View Full Version : Generation III Internal Engine
  1. New TEA Phone Number!
  2. Started my cam install today...
  3. TRex cam with nitrous possible?
  4. LQ9 bore question...
  5. Getting Parts Together for H/C Swap
  6. LS1 swap over an 94 LT1 camaro
  7. 346 h/c set-up good for 430+rwtq
  8. annoying 1514 PCM Code
  9. 120K Miles...Valvespings still OK?
  10. different waterpump inlet/outlet ?
  11. cam sensor ?
  12. What will a little spilled Coolant in the cylinders do?...
  13. need help choosing a cam
  14. Starting a new engine build!
  15. Heads/Cam for 383
  16. Time for a cam but which one.. ASA or Hotcam
  17. 408 in an 02 z06
  18. Stock heads that flow better
  19. Ms4 Cam question
  20. Home Porting 241s, Valve Seat ?
  21. H/C setup for 450RWHP N/A
  22. engine block
  23. guess my dyno numbers
  24. question for people who have blown headgaskets...
  25. will these heads clear with a ms3
  26. Tr224 and GForce tune = 391rwhp
  27. What Is Causing My P0307 Misfire?!?!?!?
  28. Trick Flow Heads
  29. Need help matching cam to these heads............Cam guru's please come inside
  30. Intake manifold 180 deg. rotate ?
  31. Oil leak after cam swap
  32. Help! Emissions Time again: is my O2 sensor bad?
  33. Cracked heads? Small cracks between valve seats
  34. Help
  35. Cam spec help from the pros
  36. Budget 6.0L/370 short block?
  37. Winter Storage A Foot of Snow on the Way to Chicago
  38. 6.0 engine 317 heads or 241
  39. This oil situation look normal to you??
  40. how many cumbustion chamber CC's are lost from a resurfacing?
  41. Valve Springs - Rockers - Push Rods???
  42. Old head gaskets .056 New head gaskets .040
  43. ARP Head Bolt/Stud Question
  44. 238/242 .600/.610 114+4 what do you think.
  45. How much 1/4 mile difference in TR224 cam over stock?
  46. UHOH! What did I break?!?! HELP
  47. Motor May Be Toast
  48. Juggernaut cam? Too big?
  49. MS3 but what lsa?
  50. Who's running that LG X4?
  51. Check out whats left of the motor guys! (eat it 56k)
  52. Cams LSA and its effects on Nitrous.
  53. how to port heads
  54. 98 oil pump
  55. broken spring's
  56. 918 springs on f14 cam
  57. Trying to find....
  58. LS1 operating oil temperature?
  59. poly motor mounts = bad vibrations! help!
  60. X-ER lobe list?
  61. wich budget short block would you have?
  62. morel lifter preload?
  63. how much hiway MPG loss with big cams?
  64. WOW, what about this new INCREDIBLE and affordable GM Perf LSX block coming soon!
  65. MS4 with stock heads??
  66. Thumbs up to PATRIOT PERFORMANCE!
  67. Rough idle....help?
  68. LS6 heads, NOT ported...Worth it?
  69. Beehive springs, good, bad?
  70. How big of a difference between BIG cam/good heads vs. tr224/good heads?
  71. Gaskets needed for Head Install?
  72. lt1-ls1
  73. Attn. Tony Mamo: Saw An AFR205 Setup Make 502rwhp/450rwtq...
  74. Rear Crank Freeze Plug Leak?
  75. m6 Idle speeds
  76. I need to be Sprung
  77. How well does a TR224/PRC Head combo Work?
  78. DESPERATLY need help... its been 2 years...
  79. Vic Jr/elbow N/a Hp #s
  80. Very Quick and Easy Question 4 U
  81. opinions from everyone
  82. Head porting?
  83. C2 or G1 MTI cam w/ 243 Heads?
  84. LS6 - LS2 Conversion
  85. Don't Get on it if it isn't tuned?
  86. Motor went BOOM! what are my options?
  87. stock lifters part number?
  88. LS1 water jackets - am I missing something here???
  89. Coolant smell?
  90. Bending pushrod problem
  91. what valves do ls2s have?
  92. Best nitrous cam ?
  93. How do heads affect idle and driveability?
  94. detonation?
  95. Lifters? High Rpm guys large cams 250+
  96. low numbers after h/c
  97. Help me identify stock springs from my comp 915s
  98. 853 heads. milling/cc and gasket questions
  99. New WS6! But stalled out a few times
  100. what length pushrods do you think I should use?
  101. Should I keep my comp R's or ditch them
  102. Question on my Cam selection
  103. head gasket
  104. what internals for a forged 346 on boost
  105. what cam to get
  106. 03 ls6 cam setup to 98 ls1
  107. Best Way to Clean Heads???
  108. Milling LS1 head q?
  109. LQ9's Heads (Need Help Getting Some ASAP)
  110. what do i need in a head for low end power?
  111. afr heads and 918 springs
  112. LS6 heads - Where to port?
  113. patriot 226 cam
  114. 2002 z valve springs
  115. Anyone running a Trex v2 and AFR 205/59cc
  116. Different Sized Pushrod?
  117. too bigg?
  118. 5.3 L which cam
  119. benefits of stroking motor *noob questions*
  120. ms4/patriot stage 2 heads?
  121. Who's still running stock lifters?
  122. Driving for a tune 50miles away with h/c/exhaust?
  123. SI7 cam question...
  124. 370ci
  125. z06 cam question
  126. Overlap
  127. compression with flycutt pistons
  128. Grind #'s from pic of TSP Giant cam?
  129. lobe pitting on cam.
  130. Changed oil and found metal sludge on magnet
  131. Torquer 3 idle (vid)
  132. m6 ms3,ms4, T-rex guys inside please
  133. TREX/Head question
  134. Milling heads and getting thinner head gaskets
  135. Seating Rocker Arms
  136. Just got an 00' LS1 and am looking for 450whp
  137. Where can I get a set of bolts for my new heads
  138. Oil Pump
  139. More Street or More Strip?
  140. taking heads/cam out and have a ?
  141. patriot heads?
  142. TR224 questions
  143. 5.3 heads
  144. Valve retainer dropped?
  145. tourquer 2 with heads PLEASE HELP
  146. can someone chime in ASAP?
  147. MS4+ETperformance240cc heads???
  148. AFR 8017 Valve Springs wth G5X2 or G5X3?
  149. No difference?
  150. TR224 + heads or TR224 + Nitrous?
  151. how hard is it to swap out rods / pistons & rod bolts?
  152. Compressed Air + Cylinder = Pop! No Compression
  153. stock head & n20 question
  154. another combo to ponder..i know i know..it never ends!COME IN
  155. Need help taking out motor!!!
  156. Come in and help please!!!
  157. afr 205 heads with tr 224 cam??
  158. Clearence question
  159. Better drivability/performace/sound
  160. Cam grinder specs
  161. Cam Question
  162. run like i lost power
  163. Head Install complete
  164. when do the lifters need to be changed? (how good are stock)
  165. what parts are needed for ls1-ls6 intake swap
  166. yay or nay??
  167. All The Best Internals
  168. LSK & XER LOBES AND STOCK LIFTERS WHOS DOING IT
  169. How to properly adjust stud mounted rockers...
  170. MS4 install problems!!!
  171. Won't idle
  172. Ms4 Cam
  173. Lifters going bad? Maybe new cam!
  174. Keeping Stock Heads...
  175. 6.0 oill pan
  176. Good idea for valvetrain upgrade?
  177. Blow by?
  178. best heads for torquer 2
  179. 383 LS1 parts give me advice
  180. Cam Help
  181. Installed the Patriot Golds today. Question
  182. Sralling Vette, please help..
  183. Afr Vs Tea Who Makes More Power
  184. Good boost cam?
  185. How good are Eagle ESP H-beam rods?
  186. name that cam?
  187. whats my compression? diamond pistons - 241 heads
  188. Compression with Diamond -8.6cc pistons and 241 heads
  189. Need Help Big Time!!
  190. cam is in and heads are on
  191. Anyone seen this Intake Manifold?
  192. My New 370 motor
  193. How much of a gain would you expect?
  194. Car went boom....
  195. can u bore a 98 ls1 block to 3.905?
  196. Camshaft Comparison
  197. what size piston rings for stock ls1?
  198. Need Advice: Refresh Stock Engine Before Reinstalling?
  199. MS4, T-rex, MS3
  200. Anyone make bigger than 72 cc chambers?
  201. Anyone running the CheaTR H/C?
  202. any ideas?...
  203. cam install last night, ran into coolant problem.... help!
  204. untuned
  205. biggest cam in AFR 62cc w/o flycut
  206. ETP Head Guys Help Please???
  207. Go to MS3
  208. ms4 soundclip???
  209. is it safe to mill stock LS1 heads to 0.030"?
  210. Recomendations for rebuild
  211. What is the biggest cam I can run?
  212. GREAT no dipstick hole on ls2 block I installed
  213. Roller rockers and lifters
  214. TR224 vs comp 224/228 .588 112LSA
  215. What can be causing my car to surge this bad??
  216. Need an LS6 spring pressure spec
  217. Guys who daily drive their TR230/224 come in!
  218. ? About some Fault Codes
  219. Vote on Which Will Explode First:
  220. need help
  221. Cam Install What Else Should I Do While It's Apart?
  222. T.R. CheaTR with 918's, GO or NO GO?
  223. PP 96mm Typhoon Intake for stock cubes??
  224. performance packages?!?!
  225. Ticking after Start up????
  226. Will I need Bigger Fuel Injectors?
  227. cam swap missfire
  228. What heads should I purchase to use with lingenfelter GT2-3 cam
  229. Stock peices can support ??? horsepower - search function not working
  230. Best cam for a 35th LE camaro SS
  231. Cubic Inches vs. Forced Induction
  232. How hard is it to fix a cracked block?
  233. Piston slap...
  234. Anyone running a solid roller?
  235. Cam Package Need Help
  236. will this micrometer work on LS1 heads?
  237. AFR heads?
  238. Why shim to within .050" of coil bind?
  239. high idle / reverse lockout / no odometer
  240. What valve spings for g5x4 cam?
  241. Tsp Ms3??? Or Ms4???
  242. Rebalance cost
  243. ls for old school 350
  244. Help to diagnose engine problem?
  245. bad news for me
  246. Bearing choices, what to choose?
  247. Breather=Unmetered Air !!??
  248. Can you build 427 c.i. using an iron 6.0L block?
  249. TSP Torquer v.2
  250. safest mill to mill the heads?
