View Full Version : Generation III Internal Engine
  1. 3.48 Stroke LS Question
  2. Insane Oil Consumption, 427 LS1...
  3. New LSK lobes hard on valvetrain ?
  4. Victor Jr. cam spec?
  5. cam help
  6. What pushrods are these?
  7. slp, ls2 zl402, 402 short block, how many hp's
  8. labor cost on forged bottom end??
  9. whats normal for a compression test
  10. Check out these nasty plugs. New problem now.
  11. Motor is very hard to roll over by hand
  12. used valve spring
  13. trans am hand brake problem
  14. Are Dart 205s worth the price?
  15. cam/ head combo
  16. Modified floors for true duals (f-body)
  17. Which way to go on 2001 LS1 rebuild?
  18. LS7 intake question
  19. question on a cam
  20. heavy duty timing chain?
  21. FAST intake question
  22. Problems with Dart heads?
  23. As RPMs Rise...Oil Pressure Falls
  24. As RPMs Rise...Oil Pressure Falls
  25. early 98 pistons
  26. Best Heads For LS2 402 Stroker
  27. Any help on selecting a cam
  28. Ticking Noise From header!/ Pinging from motor
  29. 228/232 .588/.592 110LSA (+1) VS. a TR224/224 .563/.563 112
  30. cam
  31. Anyone Using This Cam?
  32. anyone had this problem?
  33. stock crankshaft 6.0l
  34. Wanting to install a cam
  35. AFR 205's or 225's?
  36. anyone know wtf this is in my pickup?
  37. LS1/F-Body Mechanics Book???
  38. spring question
  39. head comparo?
  40. Crate Engines?
  41. How many Coolant Sensors on a 98 LS engine?
  42. F14 and TSP 200cc term. heads ???
  43. Intake runner smoothnes?
  44. stock chain, whos running one
  45. Cam/Heads question for 02 WS6
  46. need cam advise
  47. Smoke Inside Intake Manifold After Running?
  48. 3 Choices?
  49. Someone Please Friggin Help
  50. oil pressure problem/oil pump?
  51. Need advice RE: Oil Pan Bolt...
  52. LS1 Engine spec question.
  53. Another Dumb Novice Question
  54. HELP! Trying to find a shop in N. Alabama (install cam)
  55. MS4, PRC Stage 1 LS6's installed
  56. 383 or 395 stroker???
  57. Forged 346 questions
  58. Throttle help Please!!
  59. ms4 dyno #'s.....
  60. Air Velocity into TB and Intake
  61. alright engine got analysed n i need some help
  62. What would a complete 427 crate with these part be worth?
  63. Help me to find a nice combo,
  64. This possible?
  65. T-rex and 4400 stall Question
  66. crank bolt
  67. Spark Plugs
  68. Base Cirlce
  69. 98 LS1 lifters swap or not
  70. cam 101
  71. cam experts (or not) come in.
  72. Question about installing Rockers
  73. Terminator heads + TSP V3 cam - Is flycutting needed?
  74. ls6 heads with ms3 cam...
  75. Which block
  76. SI7 speed inc. cam????
  77. ls1 ,ls2 , ls6
  78. Are Heads worth the Money?
  79. Lunati Stroker Kits.
  80. someone please help
  81. Flywheel
  82. Oil question
  83. Which Cam for my car
  84. What are some of the aftermarket parts it would be cool to see installed and tested?
  85. pt# for flywheel holding tool?
  86. Another "Help me choose thread"
  87. rod bolt installation
  88. Help, No spark!
  89. AFR 205 Intake/Exhaust Valve Deck Clearance?
  90. Have some ?s about a cam in my car
  91. Optimal engine coolant temp for a Daily Driver?
  92. What kind of hp gain from switching from ls1 heads to ls6 heads?
  93. how high to spin???
  94. Need help deciding on New Engine....
  95. 4.8 vs. 6.0
  96. Put me to the next step, cam decision
  97. what cam, stock converter, 2.73's
  98. Need info on oil pressure
  99. Injector size??
  100. Head/Cam decision made.
  101. LS1,LQ4,LQ9 Combustion Chamber Q's?
  102. broken rocker arm
  103. Engine running rough after a couple runs?
  104. Need advice on choosing LSA for DD A4???
  105. cam question xxx
  106. misfire
  107. Looking for unbiased opinion on cam choice
  108. Where to position rocker on valve before measuring for pushrod length
  109. crankshaft bearing gone, best upgrade package to buy
  110. Milled Heads????
  111. ls1 swap
  112. GM and FORD talk merger!
  113. Filling the cooling system issue...is this normal????
  114. Retorque head bolts?
  115. just some basic questions hopin for some answers
  116. did 00: come with fully encapsulated lifters?
  117. Can someone identify this exhaust?
  118. MTI Cam with 1.8 Rockers
  119. Speedtek s1 cam
  120. vavle springs
  121. Start up problem 408
  122. Yet Another Cam Question
  123. I need a Stealth Cam!
  124. Shorty Headers
  125. Vote on a cam
  126. What kinda heads...
  127. Exhaust System
  128. How much should I expect?
  129. Magic Stick 3, What Lobe Seperation 12, 13 or 14 ?
  130. Offset cam bushings to change ICL?
  131. So I just found THIS in my motor...
  132. Shortened Rocker Bolts Question
  133. Rocker arms for T-Rex cam
  134. Where to get 3/8" pushrods
  135. cleaning new parts?
  136. budget 408?
  137. Does anybody know of any good LS1 Shops in New Orleans Area
  138. Low oil pressure.
  139. LS1 vs. sustained high rpm use
  140. guys wat are the stock size vavles for the 6.0 317 heads?
  141. Break In Questions
  142. Loud ticking noise?
  143. Valve spring life/interval with this setup?
  144. Low oil pressure...
  145. Upgrading, but need some help.
  146. POLL: Which short block for ETP 215 Heads & N20?
  147. How to Oil prime a new LSx engine
  148. ls1 help
  149. stock bottom end
  150. LS1/LS6 Head Gaskets
  151. heads/cam setup!?!
  152. A little help??
  153. Pushrod length question
  154. F14 Vs TR 230/236
  155. Oil accumulator questions
  156. Heads
  157. how do i determine valve relief size?
  158. need a good *basic* 98 scanner and code clearer
  159. reverse split cam
  160. What is my engine? (i've searched)
  161. How much am i going to gain any by switching to a TR224??
  162. More 346" ET 240cc 11 degree progress - 10.7 @ 131 N/A 2500'
  163. patriot heads, are they worth it
  164. Putting LS6 cam in my LS1...
  165. stock head bolts
  166. for you guys with big-ish cams
  167. aft duel springs with stock ls1 retainers
  168. Quick Cam Question
  169. Flycutting and PTV clearance questions
  170. what stall with MS3
  171. Can crane dual springs be used with stock cam??
  172. I need some help
  173. Doing heads/ cam- what bolts & gaskets to buy?
  174. LPE GT2-4,- what springs?
  175. Can piston slap cause ticking?? Help!!!!
  176. Interpret/compare these Valve Events...
  177. is it a must to drop the oil pan...
  178. Reverse Duration Relevance
  179. ?? Best Cam with Nos??
  180. Heads or Nitrious first?
  181. Pushrod Length.. How to check correctly?
  182. Anyone running a 238/244 .605/.612 Speed Inc. Cam?
  183. cnc ls6 heads?
  184. TR224 vs Cheatr
  185. Destroking a 347
  186. Input on forged internals
  187. back firing when reving down????
  188. Whats the F#*K is draining my battery?!?!?!
  189. Suggetsions on lifters
  190. Problem Help please weird noise
  191. Should I buy new STOCK heads?
  192. Help me pick an engine block
  193. 0.1 DCR change = ?% power change?
  194. What is flycutting?
  195. oil leak after head and cam
  196. T-rex/MS4 user with spray.....already searched
  197. Running Newer Crank Reluctor Ring in Older Motor?
  198. Cam with stock tuning
  199. Resleeving
  200. Whose heads would do EXACTLY 400rwhp with a TR224 & 3000 stall Vigilante?
  201. Oil Pressure!!!!!!
  202. aluminum rods
  203. My compression check....okay? Engine builders (and all else) welcome
  204. what could have happened when I bent my rods
  205. Looking for Specifics for rotating assembly upgrade
  206. Interest in tracking oil analysis reports?
  207. Anyone do a stroker in their garage?
  208. 99 dash harness different than 98?
  209. What pistons to get for heads/TRex car?
  210. Comp. ratio and head questions
  211. Contemplating g5x3 108 lsa
  212. request: Cammed Rumbler Clips
  213. Blown head gasket
  214. loud ticking noise
  215. Threw a code
  216. head/cam pairing
  217. valve spring help:
  218. whats the difference in a solid roller cam?
  219. Can you run .100 longer valves + stock rockers + Comp 977's?
  220. Need Reluctor Wheel Help ASAP!!!
  221. Cam Help Please
  222. Only 338 RWHP?
  223. Car Wont run anymore. Is it my fuel pump ?
  224. rebuilding motor soon need parts advice
  225. Lpe Gt-7
  226. question on comps lobe design's
  227. Reusing Stock Valve Spring Retainers?
  228. Prc heads and a 228R install finished
  229. maching crank pulley for double roller
  230. Anyone install a LS2 intake on a LS1??
  231. What rockers work with ET 11* heads
  232. Head bolts, does this make any sence???
  233. SDPC custom cam's
  234. 116 Lsa
  235. Cam help!
  236. LS1 rocker arm assembly
  237. Who has TSP Terminator heads?
  238. Please post pics of you dyno charts after cam install
  239. need engine work done in atl area.
  240. Installing ARP head studs, need a few tips
  241. GM high volume oil pump or Melling ?
  242. Removing EGR Cause Poorly Running Engine?
  243. MTI Stealth II Cam: Good Mid-Range Torque?
  244. Do I or Don't I -- LS6 Manifold Related
  245. Flycutting - how hard - how much?
  246. Pulling an LS1 out of an Fbody...
  247. ls1 alternator Serpentine Kits
  248. Have you ever flycut?
  249. Overheating
  250. heads for ms4
