View Full Version : Generation III Internal Engine
  1. please help
  2. overheating..radiator hoses cold
  3. How long did it take you?
  4. stg. 1 ls6 heads.
  5. teach me how to use the ve calc
  6. What else do I need for this setup?
  7. Power / performance estimate?
  8. Who's got the best reputation for short blocks?
  9. head gasket
  10. Valve size, milling-pvc
  11. What length pushrods are you running??
  12. Anyone running 20w50?
  13. horsepower tv ls1gun
  14. Tech Gurus: Please check my problem diagnosis!
  15. Need reassurance on P2V with setup
  16. Dex coolant question?
  17. how to go about replacing piston & rod
  18. Oil in intake
  19. help me find out what this noise is...
  20. Which springs to go with..........Need help.
  21. Monster NA build
  22. Where do i go for a good tune after cam install
  23. Which Lifters
  24. I don't know what it is....
  25. OLD XE vs XE-R question....
  26. dart 205 ptv?
  27. forged stock cubes
  28. LS6 or Fast Intake config
  29. 6.0 L (317) heads on LS1, what head gasket to use?
  30. Katech rod bolts
  31. ARP rod bolts rrrg
  32. Does any head produce better economy?
  33. AFR large bore 225's on a stock bore ls6?
  34. ls-1 or 2
  35. What are signs of a failing camshaft position sensor?
  36. What Lifts/duration Does Ptv Become Issue?
  37. What heads are on my 98 TA
  38. What springs to go with XFI (.600" lift) Lobes?
  39. bosch plugs
  40. head chamber ?
  41. Buying a T/A "ENGINE DAMAGE" 7K
  42. LS2 cam in an LS1
  43. What is wrong? Ticking and sqeaking, Im pi$$ed.
  44. "806" heads
  45. I have a question. about doing a heads and cam package.
  46. where is the best place to get ported heads
  47. 3.90 bore ET heads--What short block?
  48. Got my Car back H/C 347
  49. 205 vs 225 on a 384
  50. Which heads?
  51. collapsed lifter, or loose spark plug
  52. Edelbrock heads?
  53. oil pump spacer, RTV?
  54. Head bolt healacoil
  55. What's the prognosis? DR.
  56. Time for new lifters??
  57. Front/Rear cover alignment tools - are you using them?
  58. Any downside to 02+ LS6 cam?
  59. Lunati cam thoughts Vodoo 232/238 .599/.601 Anyone with experience with it?
  60. Wierd smell after changing to Mobile 1
  61. Just need advise on camshaft
  62. Need a help for cam
  63. Patriots stg 3 LQ9 head gasket question
  64. no oil in the valve cover during cranking
  65. LS1 SS - Horsepower TV Build
  66. how much?
  67. What's All Involved To Change Oil Pan Gasket?
  68. cam,flycut and tune in san diego area
  69. What heads for low-end?
  70. Seem to be having problems
  71. Wasn't somebody selling Heads?
  72. What pistons/rods for FI?
  73. stock fuel system
  74. no idle after h/c install
  75. Rod knock
  76. Shaft mounted Rocker Arms
  77. What should I do with my HEADS?
  78. exhaust ports
  79. properly tightening rockers
  80. Need Help Please!!
  81. Cracked PRC LS6 Head PICS
  82. Oil on Plugs and out Exhaust? WTF?
  83. Slight cam install problem
  84. Help, I need ARP head bolts part number
  85. 408 build help best place to build it ?????
  86. How rough did you car run after head install?
  87. need help tuning for my Cammed car
  88. 853 heads with the notch on #3/#6 pistons?
  89. car is smoking
  90. What about this ??
  91. Worn valve tips
  92. How much power from ported heads?
  93. Which block is stronger, an LS1 block, or an LS6 block?
  94. 1.85 roller rockers worth it???
  95. overheating ned help
  96. Current Head Swap - Need Help (sensor)
  97. World Casting Warhawk block
  98. Car will not idle after heads/intake install. HELP!
  99. Bore, Stroke and rod lenghts...
  100. Advice Please:Sponsers, Members Need some advice on upgrading my cam in my 02 Camaro
  101. thunder racing cam opinion
  102. HELP !! need some opinions
  103. what engine do i have?
  104. What size valves?
  105. Head gasket leaking again, any ideas?
  106. 2002 A4 z-28
  107. ARP Main Cap torgue ??????
  108. Upgrade my cam?
  109. Rod bearings Discolored..
  110. Doing Cam Swap - What Parts?
  111. Help! Engine noise...
  112. What is causing this knock? video inside
  113. 427 cam suggestions
  114. Help please.....
  115. Newbee, what to payfor one?
  116. how much $$ is a stock shortblock!!
  117. Potential 6.0 LQ4 swap problems.
  118. I'm losing oil pressure
  119. Dyno chart for 1999 Camaro
  120. beehive works with T-rex?
  121. TSP Torquer 2 VS FMS F11
  122. Benefits of running race gas?
  123. MTI-G1 cam question
  124. another head port thread *pics*
  125. set the valves and lost a cylinder
  126. 237/242 595/595 112lsa lunati cam
  127. Felpro 1041 head gaskets
  128. 5.7 to 6.0L ?
  129. TSP magic stick 4 with an A4
  130. Compression Ratios??????????
  131. Ticking when warm
  132. Intake runners on stock 243 heads??
  133. Help, Please Help
  134. i know another which cam thread
  135. streetable or no
  136. 500rwhp off bottle?
  137. Cam Swap in progress.....
  138. Need help / opinions - Winter project
  139. Please Help!!! Block Specs Needed!!
  140. Please Help!!! Block Specs Needed!!
  141. What cam to go with my AFR 205's
  142. Timing chain question
  143. F11 cam users, what is your cylinder PSI?
  144. This is a yes or no question.
  145. Cam people jump in
  146. Cam question....
  147. Magazine Cam Install
  148. new block
  149. I think I blew an oil line and damaged the engine
  150. CNC LS6 heads leak in runner
  151. what should i do????
  152. question about LG motorsport cams
  153. specs on the torquer v3??
  154. Why is my piston like this? pic
  155. I have PVC question
  156. 6.0 Head gaskets..
  157. Oil Pressure
  158. 2001 Vette motor
  159. What could cause this leak?
  160. need help fast!
  161. weird noise ..need help trying to figureout what it is...
  162. Heads swap?
  163. Installing Roller Master double roller..
  164. Should i buy
  165. Cam help PLEASE
  166. need help and quick
  167. TSP Terminator Build/Mill question
  168. Need sound clip of cam...
  169. Looking For Cam Suggestions
  170. Crower Shaft Mounted Rockers for ET Heads
  171. New cam time again!
  172. TRak sound clips
  173. Rollmaster Timing Chain Slack after 10k Miles...
  174. How bad did your car run after cam on stock tuning??
  175. Tdc????
  176. push rod question?
  177. TR- 224/224-114 or TR- 224/227-114??
  178. where to set the rev limiter??
  179. Anyone have MS4 #'s yet!? Speculation?
  180. 3.8 Head removal?
  181. $4200 cash, what can I do?
  182. opinions on F13?
  183. 415ci Cam options....
  184. A4's with cams come in!
  185. 1.85 roller rockers
  186. What cam with TSP Terminator heads?
  187. woudl that cam be good with n2o?
  188. head gasket question
  189. Complete Ls1 For Sale
  190. budget heads that will fit
  191. Need Help and Advice - Long
  192. How to wash engine
  193. Voodoo Cams
  194. Which Head Gasket?
  195. Anybody heard of the updated stock rocker arms?
  196. My Setup, Advice Welcomed
  197. valve seals shot looking for new heads
  198. Torquer 2 vs. F14
  199. Whats the biggest cam for a 346?
  200. cam ?
  201. Will TSP 200cc Terminator Heads work with a 408?
  202. New Injectors???
  203. Quick Thermostat question
  204. How Much More HP With a Tune?
  205. need opinions on 2 different brand rockers
  206. Building my LS1?
  207. Homebuilt Mini Smallblock
  208. Just Called Comp Cams....
  209. Oil pressure drop
  210. Cam Help!!
  211. Using a truck LM7 intake on 408
  212. Are cometic head gaskets reusable?
  213. 28000 Miles.. headgasket failure?
  214. Compression ratio?
  215. LS1 Vs. LS6
  216. PRC heads or Patriot heads?
  217. 130k miles and turbo and heads.... Cam swap?
  218. QUICK Q,work in progress
  219. ptv clearance f14 and lq4 heads
  220. CR quurstion
  221. Stupid question...Need help
  222. looking for a head porting shop.
  223. best cam in cali other than 224/224 (please help)
  224. Is it normal for my oil pressure to fluxuate?
  225. mains torquing sequence...
  226. Stock motor + V2 Torquer Cam + Catback = ????
  227. Tips on installing wire wrist pin clips
  228. g5x3 114 guys come on in!!!
  229. For those in th N. Idaho region looking for Syntec 0w30....
  230. My 408 needs a better head and cam combo. Please help!
  231. Rebuild or buy another
  232. everybody with TSP torquer v2!! come in!!
  233. Rockers?
  234. What you think of this cam?
  235. "Hot Cam" Owners
  236. detation????
  237. 224/230 cam too small? only 360rwhp
  238. New cam (TRAK)...Impressions
  239. Need Help Choosing a Cam!!
  240. 225 heads with stock bottom end?
  241. 408/402 swap question
  242. what size pushrods for 6.0l lq9 heads on a ls1 block?
  243. RHS pushrod length
  244. Timing Chain & Oil Pump question
  245. anyone running the tr 230/236 cam?
  246. MTI Stealth Cam??? any advice with this??
  247. dart 205 & f-13= 444.4
  248. how to make an 11 second car with all bolts ons n cam??
  249. Rod bolts worth it?
  250. please help me decide
