- Ls1/5.3l
- Oil burning 408 help....
- guess my cam from the sound clip
- My new cam sound clip.238/242,.600/.612 114lsa
- Need an interim cam combo, what should I do?
- Horsepower increase with TSP heads and current T2 cam?
- which head to go with my ms4?
- Anybody have ported AFR 205's?
- GT3 Cam
- etp 255 heads
- cam advice needed: tell me if this is right (pics)
- looking for
- aftermarket rockers - stock rocker stand
- building a 383..what is the best rotating assembely
- Head and pushrod question
- Gears
- Terminator Heads WARNING...
- Pics of my new CDNPERF 347!!!!
- ls6 cam vs ls1 comp extreme cam
- H/C or STS
- Problem that I need all the help I can get!!!!!!!!!!
- LS6 Heads
- Help me select my engine combo - budget build
- oil return
- Anyone have the new Trickflow cams?
- New heads, now what cam??
- Can I put my ls1 crank in my 99 6.0 ironblock?
- Good heads for torquer v3?
- Comp Xfi Lobes
- Couple of Questions (not cam)
- i found this on the oil drain plug.....pics
- Anything Missing From or Wrong With My LS1 Longblock Rebuild List?
- Cam install?
- Best daily driveable cam with T56 and bolt ons?
- 2002 4.8 w/ 2003 Intake
- Service Engine Soon Light
- head gaskets
- AFR 205 Heads vs TSP/PRC 200cc Terminator Heads
- So why are our pistons OUT of the hole?
- 918s and coil bind
- Valves hit pistons,update.
- Any drawbacks to using forged pistons?
- 241 heads, just a few questions
- Mixing main caps?????
- 243 heads
- ~Budget Engine Build...Turbo Set Up~
- stock rocker fix
- ls6 heads and cam swap on ls1?
- Location of galley plugs?
- newbie head cam and intake ?'s
- yelloeish gunk
- Simple pushrod question!
- Dumb pushrod question
- thrust bearing shot ?
- Custom cam help...
- ETP 4.8/5.3 vs. Trick Flow 205's 30 rwhp difference!!
- best heads for stock block 6.0
- Cam setup.
- How long for break in???
- WTH, oil pressure drops like a rock past 4000rpm
- Need advice for budget motor!!!!
- Head Suggestions
- Dual valve spring question
- Found Oiling Issues
- Cam suggestion (patrick G, Predator Help please)
- PianoProdigy DCR calculator-I'm screwing this up obviously
- Heads, educate me please!
- april carcraft 6.0L dyno numbers
- Suggest a cam suitable for DD and weekend spray.
- Oil Junk All Of It!
- Which Red Tube Loctite
- Question about A/F Rato
- patriot cams
- Torquer V.3 and Nitrous
- YELLA TERRA 1.7 rocker and pushrod questions
- Need some advice on head and cam package
- What i found in my oil today
- TSP GIant cam and My Ws6 Vids
- I Need Some Advice
- how did you install your cam and springs?
- Any info on this cam and my setup?
- 605/609 Lift cam...
- Low oil Pressure after cam install (C6)
- I want to know if I can hit 12`s ???
- MY 402 is in and i........am in LOVE
- How high can your compression go?
- running problem
- How good are Trick Flow heads? Video evidence inside!
- Need pointers for cam with best response
- Milling 241s
- how to ID HPE heads
- *** Stay tuned!***...
- Anyone running a trick flow cam?
- ls6 cam or not
- No oil pressure after cam install
- h/c swap info.
- Harland Shop rockers w/ETP's...which rocker stand?
- new timing chain issue
- 35-40 thou milled ls1 heads
- Oil Cange, stuff on drain plug.
- Stock head gasket thickness and Bore?
- Street/Strip cam only without flycutting
- Callies cranks
- What lifters to use?
- Head Gasket for AFR 225 Small Bore
- Doing Cam Install Tomorrow..
- Need rocker arm bolts for 5.3L
- Heads cam?
- Cometics from TSP: How long do they take?
- check spring question
- Throttle Position Sensor C5 help
- 226 226 112 to bif for daily driver
- Cylinder Heads Question
- Cam and gas mileage
- Lifter noise
- 02+ LS1 stock with LS6 springs?
- Cam gasket kit.
- How much $$$ for cam upgrade??
- LS1 GURU's PLEASE HELP!!!
- Problems assembling Patriot heads (spring seats)
- Braided Line Question....
- 402 block
- how much are my heads worth?
- Patriot duals install only?
- Need help figuring DCR for LQ9 with FM11
- How much does it cost for 408 machine work?
- Good Cam For me?? Help
- At what lift and duration are aftermarket springs needed?
- Best cam for spray/emission??
- After head & Cam questions on a 99 ls1
- Just out of curiosity, would a 98 ls1.....
- Anyone running MS4 w/ .040" Cometics?
- ls1 oil pan's oil filter housing pic needed
- Compatability Question
- How to id valvesprings?
- gear driven ls1
- flow #'s for ported dart 225's
- NewB With 408 In Mind...
- cam install help please
- anybody have morel's in stock?
- Ls1 oilpan removal help
- Switching from 1.7 to 1.8 rockers....PR change?
- Input...
- Blue valve seal
- ramp rate/valve spring ?'s
- how far do the pistons come over the deck on a ls1/ls6 block?
- Would I be a fool?
- LS7 heads are what casting #?
- 5.7 heads on 5.3?
- PING: Anything Else Sound Like It ???
- Cam or stall?
- How is this for a street cam?
- New Speed inc. 408-427ci cam
- largest cam only number?
- LS1 98 Heads
- H/C/I for shorties
- Car bogged and Oil Pressure gauge shut down.
- oil pan removal help
- Going to order custom cam! Best specs to pass emissions???
- Best heads for 231/237 cam?
- Bad Oil Leak After Oil Pump Install
- guys with big cam come in
- MS4 or G5x3
- Anyone know torque specs for arp head studs?
- Losing coolant, but EVANS coolant. need some help.
- Cam surge question?
- Opinions on these intake ports
- cleaning heads with...
- rocker arms i need
- forged LS1 H/C, FI, bolt ons, how much power?
- G5X4...good for a 402?
- Some MS4 Questions
- New cam what all do I need?
- Power differance between XE and XE-R lobes?
- I need a cam!
- MS4 dyno results or track results????
- How much horsepower would an LS6 cam and springs add to a stock LS1?
- Got an off the wall question
- compstar crank
- Patriot cam owners - Dyno numbers
- your thoughts please
- retainer/lock issues
- need oil pump help!
- Bearings
- found this on the 'net
- what cam for pp 243 heads
- Ls2 timing chain- suppliers to UK?
- Ticking Noise PT: 2
- stock gaskets?
- 6.100 Compstar rods and pistons for stock rods
- Do I Have To Flycut?
- What are 862 heads?
- MS4 and cam help...
- PTV issue
- Cleaning off old head gasket.
- Losing Oil Pressure?
- oil pan gasket install
- TEA heads with a G5X3 cam ??
- Cam only question....
- Cam gurus: overlap question
- Rate my setup plz.
- What do you think of this combo.
- head gasket?
- intakes for ls1 need some advise
- got ah $1000. need help to dump im motor
- ms3
- what makes a cam fall off after peak?
- LS2/LS6 heads with my cam.
- Nice Street Cam?
- new heads big difference?
- afr 205 or 225?
- Which Pushrods for Z06 Cam
- G2-3 vs ls6
- Typical price for install
- Heads/Cam or Cam only?
- Is it normal for catch can oil to look like milk? (pics inside)
- Best 383 combo?
- looking for 9's
- cam interference???
- My 408 Pics
- 225 Dart Heads, how big of a cam can I go?
- what springs to get??
- Quick-rev LS1 recipe??
- Max-effort (best ET) H/C setup for A4 w/ 3.23s and 4k stall?
- Internal Engine Newb!
- just got heads/cam installed
- MS4 cam & 6.0L heads
- Katech cams
- MTI cam on stock z28
- Iron head 6.0L
- cam help
- 6.0 Piston Help
- what else do i need
- Need good advice on
- Can you put Forged pistons on stock rods??
- changing to Katech rod bolts
- what the hell???
- Lifters...
- What advance would you install this cam at?? Patrick G?
- largest cam size -ls6 springs
- The Car Is Alive Again!!
- stock cam specs please
- pushrod length
- Sanity check this heads/cam build
- ms3 results
- A question on oil changes w/ a big cam.
- G5X2 cam...will 26.6 lb injectors support this?
- Overlap and lope question
- Cleaning 6.0 Bottom End?
- stall size for v2
