- Hi Flow Turbo website?
- Head Questions.ansa needed ASAP
- yes..another t rex question
- Cam problems
- Help with pushrod length!!
- Got cam/stall put in, want more MPH
- Torque--ARP 134-1002 cam retention bolts
- Got my ETP 225 Heads today...
- Comp same as AFR? 224/228 581/588 114 lsa
- Detonation, STOCK CAR!???
- What cam with TSP LS6 CNC heads?
- Under Drive Pulley guys please chime in
- V6 & V8 accessories interchangable
- Simple question botu heads
- 99-02 z28/ss
- 400+ rwhp w/ Ported LS1 Heads & Cam?
- any heads over 72cc?
- Torquey cam on stock 346
- Help me pick heads for my 228R
- G5X1 vs. 228R
- Ported TB on non-cammed ls1 ?
- Average cost to have your LS1 bored out to 6.0?
- Difference in LS1 Heads?
- will new gears effect my tune?
- Heads?
- LS1 AFR 205cc - Flow Numbers (Inside)
- PCV Deleted Already?
- LS1->LS6 engine swap on 99 Z28.. questions, esp about emissions and EGR
- Question about PP's dual springs?
- is the 02 Z06 cam worth it as a mod???
- All-bore motor combinations- who's running one?
- Best MS3 supporting mods
- Are Darts worth $600 more than TSP's LS6 heads?
- Most NA HP & pass the sniff
- new member need help,I must beat him
- The dices are rolled :)
- AFR 205 and Dart 205 standard springs vs LSK lobes?
- 400CID+.. what kind of intake manifold?
- oil in my FAST 90 w/ a AMW catch can
- What do I need to beat this bike?
- best heads for magicstick
- Another Successful "Want More Torque" Cam Swap
- Flycutting?
- 228/.581/114 Comp Cam Value
- new rings ??
- More pic's of the 408 install ...
- H/C Swap Now Have P0155 Code, Normal?
- Ported 853 pic
- Diablo Sport Predator Question
- Need Help With Compression!
- 206/212 .515/.522 112 lsa?
- Smoking at idle?
- DAMN LS2 cam position sensor!!!!!!!
- LG G5x3 cam?
- Help...which cam should i buy?
- ls6 cam?
- I want a stealth2 cam but what heads?
- ticking, need help. video
- demensions of JRP lifter tool?
- Harmonic balancer wobble at idle
- "Torque out of my ears"... questions??
- ANybody in GA to install my 5.3 heads and texas torquer v2 camshaft???
- Best price on CNC LS1/6 heads (stock valves, unmilled)
- Will This Combo Work Good as a DD
- Oil Consumption
- sorry,ford 351 stroker question
- Cam to big for stock shortblock
- H/C Q's
- what cam with yank 4400?
- Absolute-Speed Heads users - Q's on your valvetrain
- What is the stock lifter preload range?
- Torquer 2 and pushrod length question
- what grade oil?
- Buying a 30k-mile longblock...what should I replace?
- Who, Where, What, want bigger cam than 244/248 for my 408 N/A
- Supporting mods for my cam...
- Stock LS1 Heads
- need help with oil pump..
- FMS F11 114LSA cam questions
- Whats the best cam for AFR 205 heads?
- whats the best streetable sleeper cam
- How bad is this? (pic)
- so my reluctor wheel is hitting my crank sensor
- Tea vs TSP Vs Waldens' Machine work for the 5.3
- 6.0 motor for bo0st , as back up! plase read
- cam questions
- Ticking, Knocking noise! checked pushrods?
- Cam for a non stalled car???
- is this enough?
- Gasket help
- Cam shootout!! MS3 vs G5X3 vs Trex
- Timing Chain help
- torque specs
- Tea???????5.3
- Manifold question????
- Engine Break in Oil Pressure Question
- What should I do now, 402 LS2 or iron?
- 224 cam 112lsa... pass smog?
- Valve Seals...bad?
- Torquer V2 Cam - okay on the highway?
- oil accumulator???
- Stage II LS1 flow #s
- What size is the Crank bolt?
- ????? bout Milled Heads and Big Cams
- LS4 Oil pump?
- 400 HP Question
- 6.0 block?
- Do I have an LS6 intake? PIC inside...
- Advance or Retard for my cam ???
- Any tricks to making Cometics seal better?
- Does anyone know of a Mistubishi site as good as LS1tech?
- thinking of a cam
- Comp Cams 224/230 Dyno numbers
- New rockers prudent with heads/cam swap?
- Head recommendations for MTI-422
- How much is a 99 LS1 worth?
- How to measure valve springs
- torquer2 cam...
- Need help with cam choice!!!!
- switch to solid roller?
- Anyone test exhaust ports with more pressure?
- Ticking finally fixed
- PCV remove
- 6.0 iron parts list for my 99 ta..
- What cam do I have???
- Why are there not many 393 strokers out there??
- Stock pushrod length - Actual Measurement?
- need a cam!!
- ANYONE running COMP CAMS PLEASE POST UP
- h/c ?
- What you Think About LS6 Heads And Cam On LS1
- Changing oils?
- Head problem - time to tear down
- 5.3 and 5.7 headers????
- smoking at idle
- Curious Dyno Results w/ New Cam - need suggestions!
- 233/237 .595/.603 112lsa
- is there any way to prelube a brand new engine before starting?
- Do 5.3's have flat top pistons?
- Question about PTV with this heads/cam combo
- How much will the stock cranks handle?
- The UPS man has arrived(heads)
- cam install
- Machine work on a block for pistons and rods
- cam guru's- need advice
- New Cam Is Installed
- Can't get driver's head off! One bolt left!
- Who has Morel lifters in stock?
- Oil Change After Head/Cam Install?
- 243 heads, Cam TR224 563 114 HP torque?
- Thunder cam, what to expect?
- 1999 Pontiac Firebird Question - Not Trans Am
- Some progress with the setup, small steps!!!
- sea foam?
- TFS heads
- Whats the going labor rate for a vlv. spring swap.
- push rod length advice
- What should I do (cam damaged)
- engine running rough & sometimes backfires...help please
- Milling inquiry 5.3L head
- Rollmaster Timing Chain+stock crank sproket, YES OR NO?
- would this H/C package work?
- AFR vs. ETP (Which makes more power?)
- Valve spring troubles... solid roller
- Quick pushrod question, stupid me??
- what rockers with cam only
- how does all this sound?
- LS2 chain - what difference?
- LS1 timing chain tension
- 243 heads? and ls6 heads
- 5.3 TRUCKheads 75 dollars???
- about how much power should I be putting down?
- Intalling Cam..Need help
- MS3 Soundclips???
- No Oil pressure!
- AFR Heads Or Port Stockers?
- Will TRex work with stock LS1 heads with CNC job only?
- ls6 oil pump and slp double roller chain problem
- 1.85 Rocker arms help!
- REDLYNER's Cam swap... (PICS)
- Possible bad engine
- 408 w/ TEA CNC'ed 317's... different cam? (cam gurus inside!)
- cam lope
- which is bigger and more aggressive
- Probably a simple question but. .
- TRex with heads
- My first cam install
- In the middle of cam swap: need advice ...
- part # for the actual perimeter valve cover BOLT
- more effort on cold starts after h.c?
- Cheap head bolts: Read this
- Easiest way to check lifter preload?
- Picking a Cam to Your Specs
- 402 pkg?
- Valve seal guides different?
- how much compression i need 11.54 or 12?
- Cam selection ?
- CAM people i need help choosing a cam
- Valve locks want let go?
- Checking P to V with clay questions
- Valve spring compressor
- My new dyno #s are to high!!! I need help!
- Should i swap cams?
- high rev kit
- TSP torquer 2 112 lsa
- which cam(for sts turbo)
- Put my valve springs in today
- low lift flow numbers
- Waste of money or advantage?
- how much $$ for this engine?
- Stock LS1 ticks at idle
- cam question
- Best PUSHRODS?
- Differences between Camaro year models
- Going to new cam 228/234
- Valve Stem Seal Question
- Valve springs
- How long to get your prc heads?
- Dart Heads: Unported on 226/226 114 Cam with True Duals = What Kind of Gains?
- Simple Jesel Rocker Question
- specs on stock ls2 cam?
- valve seal help
- traditional split or reverse split?
- help me pick a cam
- Different question...Just how much will a good "street" cam wake up a "street" car?
- heads how to tighten down
- Cam Swap
- Power Plus MPG
- motor choice help
- why is this?
- LS6 Coolant pipe??
- whats needed for 241 castings?!
- Head Bolts or Studs
- how much longer will my motor last?
- Mobil 1 Royal Purple or GC
- input on cam
- Need a big cam that will run good with stock heads
- some questions about selecting heads
- RHS 11* heads
- 3500 stall, 3.42 gears and TSP Torquer cam - yay or nay?
- About to buy an 01 vette w/ 550hp. Help, smokes at idle, normal?
- Lifter preload?
- Flatout gaskets
- Porting Stock Heads
- What cam for my application?
- H/C or Cam Only for 11s
- Any sound clip/vids of the TSP T2 cam??
- Whose running a 230ish cam on a 111?
- Recommend a street cam, specifics inside
- front crank seal
