View Full Version : Generation III Internal Engine
  1. What cam to buy?
  2. Patriot 243 cnc head owners read this please
  3. Cam advice?????
  4. high mileaged LS1
  5. Whitch set of heads/cam
  6. My DCR Calculator - If you have a Comp grind, it doesn't get any easier than this...
  7. Which heads would you choose?
  8. cam causing this?
  9. A motor and trans out of a car, maintenance?
  10. MS4 111LSA vs. MS4 110LSA
  11. Rear Engine Cover Alingment
  12. pushrod length with TFS 215's and harland rockers
  13. Slight contact
  14. whats cams are you daily drivers using?
  15. Are my valve events optimal?
  16. Loud knock in LS1 after engine warms up?
  17. Jumpy Idling
  18. 224/228 113lsa sound clips?
  19. improvement w/ aftermarket rocker arms?
  20. Is this the correct part number for lifters?
  21. SLP #51013 Cam 234/228 .576/.571 113LSA
  22. How many have had a Comp cam go bad??
  23. Patriot 243 heads and Comp XER 224/228 111 +2
  24. Need help with Texas speed package!
  25. Rate some flow numbers...
  26. G5X3 plus SLP 1.85 rockers....Problems?
  27. What Do You Guys Think?
  28. Damaged Cylinder Head! Need Some Advice!
  29. 2002 A4 Mti X1 Cam
  30. need head help on 5.3 / ls6 conversion
  31. Question about heads?! help!
  32. need help, im at the next step..
  33. Almost ready to start up after a rebuild
  34. newbie here, help me out please?
  35. valve size
  36. need some advice on heads
  37. Sneek Peak at "T56's Project Crazy Power"
  38. PTV clearance help
  39. Friend has ticking sound after 120MPH drive. Any ideas?
  40. Which Head To Get
  41. Who is running the G5x????
  42. Dodge or Chevy
  43. Money to spend
  44. please someone help me out with this question
  45. 2002 ls1 with a Z06 cam, will it work??
  46. Stock spring ???
  47. Not sure what's wrong...
  48. Cam effect on idle speed
  49. Suggest a cam for new heads
  50. Hand Porting/Polishing
  51. Flycutting Stock Pistons
  52. what vendor sells the ASA cam?
  53. 6-qts, stock filter size...oil hitting crank?
  54. Block warmer?
  55. Please someone help me out with this question
  56. who made a modified cam retainer plate?
  57. Need some decisions on a Tsp cam .Take a peek
  58. MS3 vs. FM 15
  59. pushrods
  60. Biggest cam without flycutting??
  61. are these heads ls1 or ls6
  62. How many miles do you get out of your 918s?
  63. Cam question and other parts in related to swap
  64. making sure the engine is clean during rebuild
  65. 5.3 gaskets?
  66. need answer
  67. Assembly Lube Question.
  68. How to port your oil pump
  69. Cam Install
  70. what head is a 799 cast number?
  71. Anyone Else Have 119.5 Lsa Cam?
  72. what do u guys think about these heads
  73. why is there two differant pt#s for headgaskets?
  74. The cam for emissions
  75. Finally found a cam i want but which company
  76. Help Calculating DCR
  77. CAM INSTALL: Can I use my oem sprockets w/ the LS2 chain?
  78. any problems with this combo?
  79. cam guys in here
  80. 5.3 heads for a 5.7?
  81. merry christmas everyone
  82. Oil pressure seems high
  83. ASA cam base circle vs stock??
  84. cam guru's in here please...(Pat and predator Z)
  85. looking for some advice... H/C swap
  86. Comp Cams 238/240, How Much Head Milling?
  87. Push rod length.....hhmmmm?
  88. Need a quick yes or no answer
  89. switch cam with new heads
  90. Cam Install Progress & Oil pan ?
  91. Head and cam package
  92. i need some help
  93. Keep 221/221 or go 233/239?
  94. which cam to use???
  95. ARP Mains question
  96. Pics of stock cam?
  97. ported 241's on a 5.3?
  98. Heard something about sending in stock Rockers for stronger rebuild?
  99. HELP!!!! Oil consumption?
  100. What do yall think about these two cams that I have picked out?
  101. Buddy's LS1 needs quieting down
  102. Cast pistons, who makes them?
  103. LGM cam install... do I need to degree the cam? Does anybody?
  104. swapping 01 LS1 into 98 SS
  105. lunati voodoo cam!!
  106. any problems with tr224 cam and stock rocker arms?
  107. bore question
  108. Does a 6.0 lq4 have a different harmonic balencer than ls1?
  109. Which cam with Patriot LS6 heads?
  110. how much to flycutt w a g5x3?
  111. L92 Intake and Head on LS2 block
  112. Ls1 Internal Engine Problems
  113. How much to mill stock 243s?
  114. What cam should i get?
  115. lifter tick at idle after Hitting 6k rpms
  116. Anybody have this cam? Comp 228/230 571/573
  117. Trickflow 215 heads and Harland sharp rockers
  118. Anyone LS6'ed their car?
  119. Head swap
  120. Which Cam?
  121. LS1/LS6 head flow numbers
  122. Oil Pressure
  123. Another Head Gasket ?
  124. Fly-Cut Stock Pistons or Buy New Ones? (What to fly-cut at?)
  125. What do you guys think....
  126. Stock 243s flow #s?
  127. What companies make a 4.100 stroke crank?
  128. Windage tray questions
  129. motor blew, help with decision
  130. Made my decision... 370 iron block
  131. Made my decision... 370 iron block
  132. Lifters - Caddie vs LS7
  133. .040 or .054 Headgasket thickness?
  134. Gotta love it when Santa brings mods to the family! Bumpstick time =)
  135. callies compstar crank?
  136. Is it worth the money????
  137. Another head question
  138. will i lose power
  139. Best use for a .10 over LS1 block?
  140. Ideas for a 87 octane LS-1...
  141. aftermarket rod torque
  142. stupid head question
  143. Tr 224/112?
  144. MS3-v3( CAM CARD) SPECKS
  145. Merry Christmas from Patriot Performance
  146. Help identify this cam
  147. MS4 Track times?
  148. can rod bearing be replaced without .....?
  149. Valve Float at 6300
  150. Cam experts,help me understand lsa's with advance.
  151. anyone build a 5.3 for a car??
  152. Is a 4.125 stroke to much for a street engine
  153. Pushrod length help
  154. measure of CC on heads
  155. Need some opinions on quest for more power
  156. 1.85 rockers, simple question
  157. Clevite H Bearings
  158. Dart heads
  159. Critique my proposed combo
  160. Help me with a 402
  161. did I ported my stock LS1 heads correctly? see the post.
  162. G5x3 cam in a vette?
  163. Cheap royal purple oil
  164. Are these Titanium Retainers On These Heads?
  165. Ms4, Stage II heads, new bottom end help!
  166. Why does my engine knock now?
  167. l92 heads
  168. Cam Break-In
  169. Help me decide on which of these blower cams to go with .
  170. I have a rattle sounds like the clutch
  171. a 4.06 or 4.065 HG needed
  172. How to build a 98 block for forced induction?
  173. Does this sound right? (PR Length)
  174. 4.065 Bore
  175. any with a ls4 oil pump
  176. blown head gasket?
  177. Quick compression ?
  178. Cam or Nitrous?
  179. pushrods bend..alot.
  180. Are all 2002 LS1 motors really LS6 blocks??
  181. TSP 5.3L Stage 2.5 heads pix inside
  182. Does this sound right???
  183. Copper Spray Stock Head Gaskets?
  184. Crank walking
  185. where to get cylinder head coolant plug?
  186. Anyone running..
  187. people with comp 1.85's
  188. 01 C5 LS1 infamous Valvetrain TICK?????
  189. Oil leak help
  190. Guys With 6.0 Iron Blocks Come In
  191. What coupler are you guys using with your 90MM TB's?
  192. Patriot Performance Christmas Special ! 243 Heads, $350 per pair... Gold Springs $225
  193. Horsepower?
  194. Preload on comp r's?
  195. What Is On Your 2007 Wish List For New Products??
  196. Bang for Buck swap
  197. from a 228R to a 230/236
  198. Car jerks at WOT...
  199. new design tfs head in 2007??
  200. What is the stock CC volume for #243 heads?
  201. why is my coolant light on?
  202. A Piston CR Question?
  203. intake runner size/cc size of 5.3s?
  204. High pressure or high volume oil pump?
  205. 110 lsa cams
  206. Re-Torque Cometics?
  207. Which crank and rods?? Turbo app(1200-1500hp)
  208. Car Overheated - Need Some Help Diagnosing Problem
  209. wear on valvetrain - new to cam
  210. Anyone? Photos of ARP studs & head install
  211. Pinging?
  212. what cam with TSP 5.3 stage2.5 heads
  213. What causes surging?
  214. Wheres the love?
  215. why do cammed LS1s sound like crap?
  216. cadillac lifters?
  217. Need Good CAM for my 01 ls1 camaro!
  218. tuning the 7th collector pipe with 02
  219. Dart 205 or 215 for DD?
  220. Which Oil pump and timing set?
  221. Engine Ticking, FIXED
  222. upgrade injectors with new cam?
  223. Front and rear engine covers and gaskets
  224. head stud differences?
  225. large cams and vacuum
  226. lowering compression...
  227. Power range on a ms3 on a 110lsa
  228. E85 internal engine pics
  229. 353 hp out of TR224, sould it be better?
  230. casting #s
  231. Cleaing Aluminum Cylinder Heads
  232. Futral f13 114 vs 112 LSA
  233. will this cam pass Cali smog ?
  234. heads and casting #'s
  235. Arp
  236. heads for my ls1
  237. Crank damage advice needed
  238. 40rwhp improvement?
  239. dcr on this cam?
  240. got pics of a ported oil pump? what shim?
  241. throttle body question
  242. Anyone hear of "dome brushing"?
  243. Help! Gas Leak!
  244. want 40 ft lbs of torque...
  245. Have to choose
  246. ms3 or??
  247. Cam swap question..
  248. Knock Sensors/Valley Cover
  249. best 90 mm TB ?
  250. Another fn set of leaky cometics
