View Full Version : Generation III Internal Engine
  1. LS6 push rods?
  2. BEST heads for me?
  3. more pully issues
  4. Best Cam for stock application
  5. Disaster strikes solid roller, possibly wiped out cam..
  6. what heads for X1 cam
  7. are stage 3 heads to much for stock cube?
  8. Head install??
  9. quick question about timing
  10. every blown up your LS1 motor w/ to much HP
  11. head isnt head, is it? help me choose
  12. part #'s
  13. DCR Calculation for a given Cam
  14. DCR on 91 octane
  15. LS1 stock SCR
  16. So i just found out my engine knocking noise problem BIG PICS SORRY
  17. vaccum leak?
  18. Need recommendations on milling and Head gasket
  19. solid roller
  20. timing chain?
  21. Oil Pressure too Low?
  22. PCV system
  23. TRak cam/LS2 heads
  24. Best daily driver cam?
  25. stock heads?
  26. 1998 LS1 #806 heads on a iron 6.0 block??
  27. Trick Flow LS1 head pictures inside
  28. Holy Shit!!!
  29. Crank pully will not come off..Any help?
  30. Blew my lme 408 shortblock
  31. XER Lobes & PRC Dual Springs
  32. 115+3 versus 114+2 Cam LSA
  33. stage 2.5 heads
  34. Simple Math Question.
  35. PRC heads CNC and ported stage 2.5
  36. What’s the borderline between XER and LSK lobes?
  37. best cam for the street?
  38. Anyone run the Crane "quick lift" Gold rockers ?
  39. 04 GTO cam specs?
  40. 400+ HP cam and converter setup
  41. bolts and gaskets...
  42. Cam install, Do I need these??
  43. 408 on 91 octane, will this combo work ???
  44. TR CHEATR vs TSP 224R on a 116 LSA
  45. Why does my cammed car die when I turn the car on with the a/c on?
  46. Put my TSP cam in
  47. TSP SR 408 Big Issues
  48. torque sequence
  49. LS2 timing gears????
  50. Installing New Cam, What Else Do I Need?
  51. 853 heads/gasket question
  52. How do you adjust your rocker arms?
  53. MTI X1 + 5.3 heads + 6.0 LQ4
  54. Undenatured Alcohol
  55. Ms4
  56. damn coolant lines.........
  57. 7 Heat Range Plug???
  58. Mileage Question
  59. Cost for cam and install?
  60. Who has the best pricing for comp 918 springs?
  61. C5 Z06 question
  62. LS2 TB-anyone ported their own?
  63. What can you tell me about this cam...
  64. longer crank bolt
  65. best cam for stock LS1
  66. Tips for using sanding rolls on cylinder heads..
  67. 2000 Z28 engine replacement
  68. mobil one vs castrol syntec
  69. Which Eagle rods for these JE pistons?
  70. Headers?
  71. Little help. Whats the ls6 coolent lines parts #
  72. Head gasket question
  73. Rear Main Seal
  74. Buying a used cam?
  75. Yes, i searched!
  76. SLP performance package
  77. What do you think?
  78. Cure for the tick?!?!
  79. bad mpgs and burning oil....bad shortblock?
  80. Dart 205 or 225?
  81. Anyone tell me my compression?
  82. PCV sucking oil
  83. What might cause low torque?
  84. Differences in LS1 and LS6
  85. Am I being held back severely or just alittle?
  86. Help Oil In Coolant
  87. After cam install.(A4)
  88. Lowest HP
  89. What is SCR and DCR?
  90. knock on stock tune
  91. yet another cam question.
  92. Tuning Issue or What?
  93. New 402, 135-145psi on compression test?
  94. running AC and a cam??
  95. Mill my TSP LS6 2.5's or buy AFR 205 59cc??? long post!
  96. Need to Know
  97. what pushrods?
  98. Torquer v2 cam installed Vid!
  99. Is F13 an ok blower cam?
  100. Can a tech 2 detect oil pressure?
  101. What should I pay for installation of heads/cam?
  102. Cam install help!
  103. 60,000 mile tuneup/replacement?
  104. New From Dart Billet LS blocks
  105. CAM suggestions would be appreciated
  106. Where is TSP's back to back to back head comparison??
  107. 1.75 RR, Do they make you waste more gas?
  108. Can you run a T-Rex or MS3 w/o gears or stall
  109. AFR H/C recipe Questions/Alterations.
  110. On a 408 block decked 0.022, heads milled 0.036 alignment problems
  111. Anyone have a problem with Dipstick popping up under hard acceleration??
  112. T-rex Injectors
  113. HELP!! loud ticking at WOT and a little smoke comming out of oil dip stick are!!HELP!
  114. MTI Stealth II Cam & Tuning
  115. Engine storing Prep?
  116. reliability
  117. stock ls6 heads 243 cast..
  118. LS1 vs LS2 compatibility
  119. TSP MS3 Cam and Head Question
  120. 347/382 rotating assemblies and '98 LS1 bore ?
  121. AFR 205 with comp cams 232/240 112
  122. bottom end
  123. Valve Reliefs For Non-Standard Valve Angles and SIzes
  124. Power loss and back fire, any advise
  125. Different retainers/locks, what are they?
  126. FAST intake ?
  127. cam install
  128. g5x3/ prc ls6 heads from TSP???
  129. Performer Kit vs EFI
  130. TSP 231/237 cam???
  131. Need a Y Pipe
  132. No vacuum at idle, surging
  133. cam bearing ?
  134. Need new short block advice
  135. Static compression = 11:1, dynamic compression=?
  136. Pushrod length?
  137. Is a keyed crank OK to use with normal crank pulley?
  138. Seeing some knock
  139. Question on TSP cam
  140. Just curious. how much power?
  141. How many autos with 112 LSA or less?
  142. Oil burning problem!
  143. LS6 ported head
  144. Oil Pressure
  145. Shift with big cams
  146. Cam Suggestion on CNC PP 243 heads
  147. Rocker question
  148. stock ls6 heads cc
  149. Can oil pan be removed if I have a BMR K-member?
  150. GM CNC LS6 heads
  151. 280 + degree cams and pistons
  152. valve springs shims?
  153. i'm Looking for a new cam setup?? any ideas on what cam would be good??
  154. Cam Recommendations
  155. stock cc size??
  156. German Castrol
  157. Main Girdles
  158. 59cc Dart heads, 90/90, G5X3 cam install is complete.
  159. Please help with engine noise
  160. Biggest bore for a QL9
  161. Is it just me or is the year 2000 notoriously bad about burning oil??
  162. How to clean water out of engine?
  163. Pushrod length check
  164. Valve Stem Seals Are Different?
  165. Do not buy from....StockInteriors.com
  166. Heads for ported FAST intake
  167. 234/234 598/598 110 +2 Streetable???
  168. ETP 215s or AFR 205s
  169. S-cam
  170. Lt1 and ls1 IAC/TPS plug, are they the same?
  171. Setting adjustable rockers
  172. LS1 Oil Problem?
  173. This might be a dumb question but...
  174. Victor Jr. & Big Cubes What Cam?
  175. just ordered cam...CANT WAIT!!!
  176. Torquer V.2 (cam inside)
  177. Torquer cam, headers, intake dyno inside, How's numbers.
  178. Vodoo Cam?
  179. No Spark
  180. Cam Install Dot Question! - Pic inside
  181. Launch T-rex on Nittos ?
  182. Installed my LME shortblock this weekend pics inside
  183. AFR 205s vs PRC/TSP LS6 CNC ported heads
  184. How much taller are Morel lifters?
  185. Valvetrain chatter @ ~2500rpm with cam?
  186. Throwing code now that 408 is tuned
  187. porting the heads
  188. ls6 oil pump
  189. High lift, short duration v. shorter lift, long duration
  190. H or I rods?
  191. Any Melling oil pumps out there?
  192. need good cam for Magnacharger
  193. tick tick tick.....solved
  194. a couple of flycutting questions....chime in
  195. got the cam installed
  196. GMHTP: Edelbrock Heads = 54hp/41tq
  197. how much more $ do i need
  198. Parts list needed!
  199. jpr cam tool question
  200. LS1 FD Swap, 6.0L questions?
  201. cam for 2002 z28 (5.7l auto)
  202. AFR 225s/G5X3 and Cartek 4x H/C
  203. cam or heads
  204. broke an ARP head stud, pics... now what?
  205. Collapsed lifter...??
  206. am i screwed?
  207. Adding Rockers
  208. Oh yeah, I'm happy!! Killer deal on GC!!
  209. problem after heads/cam
  210. heads/cam
  211. compression test...
  212. 402,404,408??
  213. Valve Seal question
  214. Bigger valves, larger valve seat needed??
  215. Stroker Crankshaft Relearn Issues
  216. A slight problem - valve spring swap
  217. used cam's any good??
  218. XE-R 224/226 vs. 226/228 on 112 LSA
  219. Damage to engine (pics)
  220. Should I be worried? Ticking noise just started.
  221. blow smoke??
  222. Multiple throttle body LS1
  223. cam question for Victor Jr. carb intake
  224. ETP 245s in a 346
  225. service engine light!
  226. How much gains by porting stock 241 heads?
  227. HPE 'S' cam
  228. LS1 machining question
  229. Please list your cam specs and if you lost any power down low
  230. Quick Question in middle of valve spring swap
  231. overheating problems
  232. Car Ticking Question??
  233. Considering building a 6.0, but a new to LS series...
  234. loud tapping on deceleration\idle
  235. Motor let go
  236. A Question about GM Hot Cam? Help
  237. Car Ticking Question?
  238. Best Cam Package??
  239. low oil pressure / poor cooling related? help!
  240. Help, before i finish head install
  241. cam #'s
  242. Ls1 Hot cam #'s
  243. PTV measurement
  244. Showroom Stock Cam
  245. First of all I would like to say thanks to everyone.
  246. SO who here runs a BIG cam on the street?
  247. Have Crane Rockers w/ Torquer2
  248. whats the RWHP gains from heads????
  249. HELP with a 236/242 .598/.610 114+4
  250. is this cam anygood
