View Full Version : Generation III Internal Engine
  1. Need New Valve Covers?
  2. Burning quarts of oil?
  3. Quick Head Question
  4. LS1 ? Need Help
  5. AFR heads swapped!!Cam?
  6. Lightweight valves sources for LS1?
  7. Streetable Cam
  8. open exhaust on an LS1
  9. What Cam Should I Go With?
  10. New Heads without flycutting ????
  11. Is This Set Up ok for Daily Driver?????
  12. Cam only
  13. ETP heads... How much timing ???
  14. f14 camparo ?
  15. Thunder Trak CAM tuning question
  16. 408 rot assm?
  17. Precision Race Components 200cc Small Runner Pics & Info!
  18. Blown Motor!!!!!!!!
  19. Replace Rear Crank Seal?
  20. How much more power will I get with Bigger heads
  21. Anyone know where to buy mobile-1 online
  22. Started the head/cam swap yesterday
  23. help no oil pressure...could this be why?
  24. ls1 block vs. ls6 block
  25. 232/230 Dur. @.050 .580"/.580" Lift 110 LSA streetable on a A4?
  26. What Valve Guide Seals Do You Have??
  27. Problem Need HELP Any1
  28. Question about deck height
  29. 402 or 408
  30. What fuel pump yall h/c guys runnin??
  31. Possible Bearing issue?
  32. new motor coming..did i get what i needed for the install?
  33. Build my engine
  34. cam only low 11's
  35. TEA TrickFlow Heads with MS4?? :)
  36. Gen 3 hot cam
  37. Ordered my custom cam today...
  38. 408 clearance questions
  39. diamond pistons, lutani rods
  40. Checking rocker bolts after H/C swap
  41. Tsp cam?
  42. TR6 gap question
  43. ls6 cam/ls6 intake?
  44. 243 heads and LS2 cam?
  45. choice for cam with ported heads????
  46. Coolant temp dummy gauge
  47. 7 of 8 tranny bolts enough?
  48. TSP CNC LS6 heads... WHATS THE DEAL???
  49. will I pass emissions with this cam
  50. Who is using 50 weight oil? Come on in!!
  51. Lingenfelter GT1 Cam
  52. dual or single valve springs
  53. heads and cam reccomendations?
  54. Mildly bolted on LS1 worth tune? or Cam?
  55. Backfiring after installing rockers, PLEASE HELP SOON
  56. Can someone explain the catch can to me??
  57. Milling warped heads?
  58. Where can I get a catch can?
  59. More TEA Trick Flow ccfm and lift numbers
  60. how to delete pcv
  61. Valve Relief Pistons
  62. Oil Pressure???????????????
  63. anybody got the 236/230 .602/.575 112 LSA
  64. ls1 valves go in ls6 heads?
  65. Graphite gaskets suck!
  66. Valve spring installation difficulty?
  67. How Long Did It Take You To Get Your TR Cam?
  68. Whats the point of the longer crank bolt?
  69. Should the intake ports on my heads look like this??? (pic inside)
  70. Oil Pressure?
  71. how much to rebuild a LS1
  72. Hot Rod article about GMPP new heads that flow 300+
  73. Cam options
  74. New 243 Castings $385.00 per pair !!
  75. LS1 heads worth porting?
  76. Rocker bolt in intake port.
  77. LS6 heads milled to 62cc on a 4.030 bore
  78. What is the thread specs on a LS1 knock sensor?
  79. Just Springs and Pushrods
  80. Heatsoak issues.
  81. Patriot 232/230 .580 .580 110 LSA Cam
  82. Darton MID Sleeves come in please>>>
  83. Just curious about the 243 casting heads
  84. 3rd Gear Bog
  85. PTV clearance #s
  86. 15k on chrome moly pushrods bad
  87. Triple Springs
  88. cam tool
  89. ? about Dart 225s
  90. engine descion help
  91. witch cam???
  92. Are 918's good enough for this cam??
  93. Bad Lifter OR Motor is f'ed up?
  94. Magic Stick 3 owners -- how drivable in 6th?
  95. Post-Cam Install issues, please help!!!
  96. When is a good quench too close for comfort?
  97. Heads or 4.10 gears in a 10 bolt for street use only?
  98. what cam to use?
  99. Oil Cap Stumble
  100. F13 Cam specs...
  101. help make my mind up on a cam
  102. Crankshaft Scraper
  103. DCR Calculation
  104. NEED A CAM need suggestions
  105. Anyone on the board have an engine built by Speed Inc?
  106. Cam,tuning, And Tranny
  107. Need help in picking a cam!
  108. can i run Patriot Dual valve springs on these heads..... need quick answer..
  109. ARP head bolts or head studs???
  110. Rod length discrepancies with in a set?
  111. Removing secondary air good or bad idea?
  112. Knocking from water pump area. Please help!
  113. What else is needed
  114. LS1 3.898 replacement pistons
  115. Heads off. Noticed something.
  116. How much should oil pressure drop from cold to hot?
  117. 1.8 / 1.85 rockers on this cam??
  118. What makes an agressive cam "not streetable"?
  119. Heads&Cam or Force Induction
  120. When should I replace my timing chain?
  121. LS1 awaiting installation....
  122. Looking for opinions on A4 Cam selection
  123. 5.3L, LS6, ls1 heads questions
  124. Im thinkin about this cam
  125. heads cam install
  126. *New Pennzoil Platinum*
  127. LS1 FTW!!!1!!!!111one!!!11!!!!1
  128. got the new engine goin ...but now a prob
  129. what the hell does a nitrous cam do
  130. Tips on cleaning head surface?
  131. The quest for the ultimate street head and cam set up please help!!!
  132. heads
  133. What power range...
  134. New rockers with cam?
  135. H/C Goals
  136. quick question on the ls6 cam
  137. Decent cam for a4 with spray, stock limiter
  138. heads and cam combo
  139. What lifters for H/C car?
  140. Cam at 86k?
  141. cam and convertor
  142. Help me compare these three cams
  143. Easy power for you LS1 guys!! Xtreme Motorsports has the answer
  144. Heads advice
  145. Lunati lifters/preload
  146. which piston rings
  147. How many miles before AFR heads need to be reconditioned?
  148. Which Cam to Use
  149. Major Problem - No Compression Cylinder 4!!!
  150. Crank Spacer Won't Fit
  151. all 8 intake inner springs broken
  152. what valve spring kit i need for LG motor G5X3?
  153. 124,000 miles on LS1 wat should i do
  154. Oil tests....
  155. Engine break in...
  156. cam vs cam vs cam
  157. Crate Motors. What to look for? Who has the best quality?
  158. Help me pick a new cam.
  159. cam question?
  160. Heads came apart!!!
  161. Remote mount oil filter lines
  162. New motor.. oil pressure questions.
  163. While heads are off, anything to look for?
  164. How to get 500 rwhp
  165. patriot dual springs VS. crane dual springs... Diffrences.....
  166. close to final decisions on cam..
  167. piston slap
  168. bad o2 sensor(s)...tell me the symptoms
  169. what cam/heads is working on the gto's
  170. Head Experts - Combustion chamber damage
  171. Help with leakdown testing
  172. Does anyone have a model number for....
  173. 232/232 .595/.595 vs 236/236 .602/.602
  174. g 5x2 owners come in
  175. Anyone post who has blown up an Ls1 on the dyno
  176. how hard to maintain a cam only car?
  177. Thinking of doing Z06 cam swap.
  178. PCV system. PLEASE HELP!
  179. H/C/I gaskets......
  180. Superchips frist mod
  181. Bad idle/ know I want a cam&head package :)
  182. Cam and MPG???
  183. Big Cam
  184. Engine is missing throughout the rpm range, what causes this???
  185. Where's my coolant
  186. We Should List the DCR For Popular Off the Shelf Cams
  187. Motor went need help taking it out
  188. Checking PTV clearance w/hydrauic rollers and checker springs
  189. LME 408 guys in here!!
  190. TSP Torquer V2 or new Torquer v3 Question
  191. High & Low Voltage Cam Sensor Codes
  192. Need some advice/suggestions.
  193. What is this I found on my drain plug??
  194. Stock heads flow rate
  195. Stoker Kit
  196. Stock Pan or Other?
  197. Can't check P/V clearance. Is any of these cams safe to use
  198. need help with what to buy
  199. Help needed ASAP, car on side of road
  200. bad rings??
  201. Troubles with 02's Sensors
  202. My 228R and AFRs at idle
  203. Cam for C5
  204. How easy???
  205. how to install?
  206. installing harland rocker arms
  207. anyone got some great mod ideas ??
  208. Valve covers and rocker arms. PLEASE HELP
  209. Car stalled while running AC w/ new cam.....
  210. Nitrous backfire blown motor? maybe
  211. Need help with DCR, used calc says n/a
  212. more bang for the buck $$$
  213. Maximum Valve size?
  214. ls6 block question....
  215. 5.3L heads conversion
  216. Hex key broken off in ARP stud...
  217. guys with f13 cam come in
  218. 382 stroker needs cam
  219. H/C Install. Almost Done.
  220. Question for H/C guys.
  221. Anyone run a 112 LSA with an A4???
  222. Iron 347
  223. shooting for 500@ the crank
  224. Are 918's still safe for Torquer v2?
  225. PTV clearance and .030 quench question
  226. Patriot Performance LS6 Style heads $1,095.00 Assembled !!
  227. Crank pulley not all the way on
  228. Weird coil pack firing issue...
  229. T-rex AND heads?
  230. Max safe RPMs
  231. How much Compression on 93 otcane
  232. Crane Rocker Jam Nut Tips Please
  233. Texas Speed 220r cam
  234. RHS Heads
  235. Question about Flycutting Pistons
  236. Rocker arms hitting Valve Covers?
  237. Cam Guide
  238. Experts wanted to finalize and critique my setup
  239. Dart LS1 heads
  240. Dart Heads?
  241. Anyone use Comp XE grind lobes anymore?
  242. Does a 408 require a new front and valley cover?
  243. Are 317 castings LS6 heads???
  244. Can a 5.3L head accomodate big valves? (2.05?)
  245. 228/228 588/588 comp cam
  246. whats the best cam for me?
  247. TSP Dart CNC Stage 2 heads, who is running them?
  248. LS6 Roller Rockers
  249. Require 650RWHP engine for 1999 Vette
  250. Need advice on this combustion chamber: pics
