- The difference Torquer V.2 vs. Torquer V.3
- Cam for PRC 2.5 ls6 heads ?
- whats the biggest baddest cam i can get for my setup
- cam card help
- Too much funwith the gixxer can't forget about the SS
- lq4 6.0 head gasket question
- How do I measure my PP gold spring pressure?
- Replacing Bent Pushrods
- Tickets for being toooo loud..
- if i mill the L92 heads .035 do i have the mill the L76 intake?
- no o-ring=wore out pump?
- Vindicator owners
- Vindicator
- Pushrods
- cam help
- slp zl402
- Coolant Leak after H/C install
- Santa came early for me
- Question on Heads
- Just ordered torquer V3! PTV ?
- Critique my setup
- cheatr cam ?'s
- Write up on installing Harland Sharp rockers
- 241/243 and the differences?
- how much nos can this bottom end handle
- Bought a car with a cam and have some ?s
- Best cam for a Turbo?
- 231/237 pistons and valve contact
- 3/8 pushrods? Who has them for LS1's?
- Where to buy a motor?
- LS6 Cam in a 5.3???
- Bottom End Questions
- ms4
- Vengeance racing h/c/i
- attn sponsors, need lifter tool asap!
- what heads/cam package to chose
- SDPC Teaming Up With MastMotorsports!
- HELP!!! Car wont run
- Guys with a4 and tr224 112lsa
- Car Died Out And Will Not Run!! Help!
- Roll racing, does it matter? (cam)
- Opinions on running a head that has been repaired
- Dumb newb question
- Weird oil pressure issue..help!!!
- This comp cam look good for my combo?
- used cam
- What's the going rate for labor to swap dual valve springs?
- TSP Torquer V.3 sound clip
- custom length pushrods?
- oil pump problem
- head gasket prep
- Just bought Heads and Cam Package
- ms3 pros and cons
- What you guys think about this cam?
- What mod should i do next
- interested in getting a cam
- CompStar tall deck rods
- Piston clearance
- Timing chain stretch
- Which heads: PRC Ls6 or PRC 5.3 stg2
- what preload with comp pro mags...?
- AFR 205's or PRC 220cc 5.3L stage 2.5
- Confirm cam checklist for me.
- Looking to go "Max Effort" cam only.
- Looking for the best combo for street performance..
- ls1 short block
- So I ordered my Torquer 3 and 5.3 heads
- Some "max effort" Dart 225s I just finished
- Rear engine seal part number?
- Please give me your opinions/suggestions
- stock ls1 heads for 558 lift cam, LQ4
- Need Cam Help!
- 120k Ms3
- heads on a trex...
- Comp rocker clearance
- cam w/out tune ??
- could someone tell me what size socket to use for this
- 224 or 228 or bigger ??
- Detonation problem!
- Harmonic Balancer Puller
- Another question about a cam
- Cam numbers??
- Anybody know the part # for the LS6 coolant crossover tube?
- MS4 and PRC LS6 stg 2.5? QUICK?
- Ms3, Ms4, Similar Cam? Please Come In.
- Light Weight Alloys
- lifter tray
- do i need to replace seats when replacing valve springs ?
- Valve spring installed height
- Heads and Cam Question?
- TR224 112 vs 114 lsa
- First Start Up.
- ECT help.
- LS6 vs Z06 cylinder heads
- how much are my heads and cam worth?
- ??????Cam and stall relationship??????
- new car......new cam? input please
- Cam and stall question
- Differences in Vortecs and LS1s?
- Duel Cutouts and O2 Sensors
- LS6 motor w/ tr224 opinions?
- What will it take to spin a Hydraulic roller 347 to 7500 rpm?
- Head bolts
- harland sharp rockers
- comp 918s or dual patriot gold springs with tr224
- Is a H/C swap going to make my car louder?
- lq9 questions....
- To cam now or later?
- max effort 6500rpm cam only
- Cam swap pressure dropped 20psi...
- Possible New LS1
- Cam swap goes sideways, need to pull heads, going aftermarket now. Which ones?
- how much can you mill stock heads?
- Scool me on cams for the ls1 and what power to expect
- Oil leaks after Cam swap
- Whata you guys think?
- What do you guys think of this cam?
- how will this cam do on stock Manifolds+Cats.
- Highest Recorded Mileage
- ls1 machine work and piston size question
- rev limit for 5.3
- so i want over 500 RWHP with a head/cam swap what cam would be best?
- Head Gasket Help
- What Ocatane Gas is suggested on an 00 TA
- I have a quick oil pump question
- pushrood tourqe
- 4.8 or 5.3? help
- Cam/Headers finally installed
- 234/244 .551/.551 110lsa opinions?
- Can I floor It
- Do I need to FlyCut with Dart 205's?
- 918 springs
- Which TSP H/C package would you choose?
- are my valve heights correct
- valves sealing ?
- Does anyone have flow numbers for the TSP stage 2.5 LS6 heads?
- WS6 LS1 opinions needed
- Synthetic Or Conventional
- Another Oil Leak
- advice when buying a water damaged car?
- Comp 918's or PRC Double's?
- 6.0(lq4) With L92 Heads
- 383 Compression Test
- Aftermarket rod length?
- LS1tech + LS1howto = BEST!!
- 370 vs 383
- It you are going to blow one up go all out.
- What is required.... going from aluminum block to iron...
- Misfire detected
- Who has made the most power with a 224 cam or smaller?
- What pushrods are best for a stroker motor??
- HELP.... down cyd.
- Correct way to measure pushrod length question
- exhaust system
- lifters
- best forged rods and pistons?
- AC need to come out to do cam swap?
- 918 Valve Spring -update
- Cam Question
- *solved* low oil pressure after cam + head swap
- Smelling antifreeze at full temp
- Comp XFI Lobes
- Daily driver cam?
- Need Help Choosing
- lifter help!
- Comparison of Vindicator and MS4 Camshafts
- Can the HotCam pass the sniffer test?
- is 90/90 fast worth the money?
- Timing chain help.
- Cam and heads
- Interesting Lifter Test Info from Crane
- Misinformation? Or Am I Just Dumb?
- Tstat wont fit in the Meziere water pump..HELP
- Torquer v3 is in....
- what are 317 heads
- Special Tools for bottom end build?
- Help with ARP headbolt selection
- rough idle LS1 and service engine light?
- Rebuilding stock LS1???
- Anyone have a pushrod install write-up?
- When will the stock block pop?
- Torquer cam (v1)...what heads should i stay away from?
- Rod bolt install SPECIAL circumstances...
- can i hit 400?
- Differences in years on the LS1
- How to prevent detonation?
- Car blowing white smoke!
- CNC'd Edelbrock heads - rocker bolts in the intake ports (pics included)
- need help w 6.0 iron block
- Cam and Headers on 99' t/a
- Need lifters
- bent pushrod questions
- Used engine, what Di I need to make it run
- How did you guys learn to build engines?
- a few questions about building an engine...
- oil leak? Which seal / tools??
- Cam on Stock Manifolds?..
- What's the difference between...
- rod knock or torque coverter bolts ? plz help
- Talking About Bad Luck!!!
- Need Help with My Heads!
- AFR 205's or 225's
- H/C/I & more complete! Thanks for the help LS1Tech.
- thunder racing head and cam cheatr pckg
- question on a part
- largest stroker kit with stock bore?
- Oil Cooler?
- stock ported heads vs prc 5.3's
- LSK lobes for a Daily Driver?
- stock 5.3 heads
- My car is throwing some codes..
- Got head today, pic's to follow
- Loud knocking sound after head install
- New Edelbrock Affordable Heads
- Piston Ring Question
- TR224 114/AFR 205's a good match up?
- cam choice...
- service engine soon light
- stock ls6 heads/intake?
- Oil Cooler
- ARE Stage 3 Heads
- Well boys...the heads and cam are in!!!
- Spec's on 01 LS6 springs
- How many of you daily drive cammed cars?
- What Heads for 98 cam car
- Could I see 425 + rwhp with this combo?
- AFR 205's too much head for a stock motor?
- Cam gear rubbing on retaining plate [PIC]
- Cam only, or Cam and Heads?
- Lunati 221 cam in a 6.0 with stick heads
- My new TFS 235cc heads--flow #'s
- Jesel or CompCams Shaft Rockers?
- Anyone selling ls6 heads?
- Patrick G tuned my TRAK cammed, PRC LS6 2.5's car. Results inside
- Good Beginner Cam Please
- Forged 347 Cam Advice. Please Help
- Anyone have TPIS Stage 2 heads... ??
- what heads and cam
- TRex cam
- need help getting more power cheap
- Help with heads and cam setup
- Valve train gurus help the truckers pleaz
- 5.3 stage 2.5 with magic stick 3????
- cartek cam
- LS2 intake on LS1...
- Any sub 108 icl/lsa guys?
- Which Heads to Compliment My Setup?
- FAST 90/90 with smaller camshafts.
- help with valve adjustment
- Changing a cam bearing question
