View Full Version : Generation III Internal Engine
  1. ls6 block basically the same as ls1?
  2. Where can I buy the best tune from?
  3. Best Intake for L92 heads
  4. HELP!!! Missed a shift tonight 3-4 shift.
  5. loosing oil pressure! HELP PLEASE!
  6. Car Idleing to High???
  7. Lifter noise?
  8. ***Cam Guide*** Sticky Questions
  9. Will an 04 ls1 from a GTO fit into my 02 Z28
  10. Hot Cam, do I need new push rods ?
  11. 5.3 Valve Lash
  12. Valve drop
  13. ported 243's vs stock L92's
  14. Will the TR224 get me there?
  15. T-rex (Little Bigger)
  16. The time has finally come for a cam
  17. Wanna see a messed up motor pics inside
  18. 02' ls1 surging
  19. Forged 347? Iron 370? Opinions Needed
  20. Heads and Cam are in!!! Vid!
  21. Patriot gold springs and Vindicator????
  22. Will patriot performance stage ii heads work with my cam?
  23. Service Engine Soon light on 98 z28
  24. Ls1 engine swap
  25. What to expect from this cam
  26. Car Is Going Crazy!!!????
  27. Reverse Split cams?
  28. Pressure problem
  29. Vid clip of my patriot 226
  30. stock 5.3L heads
  31. What's a good DCR for a street vehicle?
  32. Oil Light...
  33. Who has milled their intake?
  34. Is there anyway to tell what's causing engine ticking?
  35. Low oil pressure on 98 ls1
  36. Ls1 427 extreme engine package from Speed inc
  37. Need some valve train advice
  38. Well Guys, More Bad Luck. Need Opinions Please
  39. Whining noise?
  40. Head help for big spray!?
  41. Hotcam valvespring choices
  42. rollmaster timing set. any good?
  43. Rockin Rockers
  44. How much to mill with 224 .581 cam?
  45. New meaning to "head" lamp. --CAUTION-- Manly thread
  46. yella terra, of old!
  47. ARP Stud Install
  48. How much noise?...
  49. Building motor #4, what's hip today?
  50. Project_SS meets Vengeance Racing
  51. Wooden dowels for cam install?
  52. set of Patriot Stage II 2.02/1.57 72cc LQ9 heads flow #,s runner size?
  53. Torque specs for ARP studs
  54. Heads/Cam install HELP!!!
  55. Heads only on an LS6
  56. piston sticking out of block
  57. 4.8 Crank in 6.0 Block
  58. Z220 cam?
  59. Cam? Which Cam? Help me out here.
  60. help with supercharged lq9
  61. worth putting a cam in a cat-back only 04 Z06?
  62. Too much oil pressure?
  63. Granatelli Roller Rockers ?
  64. What is a 6pt ARP stud kit?
  65. Diamond pistons?
  66. Vengeance VRX5 (236/238) Cam only? Anyone have it?
  67. 1st time flycutting. Any tips?
  68. ARP lube or threadsealer for head bolts?
  69. 02 LS6 cam what length of pushrod is needed
  70. another PTV question
  71. CAM advice
  72. Cheapest place?
  73. update on my H/C/I project
  74. idle after cam Install
  75. Just bought Texas speed 2.5 5.3 L heads
  76. Question on 317 heads
  77. Will I have enough piston to valve clearence?
  78. coolant temp sensors own me
  79. ls1 lifter install...
  80. valve seal install ???????
  81. connecting rod length ?'s
  82. PRC dual springs question
  83. Engine Problems! Help!
  84. Advancing a cam....
  85. Redynoed yesterday = less power. What to check?
  86. white powder on exhaust tips
  87. 224/230 cam questions
  88. New cam...any cleaning needed prior to install?...
  89. People w/Darton MID Engines, Inside Please.....
  90. what you think this normal Idle after Tune cam??
  91. Small oil leak. Quick question
  92. 400$ for a mod What to Get
  93. all you guys with "ticking" sounds this might help
  94. tell me if this is right *valves*
  95. tell me if this is right *valves*
  96. No oil pressure (need suggestions / ideas)
  97. 370 CI on stock Sleeves?
  98. Dipstick tube?
  99. ms4 + 5.3 stage 1.5 ???
  100. Just got done with the TREX !!!!
  101. Cam experts for a 409!
  102. Oil Pump O-ring? Missing
  103. All Ls1 blocks equal?
  104. Patriot dual valve springs
  105. L19 Head studs
  106. FINALLY! bought my cam MTI x1. What else do i need?
  107. Cam Lobes
  108. Heads/cam vs. cam only
  109. LS1 Alternator Question
  110. head gasket?
  111. F/S LS1 connecting rods
  112. Vrx3 Cam
  113. Slightly scratched cam bearing from cam removal....
  114. Possible problem....
  115. GM HOT CAM VIDs or Sound clips PLEASE!!!!!!!!!!!!!
  116. Round abouts install price for cam
  117. Specs on pistons
  118. stall converter w/ cam .581/.592 lift. 224/230 duration 114 lsa?
  119. Which Plugs
  120. look what i got today...
  121. Another carb LSx question
  122. cheatr cam sound
  123. What rockers for Trick Flow heads
  124. 408 guys
  125. question about 4.1 stroker crank
  126. MTI X1 230/227 .591/.571 112 LSA questions
  127. solid lifters??? what do i need???
  128. TSP H/C package
  129. Head choices
  130. TREX cam Questions
  131. cam ?
  132. Exhaust??
  133. ptv ? can i make this fit
  134. Need input on PCV delete system...
  135. Help Motor Problems
  136. My new h/c setup, some questions inside
  137. best head gasket
  138. rwhp increase after break-in?...
  139. Bad lifters???
  140. Competent/Non Competent-Sponsor/Non Sponsor Tech Support???
  141. LS6 LS2 parts compatibility
  142. High idle ???
  143. Factory Rev Limit
  144. Oilling system HELP!!!!
  145. Car won't idle, stalls
  146. Biggest Cam with 59cc heads,
  147. What cam with stock heads & bolt ons M6
  148. Right Bank Misfires!!!
  149. LS1 head torque sequence
  150. oil pump recommendations
  151. T/B and intake swap
  152. wierd idel today...
  153. preping and engine.
  154. rev limiter question
  155. PC clearence question.
  156. looking for quality machine work in BAY AREA?
  157. 450+ Hp Head and Cam Package
  158. Torquer 2 guys! What heads are you running?
  159. how much power??
  160. help...
  161. What would happen if you ran pushrods that were too short?
  162. Lifter Noise on my 99 SS
  163. good Rotating Assembly?????
  164. "Troubleshooting", Chirping noise-Darton 434...
  165. Anyone use pennzoil platinum? (and piston slap question)
  166. Roll Master Double Chain with Slack
  167. LS1 heads considerations on a big bore?
  168. milling ls1 heads
  169. Biggest CAM for the streets "A4"
  170. Need help fast..question about patriot duals
  171. Question about Cam in A4 without stall
  172. Blown motor?
  173. Bore a 5.3L block?
  174. Looking for good stroked Ls1 engine builder/company
  175. What should my PTV clearance be
  176. Cam Only ???
  177. ? about porting stock heads
  178. ways to check ptv clearance?!
  179. Installed cam, having problems.
  180. Valve spring swap help
  181. The Choppy Cam Sound
  182. New cam and stall with stock 2.73 gears
  183. how do you check preload?
  184. 6.0 higher compression pistons?????
  185. Oil pump pick up tube o-ring, a thank-you to LS1Tech members & a modification
  186. Oil issues... very recent problem not sure what to do
  187. 11:1 compression to high for a daily?
  188. Why is my engine knocking / hiccuping? (Video)
  189. New Scorpion Performance Roller Rockers?
  190. Word to the Wise using Pen Magnet Method
  191. stock internal ?s
  192. Pulling engine, those in the know, how did you handle the AC compressor???
  193. main cap installation
  194. Help with my 409!
  195. crank pulley bolt
  196. Cam install starting this morning!
  197. head bolt issue
  198. smoking
  199. need some opinions on bearings...
  200. Oil Presuure Flucuating At Same Rpm?
  201. Negative PTV clearance – very unexpected on my setup
  202. couple cam questions
  203. do i need a shorter pushrods
  204. Smoke at start up.
  205. What kind of improvement do you think I would see?
  206. OTS 4.125" bore by 3.622" stroke pistons?
  207. Anybody have the tsp h/c package?
  208. Cam install questions
  209. Can someone help me with pushrod length???
  210. Important News On Bo White:
  211. Cometic gasket not fitting over dowels. WTF?
  212. who uses REAL ls6 heads?
  213. 241 heads question???
  214. MTI heads. . . .
  215. Getting timing gear off the crank snout?
  216. Am i paraniod or screwed?
  217. questions about lq4 build
  218. torquing rockers
  219. ls408 rotating assy
  220. 6.0L Rods and Pistons
  221. MS4 in a 383?
  222. i need pics of your motor with out rear cover!
  223. Question about stock crankshaft.
  224. f14 cam questions
  225. vindicator or ms4 with a 150shot
  226. casting #799
  227. 6.0L iron build
  228. New pistons in the hole
  229. LSX True Street Challenge - Oct 2007
  230. ? about porting stock heads
  231. AFR 205 head questions.
  232. Reluctor Wheels???
  233. Thoughts on this setup?
  234. my cam only gave me 4 tenths of a second..
  235. PRC 5.3 stage 2.5 heads...getting excited :)
  236. H/C Swap now consuming oil
  237. g5x3 lg cam
  238. getting ready for heads install
  239. Intake and Exhaust seat part #
  240. What Heads W/ Tr224 Cam
  241. Can 30 deg of timing destroy an engine?
  242. h/c setup, 3rd or 4th gen, which is wise?
  243. Where can I find the LSxx specs?
  244. Rod Bolts! lets get a poll going to get some actual numbers
  245. what cam?
  246. Wiring Diagram
  247. What Loctite did you use on your cam install?
  248. why are the .006" and .200" specs of a cam not advertised?
  249. Who ports heads, and how much?
  250. what is causing my power loss?
