View Full Version : Generation III Internal Engine
  1. Futral Heads
  2. Jessel Rocker Arms
  3. Head cam swap bolt on swap info
  4. Double roller timing chain - benefit or no?
  5. Harmonic Balancer went bad, possibly bad crank? Please help.
  6. heads for turbo
  7. Can't idle - I'm about to rip my cam out and THROW IT!
  8. TrickFlow Heads
  9. Cam Idiot here... About to order, need advice.
  10. Please Help!!!
  11. Anyone know torque on LS1 heads
  12. slp camshaft
  13. I need to ask a Question?
  14. How long to break in heads?
  15. what heads work best with t-rex cam?
  16. Oil question w/ cam break in.
  17. PTV problems with T-Rex and Stage 1 PRC's?
  18. Dont Buy Into It!!!
  19. what pistons to lower compression ?
  20. cam bearing
  21. Help identifying metal shavings
  22. what pistons
  23. quick cam swap question
  24. What length pushrods do I need?
  25. Super Chevy smoking crack? stock cam 407hp??
  26. super chevy stock 407hp block... Are they on crack?
  27. How are the LS1 sleeves made up?
  28. Limit of aluminum vs iron block for turbocharging
  29. Help!!! Noice Coming From Engine
  30. cam for road race/street LS1
  31. What lsa for a high stalled auto?
  32. Finished MS3 Install
  33. Is a garage rebuild of my shortblock unrealistic?
  34. synthetic oil
  35. Where can I buy trickflow heads from?
  36. In need of some rings
  37. rocker arm ratios
  38. Symptoms of a cracked spark plug?
  39. ls2 timing chain vs gm HD chain
  40. iron block 370
  41. not sure if this is the right section but chime in plz!
  42. Morel lifters manufacturer contact info?
  43. fuel injectors acting up
  44. Porting a FAST 90
  45. Longblock vs Shortblock
  46. LS1 cam install - stainless steel tube to hold lifters up??
  47. head comparison
  48. Oil weight
  49. forged 347 ?s
  50. how to tell a motor is forged?
  51. replacing oil pan, questions inside
  52. Upgrade from 228R Question
  53. Need an opinion on a used cam I have..
  54. CA + Lopey Idle + smog = possible?
  55. 6.0 Iron block's and timing chains, and oil pump Qs??
  56. how much HP can a stock 346 block w/ fully forged internals handle?
  57. Spark Plug Gap?
  58. What about <110 LSA? Don't hear of that much...
  59. 228R w/ PRC Stage I LS6 heads, well matched combo?
  60. bushing instead of adj. T chain? also question for cam experts.
  61. LS6 components into a 98 LS1?????
  62. what heads
  63. Need help FAST Rollmaster degreeing cam
  64. Aluminum or Iron Block???
  65. trex with what heads?
  66. Another oil separator
  67. can running untuned be harmful
  68. 5.3 tahoe intake or roots type charger
  69. Cam Ideas
  70. Difference between 2.000" and 2.100" rod journals/crank pin?
  71. Budget LS1
  72. Best oil pump
  73. Rear Crankshaft Plug Help!!!!!!
  74. TR224..dissapointed
  75. Anyone have a proven PCV system
  76. perfect combo???
  77. The engine is out
  78. LS1 rebuild
  79. LS1 to LQ9 swap - common parts?
  80. about to make a 2400 mile trip but my 5.3 is acting really weird
  81. ARP bolt dealer/distributor in CT?
  82. 6.0 Lq9/lq4
  83. valve cover bolts
  84. How harmful is mild detonation at part throttle?
  85. How to pull th valve covers??
  86. Patriot cam is in - Thanks!!!
  87. valve spring tool, were can i get this
  88. 224R beats ur valvetrain? TR224 better choice?
  89. What could be causing......
  90. I need help with a problem... Anyone
  91. 402 install my tach doesnt work help !!!
  92. LSK Lobe ?'s
  93. 214-230 600/575 117 LSA Blower cam???
  94. AFR 8019 springs on a stock ls6 head?
  95. When should you switch to non-projected..
  96. ABS after cam install
  97. cam size?
  98. SLP Timing Chain to loose???
  99. Motor problem...Please Help!!!
  100. Whats a good C.R.?
  101. ms4 worth it?
  102. Cam specs AFR 224/228 Grind
  103. ETP 225 installed height
  104. which intake do i need
  105. replace the intake on 04TAHOE 5.3
  106. LS1 Engine Removal Guide (drop style)
  107. ARP headbolt torque #'s
  108. AFR or ETP for A-4
  109. HELP .. Engine problems started last night.
  110. cam ?
  111. help guy out here!!!
  112. Need help figuring out problem
  113. Whats a Smogable H/C setup?
  114. need help with pistons .....
  115. valve covers for my 02 z28,,
  116. Streatable 500HP without huge lope
  117. if i rebuild a LS1 or other motor...
  118. Patriot 226
  119. ls2 chain ,ls1 motor
  120. Greg Good is the man!
  121. bad night
  122. How hard is it to bend a pushrod?
  123. 10% or 25% UD Pulley for street C5?
  124. clearance with Ms3 and ls6 heads
  125. flowed home ported 243 vs. stock 243
  126. thinking about building a motor but cant deicde which kind...
  127. stock connecting rod lenght?
  128. 142k mile F14 cam swap???
  129. ETP 225's
  130. Higher ratio rockers?
  131. Cam question
  132. AFR, Dart, Edelbrock, TFS... Cylinder Head Testing
  133. can sbc rods be used in a ls?
  134. GM mls gaskets
  135. Deck Height Irregularities & Quench
  136. Forced Induction 500RWHP VS N/A 500RWHP part2
  137. WHat cam should I go with?
  138. Which cam sensor?
  139. Cam recommendations for my A4
  140. Question about milling stock heads
  141. 6.0L head questions
  142. push rod length question
  143. Lifter help needed
  144. Advantage of an iron 408 over LS1?
  145. High Compression heads?
  146. AFR 205 with 58cc
  147. How streetable is this?
  148. 228R cam help
  149. 110 and under LSA/ICL/ECL
  150. Cam Swap hell...
  151. 02 z28 need some info on valve springs -
  152. rocker removal
  153. stock rockers
  154. save my car!
  155. CF valve cover ????
  156. What's the diffrence between LS6, 5.3L and 6.0L heads?
  157. 400 ain't enough
  158. Need help Figuring out my compression ratios.
  159. ET 225cc heads + adjustable Comp Rockers = new pushrods
  160. Low Budget 5.3 build
  161. GM High Tech article: MS4 and PRC heads= 129HP
  162. Results with ETP heads.
  163. oil pressure...
  164. casting 317
  165. Emissions and Cam?
  166. Assembly Lube
  167. how far can i go with a 226/226 .591/.591 112?
  168. Break in..
  169. Well I screwed the pooch! Badly!
  170. AFR Cylinder head owners...
  171. cam degreeing
  172. Anyone for a billet LSx block? (eye candy within)
  173. How much lower will engine peak with +2 advance?
  174. Found Out Ticking Noise!
  175. Is CompCam 3724R available in .581 lift?
  176. Patriot 243 results
  177. ms3 or g5x4
  178. Why would my intake not be sealing properly to the heads?
  179. Patriot Announces Our NEW Gold Xtreme Spring !!
  180. stock rocker ????
  181. Pics of C5s w/aftermarket valve covers & MSD coils?
  182. Clutch install gone wrong, no oil pressure.
  183. Cam install, need some help...
  184. Confused about head gaskets
  185. ported 853 castings
  186. Will these heads work?
  187. 350rwhp w/exhaust, intake, tb? & doing aftermarket valve springs on a stock-cam'd car
  188. Recycled heads
  189. 7.400 or 7.350 Push rods??
  190. LS1 not as efficiant as the LS2????
  191. How often do you get a tune?
  192. ms3 and patriot heads questions
  193. cam qustion???how much more hp
  194. ticking on driver side need info
  195. Okay, dont bite my balls off, but, seriously, biggest cam for stock stall ?
  196. Shallower OE-style LS1 oil pan
  197. who is the cheapest top buy Patriot springs from?
  198. Bought ls1 427. Need to final bore and hone darton sleves
  199. ARP head studs-confused please help
  200. 5.3L heads
  201. Piecing rotating assembly, have a question.
  202. slight tick in the valve train
  203. 6.0 Crank+ 4.030 pistons + 6.125 rods = what cid
  204. needle bearings?
  205. School me on the 5.3
  206. Precision Race Components ALL NEW Valve Spring!!
  207. double roller timing chain/oil pump won't clear the timing cover
  208. Patriot StageII vs AFR 205
  209. 243 heads and t-rex
  210. best set of budget heads for TR224/224 , 114lsa
  211. AFR's or PRC's???
  212. Oil pump recommendations?
  213. TREX and nitrous
  214. best spring PRC or Patriot gold?
  215. TSP ls6 heads
  216. H/C install underway.
  217. something i dont understand about cams...
  218. dish pistons VS strenth~?~?!! need help fast please
  219. Building a 402 with -14cc pistons....SCR and DCR????
  220. Broken MS3 Cam?!?!?!?!
  221. Found 2 broken plugs,
  222. torquer V2
  223. Torqing Rockers????
  224. Cam install, major problems & need help
  225. Heads+Cam E85 Setup, need help
  226. Spring HELP!!
  227. Is the MS4 to big for me?
  228. Can I convert LS1 to LS2?
  229. Cam and Crank Sensor ?
  230. code p0332 knock senser
  231. What would my cam be good for?
  232. What's a guy gotta do to get a sponsor to take his business?
  233. Does anyone know what kind of cars and trucks....
  234. COMP 918 Spring lift question
  235. Balance Rotating Assembly
  236. Callies crank vs. Eagle crank
  237. Head Gasket question, lowering quench...
  238. New In Box AFR 205's w/ 59cc Chambers
  239. Help me select a better cam for my AFR heads please. For a TBSS.
  240. how to fly cut pistons?
  241. Patriot valve springs queston
  242. ls1 ls2 ?
  243. Help with flycutting!
  244. thinking about going soild roller, worth it?
  245. Stalling prob.. Please help!!!!
  246. Anybody esle with a larger cam on a stock tune have the SES light on?
  247. Missing/backfiring at wot
  248. Where are ARP bolts/studs needed throughout an engine?
  249. valve cover ???
  250. They always say you should have a plan... I need help with mine
