View Full Version : Generation III Internal Engine
  1. stg. 1 ls6 heads.
  2. teach me how to use the ve calc
  3. What else do I need for this setup?
  4. Power / performance estimate?
  5. Who's got the best reputation for short blocks?
  6. head gasket
  7. Valve size, milling-pvc
  8. What length pushrods are you running??
  9. Anyone running 20w50?
  10. horsepower tv ls1gun
  11. Tech Gurus: Please check my problem diagnosis!
  12. Need reassurance on P2V with setup
  13. Dex coolant question?
  14. how to go about replacing piston & rod
  15. Oil in intake
  16. help me find out what this noise is...
  17. Which springs to go with..........Need help.
  18. Monster NA build
  19. Where do i go for a good tune after cam install
  20. Which Lifters
  21. I don't know what it is....
  22. OLD XE vs XE-R question....
  23. dart 205 ptv?
  24. forged stock cubes
  25. LS6 or Fast Intake config
  26. 6.0 L (317) heads on LS1, what head gasket to use?
  27. Katech rod bolts
  28. ARP rod bolts rrrg
  29. Does any head produce better economy?
  30. AFR large bore 225's on a stock bore ls6?
  31. ls-1 or 2
  32. What are signs of a failing camshaft position sensor?
  33. What Lifts/duration Does Ptv Become Issue?
  34. What heads are on my 98 TA
  35. What springs to go with XFI (.600" lift) Lobes?
  36. bosch plugs
  37. head chamber ?
  38. Buying a T/A "ENGINE DAMAGE" 7K
  39. LS2 cam in an LS1
  40. What is wrong? Ticking and sqeaking, Im pi$$ed.
  41. "806" heads
  42. I have a question. about doing a heads and cam package.
  43. where is the best place to get ported heads
  44. 3.90 bore ET heads--What short block?
  45. Got my Car back H/C 347
  46. 205 vs 225 on a 384
  47. Which heads?
  48. collapsed lifter, or loose spark plug
  49. Edelbrock heads?
  50. oil pump spacer, RTV?
  51. Head bolt healacoil
  52. What's the prognosis? DR.
  53. Time for new lifters??
  54. Front/Rear cover alignment tools - are you using them?
  55. Any downside to 02+ LS6 cam?
  56. Lunati cam thoughts Vodoo 232/238 .599/.601 Anyone with experience with it?
  57. Wierd smell after changing to Mobile 1
  58. Just need advise on camshaft
  59. Need a help for cam
  60. Patriots stg 3 LQ9 head gasket question
  61. no oil in the valve cover during cranking
  62. LS1 SS - Horsepower TV Build
  63. how much?
  64. What's All Involved To Change Oil Pan Gasket?
  65. cam,flycut and tune in san diego area
  66. What heads for low-end?
  67. Seem to be having problems
  68. Wasn't somebody selling Heads?
  69. What pistons/rods for FI?
  70. stock fuel system
  71. no idle after h/c install
  72. Rod knock
  73. Shaft mounted Rocker Arms
  74. What should I do with my HEADS?
  75. exhaust ports
  76. properly tightening rockers
  77. Need Help Please!!
  78. Cracked PRC LS6 Head PICS
  79. Oil on Plugs and out Exhaust? WTF?
  80. Slight cam install problem
  81. Help, I need ARP head bolts part number
  82. 408 build help best place to build it ?????
  83. How rough did you car run after head install?
  84. need help tuning for my Cammed car
  85. 853 heads with the notch on #3/#6 pistons?
  86. car is smoking
  87. What about this ??
  88. Worn valve tips
  89. How much power from ported heads?
  90. Which block is stronger, an LS1 block, or an LS6 block?
  91. 1.85 roller rockers worth it???
  92. overheating ned help
  93. Current Head Swap - Need Help (sensor)
  94. World Casting Warhawk block
  95. Car will not idle after heads/intake install. HELP!
  96. Bore, Stroke and rod lenghts...
  97. Advice Please:Sponsers, Members Need some advice on upgrading my cam in my 02 Camaro
  98. thunder racing cam opinion
  99. HELP !! need some opinions
  100. what engine do i have?
  101. What size valves?
  102. Head gasket leaking again, any ideas?
  103. 2002 A4 z-28
  104. ARP Main Cap torgue ??????
  105. Upgrade my cam?
  106. Rod bearings Discolored..
  107. Doing Cam Swap - What Parts?
  108. Help! Engine noise...
  109. What is causing this knock? video inside
  110. 427 cam suggestions
  111. Help please.....
  112. Newbee, what to payfor one?
  113. how much $$ is a stock shortblock!!
  114. Potential 6.0 LQ4 swap problems.
  115. I'm losing oil pressure
  116. Dyno chart for 1999 Camaro
  117. beehive works with T-rex?
  118. TSP Torquer 2 VS FMS F11
  119. Benefits of running race gas?
  120. MTI-G1 cam question
  121. another head port thread *pics*
  122. set the valves and lost a cylinder
  123. 237/242 595/595 112lsa lunati cam
  124. Felpro 1041 head gaskets
  125. 5.7 to 6.0L ?
  126. TSP magic stick 4 with an A4
  127. Compression Ratios??????????
  128. Ticking when warm
  129. Intake runners on stock 243 heads??
  130. Help, Please Help
  131. i know another which cam thread
  132. streetable or no
  133. 500rwhp off bottle?
  134. Cam Swap in progress.....
  135. Need help / opinions - Winter project
  136. Please Help!!! Block Specs Needed!!
  137. Please Help!!! Block Specs Needed!!
  138. What cam to go with my AFR 205's
  139. Timing chain question
  140. F11 cam users, what is your cylinder PSI?
  141. This is a yes or no question.
  142. Cam people jump in
  143. Cam question....
  144. Magazine Cam Install
  145. new block
  146. I think I blew an oil line and damaged the engine
  147. CNC LS6 heads leak in runner
  148. what should i do????
  149. question about LG motorsport cams
  150. specs on the torquer v3??
  151. Why is my piston like this? pic
  152. I have PVC question
  153. 6.0 Head gaskets..
  154. Oil Pressure
  155. 2001 Vette motor
  156. What could cause this leak?
  157. need help fast!
  158. weird noise ..need help trying to figureout what it is...
  159. Heads swap?
  160. Installing Roller Master double roller..
  161. Should i buy
  162. Cam help PLEASE
  163. need help and quick
  164. TSP Terminator Build/Mill question
  165. Need sound clip of cam...
  166. Looking For Cam Suggestions
  167. Crower Shaft Mounted Rockers for ET Heads
  168. New cam time again!
  169. TRak sound clips
  170. Rollmaster Timing Chain Slack after 10k Miles...
  171. How bad did your car run after cam on stock tuning??
  172. Tdc????
  173. push rod question?
  174. TR- 224/224-114 or TR- 224/227-114??
  175. where to set the rev limiter??
  176. Anyone have MS4 #'s yet!? Speculation?
  177. 3.8 Head removal?
  178. $4200 cash, what can I do?
  179. opinions on F13?
  180. 415ci Cam options....
  181. A4's with cams come in!
  182. 1.85 roller rockers
  183. What cam with TSP Terminator heads?
  184. woudl that cam be good with n2o?
  185. head gasket question
  186. Complete Ls1 For Sale
  187. budget heads that will fit
  188. Need Help and Advice - Long
  189. How to wash engine
  190. Voodoo Cams
  191. Which Head Gasket?
  192. Anybody heard of the updated stock rocker arms?
  193. My Setup, Advice Welcomed
  194. valve seals shot looking for new heads
  195. Torquer 2 vs. F14
  196. Whats the biggest cam for a 346?
  197. cam ?
  198. Will TSP 200cc Terminator Heads work with a 408?
  199. New Injectors???
  200. Quick Thermostat question
  201. How Much More HP With a Tune?
  202. need opinions on 2 different brand rockers
  203. Building my LS1?
  204. Homebuilt Mini Smallblock
  205. Just Called Comp Cams....
  206. Oil pressure drop
  207. Cam Help!!
  208. Using a truck LM7 intake on 408
  209. Are cometic head gaskets reusable?
  210. 28000 Miles.. headgasket failure?
  211. Compression ratio?
  212. LS1 Vs. LS6
  213. PRC heads or Patriot heads?
  214. 130k miles and turbo and heads.... Cam swap?
  215. QUICK Q,work in progress
  216. ptv clearance f14 and lq4 heads
  217. CR quurstion
  218. Stupid question...Need help
  219. looking for a head porting shop.
  220. best cam in cali other than 224/224 (please help)
  221. Is it normal for my oil pressure to fluxuate?
  222. mains torquing sequence...
  223. Stock motor + V2 Torquer Cam + Catback = ????
  224. Tips on installing wire wrist pin clips
  225. g5x3 114 guys come on in!!!
  226. For those in th N. Idaho region looking for Syntec 0w30....
  227. My 408 needs a better head and cam combo. Please help!
  228. Rebuild or buy another
  229. everybody with TSP torquer v2!! come in!!
  230. Rockers?
  231. What you think of this cam?
  232. "Hot Cam" Owners
  233. detation????
  234. 224/230 cam too small? only 360rwhp
  235. New cam (TRAK)...Impressions
  236. Need Help Choosing a Cam!!
  237. 225 heads with stock bottom end?
  238. 408/402 swap question
  239. what size pushrods for 6.0l lq9 heads on a ls1 block?
  240. RHS pushrod length
  241. Timing Chain & Oil Pump question
  242. anyone running the tr 230/236 cam?
  243. MTI Stealth Cam??? any advice with this??
  244. dart 205 & f-13= 444.4
  245. how to make an 11 second car with all bolts ons n cam??
  246. Rod bolts worth it?
  247. please help me decide
  248. Opinions on Probe Forged Pistons
  249. 5.3 to a ls1/6?
  250. Oil Pressure
