- AFR 205 porting question for those who know.
- Crank Snout Fitment?
- lube on cam when swapping
- I need the experts opionion on a cam+ swap
- help with cam specs
- Deck height?
- What motor is it? LS1 or LS6?
- Difference between LS1 and LS6
- Bigger Cam
- Now I'm second-guessing my cam choice...
- ET Heads being made!!!!!
- Question on how to identify a LQ9 6 liter.
- quick ? about headers/cam
- Anybody Use These Rockers
- Engine surging....
- Good 6 speed cam
- Harland Sharp 1.7s
- Head gasket / compression ratio ?
- Who has ET heads? and where the hell did you get them?
- WTF IS With These Lifters
- Is 5.3 ported heads better that 5.7 ported heads.
- G5x3 Lg Cam
- x4 vs t rex
- change oil light
- dropped sleeve...anyone got a picture
- rocker bearings breaking after trak cam install PLEASE HELP!!
- rocker arms
- Huge Sale on LS1 Double Roller Heavy Duty Timing Chain Sets !!!!!!!
- H/C/I, or Transmission? Help me decide.
- Constant Sporratic Backfire
- new project! (flooded Prowler)
- My new Valve cover
- Canadian model differences???
- LS1 -> 408 ??
- LS4 solved and being dyno tuned
- What CC are stock LS1 (99) cylinder heads?
- Broke another Pioneer Valve Spring on the 97'......
- part # for oil pump o-ring ?
- I guess search is busted?...need p/n
- my mods...cam help?
- ADVANCE in CheaTR cam???
- A good start?
- Stock ROCKER arm/sticking valve question!!
- ls2 timing chain
- lq9 heads with big cam
- Anyone running the Accel 4150 Billet Throttle Body with a carb intake??
- LS6 heads & MS3 cam
- Installed height and spring pressure?
- Any 383 Strokers running the G5X3 cam?
- Southie's Setup Part II. Object: off the shelf 346ci max power. ETP 225, TRaK (LSK)
- tsp 231/237 & Comp Cam 231/237
- oil change w/ B-12 Chemtool
- Help, coolant dripping from the back!
- help, coolant dripping from the back.
- valvetrain questions (sorry so long)
- oil consumption
- rocker ratio
- Final check before ordering pushrods, Help!
- Pulling engine. Top or bottom???
- forced induction cam
- Cam question, I know not another one
- AFR205/AFR225 HP Diff?
- LS engine block question???
- AFR205 Heads
- questions about intake/throttle body setup
- G5X3 questions
- Comp 918 retainer question
- piston replacement.
- Dart Heads + Yeller Terra RR's = ? Pushrod Length
- LS1/LS6/LS2 engine main girdle???
- Intermitent low radiator water light
- my mods..cam recommendations
- injectors or something else??
- rebuild bottom end??
- Pulley or maybe something else??
- Degreeing Cam Help
- Valve spring shim installation
- where to buy ls6 bare block?
- LQ9 in 98 camaro
- Bad day need a rebuild need advice inside.
- ET Performance 225cc Hyd. Roller Pushrod Mockup
- 2cc Valve Relief, TREX, .030 Milled heads, .030 Gasket
- brown looking foam on oil cap
- Oil pick up tube
- Post camshaft question PLEASE HELP
- What size and kind?
- stock motor, new cam?
- looking for new cam??
- overhaul kit for ls1?
- Is this normal for a big ass cam?
- Dot to dot timig problem!
- Tapping
- F14 is in! Heres some input....
- Will a cam make my exhaust louder??
- Stroking Questions
- speed pro or sealed power lifters?
- Stock Head Port
- head/cam install
- Valve seat question
- Worthwhile cam upgrade?
- LS1 Rocker Arms - Comp. Adj ???????
- LS6 springs/Comp 7.400s are in!
- Hot Cam Idle Issue
- 408 milled heads, decked block, compression and pushrod length
- Help with best mod
- 222/222 cam - suggestions please
- new rings . . . is it worth is?
- Anyone using a G5X3 cam?
- What to do next?
- ETP 215's @ around 59cc, how does PTV compare to ported GM castings?
- oil pump relief shim
- Nitrous pop!!
- Help!! Is there a gasket....
- Will this cam work w/stock pistons, no valve relief?
- cam only start up vid
- Dyno results.....
- Starting a new motor....
- Dart Heads
- tdc method...valve position
- Cam ???
- Help Me With a Build
- What size pushrods for heads milled 30 thousandths?
- How bad is this?
- Least expensive tall valve covers
- Good heads for me ?
- Differences running 5/16 versus 3/8 Pushrods
- MS3 with thinner HG
- Need Help after cam swap!
- Which Head Porters Are Planning CNC World Heads
- prc heads and ms3 or order
- head bolt TQ question...
- need some compression figuring help
- mild hp rebuild kit
- how to make a rear main seal installation tool for free
- Another torque spec..
- Jesel's finally, ET solid roller pushrod length ect...
- F14 installed..have a few Questions??????
- engine ?
- connecting rod weights
- Mixing Bearings... Safe?
- rocker arms??
- 233/276@.050 Why GM?
- chugging after cam install!
- 10 sec car...cam only?
- Katech New Years hours
- Katech rod bolts back in stock
- Anybody running a 408 w/ MTI Stage III LS6 Heads?
- How good is this Port Job? (TB)
- what cam?
- Cam??
- SDPC N228 cam??
- what's wrong with my car? Please help
- TSP 228R and Comp918 springs ??
- cam break-in
- Worth the time and money?
- Dart 205 data
- Stud Problem
- Car seems to want to die at idle somtimes ????
- another cam decision thread
- who sells ls2 chain
- What else do I need?
- truck ls1's: post info and suggestions here!
- Where to put ring gaps in cylinder?
- Burning Coolant After H/C
- 5.3 lingenfelter cam
- Update on Heads&Cam R&R....
- Did search, found nothing.
- Upgrading Rod Bolts... What else??
- Can Felpro 1041's be copper coated?
- couldn`t find an answer !
- New head ??'s
- Katech Rod Bolt Install. Did I Screw Up?
- resleeve 1 cylinder?
- Lifter surprise????
- I have an idea. but I need help making it work :)
- Cracked block = junk???
- MoDs
- Engine Noise
- Question Installing Rollmaster Timing Set +2 Cam Adv.
- Stock rockers?
- Are 1.8 rockers too much with this cam?
- Anyone tried T-rex cam with Ported Heads?
- 383 or 402 stroker w/turbo
- Piston Identification
- How reliable are Cometic Gaskets for a Street Application
- harmonic balancer mounting bolt re-usable?
- heads and cam packages
- 99-02 ls1 heads fit a 98 ls1
- Compression Test results?
- do i have valve float???
- TSP 231/237 in A4 car??
- cam questions
- Canton Oil Pan: Two Thumbs Down
- Head Swap, Motor In or Out?
- It Started!!!!
- Why not 1.8 Rockers?
- School me regarding spring wear with example inside using two Lunati grinds
- bent pushrod question
- 402 stroker?
- What head company???
- can I reuse my Cometic gaskets?
- Oil Pump installation Question
- 3.905 Gaskets?
- Just got my cam specs. Whats your opinion?
- head cc/ compression
- 228/232 .588/.595 114lsa XER in 408?
- 6.0 block, 5.7 heads, what head gasket?
- ARP Head studs
- LS1 sleeves
- Oil Pump spring shim
- MLS headgaskets reusable?
- anyone in phoenix have a good valve spring compressor?
- LSA and loping
- is there a how to section?
- Will a stock LS1 TB work with LS6 Heads?
- Comp. Ratio effective..static???
- LS6 Oil pump
- head help pp vs prc
- Car shuddering
- Ferrera Valves?? worth it??
- LSK lobes...
- when measuring how far the piston sticks out past the deck...
- Need help choosing lifters
- What kind of powere are you making with your AFR 205's????
- GMPP ASA vs. Lunati 230/237 :Roadrace setup...To be used with TEA Stage 1 5.7's
- PRC 5.3L (S) 2.5's or Patriot Ls6 Heads
- Rollmaster DOUBLE ROLLER
- adverage cost of cam install??
- Any testing done on the vic jr vs gm per?
- Bad Luck With Futral Cam
- need help verfiying an ls6 cam
- Dart Head Issues
- Dart Heads???
- So I was taking the rings off my hurt #7 piston...
- Are LS6 springs direct replacement for LS1 springs?
- Replace head gaskets....whats a fair price...........
- Anyone have any info on the GT1-1 Cam?
- 383 stroker help
- New Cam
- JPR tool
- Lingenfelter GT-11 or GT1-1
- Do I Have Enough P/v Clearence And What Compression Will This Be
- Which heads are better?
- Low Lift Cams & More
- Actual Hp
- X-Mas Camshaft :)
- Soduim filled valves worth it??
- What head gasket for 99 LS1?
- Cylinder Wall Scratches
