View Full Version : Generation III Internal Engine
  1. 2007 lq4 build
  2. 243/799 heads
  3. Darton Sleeved 427 LS1 build
  4. Anyone running 228/230 @114 lsa
  5. Crack in block....
  6. Valvetrain Help Needed.
  7. Heads and Cam C5, stock intake?????
  8. Custom Application Distance From MAF to TB
  9. LQ4 434 stroker?
  10. Ls1 torquing Specs
  11. Lq4 Build
  12. someone please help!!!
  13. Who is good at freshening up my 427?
  14. Cammed CETA Video
  15. LS1 EGR and AIR system
  16. 1997 corvette alternator ,how can I get it to work without PCM???
  17. which head bolts
  18. 1997 corvette altinator?how do I get it to work??
  19. New cam install, off by 1.25 degrees.
  20. Is this still good?
  21. Oil burning compression test good
  22. What determines the PTV issues?
  23. fast 102 intake question
  24. Stock rocker going loose?
  25. compression test results before head swap
  26. Solid roller cam
  27. i think its officially time that i start a build thread (short and sweet, pic heavy)
  28. Check out my LQ4/9 build.. offer your opinions.
  29. UPDATE: ticking problem on z28 hci camaro
  30. Head bolts
  31. Heads/Cam Build Thread
  32. 317, 853, 306 head selection
  33. gaket and oring chart for a ls? IDENTIFY THIS O RING!
  34. Ticking/hum sound from both valve covers
  35. Oil Filter O-Ring blowing out
  36. how much do i mill the heads to get 11:1
  37. Welding Combustion chamber on 317 head
  38. Installing Rear Main Oil Seal
  39. help. whats the difference between ati super dampier vs a reg underdrive pully
  40. same rear seal?
  41. Cam noob
  42. Polluter cam or raptor cam
  43. Will the LS7 Oil System fit the LS6?
  44. AFR 225's on stock cube ls1
  45. Want to increase DCR
  46. Not enough PTV clearance?
  47. Lifter tick where to buy replacements
  48. ms3 or torquerv3 cam with 150 wet shot?? anybody running this set up??
  49. Newbie deciding to put him down or do a motor swap.
  50. 6.0 vs 5.7 cam bearing ?
  51. ls1 Emissions
  52. AI 218 CNC Vs. AI 226 CNC
  53. Help! Is this a lifter noise?
  54. Think about selling my cammed 96 ta for 04 gto!!!
  55. Oil Dilemma
  56. What valve spring to run? Under a budget
  57. pillar gauge install
  58. Holy shyte !!!
  59. Whats so special about 243 heads?
  60. Jesel bearings
  61. Has anyone used ls7 rods in a ls1 or ls6?
  62. Just got my ported heads back, pics inside.
  63. 6.0L Serpentine Systems Compatible with 5.7L?
  64. 243 61cc + f14 ??
  65. Rwhp????
  66. What should I run
  67. Oil pressure new pump not good
  68. ready to check pushrod length and ptv...
  69. Doesn´t start properly
  70. Mahle Piston Ring install/orientation for 408??
  71. PRC valve springs
  72. freeze plug pushed in too far in the back of the engine...HELPL!
  73. Fixing to assemble my first LS engine...anything special needed?
  74. another 408 thread.
  75. Help Me Pick my cam 13.5:1 cr ls1
  76. ls1 fuel injectors?
  77. Pick my cam!
  78. Looking for 6.0L head gasket specs...the real ones
  79. 6.0 build questions
  80. used heads
  81. oil pressure bouncing
  82. what does a -3* overlap cam sound like?
  83. turbo 5.3l or nitrous 6.0l?
  84. Stock internal, how hard do you turn it?
  85. Do I have a good combo?
  86. High lift and the effect of injector duty cycle
  87. Dished vs Flat top pistons 5.3
  88. eps 230/234 or 230/238
  89. mpg 180-220 a tank?
  90. cam differences
  91. Lets rebuild this Ls2
  92. LQ4 Build Questions....
  93. 243/799 How much milling = new compression ratio?
  94. Thinking about doing a 383 stroker setup
  95. Can I use stock rockers on TEA 225 heads
  96. how many of you switched to Regular gas?
  97. h/c swap on high mileage, worth it?
  98. Mobil 1 Oil Filters
  99. cylinder head flatness tollerance?
  100. What is the Piston pop up or out of the hole on a 06' lq9?
  101. Question About # 7
  102. Bigger valves for my LQ9 build?
  103. What size cam do you all think
  104. Comp Cam XE-R287 VS MS3
  105. Cam Install ?? Revisions to LS1howto.com instructions.
  106. Cam install
  107. ls7 lifters and pushrod length
  108. installing lifters...
  109. push rod question........need help please
  110. where does the stock cam Make most tqr and HP
  111. Mobil 1 or Royal Purple
  112. How much does mileage effect an engine?
  113. World products warhawk ls1 aluminum heads-any good for the price
  114. Anyone running Flowtech Indcution ported 243/799 heads?
  115. Rocker bolt question
  116. Engine gasket ?'s....LQ9 with LS3 heads.
  117. My Heads/Cam build
  118. LM4 Mild Build ?'s
  119. 5.3 ho build whats needed to make it solid?
  120. Oil crossover block part #
  121. 92mm throttle body help
  122. cam only lq9 with nitrous question
  123. P-to-V contact:
  124. whatever happened?
  125. When is a Tune Needed?
  126. Will a 2.08 intake valve fit?
  127. what arp head bolts and what pn head gaskets
  128. what am I doing wrong?
  129. Anyone with a Lq4/241s/z06 cam out their?
  130. Need help identifying cam
  131. New push rods for LQ4/9?
  132. Cost involved = Power Heads (243s)
  133. Oil pressure relief spring help.
  134. Guess what heads
  135. What are symptoms of rod knock/spun bearing?
  136. Upcoming H/C swap, need help
  137. need help advancing a cam with a rollmaster timing set
  138. need cam advice...
  139. Road Race Cam Suggestions???
  140. another l92 head question
  141. Pushrod Measurements
  142. Yet another LM7 build
  143. Custom grind cam questions, help?
  144. 243 heads: most cfm through stock 2" valve?
  145. lq4 heads/cam
  146. Serious question
  147. experts in valve train noise ie lifter preload please chime in here.
  148. broke a rod what would you do?
  149. Newbie needs help LS1 wont run...
  150. tick/knock? not sure where to start
  151. Engine oil
  152. stock LS1 connecting rod side clearnace
  153. 2.20 intake valve on ls1 stock pistons
  154. Balancer bolt, WHO CARRIES IT???
  155. Messed up my engine
  156. Changed pushrod length now a miss fire?
  157. Need cooling system help PLEASE
  158. rod bearing clearance with plastiguage
  159. Katech rod bolts socket size?
  160. 01 ls1 best oil help
  161. New AFR 210 LSX heads
  162. Patriot 2013 Heads
  163. Grant Piston Rings, anyone ever used them?
  164. oil pan gasket...
  165. machine shop Oklahoma
  166. LQ9 and LS2 pistons
  167. lq4 build
  168. new cam performance questions
  169. Best heads EVER ?
  170. Mesh screen in the air system??
  171. Valve spring?
  172. What Cam to use!!!
  173. My top end refresh! what to expect on the dyno?
  174. LS1 to LQ4 help
  175. What cam LS1?
  176. A little humor for you...or what happens when a machine shop isn't LS savvy...
  177. Cam Help and Other Questions
  178. Timing Gear Set Question URGENT
  179. Pushrod Length Guestimate
  180. 346 vs 408 and build ?
  181. forged rods with surface rust? PIC HEAVY
  182. 03 lq9 question
  183. NEED HELP QUICK Question !
  184. oil pump recommendation
  185. Budget LQ4 with 243 Heads...NOW WITH DYNO RESULTS!
  186. in car start with no tranny attached?
  187. new here with an lq4
  188. oil pressure.
  189. 243 heads what cam?
  190. HELP!! Ticking noise coming from my Z : (
  191. Should I do heads or a cam?
  192. P-to-V with old Texas Speed 231/237 .598/.595, stock pistons
  193. cylinder head bolts, which is best?
  194. help me choose new exhaust
  195. Longtube Headers O2 Sensors?
  196. Are there any other aluminum blocks that can have a 3.905 bore?
  197. How much can I mill?
  198. Correct head gasket for LS6 heads on 2000 LS1 block
  199. will ls6 valve springs fit a 5.3 also...
  200. 408 build questions.
  201. do i need a new ls1 block now?
  202. What springs and pushrods to use with ASA cam?
  203. L92 heads/ 408 question
  204. Amazon or Ebay catch cans?
  205. broke a rocker
  206. Losing oil pressure
  207. ls6 camshaft with standard valves, correct pushrod length?
  208. Measuring Piston to Valve clearance...
  209. Would pushrods which are too long make a stock car sound cammed?
  210. Tell me if its a thermostat!
  211. motor mount install best options?
  212. No compression in cylinder 1 after build?
  213. Valve Stem Seals
  214. stock ls3 cam in a ls1?
  215. Degreeing in ms4, necessary?
  216. are gen 1 and lsx roller lifters interchangeable?
  217. new engine needs oil
  218. 98 ls1 valvetrain noise after hitting rev limiter
  219. Stock 5.3 Upgrades
  220. lm7 build question
  221. Misses, backfires. Ignition?
  222. I have an Lq4 and Lq9, but dont know which to use.
  223. o2 sensor headache
  224. Piston to Cylinder Clearance
  225. Rod & Main Bearings
  226. Springs?
  227. Valve cover problem. H/C swap
  228. Bad bucking
  229. Weird 99 LS1 Oil issue!
  230. Ticking Noise in Head ?
  231. etp head question
  232. Lifter guide (lifter tray) bolts. Anyone got a part number?
  233. anyone know a good speed shop in pa?
  234. do i have to run a stall or not
  235. Cam Package help...
  236. 408 Guys
  237. Almost there!!.. Pulled trigger on TQ V3 cam. Right choice?
  238. cam education please
  239. good H/C/I combo for nitrous
  240. 383 trick flow new numbers
  241. Polluter Cam opinions come in
  242. what should i replace?
  243. Scorpion's or Yellaterra's?
  244. Thanks Eric !!!
  245. On a budget? Want a cam upgrade?
  246. Parts questions
  247. Degreeing Cam
  248. Decide on Heads or Cam First?
  249. Will valve covers from a 5.3 work on ls1s?
  250. First look....new LSX lifters
