- vindicator or ms4 with a 150shot
- casting #799
- 6.0L iron build
- New pistons in the hole
- LSX True Street Challenge - Oct 2007
- ? about porting stock heads
- AFR 205 head questions.
- Reluctor Wheels???
- Thoughts on this setup?
- my cam only gave me 4 tenths of a second..
- PRC 5.3 stage 2.5 heads...getting excited :)
- H/C Swap now consuming oil
- g5x3 lg cam
- getting ready for heads install
- Intake and Exhaust seat part #
- What Heads W/ Tr224 Cam
- Can 30 deg of timing destroy an engine?
- h/c setup, 3rd or 4th gen, which is wise?
- Where can I find the LSxx specs?
- Rod Bolts! lets get a poll going to get some actual numbers
- what cam?
- Wiring Diagram
- What Loctite did you use on your cam install?
- why are the .006" and .200" specs of a cam not advertised?
- Who ports heads, and how much?
- what is causing my power loss?
- Bearings for an offset crank?
- noticed some thing new
- should i check my pushrods?
- Looses power/ won't rev past 5500 rpm's
- Need some advice on top end rebuild *Look*
- lsx block
- Does anyone else have this problem
- cam install tool.....valve spring tool...
- where did u put bung for oil temp sensor?
- Does this gas mileage look right?
- Cam for a 2800lbs. car.
- LS1 Oil Pickup In front of sump, engine shop says it wont work, advise please
- Getting ready to pull short-block... what size (thread, etc..) are the head bolts???
- 03 ZO6 Cam and hand ported stock heads???
- TREX cam...is it streetable???
- Solid Roller worth it?
- Question about iron blocks
- cam upgrade.Worth it?
- Caddy Lifter Users Inside!!!!!
- TR230/224 and PRC LS6 CNC heads
- how often should I change my springs?
- low end torque cam?
- Checking oil pan-to-block clearance
- 1 cylinder buring oil?
- rough running engine
- TSP Magic Stick 4 Cam vs. TSP Magic Stick 3 Cam
- LG cams and spring life
- Vindicator Cam
- TREX/G5X4/Vindicator on stock heads? Which one?
- air in, air out
- how much slack in timing chain?
- valve seal problems
- Low power...GOT TORQUE...no
- Pulling motor out the top question
- 6.0 Engine help
- Will my Pistons Fit??????
- Pulled my vacuum lines, put breathers on, car seems to run better.
- adjustable timing set
- question about afr and trickflow
- 918 valvesprings prone to breaking??
- How much power will I be leaving on the table with my stock clutch with my H/C?
- brand new ls6 manifold w/ fast fuel rail kit
- no traction control after h/c install
- Technical ? about heads
- stupid lifter question
- Verified zero deck.. .040 head gaskets?
- Question after head and cam install
- Looking for 6.0L +0.030 piston supplier
- oh my god! FINALLY!!
- Pushrod Length Method
- What Numbers To expect With the MS3??
- Biggest cam I can run w/ out flycutting w/ tea heads
- input on a trex cam?
- CR and Fuel
- What cam will fit?
- Trex and heads new to ls1s
- 317 heads and camshaft
- oil question?
- Who runs a 370 ci iron block??......come inside.
- 2003 LS1 motor
- Smoking bad
- Thinking of going 408
- Cam suggestions for Low end tq
- my 226 cam with gas
- Valve Seals
- 03 Z06 AFR heads?
- Who makes race oil pans for an 04 GTO ?
- 66cc 317 heads, big cam, will this be my comp?
- ls1 question....
- need some help, motor might be on its way out
- 2002 WS6 engine removal
- Looking For Stock Ls1 Or Lq4 Crank
- Dude!~ Almost Done!~
- ported 241's
- having a problem with a rocker knock
- LS1 needs an EXORCISM! Any ideas?
- Heads/Cam reliability
- Has anyone tapped the hole for the water temp sender?
- Opinions, 232/236 .595/578 111+3
- 224/228 .600/.588 111+3
- ls1 valve in ls6 head?
- LS6 craziness
- stroking out to a 383
- help me!!!! car idles fine, till warm!!!
- LS6 into Fbody
- Pulling ls1
- Rebuild Options Memphis TN
- Can't remove cam retaining plate
- Is my engine F'ed??
- Heads AFR 225 large enough?
- 1.8 Harland Sharps or Scorpions???
- Tennis ball trick for pulling crank bolt?
- Pushrod/Rocker Arm Dilema
- How much to flycut?
- Porting Dart 205 Heads
- 93,000 miles?
- ppl please list mods/#'s put down w/ the trex cam.
- quick ? patriot lq9 stage 2 vs 3
- what gears for a4/T rex
- Show me your valve cover breather setups!
- Milling/decking LS1 heads
- Is there something missing on my engine?
- what happens when valve float occurs
- need a little educating
- Cam suggestion for TFS heads/402-want over 500 rwhp
- how much to have forged internals???
- Crane valve spring tool + JPR cam install tool
- cam question
- LSX Block Question
- 918 Spring Question
- budget 383 rotating assembly exist?
- Torque Specs
- tea stage 3 afrs on a 370
- LM7 max lift?
- cam and gas mileage
- hotcam????
- 370 cubic inch motor
- Which lifters?
- crane cam dual springs 99893
- How do recirculation pumps work? uses?
- Pulling motor from bottom without lift
- Balancing
- Very new to this, thinking of getting a cam
- Blower Cam Specs: Opinions?
- 98 z cracked block replace with LS2?
- 5.3, torquer v.2
- Torque on ARP head bolts?
- Valvetrain tap type noise since lt's installed
- Are PRC's .650 springs to much for a ......
- Engine Masters LS2 Head Dyno Test
- correct pushrod length?
- 6.0 machine work?
- Cam+ Heads on a budget
- pulled out head need suggestion
- Oil pan gasket removal?????
- Oil In Intake.....not Pcv
- felpro headgaskets?? tsp 2.5 5.3
- ?'s about crank and connecting rod lenghts
- engine rebuild
- Forged pistons/rods
- tell me what u think of this setup
- Problems with my car:
- cam suggestions?
- pushrod length with TSP 5.3L heads
- Help! Cleaning headbolt holes on block and now paper towel ripped off in the bottom
- Compression?
- 2003 Z06 Head/Cam setup, "Need Cam Help"
- royal purple possibly f'd up my engine????
- Heads are in
- LS1 to LS6 top end conversion: What Cam?
- Cam Install Problems/Tips?
- torque spec for plate holding knock sensors in?
- LSx PTV without flycutting questions for cam and head gurus
- anybody use this cam???
- mobil 1
- Is 400BHP a possible goal......
- How do you tell how much advance was ground into a cam?
- Head ?
- Rod Bearing failure- Cause?
- 5.3 heads on a 1998 camaro is there anyway
- Wiring harness help
- Great oil pressure, but knock when engine's cold
- F14 problems...
- What pushrod length?
- Good deal on a head/cam package???
- new exhaust and a bad MAF
- Patriot Cam: Any thoughts good or bad?
- T-rex and stock length pushrods
- Replace Oil Pan Gasket When Changing Rod Bolts
- Need Help with PTV?
- For those with 402ci Builds in a F-body
- Best Heads for the F14?
- TRex and Heads
- Rod Bolts: HP related, RPM related, or Wear and Tear related??
- Got a BIG PROBLEM
- Best cam for a 383 build
- 5.7 MLS head gasket bore and stock deck clearance
- Help with hesitation issues (LS1)
- Head gaskets for lq9 heads on 3.905 bore?
- coolant leak, out of side of the block
- Rear Main Seal?
- Should I change Valve seals?
- 1999 T/a bone stock(wat to get 400+rwhp)
- You'll be missed Cylinder 7 - Compression test results
- pistion to head
- Low TQ#'s for 408
- is there much of a difference between ls1/ls6 manifold?
- New Lifters and still have a tick....HELP
- LS1 head porting
- what cam ???
- Is this a good cam for my mods?
- Exhaust question.
- Cam for 408ci with Kenne Belle?
- head flow question...
- Is just a cam worth the time and money
- what kind of cam
- PRC Head assembly question
- Know my goals, need some direction
- Heads coming off
- Decision on what to build... money IS an object
- cheatr cam sound
- valve locks/keepers
- what broke? Help please
- Which cam and what HP should I expect?
- Cam TR224
- PRC 2.5 & Trak Cam ?
- What HP Comp 224 0.581 112: Search not working
- Cam Qustion
- 4/7 swap camshaft
- cam,gears,heads,stall,headers
- SDPC Budget Forged pistion kits any good for FI?
- Will a cam affect the integrity of my engine?
- Zero deck
- At a crossroad with a 427
- reason for spuned bearings
- 5.3l heads on a 408???
- cam makers?
- 2008 C6 LS-3 First Dyno at LG Motorsports
- First Time H/C Any Comments?
- Cylinder head coolant plug
- ls6 in cadillac cts -v help please
- Morell Lifter Preload and Engine break in Oil
- Question about notch on deck of heads on 853 Castings
- How high can i spin?
