View Full Version : Generation III Internal Engine
  1. cam help questions
  2. ls1 misfire #7 ...steps taken..help needed again.. car doesn't like me
  3. Head Gasket
  4. Yay!!
  5. balancer bolt
  6. Milky oil right after cam install
  7. Next Mod's
  8. What timing chain to use?
  9. What is this stuff inside my intake tube *pic*
  10. 4.8 heads ?!?!?!
  11. Finally!!!
  12. do you bend alot of pushrods?
  13. torque specs list?
  14. New Shortblock, few questions
  15. TR 224 or TSP 228R?
  16. Diff between 99 and 01 crank reluctor
  17. New Texas Speed Camshafts & PRC Heads Combo NEWS!
  18. LS2 cam into 05 yukon?
  19. few question
  20. Lasershop's Patriots reflowed
  21. Anyone know the exact weight difference?
  22. fuses blowing? dont know what it is.
  23. LQ9 Part number
  24. Request for proper block break in procedure
  25. Please help me figure out how much compresion.
  26. H/C "Package" that will pull to 7k - M6/4.33 Gears/2700 lb curb weight
  27. engine break in time?
  28. TSP/PRC Stage II Darts. Smoking issue.
  29. Differences between Camaro and Vette LS1 ?
  30. changing cam...
  31. Piston to Valve Clearance?
  32. Looking at LS1's....need tips please.
  33. Engine Go Bye-Bye?
  34. What is a safe rev limit for me?
  35. Mahle Power Pak
  36. HPE S Cam Vs TSP MS3
  37. Difference between large and small bore AFR heads?
  38. Cam question inside PLZ
  39. 383 Stroker
  40. Picked up weak springs and fuel line tool
  41. Please explain spark knock and rattling can noise
  42. cam install time ?
  43. What all is needed for a cam installation?
  44. 650+ lift. what springs r u using?
  45. What lifters??
  46. Streetable cam-400+ rwhp NA but good with N20? attainable?
  47. Whats needed to make an ls1 a high rever?
  48. ZO6 Cam in a Yukon XL 5.3L
  49. Are ls1's tougher than the average bear?
  50. Is is possible for lifter to go bad.....
  51. Hi Temp RTV on exhaust gaskets?
  52. valve noise, adjusted rockers a million times
  53. ideas for valve train
  54. Maintenance after Cam
  55. porting stock ls1 heads
  56. Still consuming oil
  57. pics of headwork?
  58. N/a Or Turbo
  59. Solid cam help
  60. Rotating assmbly
  61. Stock lifters should be ok Right?!?!?!
  62. what do you do?
  63. dumb question...
  64. Comp 918 Springs
  65. texas speed ls6 heads
  66. First ever Bumper to Bumper cam question..
  67. Seating new rings = fine metal dust?
  68. TPiS ZL11X Cam
  69. What can i spin safely? 6800???
  70. Need Help!
  71. Rotten egg smell from exhaust?
  72. Engine assembly lube
  73. Fuel line removal tool?
  74. cammin
  75. going to pick up a 6.0 motor tonight what to look for?
  76. valve cover gaskets
  77. Stock Engine Limits
  78. Rate My Mechanical Skills!!!!!!!!
  79. Is there any lope to a F13 114lsa?????
  80. displacment question.....
  81. How does shimming a valve spring allow for more lift?
  82. Used camshaft polishing
  83. tranny and rear end question...
  84. LSx Engine into 93-97 body....
  85. What do I need to go with cam?
  86. Good size cam for my setup
  87. Lunati PRO MOD Valve Springs Opinions?
  88. Dart 225 pushrod length
  89. How much HP does it take to turn the A/C compressor
  90. How to tell if your running on all cylenders
  91. New intake around the corner
  92. Darts just went up at jegs...
  93. Have Goals, Need advice
  94. stock pushrods on stage 2?
  95. Short duration solid roller
  96. Got another question for you guys..
  97. Bank 2 Side Plugs All Black
  98. Do I have everything?
  99. How can you tell if one of your cylinder is out?
  100. How do you know if you have valve float? / Possible Issues
  101. Im having trouble getting my stock pulley back on.
  102. Need Help. Cam almost decided.
  103. LS1 O2 Oxygen Sensor
  104. Can't remove rear pass side head bolt
  105. engine code search
  106. 5.3 Heads (need to make a decesion quick)
  107. Where to get ls7 lifters
  108. alot of engine noise please come in
  109. Am i missing anything?!?!?!? (cam install)
  110. Do 1999 camaros with ls1 run the same 26lb injectors and ruel rail as 2000 trans am
  111. tsp 233/239
  112. PRC LS6 CNC Ported Heads
  113. Pushrod Length ETP Heads
  114. QTP cam cover.
  115. Your Thoughts?
  116. which heads is the best for my baby cam?
  117. What do u think of this for a cam?
  118. "A" casting mark on intake runners
  119. Does this count as Internal? LoL
  120. Just In ! Patriot Ls6 heads! pics..flow #'s
  121. another help me pick heads
  122. got an ls1 have questions
  123. Knock sensor question...
  124. Meth Kit On A Na Motor?
  125. Hole in block?
  126. A ? for the cam Guru's, lobes lift and +?
  127. How to tell if pushrods are bent?
  128. rebuild stock rockers w/roller tip?
  129. titanium locks
  130. N20 build up stock ls1
  131. Is there a 'selecting heads' how-to? Advice?
  132. cam question for ls6 cts v
  133. 317 & LS6 heads
  134. Anybody looking for an engine?
  135. Nick on Valve Stem....HELP!!!
  136. Texas Speed MS4?!?
  137. gettin a cam this week SO HELP ME lol
  138. T-rex on 35th anniv. SS
  139. Questions about heads and P/V
  140. ARP Main Studs????
  141. want to cam it....but with what?
  142. when checking out a camaro...
  143. Anyone running Lunati
  144. Help, missfire between 2500-4000 WTF!!!!!
  145. 98 vs 2001 ls1
  146. Vacuum pump && Ring/bore wear...
  147. Best Heads for a Nitrous car
  148. Anyone ever put this stuff in thier engine????
  149. Rod bolt swap done a new way in the car??
  150. Emissions confusion
  151. PCV routing ??
  152. TSP oil pump failing?
  153. will I have to change to a different weight oil after a cam install??
  154. ET performance vs racing head services
  155. Why would one bank run lean??
  156. Individual Runner LS1 intake Manifold
  157. pushrod check
  158. FAST 90intake and 90TB with 205/G5X3 worth it?
  159. cam horsepower ????
  160. I'm officially cammed
  161. TSP 228R cam what heads?
  162. the best cam for a 3400 stall?
  163. Valve Failure Article
  164. Is my motor going to die on me?
  165. Big cam guys.... what rockers you using?
  166. TR224 verses torquer v2
  167. ls1/ls6 239 251 grand am cup cam?
  168. Head gaskets-how thick are they
  169. Car Idles Rough - Bad Coil Packs?
  170. 226/226 .591/.591 Tuned by SRP
  171. LS2 timing chain
  172. Is this piston ring flutter? Correct answer wins money
  173. Patriot heads and nitrous.
  174. Melling vs. QTP HV Oil Pumps
  175. TREX cam way to much?
  176. Could 89 OCtane set off a code!!!!!!!!
  177. bypass evap system?
  178. Thinking About Heads
  179. Cam Degreeing
  180. 1998 Heads Question
  181. ls7 top end conversion complete!
  182. MS3 Guys Inside
  183. How do the new heads look?
  184. '86 Z28 heads on a '98 LS1 TA??? HUH???
  185. Cheatr Cam Card?
  186. oil recommendations
  187. what should i do
  188. Milling stock heads
  189. FAST 90 with shorter intake runners?
  190. Need Patrick G's advice on cam selction
  191. Cometic head gaskets
  192. TREX and auto tranny??
  193. need a H/C combo that passes smog!
  194. Got my motor together...almost
  195. main stud question
  196. LS1 block question
  197. Valve Springs shimmed to .050 coil bind
  198. Patriot Heads
  199. what can you guys tell me about this cam????
  200. TRAK Cam installed last night ( pics link inc )
  201. Cometics seeping after winter
  202. random multiple misfire
  203. 02 problem
  204. what do i need to hold this power???
  205. Sounds like I have pebbles in my motor when I get on it?
  206. ’98 stock Vette heads into Stage2 Questions, Help PLZ!!!
  207. Texas Speed
  208. going to buy dart heads but have a question
  209. smoke when i rev my car ...?????
  210. timing my short block
  211. BBK TB 80mm - substantial HP gain with heads/cam/bolt-ons?
  212. PRC 2.5 5.3 Heads/ MS3 Cam what kinda POWER?
  213. oil pump install question
  214. HOLY SHEET!!!! H/C car with problem
  215. Weird problem
  216. What color smoke does Dextron produce?
  217. LS6 PCV mod for 6.0??
  218. pulling and checking pushrods?
  219. newb on heads
  220. TSP CNC LS6 vs Livernois CNC LS6 heads
  221. 1999 Z28 needs a tune-up
  222. Do ET heads need 2 different length pushrods?
  223. People with a Big Cam and no cats....
  224. sorry to interupt, hav a question for ya
  225. Gasket Bore size??
  226. Zero oil pressure @ idle????????
  227. cam advice
  228. bent valve
  229. Brand new engine...Fuel in Oil...need help bad!!!
  230. What makes the best heads for power?
  231. 231/237 Info
  232. 6.0 cranks, strength or displacement?
  233. 98 LS1 and 99-02 LS1 what are major differences???
  234. All these new heads, still high price!
  235. Shimming PRC springs?
  236. forged pistons?
  237. Cammed LS6's need advice..
  238. Help quick with crank pulley
  239. Are MLS head gaskets reuseable?
  240. WTF? This is the craziest thing Ive ever seen!!!!!
  241. What thickness MLS Cometics (setup inside)?
  242. My car just died
  243. New ls-1 runing kinda wierd.
  244. SES on after cam install
  245. TRex vs. MS3 vs. F15 vs. G5X4
  246. wat u think??
  247. when to buy a cam?
  248. Link to different aftermarket head CFM #'s and stock LS1/LS6#
  249. Break in period after heads/cam install?
  250. Any luck running heads with TR230/224?
