View Full Version : Generation III Internal Engine
  1. Safe to drive
  2. cams with awesome Torque and good mid-upper range?
  3. Car Wont Start. Help
  4. Cam ?
  5. ET Performance heads
  6. 853s v 241s?
  7. Whats all needed for header install?
  8. ls2/ls6/ls1 bottom end
  9. Those running 90/90--which MAF are you using?
  10. Use stock LS6 lifters on new forged blown shortblock with new cam?
  11. New here, need some help
  12. cam component help
  13. Just came in !
  14. Is there still a market for ported stock LS1 heads?
  15. Need part numbers please!
  16. Home porting LS1 heads
  17. Comp Cams "Cam Help Call Line" what a Joke!!!
  18. knock knock?
  19. Who drives there 408 car more than 3-4 times a week?
  20. Buying a Torquer 2, what else do I need?
  21. Cold Cylinder! Help!
  22. ARP rod bolt torque spec
  23. #7 hole why is it the problem???
  24. New Oil Pump...
  25. Oil change....
  26. Looking at different cams for DART 205s
  27. x4 and x5 cam guys need your help?
  28. What determines pushrod length?
  29. Head suggestions???
  30. Went to slp website and have a question on one of their heads and cam packages.
  31. Finally tuned :)
  32. new to LS1 tech, one question
  33. titanium retainers???
  34. Oil Pressure 11-15 PSI at idle.. HELP! I'm Scared
  35. Oil pump swap
  36. G5X3/112 Duel open cut outs (video)
  37. port and polish or new heads?
  38. How To Tips: Battery Cable Replacement?
  39. were's the best CR calc at?
  40. cam size and timing , does the cam
  41. Blew Headgasket on Dyno w/ 14.0 A/F, what can the headgasket take down with it?
  42. Need help asap!! about swapin heads
  43. smoke
  44. Need some help
  45. Heads question
  46. break in a cam?!?!?!?
  47. cam question
  48. Had a set of Dart 205s on the bench this morning,
  49. Too Many Heads To Choose
  50. Procharer Or MOTOR?
  51. new timing chain a MUST for new cam and heads?
  52. Regretably, another "tick-tick" question
  53. Oil Pump Assembly?
  54. LS1 hole vs. LS6 no hole why?
  55. Engine coming out, what to do while it's there?
  56. Head studs on a C5
  57. Isky 1.44" Diameter Duals....Part #?
  58. cam questions ???
  59. Patriot H/C Package
  60. RHS Heads
  61. best sponsor to buy a cam from?
  62. tpis heads??
  63. Resleeve just one cylinder?
  64. Best cam for Dart 205's?
  65. help a young guy out .need a TSP cam
  66. Stock balancer?
  67. Ported 853 Pics *UPDATED*
  68. I finially ordered a new cam for my AFRs
  69. oil catch can
  70. Modified & Simplified VE Calculator! - I need some input!
  71. knocking, ticking, noise and where to get serviced
  72. How Much For Porting Heads?
  73. Shortblock Assembly??
  74. ls1 hotcam package
  75. MSD Blaster Coil Packs ?
  76. Any room for thinner gasket/increased compression?
  77. new blocks
  78. royal purple ..
  79. Quick ICL & Advance clarification question
  80. just a cam get 400/400+ with not a big loss in low end tq?
  81. How much could you mill heads and keep the 7.4 length pushrod?
  82. highest possible compression on pump gas
  83. Question for Texas Speed Guys
  84. How much better do stock ls6 heads flow over stock ls1?
  85. motor going bad?
  86. Hand Porting LS6 heads at home
  87. Another ARP lube question
  88. 6.0 iron block parts list..
  89. Forged?? what all goes into it
  90. DCR / ICL Clarification
  91. fm13 in a 370??
  92. Anyway to test piston rings while heads are off?
  93. what cam with my combo
  94. cam install
  95. future plans
  96. trex question
  97. Bad lifter??
  98. 5.3 truck crank, 5.3 aluminum block
  99. Which cam is better?????
  100. Whys does my car idle high sometimes?
  101. Couple ? Texas Speed 224 cams.
  102. Is there no pride anymore?
  103. Help and info needed please re cam timing.
  104. Found this while changing the PCV valve...
  105. Breaking Rocker arms
  106. Safely raising redline and power curve of LS1
  107. Ordering ETP 215s, what other stuff do I need with 11 degree heads?
  108. .085" flycutt = what cc?
  109. New ARE Heads install same results as stock heads
  110. new stroker
  111. Cam only or H/C
  112. Stock Cam Questions? Please Help
  113. break in oil???
  114. Please help with picking my cam???
  115. DCR with G5X3 on 112 LSA, .045 gasket, ETP 215s with 62cc chamber?
  116. Which bearings?
  117. Do I Just Need A Tune?
  118. Ms3 112 Lsa ?
  119. strange power loss
  120. new 347 on the way
  121. New custom grid
  122. where is my SS supposed idle?
  123. Whining Noise Under Acceleration
  124. Need a little pushrod help
  125. a few questions about car after cam install
  126. most popular rocker ratio after cam install?
  127. Cam Doctor of an XFI
  128. questions about LSA and advance for my cam
  129. 402 build up?
  130. video My car G5X3 AFR 205's 59cc
  131. Car dead this morning
  132. Do LQ9 heads use the stock length pushrods?
  133. patriot performance LQ9 heads
  134. LS1 Engine to LS2
  135. Dart 205 heads and MTI B1 cam, what pushrods?
  136. Any Guesses? 58.6cc Cylinder Head Compression
  137. What is the most lopey cam I can get for a Z06 without flycutting?
  138. Switched from RP to Germ Castrol
  139. yella terra 1.7, is it worth it with g5x3?
  140. need advice on a good streetable cam
  141. ls1 ls6 383 stroker shortblock , WHAT do you think ?
  142. Valve hit piston
  143. Ls1 Ls6 383 Stroker
  144. heat
  145. longer bolt
  146. ARP Head bolts
  147. Trickflow heads
  148. Damn it..broke a cam retainer bolt..pic..help?
  149. Cam question
  150. Build a ls1 347 or ls2 shortblock???
  151. 408, Cam Specs, DCR, Vacuum Issues. asking advice
  152. Valve size
  153. H/C swap with problem. Coolant in exhaust...NEED HELP!!
  154. engine trouble
  155. matching cam to stall
  156. XFI lobes for LS1?
  157. what to get w/LS1 383 Stroker Shortblock assembly.ith
  158. getting heads w/ cam....should I?
  159. Metal On Drain Plug BIG HELPPP
  160. Broke a sensor...pics...what is this?
  161. Another 5.3 question.
  162. Coolant Plug Leak On Dart Head Help
  163. LS* oil pan?
  164. 5.3 prc ms3
  165. What cam with this setup?
  166. Engine run without valvecovers?
  167. Motor need a bigger cam, what to do?
  168. Rollmaster double roller and March Pulley Q??
  169. biggest cam with stageII 5.3 heads..
  170. Highest mileage ls1 youve ever seen?
  171. Torquer V2 soundclips. anyone?
  172. torque question
  173. Piston cleaning? in process of h/c install....
  174. How much HP am I losing? (pic)
  175. cam help...stalling and surging
  176. Cam swap complete, now a weird valvetrain noise.
  177. 402 Stroker....need piston advice...
  178. Torquer v2 install done! Vid inside
  179. 1.8 harlan Sharp ????
  180. what is some of the down falls of a BIG cam?
  181. Possible head bore problem?
  182. Things No One Told You About Stroker
  183. Cam Motion part number and specs
  184. trying to help a friend low oil pressure new motor..
  185. How to find specs on AFR Heads and Cam?
  186. Stock motor with cam.
  187. Stupid question but i need to kno
  188. Stock LS6 heads with TSP Cam...what pushrods?
  189. GM Hot Cam Question
  190. short stroke gen III
  191. MTI H/C Package
  192. ls6 2002 vrs ls6 2004 blocks!
  193. TRex is down on power, problems at track.
  194. GTO LS1 to 400hp ??
  195. Good DD on an A4: 224/230 114?
  196. new fuel injectors
  197. Need help fast!! In the middle of H/C swap @ 2AM
  198. help choosing a CAM
  199. Hot Cam Question
  200. oil question please
  201. rocker and lifter combo?
  202. How is crank position signal read?
  203. Quick ? on PRC Spring kit for those that have changed
  204. crank bolt
  205. Nice heads for LS1 with TR230
  206. Which Heads Better with G5X3 and ... ET or AFR ?
  207. High oil pressure
  208. OK whats the latest on Rockers..
  209. big mods what kind of gains???
  210. Too much oil pressure???
  211. map sensor readings
  212. Hesitation up to 2500 RPM???
  213. head swap gasket question
  214. iron block question...
  215. harmonic balancer removal
  216. Heads & Cam ?
  217. Torquer cam coming, which heads or stay with LPE LS1 ported
  218. heads for my 402cid
  219. Comp Pro Magnum Rockers ??
  220. ETP Heads question
  221. casting numbers
  222. What are the head bolt patterns on 99 and 2000 ls1 engines?
  223. Those running or who have knowledge on Cam Motion Cams please enter.
  224. Cam damaged, need opinions
  225. best cam for my mods
  226. showdown.MS3 or Torquer v2
  227. have shaft mounts, stay hyd or go solid?
  228. Anybody have instruction book for Rollmaster chain?
  229. Anyone bent a pushrod???
  230. LS1 friendly machine shops?
  231. What to do with heads???
  232. Cam with mileage?
  233. loose rockers?
  234. have searched.... but what difference does LS6 pcv system make?
  235. quick cam questions
  236. No more burning oil!
  237. quick answer needed - oil system
  238. Crap - Quick help here guys
  239. 99+ knock sensors in a 98
  240. H/C package? Cam guru's please help.
  241. **How do I get my gas out of my car?**
  242. LS2 Timing Chain question...
  243. Crank Confusion: 'Recessed 0.400" ' = ???
  244. slp heads/cam package
  245. Rocker Arms Question - Please help!
  246. SHOCKED 243 castings factory on 02 Z28???
  247. 6.0L Heads - Will Stock Valve Covers Work
  248. looking at car, what do u think about its mod list
  249. Best oil to use
  250. What Pushrods?
