. How many miles did you have when you installed a bigger cam and has it held up??
  58. one more cam question
  59. wanting to mill ls1 heads
  60. MS4 question
  61. how much faster
  62. milled 5.3 heads asa cam 1.8rr ptv clearance
  63. reluctor ring question
  64. need help with idle,what size drill bit 4 trex? ??? {trex guys}
  65. Best way to change valve springs?
  66. how much to have milled???
  67. my knock sensers are messed up
  68. Rocker question
  69. AFR Or Trick Flow Heads. Which is better?
  70. 251/259, .660/.663, 111LSA 408 power curve
  71. Cam?Buying one!
  72. lightest crank???
  73. Switching Mas Air Flow
  74. Rocker arms effected idle vacuum?
  75. timing chains-i shoulda stayed w/big block
  76. high rev how to
  77. LSX Build Parts List
  78. Crank Sensor ????
  79. 408 Iron Stroker
  80. Cam suggestions for my A4 LS1
  81. heads and cam package
  82. Looking to see what will fit?
  83. Wrapping alot of my threads up
  84. Motor oil recomendation after H/C
  85. Thread sealer?
  86. Keep LS6 intake or go LS2?
  87. broken tail housing?
  88. Stock springs ok
  89. noise from exhaust
  90. Whats Is this hose/line
  91. FEL PRO Gasket Specialist
  92. What difference in power?
  93. this is it...cam time.
  94. Oil leak from rear of engine. Pics inside
  95. cam and spring question?
  96. Older Compstar rods?
  97. Oil Fitting PN?
  98. Switching to smaller cam from Trex... anything that I should change?
  99. 5.3 block Ls6 Heads Are they worthwhile?
  100. HELP rod direction?
  101. Looking for a good shop to get work done i live in central NJ
  102. cam with stock stall?
  103. throttle body
  104. Anyone running the vengeance vrx3 cam?
  105. LS1 cam help
  106. help with vindicator
  107. cam bearing question
  108. Question on LS6 heads
  109. Rod Help!!!!!!
  110. Tricks on tightening crank bolt
  111. idle clip of TR230/224 .575/.563 111 LSA
  112. realistically cam swap price?
  113. new engine break in
  114. trying to ind the right custom gind cam perscription any ideas
  115. ls1 heads vs ls6 heads
  116. connecting rod bolt torque specs
  117. ls2 gto
  118. Adding in LS6 Yellow Valve Springs to an LS1
  119. Here's one for the gurus
  120. Question about CNC machining finish
  121. flycutting for a tspv3??
  122. Heads Cam pricing?
  123. MS3 cam question
  124. What's causing parking brake light and ABS inop light to stay on?
  125. Question on SCR and DCR with 91 octane...
  126. 5.3l heads vs 243 heads
  127. Will this cam work with a stock ls1(w/ bolt-ons)?
  128. WOT Misfire?
  129. What is a LS1 block worth?
  130. Can I get this cam to fit.
  131. bought some used afr's! Replace valve seals?
  132. max power cam for a 408
  133. Cam identification?? Z06??
  134. oil pan and end plates
  135. first year ls1, no good?
  136. Dart 225 heads...now what valves???
  137. Newbie looking for cam help for my Z06, custom grind or off the shelf?
  138. Double Roller fitment issues?
  139. Does $1200 sound about right for rods & pistons
  140. We need a regular supplier to the UK of LS parts
  141. Wanting to go bigger than a MS4 cam
  142. new intake from weiland?
  143. degree a torquer v2 cam
  144. ls6 oil pump and timing chain?
  145. Major radiator poblem
  146. Cam help
  147. LS1, LS2 or LS6????
  148. H/C swap Checklist! Please read.
  149. 224 cam
  150. LS1 heads.what year what number?
  151. 383 427 0r 355 kit help please.
  152. pushrod length?
  153. Fuel rails
  154. Please Help !!!misfire
  155. Possibly going different route with motor, need advice (Kinda long)
  156. What is the maximum amount you can safely flycut?
  157. 100mm MAF and the 1/4 mile
  158. 100mm MAF and the 1/4 mile
  159. 383 SCR/DCR help!
  160. Sluggish and weird sound when I used nitrous
  161. cam Q??
  162. PR help!!!
  163. OK, tried searching, no luck.. Need to pick some stealth cam specs
  164. katech rod bolts
  165. PTV clearence
  166. Question on Patriot LS6 Stage II heads w/225/229 cam
  167. Which oil pump?
  168. timing chain
  169. how big to go???
  170. Cylinder Head Help
  171. New Here - Patriot Performance Valve Springs?
  172. new valves installed price?
  173. How to make my car quit pinging
  174. toss me some ideas?
  175. LS6 double roller install question
  176. GM Part # ???
  177. LS1 Engine Removal, Top or Bottom ???
  178. will a oil cap breather get oil all over the motor?
  179. Cam and Milled heads- What cam Do I get to avoid PTV problems
  180. Idle skip/miss
  181. EGR Removal Problems
  182. Bottom/Crank Pulley Runout?
  183. oil pan LS1??????????any one know the answer?
  184. How many lbs/ft to turn crank over by hand
  185. Part number?
  186. Busted Rocker Arms
  187. Production numbers?
  188. fuel in the oiling system on the first run of a rebuilt engine
  189. anyone elso ever heard of these rods?
  190. ls7 vs. ls1 lifters cup depth difference
  191. Whats the difference- LQ4 & LQ9
  192. Oil pressure question
  193. Camaros with Motor driven throttle blade???
  194. which oil pump?
  195. Valve Cover
  196. Rod bearings...what causes this?
  197. Can I run this cam?
  198. SPONSORS!!! WHO HAS AFR 205's IN STOCK???
  199. Why does longer cam durations cause less torque?
  200. how difficult?????
  201. I Have A Problem With My Ls1!
  202. Every piston hit by valves...
  203. bought oil pump off member does not turn
  204. Changing rod bearings with which ones?
  205. Crane or Comp Guide Plate Question - Roller Rockers
  206. Different head runner sizes
  207. tsp 228r vs. spdc 228/228 vs. possible custom grinded 228
  208. Help!!!
  209. NEW *** Corvettes - Classic Cars - Links - ***NEW
  210. Port and Polish
  211. shoul I buy new afr or used afr head?
  212. LS1 help
  213. Leak down test question
  214. Quick cam question
  215. Witch sponsors sell the items needed for a ls7 cam into and ls1 swap
  216. Soooo lost on choosing a cam
  217. Callies Cranks
  218. I believe my LS1 has a rodknock..
  219. Untuned cam advice?
  220. Putting together short block and crank is binding
  221. H/C + rebuilt t56 + clutch + 9" break in
  222. Dart heads?
  223. Are my valves hitting the pistons?
  224. Can I reuse katechs?
  225. Stock LS1 Connecting Rod Weight?
  226. While doing rod bolts I checked out my bearings and now I'm wondering
  227. Is this a rod knock? Video
  228. More RPMs Scotty!!!
  229. Why - Rockers hit retainers!
  230. motor going bad or trans?
  231. Can ARP MAIN bolts be used w/ align hone??
  232. zo6 cam question
  233. valve rotation ?
  234. Iron Block in 2005 C6 Vette - question
  235. idle clip
  236. Found a bit of a problem, what is it?
  237. Trashed new motor?
  238. Changing oil on garaged car
  239. Any Trouble With Slp Lm1
  240. Head gaskets
  241. Finally decided on what I wanted... High RPM stealth cam recommendations?
  242. Another engine noise thread
  243. 918 springs on LQ4 heads?
  244. Part number for LS1 shortblock?
  245. Really dumb question but what are the holes on the crank pulley for?
  246. Remove a Camaro SS 00 LS1 Engine from Top or Bottom ???
  247. pistons side by side
  248. any other f15 cam owners?
  249. What cam would you guys reccommend
  250. Buying Salvage LQ4
