- How's this setup - H/C?
- Will 2001+ valve seals work on older ls1's?
- Low oil light question
- cranks and blocks questions
- Decision...Heads and Cam
- best setup?????
- Are 799's valves sodium filled?
- Comp timing set 3153KT
- Would these be good heads to run with MS4
- MS4 and gearing question
- 228 in a full bolt on z28
- What kind of cam is this? or whos car is this?
- whats my c/r
- Do I need my ASP machined for Double Timing chain?
- Double timing chain compatibility with GMPP Damper
- need help with a few things
- heads
- is this cam to radical?
- cams/cams
- XHP LS6 race heads, who knows about them?
- cats off the camaro help please
- Ls1 block anyone wants to sell
- Help me diagnose oil burning after cam.
- How I Selected my next Cam.
- what push rods do i need?
- high compression head= better gas mileage?
- 98 LS1 heads?
- Is the stock crank good enough?
- cheapest way to flycut:part 2. check it out
- guys with 408strokers or anyone opinions needed on set up
- Cam setup help please
- ms4?????
- Twinscrew?
- Cam only numbers A4 full bolt ons 421.74HP 394.29TQ...got a lifter ticking problem
- Head Gasket?s
- Burns oil and smokes, where to start?
- Thinking about buying used cam... I'm leery
- you know you have a spun cam bearing if.....
- Quench - Would .035 with 9.1DCR or .046 with 8.9DCR be better?
- MS4 scares me, going with Tqv.2 some questions:)
- Part # for stock rockers
- Adding "LIFT only" with a cam (Outcome?)
- '03 LQ9 fair price? Tranny options?
- trying to learn...need your help
- Anyone clearanced their rocker arms?
- question
- when should oil pump be replaced?
- Time to say goodbye?
- Po301 misfire sometimes?
- Which bolts are torque to yeild?
- Questions on the Iron Block 6.0
- isky 227/230 580 somthing/590 somthing 112
- quick head question
- Out the bottom with no lift?
- Rough power estimate.....
- good deal?
- What cam should I get?
- Ls1 = Lm7 = Ls4 = Ls7????
- Ideal cam for DD 408?
- PRC springs w/ .560 lift = ? mileage
- PRC LS6 & MS4 or PRC 5.3s & MS3
- good cam for stock motor?
- LS1 vavle spring tool
- GM Goodwrench Replacement Engines, $3,551 w/ 100K-Mile Warranty?
- Loud valvetrain
- Cam for autoX? Fuel Injectors #?
- tsp 228r vs tsp torquer v.2?
- 3.903 bore block
- Absolute Speed stage 2 5.3's...should I finally change?
- Should I change my cam?
- odd issues: DTC 300, clanging, runs like a bat out of hell though
- RPM Shift Point Question
- valve spring kit
- Can you use stock valve retainer locks with comp titanium retainers?
- patriot dual spring 650 lift without pushrods
- Carb'd 5.3l cam opinon
- Can you Identify this cam and its specs 229 14 2871 H Who grinds this cam?
- camshaft question
- Dont want to overcam
- problems after H/c swap
- 1.8 yella new kind?
- 5.3L block same as ls1? what is max C.I. out of one?
- 03 zo6 heads work ok with my mods ??
- wondering if anyone is running a similar cam
- Is this Cam Too Aggressive?
- Lets talk built 346's
- Melling oil pump
- Can stock crank do .020 over and still take 700-800 hp?
- trickflow performance head and cam package.has anyone got it from summit
- PRW rockers?
- PP S2 64cc or PP S2 62cc
- Rebuild or Wait?
- Cam Questions.
- 1.8 rockers worth it??
- Question about 241 vs 243 Heads
- Rolon timing chain
- Streetable at highway speeds?
- MS4 with stock LS6 heads? work ok?
- Custom cam grind who?
- good for n2o
- Yet another "help me chose my cam" thread
- Since LQ4=Low Compression... Should I get some heads to raise the compression...?
- quick help with cam selection please!!
- Just Finished my H/C install
- new some help
- rods good to 1000whp?
- Help me choose a CAM!!!!
- anyone ever ran a trick flow 228/230 cam with 585 lift
- Help me with my Goals. Cam Help
- Major differences between S2 and S3 heads?
- '03 Z06 heads: Any real benefit over stock '02 LS1 heads??
- Have To Remove My Head
- MS4 with PRC 2.5 LS6 heads, stock fuel system?
- slight knocking noise??
- All forged ls1(98 ss engine type)
- Cam only
- What you think ? LS6 with few mods in dyno
- point me in the right direction
- timing chain advice
- Help with LQ4 install!!!!
- 6.098/6.100 rods
- GMPP Cams
- SLP Firehawk in LS1 tech calender
- lq4 pistons
- Will 02 MAF work on an 00 LS1 motor?
- Won't EVER do this AGAIN! SUCKS!!!!
- Need Help with a noise that has been driving me nuts
- 317 heads lq4 or lq9
- quest for more compression w/o pvc problems.
- Where to install water temp probe??
- lifter question
- Where should I post now?
- New cam.. Overloading with gas??
- Is it ok to refer to a C5R engine as an "LS1"?
- Highest horsepower
- My new/old ride :) Former mustang owner needs ls1 help..
- 404cid with ETP heads
- short head bolts for 04+
- torque specs on rod bolts????
- is this a good cam?
- Ported LS1 castings VS. AFR's
- Am I missing anything? (head/cam swap)
- ETP L92 Heads for 3.9" bore
- Estimating power? 421 Stroker.
- Oil pan question.
- Oil in manifold/intake ports.
- idle problem after H/C swap
- How much for a full overhaul? If I need one
- G5X3 or MS3
- cam bearings
- LS6 Heads worth it ?
- Difference between correct tune and pro tune
- Heads and Cam clip and sound
- oil pump relief valve shims
- Help please
- UD Pully w/ Heads Cam swap
- heads/cam swap on C5 and a couple questions!
- What heads do i need!!!!!!!!!
- Any1 Got A Ls6 Intake 4sale?
- Exhaust Set Up Please????!!
- a few cam questions.
- Is there a difference between LS1 valve covers and LS6?
- Need advice on cam, and cam install
- CMP Sensor Woes! DTC P0343
- LS6 valves question
- What are u doing o keep lifters from falling??!!
- how much power are patriot heads worth?
- which of these two is the better timing Kit...
- thinking of buying this motor... good deal?
- Possible Overkill
- recommendations with 228R cam??
- Moroso oil pump.
- anybody running a 373 cu?
- H/C upgrade for 382
- ls6 vs ls2 TB? both work on fast 90?
- Question on bare Dart 225s
- Custom grind using 1.85 rockers?
- what head gaskets for Comp. ratio & PTV?
- 408ci nitrous motor questions...
- higher miliage oil??
- Z06 LS6 VS GTO LS6 Heads
- 1.85 ratio rocker arms???
- Quick question on crank bearing installation
- GM head gasket 12558809 and 12558810
- Cam installation.... just makin sure
- LS6 with AFRs
- Worried about PTV clearence with GMPP CNC LS6 Heads..Any help?
- oil pickup tube bolt!!!
- Lifter preload
- Injector driver install ? on LS-6
- Need quick head advice
- Question about my 427
- Questions about some Milled heads
- guide plates?
- how can I tell valves are zo6 magnesium valves ? ?
- What would you do with $6000...?
- Drain oil to change timing chain?
- Good pistons vs Better pistons
- ENGINE TICKING!!! i have no clue what it is video inside!!!
- Which Patriot heads for T-rex?
- Custom Cam Specs and SCR-DCR - Can someone check my math?
- Gm Hot Cam & Kit
- N-Motion Double Roller Install Questions
- Alternator Bolt hole not tapped in my 6.0 block.. Help!
- How should the rockers sit w/ heads off car?
- Compression ratio? help please!!
- Diamond 382 blower pistons 10.0 compression???
- All Pro heads?
- Quick!! In Here!! Help me decide how im gonna Blister my buddies C5
- Long tube help
- If I give a sponsor the weight of my pistons and rods, can they balance the crank
- The numbers are in on 224/224 cam swap
- Who has had P2V problems with 230ish cam
- 2001 LS1 Long BLock value?
- LS6 heads
- Best Possible Heads For X1
- Valve Seals
- SFI 18.1 Approved Fluid Damper, Feedback???
- sponsers!
- asa cam question
- strongest Pushrods?
- hows this cam?
- Now this is a set of heads.
- How can you tell when a hyd lifter is collapsed?
- Question On Coolant in the Oil
- rocker arm question
- MS3 in fully stock car ???
- TR 224 + milled PRC 5.3 = PTV issues?
- LS6 valley cover mod ? for better oil control?
- rod bolts and bearings
- Need Instructions for LS1 Rollmaster adj timing chain
- what heads
- Help me decide
- Oil Pump Porting How-to
- Gains with my cam and head swap?
- Does anyone have a cam retainer plate handy?
- 906 casting number what are they...
- What brand rods have SYSC stamped on them?
- Carnage pics from my LS1.
- Question about cam lobes
- Daily driver
- 393 Question
- what is the benefit of a high lift cam?
- 1st start-up after sitting for a yr??
- What Cam to use with this Head Combo?
- Cam Question
- LS6 heads
- Will an LS2 chain work with a Melling High Flow pump?
- another help me pick my cam thread...sorry
- Cam effects on CO and HCO
