View Full Version : Generation III Internal Engine
  1. is this going to be a good cam
  2. Valvetrain knocking
  3. Corvette z06 problem.....
  4. Looking for the best heads/cam combo to run 10's
  5. Need help choosing heads
  6. LM4 Head Bolts
  7. are all 706 heads made by Castec?
  8. 6.0 turbo build help and ?
  9. Basic 5.3 rebuild questions.
  10. Quickest/easiest most effecient way to gain a solid 40-60 rwhp? No nitrous..
  11. LQ4 build help
  12. Problem, motor was removed, reinstalled and starter problem???
  13. 400rwhp power goal... need heads?
  14. Head Gasket thickness.....
  15. what would be a good cam for my 01 z28
  16. Main stud and main bolt question
  17. Cam me
  18. No oil pressure......
  19. Sleeper 1/4 mile cam for my setup?
  20. Machine shop
  21. ? on my LQ4 build.
  22. 2004 5.3 need a cam ???
  23. Help me pick a cam.
  24. lq4 build questions
  25. Pining a Eagle crank.....
  26. UpGrading Stock Rods That Have Forged Pistons Already Hung On Them?
  27. how does this grind sound
  28. .086" Preload too much??
  29. 421 pulling truck build
  30. trex idle and rev
  31. 1999 LS1 with a miss
  32. Lunati springs?
  33. 224r cam 35^ hp?, Sound stockish on 114 lsa?
  34. Pistons for 3.925 bore
  35. 02 LS1 in 69 C-10 Horrible Misfire HELP!!
  36. Anyone know who grinds this cam?
  37. Any Suggestions?
  38. Please help me pick a cam
  39. 2004 Thermostat Housing Fits 1998?
  40. Where to buy bushed rocker arms
  41. 5.3 alum. Block & iron block ???
  42. Is my block destined for the scrap heap?
  43. Valve spring Identification Help
  44. Please help calculate my 427's compression ratio
  45. New LS1 Shortblock vs OEM block
  46. 5.3 Heads on 6.0 LQ4??? Should I
  47. Budget build 02 z28
  48. Vengeance VRX-4 Cam Kit in 2002 Camaro SS! Pics/Vids/Details INSIDE!!
  49. LS1 in 1959 El Camino
  50. ls1 camaro runs hot then cools down
  51. Piston removal..........
  52. Porting the Fast 102 intake?
  53. Caddy Racing Lifters
  54. stroker kit?
  55. new engine?
  56. Which cam is best for nitrous
  57. New lifters, rocker arms and pushrods needed?
  58. 03 Z06 lost oil pressure / missing
  59. At a crossroad
  60. Couple 5.3 questions
  61. Piston Decision Help
  62. Ticking after lq swap and cam.
  63. PAC or ls2 valve springs?
  64. Another tap
  65. One mod just creates another mod needed
  66. 4.8-5.3 heads
  67. Auburn gear differential Installation
  68. 6.0 cam in 5.3
  69. 228r questions
  70. Reminder: Don't use a truck pan in a mustang swap
  71. installation time for new cam, heads, intakeifold and throttle body?
  72. Spartan build around the corner.
  73. LQ4 6.0L in a 95 z71
  74. smashed/bent ls1 pickup?
  75. My 228/232 cam dyno video!! Finally
  76. sdpc cnc
  77. LSA Oil Pump in a LS1
  78. Help me pick a head gasket w/ my set up; Other Questions
  79. Core LS1 engine prices
  80. lq4 stock crank rpm limit vs hp?
  81. Are these scratches normal? rebored block
  82. Biggest cam with 5.3 heads
  83. Cam and head swap the right way - Part checklist
  84. cam for 5.3
  85. keep the tfs 215 or go bigger?
  86. Blue smoke once at operating temp
  87. What will my compression be??
  88. Lost Oil Pressure Significantly Mid-Race! Built LS1
  89. Initial upgrade from stock questions, HPtuners questions
  90. need help with gremlin
  91. where do i buy a new floating piston pin retaining ring(snap ring)
  92. GM Performance Cam for LS!?
  93. Cam & stall question
  94. Making it a daily driver again, few questions
  95. recommendation's for start up after 4 years
  96. Next hot cam question- What is base circle on the gm hot cam?
  97. Lunati LS Retro-Fit Rocker Arms
  98. Sorry but...spec my cam?...LQ9 408.
  99. help with build sugeestions
  100. Ackerly & Childs Piston Rings for 6.0(LY6)
  101. Top of valve worn more than others?
  102. LM7 with LS3 cam (FREE CAM and parts)
  103. Crazy Question
  104. new head cc size?
  105. Can you get a custom cam to work with ls6 springs?
  106. 98 LS1 stroker?
  107. Bearing questions
  108. need help with oil pump o ring!
  109. reuse or get new dowel pins for heads?
  110. Short-notice install
  111. Crazy tapping?
  112. Best Intake Manifold and Throttle Body for LS1 Upgrade
  113. Dart Pro 1 205cc Heads Any Good Porters Out There?
  114. Oil pan broken??? HELP!
  115. ls1 lifter noise
  116. 5.3 and MS3
  117. Old build questions, opinions wanted
  118. 5.3 silverado
  119. Preparing for a cam swap. Am I missing anything?
  120. Is this internal or external? Tensioner, Alt, etc.. video included
  121. intermittent valve tap?
  122. Does pushrod length affect lift?
  123. Need Opinions...
  124. 2004 LQ4 6.0 (new style floating piston) i need rings
  125. Got my new heads!
  126. What to expect out of this setup!!
  127. Replacing valve seals, should I upgrade anything else?
  128. Lq4 Piston
  129. Junkyard 6.0's chime in please on your experience
  130. 226/229 575/578 - 112 good for a 5.3 build?
  131. So Vengeance stopped carrying Yella Terras 6645's because of increased failure??
  132. help: where can i purchase these valve seals?
  133. blown up ls1
  134. LQ9 Buget setup 415-430whp
  135. Is a Lunati 60512 cam 232/238 .599/.601 on a 113 torque curve?
  136. HELP!! About to do a cam swap
  137. Blowby Causing Pinging?
  138. Weak motor after overev
  139. long story of a oil pressure problem! please come in and help!
  140. Who can ID my Hardened Pushrods??
  141. Swapping 806 heads for stock 243s?
  142. PRC 227 CC heads
  143. dead ls6, replacing with either a 370 or 408 iron block
  144. gm head gasket options for prc 215's
  145. Wich will get me better 1/4 mile gains and top end mph gains? Ls6 vs hot cam
  146. Cold Cylinder
  147. Cathedral or Rectangular Port heads on 6.0
  148. 1.8 Rockers Pushrod Clearence
  149. Vengeance VRX4
  150. which is the best?? TFS or AFR or PRC ???
  151. Head/cam expert? Step inside
  152. euro 2012 finals
  153. AI dart 223 or TSP 2.5 cylinder head kit?
  154. Lower RPM throttle feels squidgie
  155. What components were in Agostino Racing 360cu motor?
  156. Stock replacement LS6 pistons
  157. Oil Pan & Covers
  158. LQ4 cam bearings look weird.. teardown what to replace?
  159. I think I'm having valve float help!
  160. TSP 224R questions
  161. HELP ls1tech, need some creativity, paper towel stuck in head bolt hole
  162. LQ4 6.0L Aftermarket cam
  163. Using 5.3 crank with 5.7 pistons and rods.
  164. LS1 - Rebuilt/d
  165. Lq4 ticks/snaps randomly after cam swap??
  166. Built LS1 performance question
  167. Oil Pressure Hiccup
  168. LS1 vs LS7 lifters
  169. vacuum question
  170. Autopsy of dead LS6
  171. Troubleshooting question: valve float or what?
  172. Engine started knocking/ticking on drive home
  173. Help: New rotating assembly?
  174. mystery TSP cam
  175. perimeter valve cover pcv ?s
  176. Camshaft Help ( PVT ) Clearance
  177. Identify these lifters?? Anyone?
  178. Ls3 heads on a ls1?
  179. Rod bearings, dowel hole or not ?
  180. can i fix, or replace
  181. Ls6 cam vs hot cam ?
  182. Valve cover gaskets not fitting....
  183. Biggest valves on LS1
  184. Ported Vortec Intake Manifold Question
  185. Noise from timing chain area
  186. anyone running Lunati voodoo 282/288 cam in LQ4/9?
  187. PTV clearance to tight??
  188. Forged 6.0L LQ4
  189. tsp cam?
  190. will this be a good setup for m6 dd lq9 01 ss camaro
  191. ptv with stock cam??
  192. H2 6.0 performance help
  193. At what HP does the flow on 241s become an issue?
  194. What valve springs
  195. 4L60 Street cam
  196. LS1 Oil Level Sensor wiring for swap clarification
  197. Cam Suggestions......
  198. Gasket set
  199. gear choice for eps 230/236 cam
  200. Blowby Causing Oil to turn Black, Re-ring?
  201. cam choice ahhhh
  202. Coolant Smell from Exhaust after pulling heads
  203. spark plugs for 11.528 compression
  204. max compression to run on 93
  205. 1000 whp stock crank?
  206. With all the 228R cams
  207. Main bearing clearance ?
  208. Am I limiting myself with current cam in LQ9??
  209. overall opinions
  210. quick power ( heads)
  211. Water pump veratility
  212. Will ls6 cam have any more chop than stock ls1 cam?
  213. Nissan 350z LS1 Swap!
  214. High compression SBE experiment
  215. anyone know the thread size of the coolant temp sensor in a ls1... stripped
  216. Machine work
  217. Can i run a 6-7 sec 1/4 mile for $5000 with a 2002 Trans Am
  218. Dissapointing results from EPS cam
  219. An odd P to V question
  220. LS1 (5.7L) Accessories on a 6.0L
  221. Anyone using the cam bolt lock plate?
  222. Fair price for hotcam & LS6 springs?
  223. used short block??
  224. Thunder shim kit with 59cc TFS heads. Questions..
  225. Need Help...high pitch squeal coming from engine.
  226. Heads on a stock bottom end?
  227. Which spark plug? 383 LS1
  228. SES light flashing
  229. 660 springs too big for cam?
  230. Anyone Have Info on Comp Cams QC?
  231. EPS vs Pat G cams
  232. Retreiving Dropped Rocker Shim
  233. Livernois or Katech H/C Packages
  234. LS1 upgrades?
  235. 2006 Silverado--LS1 Swap--Few Questions
  236. Ls1 spun rod bearing
  237. Rocker arm bolt rounded off. How do i get it off?
  238. Losing Radiator Fluid
  239. What is causing this?
  240. need help finding a few bolt spec's
  241. How much power will i gain by putting just 243 heads on my 2001 5.7 firehawk
  242. cam /converter choice suggestion help, stock. in 82 vette
  243. Ticking noise (vid)
  244. Prc stage 1 ls6 question.
  245. Got my TEA stage 2 ls6 heads today(pics+flow#s inside)
  246. head/cam/pushrod suggester button
  247. Stock LS1 engine with a tick, PLEASE HELP!
  248. Stroker 383 iron block, AFR heads, FAST top end build thread, lots of pics
  249. Going with this combo. Thoughts?
  250. Just a little something ive been working on.
