View Full Version : Generation III Internal Engine
  1. Direct bolt up or will I need extra parts?
  2. I want just a bit more grunt
  3. metal in oil
  4. What ring gap size and rod bearing clearence?
  5. Truck/Car balancer.
  6. Forged Rods $ ?
  7. SI3 cam?'s
  8. Fix My Car Please!!!!!!!!!!
  9. cam & highway fuel mileage
  10. stroker motor
  11. 5.3 liter bored= 5.7 ls1 style iron block??
  12. These heads
  13. Motor is out, got a few questions
  14. cam to small or not ?
  15. Will a 6.0 Iron Block Truck Oil Pan Work on an F-Body?
  16. ptv clearence
  17. Iron vs aluminum block: Lifting heads
  18. Castrol Syntec different shape???
  19. Wanted 400 HP cam for cam only set up!
  20. Could I use 1.8 roller rockers with this cam?
  21. right cam
  22. Rhoads Lifter Cold Start Vid
  23. Need Advice On A Bigger Cam!
  24. Monaro LS1 full bolt-ons and now looking for a CAM
  25. reluctor wheel removal
  26. Anyone tried this cam?
  27. Does ARP make a C5R head stud kit?
  28. 2004 gto cam only ticking
  29. How many have de-modded or considering?
  30. Valve Stem Damage - Anyone seen this before?
  31. Piston Types?...
  32. Cam ??
  33. TR224 vs fms F2vs TSP228R
  34. Roller Got Stuck On Brand New Lifter
  35. Piston types?...
  36. Compression Question?
  37. which ENGINE for racing ????
  38. Stock push rod length?
  39. Crank threads...
  40. Need torque specs for bottom end & rod to rod clearance?
  41. ARP head studs or not
  42. AFR head combos ?'s
  43. Aftermarket parts on new DOD/AFM engines
  44. New GM Performance heads
  45. Rering or R&R/bore 2000 z28
  46. think another valve spring broke again
  47. 918 springs on afr 205 heads?
  48. TR224 Killed my MPG
  49. Figure out CR?On 408ci
  50. main cap bolt ?
  51. Cam Bearing Tolerances
  52. cam selection
  53. buying used heads??
  54. PTV Clearance
  55. big bore/short stroke LSx
  56. Cam swap: What method for Keeping lifters up??
  57. 5.3L oversized pistons
  58. short stroke/big bore LSx
  59. DIY Head Porting Project (5.3 Heads) Lots-O-Pics 56k Beware
  60. cam vs cam
  61. Max SCR and DCR to be totally safe???
  62. BitVipers Build Off..
  63. input please! NOOB H/C swap ls6 heads + MTI Stealth II
  64. What cam?
  65. 806 heads on a 6.0
  66. help me in heads/cam install?
  67. hand finishing cnc'd heads ???
  68. My TSP Shopping Cart.what do you think
  69. Cam Power ???
  70. Pre Owned 66cc AFR 205 cc heads
  71. carbed ls1 / cam
  72. Heads Question
  73. Which rockers
  74. 03 ls6 cam
  75. need help diagnosios
  76. cam swap questions??
  77. Cam Suggestion??
  78. SELLING MY BIKE: Now getting H/C Package?? Which Should i go with?
  79. Manley dual spring identification marks?
  80. Is there Engine building how to book?
  81. LT-1 To LS1??????
  82. Oh yeah - a Gasket question
  83. question for those with an F14
  84. 218/228 .558/.558 116 any good for a small budget cam?
  85. 402 cam pick one
  86. Anyone have LS6 Intake/MAF CFM numbers?
  87. Prefered head gasket for a H/C swap?
  88. Trex cam = 377hp
  89. Pics of my new Canadian Performance 347!!!!!Time for Boooossst!!!!
  90. 862 casting combustion chamber size, WTF???
  91. Is this a scratch or crack??? in No7
  92. stock cam specs
  93. Quick question...MTI X1 or Speed Inc SI007...
  94. I bought a 6.0l Block what now?
  95. head gasket thickness
  96. will my car break
  97. Where to buy rev dual springs??
  98. Trex + Ls6 ported heads
  99. Trex vs 244/248 stroker cam
  100. Rebuilding LS1...
  101. About to buy some AS 5.3 heads ... is this what I need?
  102. Please help identify this cam.
  103. Cam help with intake angle
  104. Cheaper rods with Katech bolts?
  105. Last question on my head/intake install!
  106. changed my mind
  107. Lowering compression???
  108. Springs
  109. 15k miles... springs need replacing
  110. How does VVT(Variable Valve Timing) on new 6.0 work?
  111. Harland Sharp Rockers....question about metal strip from stock head?
  112. After Market Rocker Arm Stud question....
  113. ASA cam or similar custom cam w/ Dart or AFR 205's
  114. My Cometic Head Gaskets still good(pics)
  115. Pushrod size - 7.400 or 7.350?
  116. Effect of Swapping 1.8 to 1.7 Roller Rockers?
  117. boltons just dont cut it anymore
  118. mls gaskets with old ls1 head
  119. [B]Cheapest way to get 400hp out of an LS1?[/B]
  120. SLP 233/239 Cam
  121. low vacuum
  122. Don't want to get stuck in the ricer mentality of horsepower stacking...
  123. Cam time
  124. 402 Cam Swap? And Dcr?
  125. Internal Engine Question(s)
  126. LS1/LS6/LS2 compression, gasket, cc questions
  127. 02 Head Gasket Question (Experts with Expereince Please!)
  128. Pending head upgrade install "lifter & rockers"
  129. Check Out This Dyno - Cam Q?
  130. Heads and Cam Questions!!
  131. Changing Rod bolts
  132. Stock h/c swap worth it?
  133. Well...tomarrows the day!!
  134. bigger valves on stock short block
  135. pros/cons of running a bigger cam over a 224?
  136. need help with a H/C decision please.
  137. easy engine question for the gurus
  138. LS2 heads?
  139. Question about head/cam package
  140. rattle noise?
  141. Mti x1 cam.
  142. whats your thought on compstar?
  143. is a swap to a .040 gasket thae same as a .015 mill?
  144. Accel 4bb throttle Body
  145. Another damn cam question
  146. 918 or PRC duals for 228R?
  147. What's the formula for milling? (How many thousandths off for increased compression)
  148. Need Some Help With these Ebay Heads?????
  149. need help ASAP with patriot gold install! look!
  150. How much boost on forged 10:1 Compression motor?
  151. head and cam question
  152. Largest cam with a stock stall converter...?
  153. part # for napa gold long filter
  154. Approx how much extra PTV clearance do you gain with -4cc Mahle pistons?
  155. Big HP H/C Packages - Common Denominator
  156. Best cam for my setup??
  157. Why are tolerances looser for an engine setup for n2o?
  158. best non stalled cam?
  159. TSP Heads Competition valve job
  160. Iron 346 for twin screw application
  161. Cam swap Advice!!
  162. Are single-chain Rollmasters loose on the crank?
  163. MTI S1 cam clear with stock heads?
  164. Ported 243 Casting + MS4 or TV3?
  165. special finish hone for hellfire rings?
  166. Ring gap questions
  167. F14 with stock heads?
  168. Will i have enough PTV clearance?
  169. veteran that needs help with new setup
  170. Help with a TSP CAMSHAFT Package.
  171. Smoke from the tailpipes
  172. electric water pump
  173. Help
  174. Catch can through ported or manifold vacum?
  175. Broken Timing Chain & Piston Damage
  176. What thread type / pitch are the LS1 headbolts?
  177. where is the casting number on the heads?
  178. Trex cam what Heads?
  179. Missing after cam install??
  180. Anyone running the TPIS ZL-15 Cam
  181. Car Stalls but Runs Good.... Help me out!
  182. PTV on .40 gasket and 60cc TSP Heads
  183. See you at PRI
  184. Cam @ Heads Or Cam @ Nitrous????????
  185. Sweet Oil Filter!!!!!
  186. should my machinist have used a torque plate?
  187. Good Cam for California Car...
  188. car go boom. christmas early..few questions...
  189. what heads would work best for my setup?
  190. Cam swap on an A4 question..
  191. The Engine Torque Specs
  192. *HEADS* winter project
  193. Just Changing Springs for 224 563* cam
  194. why bore to 408
  195. Should I Change Out My Cam?
  196. noob cam questions? opinions please
  197. Stock rods
  198. head porters, opinions/theories inside.
  199. more help with dcr
  200. Parts to order?
  201. Q's about using this DCR calc?
  202. LS 1 rockers
  203. Please fill me in!!!! Please post up!!
  204. How to clean a piston?
  205. Cam Install Complete ... few questions about issues with motor ...
  206. When should I change valvesprings?
  207. Help with spring install!
  208. 3.903 mahle pistons
  209. Identifying year of heads
  210. ARP 2000 Rod Bolts w/ Eagle rods tq spec?
  211. best cam for 5.3 StageII?
  212. 228/228, .571/.571, 112+2
  213. Who best to buy a 383 shortblock from?
  214. Valve tip wear?
  215. 228r, 233/239, MS3, MS4...from 20mph roll
  216. thoughts on 244/248 612/615 112+2
  217. moisture in oil.. Why?
  218. PTV and compression ? with my combo
  219. Quick Cam question.
  220. 918 retainers on 921 springs?
  221. Best cam for 59cc heads?
  222. some help!!
  223. engine math help
  224. GEN III/LS1/LS6 350 Xtreme RPM HIGH LIFT XR265HR Cam
  225. LPE GT2-3 vs. Custom XFI, Int/Exh dur '02 LS6 Cam @ .200"? (Maggie-cam choice)
  226. MS3/PRC Stage 1.5 5.3 heads, sound good?
  227. LS1 mileage question
  228. X-er 232/234 @ 112
  229. LG G5X4,Afr 205's, and compression
  230. Stock 241 intake runner vs. 243s
  231. Heads/Cam Suggestions (From the gurus preferably)
  232. TFS Heads, FAST and ECS Cam Install Pics
  233. Rings for my boosted short block?
  234. Ticking at higher rpms only in overdrive...
  235. Carbon pitting on the valve seats???
  236. in-lbs to ft-lbs?
  237. What parts to soak in oil?
  238. lifter trays?
  239. Help me pick a cam for a 408
  240. How much does your engine shake?
  241. Questions for Dart Head Owners w/Beehive Valve Springs
  242. Wrong bearings?
  243. Cam install done - seem normal?
  244. Looking for opinions on my H/C combo
  245. LS2 or New updated LS6 springs?
  246. Rev limiter
  247. Head flow numbers???
  248. Question on Oil Level
  249. Valvetrain replacement on 551/551 cam
  250. Timing Chain lose
