View Full Version : Generation III Internal Engine
  1. kinda lost here , need some fast help
  2. LS2 Water Pump belt alignment?
  3. Checking PTVC. Let me know if this sounds right.
  4. Sound clip for those thinking about this cam 230/230 111+2
  5. dirty intake
  6. How's this setup - H/C?
  7. Will 2001+ valve seals work on older ls1's?
  8. Low oil light question
  9. cranks and blocks questions
  10. Decision...Heads and Cam
  11. best setup?????
  12. Are 799's valves sodium filled?
  13. Comp timing set 3153KT
  14. Would these be good heads to run with MS4
  15. MS4 and gearing question
  16. 228 in a full bolt on z28
  17. What kind of cam is this? or whos car is this?
  18. whats my c/r
  19. Do I need my ASP machined for Double Timing chain?
  20. Double timing chain compatibility with GMPP Damper
  21. need help with a few things
  22. heads
  23. is this cam to radical?
  24. cams/cams
  25. XHP LS6 race heads, who knows about them?
  26. cats off the camaro help please
  27. Ls1 block anyone wants to sell
  28. Help me diagnose oil burning after cam.
  29. How I Selected my next Cam.
  30. what push rods do i need?
  31. high compression head= better gas mileage?
  32. 98 LS1 heads?
  33. Is the stock crank good enough?
  34. cheapest way to flycut:part 2. check it out
  35. guys with 408strokers or anyone opinions needed on set up
  36. Cam setup help please
  37. ms4?????
  38. Twinscrew?
  39. Cam only numbers A4 full bolt ons 421.74HP 394.29TQ...got a lifter ticking problem
  40. Head Gasket?s
  41. Burns oil and smokes, where to start?
  42. Thinking about buying used cam... I'm leery
  43. you know you have a spun cam bearing if.....
  44. Quench - Would .035 with 9.1DCR or .046 with 8.9DCR be better?
  45. MS4 scares me, going with Tqv.2 some questions:)
  46. Part # for stock rockers
  47. Adding "LIFT only" with a cam (Outcome?)
  48. '03 LQ9 fair price? Tranny options?
  49. trying to learn...need your help
  50. Anyone clearanced their rocker arms?
  51. question
  52. when should oil pump be replaced?
  53. Time to say goodbye?
  54. Po301 misfire sometimes?
  55. Which bolts are torque to yeild?
  56. Questions on the Iron Block 6.0
  57. isky 227/230 580 somthing/590 somthing 112
  58. quick head question
  59. Out the bottom with no lift?
  60. Rough power estimate.....
  61. good deal?
  62. What cam should I get?
  63. Ls1 = Lm7 = Ls4 = Ls7????
  64. Ideal cam for DD 408?
  65. PRC springs w/ .560 lift = ? mileage
  66. PRC LS6 & MS4 or PRC 5.3s & MS3
  67. good cam for stock motor?
  68. LS1 vavle spring tool
  69. GM Goodwrench Replacement Engines, $3,551 w/ 100K-Mile Warranty?
  70. Loud valvetrain
  71. Cam for autoX? Fuel Injectors #?
  72. tsp 228r vs tsp torquer v.2?
  73. 3.903 bore block
  74. Absolute Speed stage 2 5.3's...should I finally change?
  75. Should I change my cam?
  76. odd issues: DTC 300, clanging, runs like a bat out of hell though
  77. RPM Shift Point Question
  78. valve spring kit
  79. Can you use stock valve retainer locks with comp titanium retainers?
  80. patriot dual spring 650 lift without pushrods
  81. Carb'd 5.3l cam opinon
  82. Can you Identify this cam and its specs 229 14 2871 H Who grinds this cam?
  83. camshaft question
  84. Dont want to overcam
  85. problems after H/c swap
  86. 1.8 yella new kind?
  87. 5.3L block same as ls1? what is max C.I. out of one?
  88. 03 zo6 heads work ok with my mods ??
  89. wondering if anyone is running a similar cam
  90. Is this Cam Too Aggressive?
  91. Lets talk built 346's
  92. Melling oil pump
  93. Can stock crank do .020 over and still take 700-800 hp?
  94. trickflow performance head and cam package.has anyone got it from summit
  95. PRW rockers?
  96. PP S2 64cc or PP S2 62cc
  97. Rebuild or Wait?
  98. Cam Questions.
  99. 1.8 rockers worth it??
  100. Question about 241 vs 243 Heads
  101. Rolon timing chain
  102. Streetable at highway speeds?
  103. MS4 with stock LS6 heads? work ok?
  104. Custom cam grind who?
  105. good for n2o
  106. Yet another "help me chose my cam" thread
  107. Since LQ4=Low Compression... Should I get some heads to raise the compression...?
  108. quick help with cam selection please!!
  109. Just Finished my H/C install
  110. new some help
  111. rods good to 1000whp?
  112. Help me choose a CAM!!!!
  113. anyone ever ran a trick flow 228/230 cam with 585 lift
  114. Help me with my Goals. Cam Help
  115. Major differences between S2 and S3 heads?
  116. '03 Z06 heads: Any real benefit over stock '02 LS1 heads??
  117. Have To Remove My Head
  118. MS4 with PRC 2.5 LS6 heads, stock fuel system?
  119. slight knocking noise??
  120. All forged ls1(98 ss engine type)
  121. Cam only
  122. What you think ? LS6 with few mods in dyno
  123. point me in the right direction
  124. timing chain advice
  125. Help with LQ4 install!!!!
  126. 6.098/6.100 rods
  127. GMPP Cams
  128. SLP Firehawk in LS1 tech calender
  129. lq4 pistons
  130. Will 02 MAF work on an 00 LS1 motor?
  131. Won't EVER do this AGAIN! SUCKS!!!!
  132. Need Help with a noise that has been driving me nuts
  133. 317 heads lq4 or lq9
  134. quest for more compression w/o pvc problems.
  135. Where to install water temp probe??
  136. lifter question
  137. Where should I post now?
  138. New cam.. Overloading with gas??
  139. Is it ok to refer to a C5R engine as an "LS1"?
  140. Highest horsepower
  141. My new/old ride :) Former mustang owner needs ls1 help..
  142. 404cid with ETP heads
  143. short head bolts for 04+
  144. torque specs on rod bolts????
  145. is this a good cam?
  146. Ported LS1 castings VS. AFR's
  147. Am I missing anything? (head/cam swap)
  148. ETP L92 Heads for 3.9" bore
  149. Estimating power? 421 Stroker.
  150. Oil pan question.
  151. Oil in manifold/intake ports.
  152. idle problem after H/C swap
  153. How much for a full overhaul? If I need one
  154. G5X3 or MS3
  155. cam bearings
  156. LS6 Heads worth it ?
  157. Difference between correct tune and pro tune
  158. Heads and Cam clip and sound
  159. oil pump relief valve shims
  160. Help please
  161. UD Pully w/ Heads Cam swap
  162. heads/cam swap on C5 and a couple questions!
  163. What heads do i need!!!!!!!!!
  164. Any1 Got A Ls6 Intake 4sale?
  165. Exhaust Set Up Please????!!
  166. a few cam questions.
  167. Is there a difference between LS1 valve covers and LS6?
  168. Need advice on cam, and cam install
  169. CMP Sensor Woes! DTC P0343
  170. LS6 valves question
  171. What are u doing o keep lifters from falling??!!
  172. how much power are patriot heads worth?
  173. which of these two is the better timing Kit...
  174. thinking of buying this motor... good deal?
  175. Possible Overkill
  176. recommendations with 228R cam??
  177. Moroso oil pump.
  178. anybody running a 373 cu?
  179. H/C upgrade for 382
  180. ls6 vs ls2 TB? both work on fast 90?
  181. Question on bare Dart 225s
  182. Custom grind using 1.85 rockers?
  183. what head gaskets for Comp. ratio & PTV?
  184. 408ci nitrous motor questions...
  185. higher miliage oil??
  186. Z06 LS6 VS GTO LS6 Heads
  187. 1.85 ratio rocker arms???
  188. Quick question on crank bearing installation
  189. GM head gasket 12558809 and 12558810
  190. Cam installation.... just makin sure
  191. LS6 with AFRs
  192. Worried about PTV clearence with GMPP CNC LS6 Heads..Any help?
  193. oil pickup tube bolt!!!
  194. Lifter preload
  195. Injector driver install ? on LS-6
  196. Need quick head advice
  197. Question about my 427
  198. Questions about some Milled heads
  199. guide plates?
  200. how can I tell valves are zo6 magnesium valves ? ?
  201. What would you do with $6000...?
  202. Drain oil to change timing chain?
  203. Good pistons vs Better pistons
  204. ENGINE TICKING!!! i have no clue what it is video inside!!!
  205. Which Patriot heads for T-rex?
  206. Custom Cam Specs and SCR-DCR - Can someone check my math?
  207. Gm Hot Cam & Kit
  208. N-Motion Double Roller Install Questions
  209. Alternator Bolt hole not tapped in my 6.0 block.. Help!
  210. How should the rockers sit w/ heads off car?
  211. Compression ratio? help please!!
  212. Diamond 382 blower pistons 10.0 compression???
  213. All Pro heads?
  214. Quick!! In Here!! Help me decide how im gonna Blister my buddies C5
  215. Long tube help
  216. If I give a sponsor the weight of my pistons and rods, can they balance the crank
  217. The numbers are in on 224/224 cam swap
  218. Who has had P2V problems with 230ish cam
  219. 2001 LS1 Long BLock value?
  220. LS6 heads
  221. Best Possible Heads For X1
  222. Valve Seals
  223. SFI 18.1 Approved Fluid Damper, Feedback???
  224. sponsers!
  225. asa cam question
  226. strongest Pushrods?
  227. hows this cam?
  228. Now this is a set of heads.
  229. How can you tell when a hyd lifter is collapsed?
  230. Question On Coolant in the Oil
  231. rocker arm question
  232. MS3 in fully stock car ???
  233. TR 224 + milled PRC 5.3 = PTV issues?
  234. LS6 valley cover mod ? for better oil control?
  235. rod bolts and bearings
  236. Need Instructions for LS1 Rollmaster adj timing chain
  237. what heads
  238. Help me decide
  239. Oil Pump Porting How-to
  240. Gains with my cam and head swap?
  241. Does anyone have a cam retainer plate handy?
  242. 906 casting number what are they...
  243. What brand rods have SYSC stamped on them?
  244. Carnage pics from my LS1.
  245. Question about cam lobes
  246. Daily driver
  247. 393 Question
  248. what is the benefit of a high lift cam?
  249. 1st start-up after sitting for a yr??
  250. What Cam to use with this Head Combo?
