View Full Version : Generation III Internal Engine
  1. Running head/cam car without tune
  2. HELP! Car is screwing up and I dont know why:
  3. LS1 Rebuilt..
  4. How Much to Mill Safely with this Cam
  5. Oil Pressure Gauge
  6. New motor using oil
  7. started my car to today after heads and came installbut
  8. Intake
  9. Motor swap
  10. Famous GM Piston Slap
  11. LS1 Heads FAQ?
  12. Help, spring seats
  13. Double help needed
  14. DCR help please
  15. vindicator cam, how much$
  16. Oil Pump reading Zero at startup, then goes up. Is this normal?
  17. help ..Another Question. Middle of cam install
  18. Push rods and Rocker Arms
  19. fresh cam install how long before wot
  20. N/a Strokers Above 6500 rpm.
  21. G5x4 Idle Clip........
  22. Approx Compression?
  23. Largest or Best Cam with a Vig. 2800 Conv.
  24. cam lobes???
  25. FAST gasket install ?
  26. LS7 "Style" heads for LS1/6
  27. You learn something new every day.
  28. Cam only question...
  29. Skipping-sputtering Help ASAP!
  30. H/C combo, what else??
  31. back fire on passanger side?
  32. What pushrod length for 232/236 LSK??
  33. SI5 cam
  34. MS4 in, now what?
  35. Engine Break In !!!
  36. Cam for my car?
  37. MS4 install finished!
  38. Can someone explain "flycutting" to me
  39. DCR Combustion chamber advantage - timing/knock
  40. 5.3's on my 99 C5
  41. Next Modd???
  42. 383 Rotating Assemblys.
  43. help me!!!
  44. Texas Speed MS4 heads/cam package FINALLY in.
  45. Head Gaskets
  46. AFR heads and anti sieze
  47. 5.3 truck heads
  48. Update on the TSP Cam Install
  49. Getting a part list
  50. Getting a list
  51. Alternator problem
  52. which cam to use
  53. Is SS in trouble?
  54. Valve springs & Push rods?
  55. Ls4 Oil Pump With Stock Spring?
  56. Service Engine Soon light....
  57. Head question
  58. WANTED: TR224 112 cam card
  59. Middle of cam install ..NEED HELP ASAP!!
  60. ls6 cam
  61. Head Question
  62. Whose running 12:1 to 1 compression on 93 octane?
  63. Crank machining price
  64. Hitting Rev Limiter Bad?
  65. How much does milling affect CC size?
  66. Those running G5X4 cam inside!
  67. cam identification question
  68. Where to get L19 head studs?
  69. melling high volume oilpump porting ?
  70. c5 codes say running lean???
  71. FS: GMPP 60.9cc LS6 Lingenfelter Heads 1100$
  72. to change or not to change??
  73. Cam help: Unique application
  74. Oil Pump Service Mileage?
  75. new cam start up????
  76. car wont start need help asap!
  77. Need help ls6 engine oil on threads of sparkplugs
  78. WHo has TrickFlow Heads in stock and at best price?
  79. Warranty Head , Cam and Piston replacement
  80. t-rex cam only results!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
  81. Tinker Performance? Dallas, Tx Anyone Help!!!
  82. A slightly different version of Patrick G's cam
  83. cam bearing wear
  84. mill 5.3 heads for a 408?
  85. air fitting tool for cam installs
  86. Ms3 People!!!
  87. Bent P'rods and compression test.
  88. need some help
  89. oil leak
  90. Proper piston ring gap for nitrous use?
  91. Here's the COOLANT article from Master Technician magazine
  92. 427 or big cubed motors
  93. pcv problem
  94. 231/237 589/595 112+4 guess the dyno number?
  95. Magic Stick 4 Cam - could use some advice
  96. LS7 heads work on LS1?
  97. how much gain
  98. Anyone have stock flow #'s for these heads?
  99. bolt ons before a cam
  100. How to remove rocker arm studs?
  101. Oil pump swap help needed
  102. Patrick G custom cam startup!
  103. Knock Sensors are toast: Why?
  104. checking cam size in the motor
  105. **Just did my Cam Swap...possible problem**
  106. ++Sputtering problem....NEED FEEDBACK++
  107. Can someone check if this looks right
  108. Cam gurus- Questions about a non-LS1 cam(SBC)
  109. need some part numbers
  110. SLP heavy duty oil pump???
  111. Can I use stock pushrods?
  112. Vin # on 98LS1 ?
  113. I need help on my valves
  114. RE: Throttle Bodies
  115. How much to replace a sleeve in an LS1 block?
  116. tr224 nitrous cam
  117. rebuild
  118. Cam only 98 cars
  119. TR 230/236 112 cam specs
  120. Tr230/224 Reverse Split
  121. Couple of heads/cam questions for you gurus?
  122. 228/232 115+2 LSK lobes
  123. Cylinder head porn!!!
  124. TFS Heads: to mill or not to mill...
  125. Diamond or Mahle?
  126. Any dyno numbers on Voodoo 222/228 cam?
  127. Heads/cam selection ok?
  128. Need help diagnosing engine!
  129. Dumb question maybe, but...
  130. TTP Camshaft-who is TTP? Any cam gurus out there?
  131. Valve guide inspection...
  132. two different oil pressure sensors?
  133. Is a .030 head shave and this cam ok?
  134. ls6 part numbers
  135. Has any one explored the new LSX block.. Price wise?
  136. How much power in in cubic inches?
  137. New Motor, Low oil pressure
  138. Mechanical Oil pres gauge "how to"
  139. Pulling short-block (no heads) out from top, what to attach chains to???
  140. what do yall think of these h/c packages?
  141. fly-cut size
  142. Are SLP H/C combos worth the money???
  143. homade jrp tool
  144. ls6 part numbers
  145. Quiet Cam
  146. 1.8 rocker hp gain, worth getting them?
  147. Finally started my shortblock
  148. LS7 goodies on a LS1
  149. 228/232 .588/.592 110lsa
  150. I Start My Head/cam build Tomorrow
  151. Poll: which cam for power under curve?
  152. help with motor
  153. Do TSP/PRC heads have anything engraved on them?
  154. Looking for some part numbers, can't find online
  155. Low oil pressure.. help..
  156. Oil pressure with aftermarket gauge??
  157. milling q
  158. Cam in a GTO
  159. summer project (H/C) advice
  160. LS1 technical questions
  161. Help with Identification of heads
  162. engine swap
  163. Valve stem damage????
  164. F13 (230/232) 110lsa
  165. My oil smells like gas?
  166. Could this be daily driveable?
  167. Lingenfilter Gt2-3 cam??
  168. What Cam Did I Have???
  169. Heads/Cam package - Your thoughts
  170. help! coolant in intake ports!
  171. Cam bad?
  172. TSP Cam and heads are on!!!!
  173. Best heads for the money??
  174. DESPERATE! new head cam package will not start
  175. Downside to running heads that are too big?
  176. Need Help ASAP
  177. Early 6.0L crank with .400" extruded output?
  178. Need advice on refresh of 2001 LS6 longblock I bought. Rings,Bearings, ARP, gskts?
  179. Need advice lt1 to LS1 iron
  180. ms4 ?
  181. should there be a bearing behind the cam gear???
  182. Stroke ??
  183. 408 guys: likes/dislikes of daily driving?
  184. Got my new cam installed...clip and specs
  185. Straight up on an MS3 cam?
  186. Lifters
  187. Piston Slap ??
  188. Laying out the final plans for the car...
  189. those with T-rex-what are you running?
  190. which cam is the best ?
  191. big cube LS1 benchracing...
  192. TR224 vs TSP228r
  193. Funny noise coming from front of oilpan
  194. Breaking in a new engine....
  195. Looking to build a 400rwhp ls1.
  196. compression with head swap
  197. Do any shops market small cams anymore? why NOT?
  198. Valve spring identification
  199. ls7 cam in ls1
  200. Too MUCH oil pressure?
  201. Mahle Forged Pistons
  202. new cam extremely tight in new block, whats wrong?
  203. what else ?
  204. ls1 questions
  205. flycutting tools
  206. Theory on cam vendors
  207. First Time I Go WOT in 6 months - Bent a Pushrod?
  208. Patriot Gold Dual Springs
  209. Rocker arm ratio changes net more power?
  210. made my cam selection,what ya think???
  211. I've searched... what direction do the ARP washers go on the head studs?
  212. 408 Twin Turbo Build - Clearance Questions
  213. just an idea? short block over H/C
  214. normal wear for cam bearings? 72k miles
  215. Coated Dart heads?
  216. LS7 lifters?
  217. Brand New 4.8/5.3 Castings Assembled $135.00 Each !!!
  218. low dyno #'s
  219. What is possible for a street driven H/C/I car?
  220. c6 oil pan on a fbody
  221. LG Cams?
  222. ported oil pump
  223. Cam V.E. question
  224. LS Engine running rough? CHECK THIS OUT..CRAZY BUT REAL!
  225. 2001 241 LS1 Heads
  226. Offical Dex-Cool vs. Green Thread
  227. how to check if a lifter is messed up!!!!!!!!
  228. What belt do i use?
  229. Very strange mid range power loss
  230. Lifter Noises??????????????
  231. need help on cam selection
  232. 6.125 VS. 6.098 Rod length
  233. 5.3 heads, whats the casting number?
  234. Z06 Cam
  235. Daily driving ok?
  236. How do you take a balancer off if engine is out of car?
  237. Bottom of Fast 90 intake cracked??
  238. CheaTR cam owners- come answer my questiona
  239. Cam gurus inside
  240. 130,000 mile rebuild
  241. Building a 370 with questions
  242. I was racing and something wierd happened...
  243. Vengence Vindicator .022" Piston To Valve WTF?
  244. changing oil pump
  245. Short Block Weight
  246. Which Valve Spring removal tool to use w/AFR heads
  247. Cam help, TSP Torquer V.2, V.3 or MS3???
  248. Motor Swap Help
  249. Engine / Trans alignment pin - messed up
  250. What do you think?
