View Full Version : Generation III Internal Engine
  1. LQ4 w/ 241's What's my CR?
  2. lme or sdpc
  3. 5.3 stage 1.5 heads/ported fast 90/90 and MS3
  4. valve job, timing chain, oil pump questions
  5. need a little help
  6. Ls2 swap?
  7. Cylinder deglazing
  8. Disgusting Carbon Buildup Everywhere!!! Take a Look!!
  9. Head & cam swap day 1
  10. porting/milling dart pro 1 heads....
  11. Cam Selection Issues
  12. LS2 Chain-Only or Double-Roller?
  13. 408 heads? ported ls6 or ported l92
  14. Anyone want a 5.3 liter vortec?
  15. rotating assembly
  16. main bearing fitment
  17. help me fixx thisss!!
  18. check PTV withOUT pulling the head???
  19. Recommendations:MAXIMIZE Lowend -Offroad LS1
  20. gas mileage with new cam??
  21. Changing cam..best possible with TFS heads?
  22. Yella Terra/Edelbrock Rocker Bolt Combination
  23. ok another 408 compression thread please help :)
  24. Installed LS2 timing chain, have a problem
  25. Opinion on mild XFI cam and DCR
  26. Building the 5.3L block
  27. Do I have to break-in new valve springs?
  28. PTV with custom grind Comp Cam?
  29. What cam shaft?
  30. Patriot Heads
  31. guyz with 408 strokers
  32. cam problems
  33. best setup
  34. SLP oil pump
  35. Main bearings
  36. Pinging question
  37. Opening Up The Combustion Chambers
  38. should i buy a new cam?
  39. Electrical problem. Launching.
  40. Will spinning motor by hand throw off cam sensor?
  41. Oil pressure fluctuation?
  42. Cam for manifolds or shorties, high revs
  43. Aftermarket Fuel Rail....any gain?
  44. LS1 Fuel pump question......
  45. engine fck'd up, need expert suggestions over here
  46. opinions on scat I beam rods?
  47. ARP MAIN STUD questions ?
  48. Bang for Buck N/A Power Addition
  49. Traction control switch
  50. Blew Motor Up
  51. Can you identify what LS cam this is?
  52. Heads
  53. Damn It Guys Help Me Out Here?
  54. Dex-crap sludge
  55. Crankcase Ventilation
  56. Who has passed CA sniffer with 224 or larger cam?
  57. PRC duals need to be shimmed?
  58. power for ls1 with!!
  59. Quick Easy LQ9 question
  60. need some 10 second advice plz!!
  61. milling vs combustion chamber ....
  62. Double or single springs? Proper Cam?
  63. Some Lq9 questions...
  64. Here's My Winter Mod List....Opinions??
  65. What would work best?
  66. Hemi heads on an LSx motor?
  67. PAC racing springs
  68. Help with COMP cams cam guide program
  69. Valves banging pistons and bent and broken push rods...
  70. Low Oil Pressure After Rebuild
  71. 500 BHP Heads and Cam
  72. Valvespring Compressor wont fit back to cylinders! URGENT
  73. What is hurting my power?
  74. cam help
  75. What is this sound???
  76. Port matching intake to head?
  77. Misfire - Cylinder 1, 4, 6 and 8?
  78. problem with my car please help.
  79. 243 Heads
  80. list of Clevite bearing suffixes
  81. Unknown year ls1
  82. new stuff from Comp Cams for '08
  83. Patriot Christmas Special CNC Ported 243's, Cam, Pushrods, & Bolts $1395.00 !!
  84. comp double roller chain
  85. are new lifters a must with a new cam? which lifters?
  86. Which rods, pistons and rings???
  87. stock to zo6 swap
  88. Comp Cams 7955-16 vs Comp Cams 7638-16
  89. Stealth II cam?
  90. GM Oil pans now have diff size oil filter adapter?
  91. Spark plugs
  92. Loud Lifter type noise after head swap
  93. Cam needed parts?
  94. Pulstar Plugs
  95. LS1 Ticking sound
  96. multiple missfire????
  97. about 2 install 90/90 and t rex!!!!
  98. Finished Product?!?!?
  99. 1st start up after heads/cam swap?
  100. 066 cam
  101. Wierd vibrartion
  102. Head Intake + Exhaust for given port size - what affect on hp/tq vs rpm band?
  103. PCV setup
  104. it went boom....Help figure it out
  105. Cam Help!!!
  106. Are ls1's supose to idle higher on start up for warm up?
  107. small cam +1.8 rocker????
  108. Questions about Head/Cam swap...?? (Patrick G, feel free to come on in)
  109. i'm lost. Need 383 help. also hp limits on such
  110. Headgasket options
  111. PRC 5.3L Stg 2.5 and a MS3
  112. ls3 into ls1 car
  113. ses code after cam install
  114. Anyone here running a G5X3??
  115. Torquer V3 cam
  116. stock hp
  117. Timing Chain/Set
  118. Torque converter
  119. speed pro pistons
  120. what price to expect for LS1 water pump?
  121. Could it be preload on lifters Trevor or Jason come in
  122. MS3 cam
  123. Who cnc ports used heads?
  124. LS6-LS1 Differences?
  125. Fel Pro 1041 gaskets?
  126. 91 camaro Ls1 swap, Ls1 has had better days
  127. C.A.T. crankshafts
  128. 404 Stroker No Good??????
  129. I need some Cam Help
  130. ptv with ms3 and prc stage 2.5 5.3s
  131. Help me plan my path to power!
  132. Stock motor blew up. Going to go w/ MS3. Can I use stock 241 heads?
  133. CC'd my heads
  134. Whats needed for a reliable 400rwhp on stock heads?
  135. Milling head - Question
  136. What would you do?
  137. Yank SS400, Nos 5177, MS4, and what heads?
  138. What would be the cause of this !!
  139. which cam will better suit my combo??
  140. Best cam to run in my 402ci.
  141. BUDGET ls1 work. what oil pump and timing chain for a 99 ls1
  142. Power Steering Pump Reservoir
  143. dyno numbers?
  144. weird surge with a code sometimes
  145. Harlan Sharp 1.8 Rockers
  146. LOUD knocking...
  147. need help with engine choice
  148. head and cam or cam only??
  149. what GM headgasket for a 99 ls1 241 heads? why are ls1's so confusing?
  150. How would changing 1.7RR for 1.8RR effect my cam lift???
  151. fast intake !! info ?
  152. Anyone running Isky cam?
  153. Quick Timing Chain Question
  154. bigger exhaust ports....affect on power
  155. I'm just curious...
  156. piston and cam question for new build
  157. spring 4 t rex?????
  158. Doing it all at once - LMK what you think
  159. ls1 specs and dimensions??
  160. LS2 short block w/ ls6 heads/intake?
  161. Cracked front cover.
  162. Boosting my LS1, the break down list
  163. Valve Seals all the same color?
  164. 111lsa cam idle..
  165. 370 v/s 408. what to do?
  166. Help needed from all you old timers...or you youngins.
  167. 1.85 install
  168. Comp valve spring question
  169. Head swap pics and video (56K = No No)
  170. Forged Bottom End
  171. 414cid LS2 Aluminium Stroker or H/C Ls1??
  172. DDing ms3 in gto
  173. PRC Stg 2.5 5.3L Heads + Which cam?
  174. 6.0 iron block question
  175. different specs of LS1?
  176. Cam+Bolt-Ons HP???
  177. Engine swap and elec
  178. URGENT! Damaged threads on head
  179. Carburetor LS1/LS2 (need info)
  180. Thermostat replacement ?
  181. What Cam Is This?
  182. 383 LM7 best cam for E85 and Turbo?
  183. time for new springs
  184. Question: On LS6 from factory in f-body!!
  185. My friend is having some trouble with his firebird
  186. MS4 vs. Thunderracing T-Rex v2
  187. What do you guys think about these numbers...?
  188. Best LS1 Head?
  189. MS3 PTV question
  190. Cam only....now heads
  191. Katech
  192. Which cam?
  193. 347 or 383
  194. Need Help with camshaft
  195. Cam/head combo confusion
  196. pushrod help now!!!!!!
  197. HELP after head swap
  198. ASA cam swap trouble
  199. While I'm at it?
  200. LQ9 piston/valve clearance/compression
  201. Which Cam to go with 01 WS6
  202. what clevite bearings to go with
  203. anyone run this setup..what kind of power #'s
  204. whats involved when dropping the erl pan?
  205. Piston and Head???
  206. Where do you tech sav guy's buy your internal engine parts?
  207. F13 install done!
  208. How high you spinning those 408's?
  209. is this worth it? gen III hotcam and stg 3 LS6 heads
  210. new rockers
  211. stock rods?
  212. ET Heads
  213. 6.0L wall thickness??
  214. Intake Gaskets?.
  215. Ms3 with turbo ? Will it work ok ? let me know what you think
  216. I need your input.
  217. Advice for this set-up?
  218. LS2 and LS1/6 main cap area
  219. g5x3 or this cam?? need input
  220. Crank question
  221. Help! Looking to buy a car.
  222. Labor for Shortblock
  223. Heads for TRUCK with LS1/228R
  224. LS Pro Shaft Rockers
  225. 6.0 head and valve spring?
  226. Eagle ARP rod bolt part number???
  227. What does the 317 stock
  228. Stroker Motor not starting...
  229. Bunch of (noob) question
  230. Cleaning the deck..?
  231. LS1 1.8 roller rockers
  232. Need some Help on this Cam
  233. Cr calculation help
  234. header bolts
  235. Headers
  236. 408 Question
  237. Forged 346, 364, or 370
  238. Heads and Cam HELP!!!!
  239. The age long question: 5.3 vs LS6 for my setup...
  240. Bolt size?
  241. Crank Bolt Stripped, let's talk options?
  242. Anything to look for?
  243. blue smoke on decel?
  244. My Gas Mileage is TERRIBLE whats wrong??
  245. what size injectors
  246. cast iron 6.0 ls1 or ls2?
  247. AFR / LS6 Heads ?
  248. Whats the best places for pistons head gaskets and rings?
  249. 6.0l ??
  250. spark knock with 93+ HELLPPPP
