View Full Version : Generation III Internal Engine
  1. Will LS6 springs work with .555" lift???
  2. Lets talk heads
  3. 5.3 or LS1 heads?
  4. Camswap completed
  5. G5x3...shifting and rev limiter?
  6. Can Get Exact Length Of Pushrod! How?
  7. input
  8. LS engine in 240SX!
  9. Ka-boom! Nitrous Mis-hap Pics
  10. ordered my g5x3
  11. is my valvetrain too loud??? vid inside...
  12. should I use copper spray on my head gaskets?
  13. 5.3 Heads
  14. Help Please. Crank gear.
  15. Who built your forged engine? Just doing more research...
  16. Stock Crank
  17. Will these heads work for me???
  18. Stock Rocker Arms Fall Apart
  19. parts started arriving
  20. Stolen: jesel mohawk rockers for ET 245 heads
  21. LS7 lifter preload
  22. valvetrain question
  23. are my heads clean enough to install???
  24. PRW shaftmount Rockers
  25. what push rods
  26. Will ls6 springs work on lt1?
  27. Question about power under the curve and low rpm torque
  28. L33- 5.3 aluminum block motor performance mods
  29. 6.0 block parts
  30. Help on Texas Speed PRC heads
  31. Worth it to switch to ported ls6 heads from ported ls1 heads?
  32. what's the advance on a 228R?
  33. Need some general install advice.....
  34. Trying to prime LS1 before startup
  35. Build my Engine
  36. newbie h/c advice
  37. Trouble with Fumes
  38. drilling 190 stat
  39. PRC heads and Torquer V3 camshaft
  40. oil pump question
  41. whatcha think ??
  42. Need Cam-Only Advice on Specific Setup
  43. How do ya measure base circle radius?
  44. Cam ?
  45. clean block for new headgaskets, best way??
  46. 408 running rough headache for 2mo!!
  47. 243+ms4+fly cut
  48. Getting stuff together for h/c, what do you h/c guys think?
  49. Cam only?
  50. Preload for LS6 lifters?
  51. ls1 internals
  52. Cam selection advice
  53. Lifter ?
  54. Any idle videos of the g5xx cam
  55. HELP: Front Cam Bearing Damage... Please Look!
  56. LSX intake?
  57. How many times can you rebuild a 346
  58. ls1 engine cover question
  59. Piston choice
  60. what year did the vette get the LS6
  61. NEW ls6 cylinder heads for sale
  62. Machine shop in the DC, Northern VA area...???
  63. 1.7: harland sharp rockers
  64. Katech How-To: Check lifter preload
  65. Pushrods
  66. Need opinions from h/c guys
  67. Very Bad Ticking
  68. What would you do?(piece by piece, or complete)?
  69. Pushrod size?
  70. LS6 springs max?
  71. another stupid flycutting question...
  72. 1998 F-Body LS1 so bad?
  73. New Engine Project
  74. same heads?
  75. cam choice
  76. Am I f'ing my sh_t up?
  77. TEA 1.5 ls6 or livernois Stage 2 w/ g5x2 cam
  78. LS1 T56 considerations; maybe a LT1 T56 instead
  79. TR224 on 112lsa sound clip!
  80. To install or not to install...........
  81. Deck surface clean enough
  82. snag during camswap.
  83. who has cometic MLS .040" gaskets?
  84. question to you tech nuts
  85. Will a ls1 to ls6 intake swap cause me to throw a code?
  86. Heads? Newb Sorry
  87. My ticking engine. Pics of lifters
  88. Will LS2 rockers fit 317 heads?
  89. TSP 5.3L Stage 2.5 heads results inside
  90. Shortblock assembly guide
  91. Motor Problems and stroker q's
  92. pics of ported oil pump and correct setup on engine
  93. ls6 heads and cam question
  94. ls2 timing chain question
  95. cam install question
  96. sewing machine sound after cam?
  97. New Engine Question?
  98. problem with forged 347
  99. turbo cam
  100. pulley ?
  101. Ticking noise?
  102. 2002 Z06 Heads
  103. What is the difference in head casting numbers?
  104. need help!!!!!
  105. Oil Consumption
  106. Trex and Edelbrock Terminator heads...
  107. Lq4 ?
  108. A little help regarding Rocker arm replacement
  109. deleted AIR and EGR, doing heads/cam what to do?
  110. 98 Heads VS. 99+ heads
  111. Head Choices??? Experts chime in
  112. 02 LS6 Head Question
  113. QUICK QUESTION so I can figure out my DCR
  114. is it hard to torque the head bolts??
  115. took off my oil filter/pan and found this! broken? (pics)
  116. BIGGER ROCKER ARMS? Stock appearing LS1
  117. will LS2 lifter trays fit an LS1?
  118. Can you re-use head studs?
  119. Is this a good deal? h/c
  120. Pics of my New Canadian Performance 347!!!
  121. 226 cam???
  122. piston to valve Ok??
  123. Lifters solid vs. squishy & preload measurment?
  124. Newb question...How can I tell which block I have?
  125. Torquer v3 + Winter projects: DONE!
  126. Blow by Smoke Outta the oil cap Breather Filter
  127. Help me choose a cam!!!!!
  128. Cam change ?
  129. Problem with shortblock shipped, deck block?
  130. Southeastern US Engine builders
  131. stock rod with good bolts?
  132. Cammin' the Z06
  133. 98 heads (flow)
  134. header help quick....
  135. H/C ++ HOSE of NITROUS
  136. are all 02-04 zo6 pushrods 7.45?
  137. Degreeing MS3 cam
  138. Patriot Gold springs question.
  139. tsp 5.3 stg 2 heads with tsp 233/239????
  140. Help with Wiseco/Eagle measurements
  141. what is a ls4
  142. symptoms
  143. looking to buy a 408
  144. New piston ring ??
  145. Pulled motor???
  146. Can TTY stock headbolts be re-torqued?
  147. Has anyone tried the GM manifold and a carb?
  148. SLP Pulley + DR Timing Chain
  149. Almost Done Install
  150. What cam should i go with for a blower setup
  151. should I use .030 or .040" cometics?
  152. Dart225 Head's and Stock Rocker's
  153. What SCR / DCR to target for?
  154. Anybody happen to know the exact length of stock pushrod?
  155. Oil Pressure Stays up
  156. input needed with oil pressure issue
  157. ls1/ls2 valve question
  158. what rod length for 4.8 crank + ls2
  159. Questions about Head/Cam setup!
  160. Help Engine Assembly ?'s
  161. Trying to find "ignition switch hot lead"
  162. Please help me to verify the 2001 Z06 cam
  163. what will work
  164. Lifters
  165. Help! Hate to do this but I need help with
  166. flycutting pistons
  167. C5r timing cover
  168. Need cam position sensor connector help!
  169. what Lobe Seperation for a 228R??
  170. ms4 vs. ms3 ..
  171. Cam Only w 90k plus miles w stock lifters
  172. Do I need new Studs
  173. can i use green scotch brite pads and wd 40 to clean...
  174. adjustable rockers. What ones?
  175. simple head gasket question.
  176. Cam Help.. Newb Questions!!
  177. Stock heads on a TSP 228R?
  178. What to expect H/C LS1?...
  179. Head and cam install, then...
  180. Next Mod ???
  181. what heavier oil to use?
  182. Double timing chain with pully ?
  183. Head question?
  184. do i need to replace my cam or will li be ok
  185. LS1 blcok,,or LS6,,or Mutant??
  186. F14 installed straight up or degreed ??
  187. Quick question
  188. Are head bolts reusable?
  189. What diameter rod to use to hold up lifters, 1/4" or 5/16"
  190. ported my heads what do you think
  191. 383 LS1 Eagle crank and rods hitting oil pan
  192. How many HP stock LS1 can handle?
  193. Help~Head and cam combo
  194. Morel lifters est. ship date. ...
  195. compression height
  196. Dowel pins or Flywheel?
  197. locking down the flywheel
  198. Finally ordered my Cam Package From TSP
  199. Having trouble finding a LS4 oil pump?
  200. anyone using this?
  201. Confused on Head Gaskets
  202. GM high-flow oil pump 17801830 vs. LS4? Help, is 17801830 just an LS6 pump?
  203. Yellow Terra's
  204. Does anyone know the actual price of the LSX block?
  205. TR5's same as TR55's ???
  206. Deck Height: +.006 or -.006?
  207. compression
  208. Help me choose the right cam!!!
  209. Customers of HPE please read!!!
  210. Damage after h&c install.
  211. Cloyes Adjustable timing set – Used ok?
  212. stock 5.3L cylinder head cc?
  213. 918 Valve Spring Question
  214. I have a strange one for you
  215. torn between cams
  216. How can I tell which block I have?
  217. Anybody in southern Iowa or northern Missouri ? need help
  218. PRC 5.3 stage 2.5 VS. PRC LS6 stage 2.5 on a 228R?
  219. why do some cams make a whine sound?
  220. What kind of Hp from this combo?
  221. 422 stroker
  222. Fel-Pro head bolts any good?
  223. Need help ASAP!!! Motor won't turn over!
  224. Afr ?
  225. Who does the best ported LS6 heads for a 3.905 bore?
  226. Heads only setup?
  227. PRC 5.3L stage 2.5 heads, 228r cam + other goodies
  228. TR224 112 owners check in
  229. Cam choice for my application
  230. what size heads
  231. Fast 90/90 with a mild H/C set-up?
  232. crank question
  233. crane cams
  234. How does milling affect flow #s?
  235. Looking for a good set of headers to match . . .
  236. Help - Starter Wiring Problem
  237. Cam Suggestions
  238. Flywheel question
  239. Cam arrived today. Grind is off. What to do?
  240. LIfter gloves
  241. Blown Head Gasket?
  242. cam choice for best et ability
  243. whos made over 800hp on a 346ci??
  244. Better street cam...G5X1 or Patrick G's 228/232
  245. 500WHP+ N/A possible??
  246. Project Crazy Power is ALIVE!!!!!!!!!!!!!!!!!!!!! 1st DYNO NUMBER IS IN
  247. Head bolt questions, ordered wrong ones.
  248. Need help picking out a cam for my application!
  249. Pressure readings do differ from one sensor to another..
  250. Poll: Bore or Stroke?
