View Full Version : Generation III Internal Engine
  1. cam install help!!!
  2. What is the flow rate of the LS1 oil system?
  3. Does anyone have a set of Dart 205's on the bench?
  4. f13 to ms4 worth the time?
  5. Passenger side JPR dowell will not go in, think i have a stuck lifter
  6. cam swap trouble
  7. 2.08 size valves too big for stock bore?
  8. Flat top piston options?
  9. Anyone know a guide to replace ls1 valve springs?
  10. any ideas what is causing this?
  11. main bearing clearance
  12. JP Performance Timing Chain
  13. How Much Is Safe Head Milling Questions
  14. I think i have a cracked head....now what?
  15. LS1 ARP head bolt torque
  16. Another cam decision
  17. How do I make this NA combo faster?
  18. How much can be milled?
  19. 243 LS6 heads
  20. Quick LQ4 crank question
  21. Ms3 Guys Any Audio??? Post Up
  22. LSK daily drivers, how are your springs doing?
  23. How much spring pressure can the Morels take?
  24. Need to rent the flycutting tools
  25. heads gasket/head install questions
  26. what are the specs of a z06 cam
  27. H/C Nightmare - PTV Problems - Help
  28. pvc and cr question
  29. Sputter/Stall
  30. Futral F13 or Torquer 2?
  31. It's On Now! (pictures)
  32. O-ring or Piston slap?
  33. people with tr224 cam come in please!
  34. Ls6 ?
  35. Help Me.....
  36. Coolant Pressure Test Help
  37. I think it is time to sell my SS Camaro 300 gas bill.
  38. Loud Vacuum Noise (Intake Manifold)
  39. Head removal to change lifters?
  40. HELP!!! No oil pressure!
  41. Source for stock short block?
  42. 408 Numbers - Advice Please
  43. cam break in?
  44. Crank Pulley Bolt?
  45. Need serious cam help!!! Sponsors look too!!!
  46. Is it safe run run airplane gas?
  47. What kind of power can I expect with this set up?
  48. replaceing rings and bearings
  49. Lq9 and Lq4 piston rings
  50. Are the chamber designs on LS6 and LS2 heads the same?
  51. new cam and motor problems PLEASE HELP!!!
  52. Heads And Cam Setup
  53. Building a Forged Shortblock
  54. How does this Futral PTV recommendation sound? (FM14 with heads)
  55. German Castrol 0w-30 or M1 0W-40???
  56. Might be time for a cam!
  57. heads/cam or nitrous....
  58. power from 2001 ss ls1 heads
  59. Solid Or Hydraulic Cam??????
  60. colder thermostat....worth it??
  61. blown head gasket...
  62. H/C Job on the Cheap?
  63. Ported LS6 intake
  64. LS6 Heads on a LQ4 Vortec 6.0
  65. Anyone drive long distances with big cam?
  66. Installed Cam, 150 miles later, knocking?
  67. Steam hole plumbing.. required or blocked off?
  68. Flycutting?? milled Tsp 5.3s & ms4
  69. Need Help...
  70. Parts Compatibility Question--Aftermarket Z/28--->C5
  71. bent pushrods
  72. Blower cam: LS6 vs. 224/228 114lsa
  73. Cam Install A Suscess! A few questions?
  74. Are shorter pushrods required with LS7 lifters?
  75. Ls1 piston rings (file fit) Need HELP!!!!!
  76. AFR 225 heads
  77. LS1 piston rings (file fit) What Gap?!? Need HELP!!!
  78. LS6 Head Swap to a LQ4 6.0
  79. Should I install my TR224 or go custom?
  80. The dredded "ticking" noise
  81. Ticking sound?? With Video Oil Pressure great
  82. is trick flow worth the money?
  83. LSx timing/pointer indicator???
  84. 408 Performance Question
  85. Just Hot Cam 1/4 mile times
  86. Noise?
  87. whine in the engine bay
  88. 5.3 heads???
  89. Anyone running a 2.08" valve on a stock CID motor?
  90. 853's vs 243's
  91. Thicker 30W Oil then M1
  92. Help!
  93. Comp Cam 7.400 Push-rods and Hot Cam Question??
  94. T2/5.3 stage2.5 heads and TSP mail order tune?
  95. who wants a write up on flycutting??
  96. Search Down, 799 casting/243 casting/6.0L 317...?
  97. lifter change ?????
  98. What is this part?
  99. BAD internal noise after start up. Expert help needed!
  100. Engine slowly overheats. Causes?
  101. what is an optimal MAP sensor reading?
  102. i need some help and info
  103. what heads to choose?
  104. 112 LSA with spray?
  105. Whats needed for a head swap?
  106. Cam Only Guys come in!
  107. Update on engine ticking, stuck lifter.
  108. which h/c setup
  109. Morel Lifter Question
  110. 5.3 block question
  111. Opinions on LS6 and SDPCs Z+220 cam
  112. Question on built motor
  113. Yikes. Check out these plugs.
  114. T-Stat?
  115. I have to pull a head
  116. Can some one figure out my SCR & DCR?
  117. mixed valves...this is bad?
  118. SLP 51015 Camshaft HELP
  119. Melling Oil Pump - C5 Vette???
  120. valve springs for T2 cam
  121. Tr224 Cam
  122. Dirty Coolant/Heat Core Cause Misfire?
  123. I am going to run into a problem??
  124. Head Gaskets for Ms4
  125. rocker question
  126. non-synthetic oil????
  127. Checking PTV?
  128. gasket kit PN?
  129. Damaged the motor, what do you think happened?
  130. What's that goofy plastic plunger behind the rear cover above the oil filter for?
  131. Cam recommend for LS1 in 71 Firebird..
  132. Looking for info LS6 power potential
  133. Valve Size Help
  134. help with motor components
  135. Some clutch issues?....maybe??
  136. Buying a 02 ws6 What Kind of H/c package should i get.?
  137. 232/228 cam and heads for c5
  138. Anybody running the Patriot 226 camshaft?
  139. What 408+head combo?
  140. Futral F7 or F9
  141. help me build my engine (suggestions)
  142. Gathering up parts for my PatrickG Cam install. Questions
  143. T-REx First Start Video
  144. pressed versus full floating pistons
  145. Edelbrock Cylinder Heads
  146. need quick advice, lifter install
  147. cylinder scoring
  148. iron block vs aluminum
  149. Whew! 408 installed! Now that that's done - advice please.
  150. Is this normal?????
  151. 383 build
  152. new heads = new spark plugs ?
  153. Engine Machining Question
  154. WTF is this for ?!?!?
  155. How to identify a C5R block?
  156. results from my LOOOONG heads/cam build.
  157. Pushrod length be effected on the cam size?
  158. TQ to yeild head bolt install ???
  159. need some serious help...
  160. Whats the difference between an LS1 and an iron 5.3L?
  161. Cylinder heads poll: AFR vs. Terminators
  162. Tjz28
  163. Rear main seal?
  164. piston ring
  165. 6.0 crank spacer
  166. Ticking
  167. ets with tr224 cam
  168. Help on cam choice
  169. forged internals/ 402
  170. Engine assembly questions...
  171. Everyone Check Your NUTS!!!
  172. Code question
  173. LS2 Timing Chain?
  174. sensor like plug in on the back of the alternator? what is it
  175. Putting heads back on
  176. What kind of numbers?
  177. budget 408
  178. Knock retard after cam install
  179. lq4 t-rex ms3
  180. Cam specs for my 370??
  181. nitrous express cams?
  182. what should it cost?
  183. I NEED SOME CAM GUROS in here to help with ENGINE KNOCK..Pushrods ,lifters. wtf
  184. forged 346 advice
  185. Does bent valve=damaged guide?
  186. H&C for an 04 Zo6 Recommendations
  187. Just picked up a set of stock 5.3 heads.
  188. Installed FAST intake and 90MM - HELP
  189. Oil restricting pushrods?
  190. Pictures of the damage
  191. Gasket Question
  192. Pushrod length / valve contact area
  193. What Valve Springs for 7200 RPM shifts
  194. What to do with '03 Z06???
  195. need streetable 380-400rwhp
  196. pushrod lenght w/ patriot ls6 stage 2
  197. noodling on an engine combination
  198. Installing motor and trans
  199. crank bolt trouble
  200. stock tb on cam only
  201. Hydrolocked motor...going to insurance company
  202. Help me achieve 9.0+ DCR
  203. Heads to suit Turbo FI
  204. Strange rod bearing wear pattern
  205. GM Racing Lifters Failed in New Motor
  206. Retainer issue...
  207. Good reference for understanding valve events??
  208. Cometic Vs. Gm
  209. Hot Cam and Oil Pump question??
  210. which cam before d1sc?
  211. Rust on crank journals
  212. MS3 Q's
  213. help me out...car not starting...
  214. can someone calculate my compression?
  215. bottem end
  216. Bad rings? Will a compression test help tell?
  217. ms4 guys step inside please
  218. Head/Cam packages
  219. g5x3 112 pushrods?
  220. How thick is too thick?
  221. Shops installing cam?
  222. LS1 Stage 2 Heads & Cam and Tune dyno #'s
  223. AFR head and cam set up question
  224. Another Dumb cam install question!
  225. Where do I get a LS2 timing chain
  226. wd40 in bolt holes crack block?
  227. ~~Opinions... 224/232 .600/.600 115 LSA..... good cam for desent NA and boost
  228. LT1 02 sim/LS1 (98-02) the same thing?
  229. Aftermarket cylinder heads... check this out
  230. LS2 cam in LS1 Question
  231. TR224 cam which heads 862 or 241?!?!?!?
  232. Which cam : Hellion Cam or keep my X3
  233. Max safe DRC recommendation please
  234. cam is installed ..now a Big TICK TICK TICK
  235. sparkplugs and wires
  236. Dyno Tuning ?
  237. Misfire after 10-15 seconds of idle
  238. roller rocker install help
  239. Blow by/ blown head gasket?
  240. Speed Inc Cams
  241. Wierd oil pressure problem popped up
  242. How high should I spin my stock cam?
  243. Mild Head/Cam setups?
  244. Got an MTI X1 cam with a dyno graph?
  245. Just called comp about using 918's with t-rex and ms3
  246. Need help choosing a motor!
  247. LS1 into rockcrawler need horse power
  248. What could my mis be?
  249. patriot or TEA heads?
  250. Hot Cam or Bigger
