View Full Version : Generation III Internal Engine
  1. My LS1 is being bitchy...
  2. cam selection, again
  3. my 1st h/c/i install
  4. What To Do Heads Or Cam
  5. push rods to long?
  6. I blew up my motor!!
  7. ls1 shortblock
  8. Oil Consumption !!!
  9. Knocking please read!
  10. Exhaust leak?
  11. Daily Driven 6 Speed WS6.
  12. Crazy Stealth Cam Idea
  13. Build bottom end?
  14. Mahle pistons in a 408
  15. Good all-around cam for high peak numbers and 350 tq at 3k??
  16. Cam Question..
  17. Breaking up under full Throttle
  18. 383's,408's what kind of MPG?
  19. Just changed my rod bolts, questions
  20. Oil Plug Size
  21. Ls7 In A Ls1 Car ?
  22. what cam is better for nirous?
  23. Short Blocks?
  24. I have an idea...
  25. Patrick G and predatorZ and all cam gurus please advise
  26. 98 Block mods?
  27. Need Roller Rocker Opinion Difference
  28. trex cam?
  29. If you have a blown HG, should you resurface the head?
  30. MAP Sensor Failure and Engine Misfire
  31. TSP Vs. TSP
  32. Help identify these heads
  33. Help Me Choose Pistons -cc's
  34. new motor
  35. What Heads Would Be Good Please Help
  36. anyone running the ls6 heads
  37. comp 222/224 + cncd ls6 heads = ?
  38. Will MTI Stage 3 Heads work with this cam????
  39. how much power do you think i could make
  40. Help me decide on a cam...
  41. Choose the Optimal DCR - Quench...!
  42. Stock Bottom End LS1
  43. Heads/Cam/Intake Mani MPG
  44. 6.0L MLS head gasket
  45. Burning Oil?
  46. Low oil pressure
  47. Will this Cam Clear with 59cc LS6 Heads
  48. what pushrod length shoud i use
  49. Should I be concerned with this???
  50. oil pump
  51. high LSA cam ?
  52. ride control message on 1997 vette
  53. question about headlight motor on C5
  54. Can I install oil pump without removing pan?
  55. Quick question about valves....
  56. Oil use after H/C install
  57. NItrous cam??
  58. Bigger cam for auto-x
  59. stock oil pump on a 02 F-body?
  60. Any 440+ A4 cars?
  61. Cam dowel???
  62. 3/8" Pushrod Question with ETP 215 Heads
  63. tapping valve
  64. Any negatives from removing the pcv system?
  65. heads/cam on a 98 ls1..
  66. Rods that handle 1000hp?
  67. ported my heads, getting valve job, should I use aftermarket valves?
  68. Are Mahl pistons stock?
  69. Question about Heads removal
  70. help me decide what heads to get.....
  71. 4.030 heads on a stock cube engine?
  72. Stock crank
  73. Head Gasket
  74. Build-up stroked 383..
  75. PtoV clearance (did search)
  76. Long Tubes
  77. Iron 402 and Stock Heads?
  78. where to buy/rent piston notching tool?
  79. Compression - milling, flycutting
  80. LS1 block/LS6 Top End
  81. Installing roller rockers on LS1
  82. Loose valve cover
  83. Loose valvecover
  84. Cam Degreeing Questions
  85. Harland Sharp Rocker Kit?
  86. f13 piston to valve - confused here
  87. help piston slap
  88. Pushrod Q - Will I be alright?
  89. Changing springs (quick) questions...
  90. 402 shortblock
  91. Three F-ups... three questions
  92. heads rebuild
  93. thicker head gasket instead of flycutting??
  94. AFR 205's With T2 cam???
  95. How does this sound for a setup?
  96. Do I have to flycut??
  97. Cam swap with heads on?? Special tool for holding lifters??
  98. MS3 or MS4
  99. PRC Springs question.
  100. Tapping a Forged Crank
  101. new heads and cam question
  102. Tick above 3k rpm
  103. TSP Torquer 2 or 3
  104. Help with heads for max effort 427
  105. Oil Analysis on Amsoil XL 5w-30.
  106. What company to ship parts?!?
  107. Head/cam combo???
  108. File fitting rings, which ones??
  109. Help pick lsa for torquer v2
  110. Valve job?
  111. When is a cam not safe for DD?
  112. To Sell? Or Not To Sell?
  113. looking for a good cam only set up for a4 z28
  114. pushrod length?
  115. what head should i get for my ms4?
  116. hows the g5x4
  117. What HP did you pick up with Trickflow 215 heads
  118. stock motor tapping
  119. what will LG G5x4 cam spin to?
  120. cam dagree
  121. Compatible parts?
  122. Cam swap info needed
  123. Pushrod size for TSP 228R
  124. G5X3 on a 110 LSA
  125. Milling 243's
  126. Slight knock... 18k miles?
  127. 370c.i. questions... Please come in..
  128. Sewing Machine????
  129. oil pump question
  130. TREX and who is DD them
  131. Anyone hydraulic roller running 7400+
  132. Cam Installation Parts?
  133. Thought I had Piston Slap
  134. Just put in a Z06 cam (long, walk through)
  135. Loud noise from inside of eng.
  136. strange smell at WOT
  137. 5.3 706 casting heads on ls1??
  138. 5.6 706 casting heads on a ls1?
  139. good street cam?
  140. How much power is lost with mileage?
  141. new engine help
  142. ati pulley help
  143. Any info on the T-RAK cam ( 415hp ? )
  144. CALLING TSP/PRC spring users
  145. ms3 vs f13
  146. base circle question when using COMPCAMS pushrod length checker
  147. How do these plugs look...
  148. Cam swap parts package?
  149. DCR calc. please!
  150. Need help using Pushrod Length Checker....
  151. Bearing damage: What do you think?
  152. Help please!!!
  153. 4.8 with 5.7 heads, intake, etc?
  154. C5 cam???
  155. aluminum block rust?
  156. another cam thread
  157. Where to buy head locater dowels other than dealer???
  158. What size injectors?
  159. Engine hydrolocked..what do I need
  160. DCR calculation
  161. New best with Trick Flow heads!
  162. Stroker question
  163. Cam for a 383ls1 any ideas
  164. New Cam for Trick Flow Heads, want your final opinion
  165. which cam - TR 224 or MTI Stealth 2 ???
  166. where to buy valve spring shimms?
  167. Is this valve float?
  168. Help me decide on a setup please
  169. I Just switched from M1 to Amsoil (POLL)
  170. Help Opinions needed Nitrous Mishap
  171. when should my torque kick in?
  172. anyone have a car with this cam???
  173. patriot stage 2 heads and patriot cam
  174. Whats an incomplete LS1 worth?
  175. Cleaning block
  176. pushrod question
  177. Help calculate my compression
  178. LS1 block vs. LS6 block
  179. too big of a cam???
  180. gpossible problem with cam change- am i building compression
  181. Simple LS1 question
  182. effect of more lift ?
  183. ? for people running TSP Torquer V2
  184. Expected power
  185. new to ls1 world... need guidence
  186. heads for g5x2
  187. Opinions on setup?? all welcome
  188. Forged pistons only
  189. your opinion please
  190. 13b vs ls1
  191. ms4
  192. 13b vs ls1
  193. strength of a LS6 crank
  194. well im done for the year....408 piston came apart
  195. Lift in Cams....
  196. Those who bought an aftermarket cam, then bought a different cam, Why Did You??
  197. Patriot Stage 2 Heads And Cam Swap Making Lifter Noise Help!!1
  198. H/C on a 105k motor, bad idea?
  199. heads and cam only 380rwhp?
  200. Why TTY, oil consumption and piston slap notes (in case you didnt know)
  201. Different rings in an 01?
  202. Do i need to flycut?? ((Terminator Cylinder Heads 62cc & MS3)) !
  203. i need answers to these questions urgent
  204. cam mods
  205. Lifter tray ???
  206. Oem rocker arms SUX
  207. Just Change the motor need some help
  208. How to tell if I have an ASA cam?
  209. TSP heads/cam packages
  210. 160 Tstat
  211. Budget power gains (what would you do?)
  212. How To Set Air/fuel Ratio???
  213. what determines low-end torque for heads?
  214. What determines how high I can SAFELY rev my engine?
  215. Lifter installation
  216. Oil info needed
  217. NGK part number?
  218. Ms3 And Prc LS6's Results revised!
  219. Ms3 And Prc LS6's Results revised!
  220. Ring Flutter
  221. Combustion chamber
  222. Pushrods Selection
  223. Contributing factors to LS1 oil usage
  224. Low numbers after heads/cam install
  225. TSP Terminator 200cc track results(11.2 @ 122)
  226. Anyone w/ Patriot stg II/f13 set up?
  227. what do you think?
  228. What would you do?
  229. p to v clearance on t rex cam, ls6 heads
  230. When to change lifters?
  231. Guys here is a custom cam for my setup
  232. Lifter Trays
  233. oil pump gone bad.. what to do?
  234. harmonic balancer on 4" eagle
  235. Need some piston help
  236. Cam For Over 400 Horsepower
  237. Help me, what could possibly be causing this noise?
  238. What To Do Please Help
  239. Anybody running Thunder Racing GTP stage 2 heads??
  240. ratating assymblies
  241. Penzoil Platinum oil
  242. What head gaskets should I run??
  243. HELP!! huge dead spot... :(
  244. What sponsors sell the Dart 205's? Don't know if this is the right section or not??
  245. LS6 valves
  246. Strange, inconsistant starting issue
  247. MS3 or MS4 or something else?
  248. Aftermarket Blocks for the LSx based platform
  249. g5x3 on 112lsa, heads, power, idle and flycut
  250. fly-cut?
