View Full Version : Generation III Internal Engine
  1. Head and Cam Question
  2. Just got my new cam installed
  3. Wondering if I was being tricked..
  4. Need advice for head and cam package for the track
  5. dry sump
  6. help me pick a cam for my setup
  7. Anybody seen an LS1 block crack like this??
  8. Ls1 To Ls6
  9. MS4 Cam swap, do I need an underdrive pulley?
  10. Quick reusing cometic question
  11. Torquer 2 vs. F13
  12. V3. with 2500 stall??
  13. corresponding bolt ons with new cam
  14. TR230 people come on in
  15. vig3200 with MS4???
  16. Heads
  17. CAM Vote- HELP & ADVICE needed
  18. The older SLP split duration cam...
  19. Same cam diffrent LSA how HP,TQ More
  20. bigger cam or a FAST 90/90
  21. How good is our stock oil pumps ??
  22. Big Cam Question
  23. Whats this cam got over this cam ?
  24. Heads/Cam swap questions
  25. Looking for the Best Roller Rockers LS1?
  26. Advancing cam question
  27. Trying to avoid flycutting...
  28. Oil pressure gauge.. Stuck at 100psi….
  29. It has begun... Out with the old!
  30. Can I reuse this knock sensor?
  31. wont start after cam + lifter swap
  32. World Warhawk LS1X Heads *Pics*
  33. Part number for Head Gasket
  34. How much can an LS1 handle
  35. HP gains on thinner oil
  36. Lifter difference Comp Cams
  37. need part number for springs retainers.HELP
  38. Looking to get a cam installed...few questions.
  39. How good are the factory rods?
  40. Head swap is finished
  41. It's been christmas at my house.
  42. best pistons/rods
  43. Dart heads with factory rockers/pedestals
  44. 347 cam only questions
  45. What is best Carbide Burr for port matching intake
  46. New project begins, 408
  47. Getting ready to buy Heads/cam! Need Help
  48. MTI 2E/X1 or AFR 205/TR 230/224
  49. Which Cam For My Set up?
  50. What's the best tool to use for replacing dual valve springs with engine in the car?
  51. building a 6.0 iron block what stroke is best?
  52. Fuel problems
  53. How you like your cam now?
  54. Extreme power loss- Dyno graph inside
  55. Need some help here.
  56. Need Info. - Lingenfelter Heads / Cam
  57. speedinc SI7 cam?
  58. Need your help!
  59. 408 owners -what heads & track times?
  60. cam help, 408/trickflow 225
  61. What cam would the public recommend for...
  62. stock z06 cam replacement
  63. Some trouble after H/C Install
  64. When A/C is on i smell coolant?
  65. Who's had both big NA cubes and FI....
  66. Head install on my friends Z28
  67. Good shortblock sponsors?
  68. Critique my potential 408 build
  69. SLP 1.85 Rockers on 98 LS1 ? (TAPPING & low oil pressure)
  70. TR220 and PRC 1.5 heads - Speed / TSP
  71. 98 ls1 block?
  72. headgasket and valvetrain questions
  73. Oil pump install writeup?
  74. Lifter Tray part #?
  75. patriot heads and cam package
  76. Start up of the TREX!!! wat uve all been waitin for.
  77. smoke!
  78. Stock Heads (806,853,241) Enough Difference To Matter?
  79. Question about DCR and camshaft selection.
  80. HELP me choose a cam thats good with nitrous
  81. wondering about my cam......
  82. What oil were you running when you spun your bearings?
  83. Forging on a "Budget"
  84. compression ???
  85. redline oil.....opnions?
  86. The hell noise is this now..
  87. dropping ls6 into camaro, have ?'s
  88. guys help me spend 4000$
  89. how does my cam stack up
  90. car wont start has fuel just no spark please help
  91. Hows this look?
  92. Pushrod shroud broke???
  93. Best Head/Cam package for 02 WS6
  94. need opinion, biggest cam with patriot stageII 59cc
  95. Torque converter
  96. what kind of difference can I expect out of these tow cams?
  97. So many Cams to choose for my setup Help!
  98. LS1 Head Shootout!!!
  99. blew up motor with TSP ms4 and heads
  100. write up for pulling the motor from the top?
  101. what the hell happened to my main bearings?
  102. Help new build
  103. oxygen probs
  104. building a 6.0 iron block to a 408. what machine work needs to be done?
  105. Who sells Katech LS1 Mains Caps Online ?
  106. need help
  107. Whining/wheezing noise
  108. which cam need help
  109. can i use stock head bolts for new heads or use?
  110. cam for n2o 347
  111. Tr 230/224 Vs Tr 236/230
  112. How do you remove the sleeves from the Valve cover bolts?
  113. MS4 and stock stalled A4???
  114. what cam for TEA 1.5 heads
  115. Is MS4 too big for an Automatic?
  116. Rocker Ratios
  117. Can somebody double-check me?
  118. Question about milling heads...
  119. 2000 m6 z28, bolt ons, how much power yall thinkin?
  120. Stock size aftermarket pistons
  121. compression calculator
  122. Mocked up the 409 yesterday.
  123. looking to get heads and 238/244 cam.
  124. Factory oil pressure gauge acting all funny!!!
  125. All Storker LS1 Cars Need advice
  126. Maybe a dumb question here about oil priming
  127. What size to make it? 383, 395 or 400+!
  128. Car is burning/leaking oil, ls1 guys need your OPINION!
  129. Engine swap cost?
  130. How well will a 244/248 cam work in a 346?
  131. engine identification
  132. Good Cam With 114 Lsa
  133. Lunati cam vs. TSP cam
  134. 2003 z06 heads/cam combo
  135. Rebuild on a budget
  136. Trick Flow heads what pushrods and what roller rockers?
  137. Revised trickflow heads?
  138. new motor time.
  139. Lobe Seperation Angle
  140. max rocker ratio with setup?
  141. Graphite head gaskets ok to use on my h/c swap??
  142. need help!!!
  143. TRex or Vindicator
  144. LS6 conversion package??
  145. LG g5x-2 vs TSP TV2
  146. Katech block owners, check photos please..
  147. Lookin for a reputable shop in So.Md./ NoVa area!
  148. oil starvation?
  149. How important is it to tune after head install?
  150. What kinda gains are usually seen from the GM Hotcam?
  151. Help me build my bottom end
  152. How do you check for a collapsed lifter?
  153. All bore 401, cost effective?
  154. AFR heads for a good price...
  155. LS6 into 2000 Z28
  156. HELP; I think I royally screwed up my H/C install.
  157. where to buy a 383 or 408?
  158. Mysterious tick... could this be the cause?
  159. 4.8liter modification suggestions
  160. dcr ?s
  161. Best Oil Pump for 7500rpm Solid Roller FI 408
  162. Rocker Arms !!!!!!!!!! Help needed !
  163. what kind of numbers am i lookn at????
  164. What cam could I get away with?
  165. how much do you think you can bore a 98 block
  166. tsp torquer v.2 good for me?
  167. 415 stroker
  168. What would cause a spun rod bearing in 300 miles?
  169. CAM question
  170. Is 270* Oil Temperature Too Hot???
  171. Bad Smell When Idling At A Stop Light
  172. Livernois vs PRC LS6 Heads
  173. what heads with MS4 and full bolt ons?
  174. What is the difference between LS1 and LS6 intake?
  175. Does anyone know where I can buy the gmpp caddy lifters individually?
  176. whats the realistic RWHP to expect from my set up?
  177. 1st Cam, Got Some Questions
  178. What do i need
  179. What tap size for the 6.0L LQ9 block head bolt holes?...
  180. nasty tick in top end
  181. Question about L92 Heads and VRX3 Cam
  182. iron 6.0l bore
  183. What caused it? Need help....
  184. Compression test...what do these numbers mean?
  185. Chugging?
  186. Cams in with vid (torquer 2)
  187. need some help
  188. scratches in cylinder bore
  189. Erik 408 is in - Hard or Easy Break in???
  190. project shadetree(408 time ) pics
  191. Torquer V2 vs V3
  192. Bent Valve?
  193. can you install a cam off even thoe it dot to dot
  194. How Much Did You Gain From Your Heads!
  195. Dropped a piston, damage assesment
  196. Deleting cats?
  197. how well will the PRC stage 2.5 5.3l heads and cam package work with a th350?
  198. Has anyone used this setup??
  199. can I change bearings without removing the motor
  200. can i put bearings in without removing engine?
  201. LS6 cam?
  202. Can 918's be run to .600 lift safely???
  203. Figuring out cam to go with PRC 2.5 5.3L heads?
  204. To Cryo or not to Cryo, that is the question....
  205. I dunno what its called but its broke!
  206. Coated bearings?
  207. Stuck studs
  208. 6.0 weight
  209. What bolts, plugs etc do I need to finish shortblock?
  210. Need help!!!!!!!!!!!!!!
  211. ls6 block basically the same as ls1?
  212. Where can I buy the best tune from?
  213. Best Intake for L92 heads
  214. HELP!!! Missed a shift tonight 3-4 shift.
  215. loosing oil pressure! HELP PLEASE!
  216. Car Idleing to High???
  217. Lifter noise?
  218. ***Cam Guide*** Sticky Questions
  219. Will an 04 ls1 from a GTO fit into my 02 Z28
  220. Hot Cam, do I need new push rods ?
  221. 5.3 Valve Lash
  222. Valve drop
  223. ported 243's vs stock L92's
  224. Will the TR224 get me there?
  225. T-rex (Little Bigger)
  226. The time has finally come for a cam
  227. Wanna see a messed up motor pics inside
  228. 02' ls1 surging
  229. Forged 347? Iron 370? Opinions Needed
  230. Heads and Cam are in!!! Vid!
  231. Patriot gold springs and Vindicator????
  232. Will patriot performance stage ii heads work with my cam?
  233. Service Engine Soon light on 98 z28
  234. Ls1 engine swap
  235. What to expect from this cam
  236. Car Is Going Crazy!!!????
  237. Reverse Split cams?
  238. Pressure problem
  239. Vid clip of my patriot 226
  240. stock 5.3L heads
  241. What's a good DCR for a street vehicle?
  242. Oil Light...
  243. Who has milled their intake?
  244. Is there anyway to tell what's causing engine ticking?
  245. Low oil pressure on 98 ls1
  246. Ls1 427 extreme engine package from Speed inc
  247. Need some valve train advice
  248. Well Guys, More Bad Luck. Need Opinions Please
  249. Whining noise?
  250. Head help for big spray!?
