View Full Version : Generation III Internal Engine
  1. strange tapping noise!!!!!
  2. Best Cam
  3. PTV checking, help
  4. Help ASAP
  5. Strange question about my 98 heads...
  6. better head fit for ms3
  7. Ls2 6.0
  8. Heads cam or a different route this winter...
  9. runs horrible after cam install...
  10. Which head gasket to get?
  11. Need advice on head/cam selection.
  12. Signs/symptoms of a bad lifter....
  13. Install?
  14. much needed help.
  15. PTV issues with 5.3 heads and tsp 233/239?
  16. Balancer removal is being a biatch!! Help!
  17. good cam idea ???
  18. Anyone have a flycutting tool or know where to get it?
  19. 4" stroke issues with a 6.0 block?
  20. has anyone use this 80mm Tb from CRT performance?
  21. Redesigned #26918 Beehive™ Valve Springs
  22. best setup up
  23. 5.3 to 383 Cost Estimate
  24. 450RWHP daily driver...possible?
  25. Indications of insufficent p to v clearance
  26. Broke 2nd set of Rocker Arms?
  27. Head bolts on LQ9 408 iron block
  28. Do I NEED ARP bolts/studs?
  29. valve spring compressor
  30. Cam application and suggestions
  31. anyone tried the edelbrock rpm xtreme series heads
  32. Is the cheater Cam powerful
  33. Uh Oh, Too Much Compression?
  34. Stupid California
  35. Will stock locks work with patriot dual springs??
  36. Down to 2 cams. Tell me what to get
  37. What would be best???
  38. Porting Stock LS1 Heads???
  39. what heads came on a 97 vette, and a 99 TA?
  40. Is a cam for me?
  41. Aftermarket rocker bolts
  42. g5x2 on a 114 +4
  43. ASA and AFR's
  44. does anyone have of vid of this cam??
  45. big cam plus NO2
  46. Which cam to meet my goals? TR230/224 or Trex?
  47. L92 heads on LS1 block
  48. 408 with afr 205s
  49. Rolmaster double row and timing cover wont fit
  50. ported head question
  51. measure cam profile
  52. Where do you find the Edelbrock 454 hp H/C package?
  53. Sarted the winter project this weekend (pics)
  54. Oil Question????
  55. pushrods size
  56. Best way to get Powerbond Pulley started on crank?
  57. What should I look out for, or be weary of when buying used heads?
  58. heads?
  59. car is overheating???????????????????????
  60. Shavings in oil
  61. ah Dangit!!!!!
  62. Advice on the cubes/build for sweet,sweet torque...?
  63. TQR II: 205 or 225 AFR(or other) Heads? Which size?
  64. Milling 205 AFR's....
  65. What size cam in a stock stall? Not a 1/4 mile car
  66. MS3 or Ms4 post up!
  67. Adjustable Rocker arms
  68. advice plz!
  69. Does CompCams make Texas speed cams?
  70. 224/228 114+2... ok with stock lifters?
  71. 5x30 or 10w30 or other?
  72. goin get a trex tomorrow will my 918's hold up?
  73. Which one??
  74. epoxy filler in the head intake runners
  75. how bad is the LS1 intake hurting
  76. Leak down test results
  77. valve stretch
  78. LS1 block
  79. TR230/224 .575/.563 111 LSA: OK to drive 180 miles to the tuner?
  80. wanted 6.2 liter stock pistons size 4065
  81. Crank bolt stuck...suggestions?
  82. Best Medium Size Cam???
  83. Please Help..........ls1 Comparisons
  84. rear mail seal leak
  85. 3/8 -> 1/2" Head gasket holes
  86. cam experts,what would you recommend
  87. Comp Cams said I had to?
  88. Advice on rockers
  89. 7.375 or 7.400 Pushrods.
  90. 6.0 + Cam + Spray
  91. What length pushrods will I need??
  92. ls6 maf to ls1 conversion Q'
  93. Compression check?
  94. ported & shaved ls1 heads
  95. what is the best cam for 243 heads LS6
  96. Will I need to flycut?
  97. Thinking about ETP 215cc Heads...Opinions?
  98. Do these heads need to be milled?
  99. cam package
  100. Thick White Smoke at WOT
  101. Oil Pressure Question With Heads And Cam ??
  102. Cam Recommendations
  103. 98 trans removal ( HEEEELP )
  104. possibly running lean?..opinions
  105. Can i mill a 317 .045 with out problems
  106. MS4 Cam
  107. stripped cam retainer threads...
  108. valvetrain questions
  109. Sealant on GM head bolts?
  110. TSP 228R or Vengeance VRX3
  111. Eneos Oil
  112. Nitrous or heads? And what heads?
  113. cam only soon to be 408
  114. Car doesnt crank?
  115. F13 cam, 7.4 pushrods or 7.425?????
  116. help with new radiator please
  117. fresh air hose?
  118. Ls6 405hp Heads P/p Info??
  119. best & cheapest? diagnostics 98'Z LS1 ?
  120. Oil Question (nothing to do with weights)
  121. Cam help
  122. Help me ID this Heads ???
  123. dumb questions from an LSx dummy
  124. New car....no start (I don't think it is VATS)
  125. LT1 guy says his bottom ends stronger then ls1?!?!?!
  126. Stock head/cam compatability
  127. Quick Tech question
  128. Solid Lifters
  129. please read: problem after cam install..never heard of this
  130. What else req. for 408
  131. Cut out Q'... get one or skip it?
  132. Ticking... Lifter?????
  133. Engine chattering / clacking upon startup?
  134. attempting budget copy of gmpp cnc'd ls6 heads...
  135. estimated amount of time to change lifters?
  136. LS1 Supercharged 383
  137. Will ls7 heads work on a sleeved ls1
  138. Cam question
  139. bbc in a ls1 car what do you think?
  140. Iron heads
  141. Drive shafts
  142. So much for quality control.... ("new" water pump from Advance)
  143. Possible cam.
  144. This needed to be shared....
  145. 98 WS6 w/129k on it...... worth modding?
  146. Dyno Numbers
  147. my electric autometer gauge seems to stay at 50 psi.. why?
  148. LS6 or High Volume Oil Pump??
  149. Forged 347ci on the way...
  150. Where to get .040 MLS Head Gaskets?
  151. Head Bolts or Studs????
  152. will I need a tune if I get a 78 mm ported TB?
  153. using arp bolts in rods
  154. Cam question for 408
  155. of the line launch
  156. whats all needed to change lifters?
  157. Help!!!!!!
  158. Need opinions on what to do with my motor.
  159. Cometic Head Gaskets .040
  160. valve noise
  161. MTI X1 owners... come on in.
  162. 402 upgrade...
  163. 402 and Torquer v.2
  164. Should I change the cam too?
  165. Change cam too?
  166. mti x1 or ms3 cam??
  167. Subjective Performance Difference Between Heads
  168. Just Bought a TSP 233/239
  169. headers or gears
  170. C5R reluctor wheel?
  171. hyd roller cam ?
  172. Mains
  173. Cam Swap
  174. hp from ls1 build
  175. Need To Find A Good SHOP!!!!
  176. Crank Shaft Question
  177. can i re use my stock head bolts??? if not why???
  178. pushrods to long
  179. self aligning or adjustable rockers?
  180. Looking for videos of 400+ ci lsx's
  181. Patriot Performance cam
  182. Need Cam help for LS2 402....
  183. PRC CNC Dart 225 Head?
  184. MS3 guys...
  185. 232/232 110+3 need more exhaust duration?
  186. now this is a failed lifter
  187. Pump Gas
  188. Catch can
  189. GMPP Hot Cam
  190. Anyone have LQ9 head's with Lingenfelter GT2-3 cam
  191. spark plug w/ oil all over it...HELP!!
  192. want a cam that wont require spring changes every xxxx miles
  193. .037 gap???
  194. Rod bolt install pics.
  195. Help me avoid the sewing machine sound
  196. How's it so economical?
  197. Need Help: MTI Stg3 heads on 346ci?
  198. fuel line trouble.
  199. nitrous + custom cam recommendations?
  200. Cam choices P/V issues
  201. Looking for more power, but mileage is getting high
  202. Diff in years for LQ9
  203. Patrick G Donkey Dick Cam
  204. Brown Smoke @ W.O.T. - is this normal?
  205. Need Head Advice
  206. Stock LS6 Heads and Cam
  207. best cam to run with stock heads
  208. Gasket thickness and timing question.
  209. Cam suggestions?
  210. Need help. Whats my SCR/DCR
  211. Got a 346/347 h/c and a 9" rear?
  212. your opinion???
  213. TR 224 on stock ls1 heads? Worthless?
  214. valve spring
  215. 1 clean piston.. 7 dirty pistons.. Question..
  216. Pistons, and rings
  217. MS3 vs. TSP 233/239
  218. ls1 intake
  219. where do you buy the PAC springs from?
  220. TOo much gap?
  221. Comp revises the 918's!!!!
  222. Timing chain help and info
  223. getting a cam
  224. whats the issue?
  225. we have success, so far...listen
  226. 383 stroker, worth it?
  227. Can You Run Yella Terra Ultralights With TFS 215 Heads?
  228. cam/heads
  229. my ls1 build questions
  230. I wanna go .030 over but have a few questions first
  231. Need Some Help
  232. SES light is on??
  233. exhaust ?
  234. 5.7 heads on a 5.3?
  235. AFR heads and Patriot gold springs????
  236. Anyone done a H/C swap without complete header removal?
  237. testing plugs and wires
  238. rp head and cam
  239. Ring Gap
  240. need cam help
  241. So how are the patriot cam cars making out?
  242. Cam recomendation for stalled A4
  243. Putting Motor Back in
  244. New Rods Do i need to Balance the Rotating Assem.
  245. Cam for a 01 Z-28....
  246. High Milage LS1 power?
  247. ls6 cam with stock 241 casting springs
  248. cam for the streets
  249. Lifter Question About The Notch
  250. cam install question
