View Full Version : Generation III Internal Engine
  1. ETP 225 Heads arrived.....OMG :)
  2. patriot stage 3 LS6 heads
  3. Any write up for rod bolt install?
  4. 396 LS1 stroker guys
  5. How to Determine Deck Height?
  6. Patriots and CheaTR Installed
  7. Cam Install
  8. Cam Question
  9. Does anybody here have an MTI cam in their car???
  10. Running Rich on the pass. side
  11. Correct pushrods for my combo?
  12. Which is the intake valve
  13. Ls2 Timing Chain
  14. Which Forged pistons and rods...
  15. Building Sleeved Stroker vs. Rebuilding Stock LS1
  16. shims...
  17. Look good to you guys?
  18. Question about p/v clearance with et heads..
  19. ANYONE WANT TO RENT out their flycutting tools and head?
  20. Magic Stick
  21. Just ordered my 408! What cam?
  22. Revival options: LQ 6-liter for F-body, yay or nay?
  23. Check out this new product , LS1 engine girdle !!!!
  24. Am I missing anything?
  25. Smoke coming out of oil cap when car is off
  26. Any results from the Dart heads yet???
  27. Cam bearing Is it ok? [Pics]
  28. TRAK Cam Install
  29. T-Rex Question
  30. Windage Tray
  31. Which Rockers in 245 ETP heads?
  32. Absolute Best LSX Head?
  33. Just got a set set of Dart 225's
  34. Tell me it's not what I think.
  35. Custom camshaft for n/a and nitrous power.
  36. afr 205's vs mti 2e heads
  37. 918's with a stock cam?
  38. my cam is stuck in my motor
  39. Had gasket removal
  40. Need serious advice.....
  41. Can I do this with 4 grand?
  42. timing chain ...
  43. Unshrouding AFR205's
  44. rebuild prep for blower.
  45. hot cam
  46. anyone running this cam from crane
  47. TSP Giant
  48. what to buy a bare 6.0 block
  49. Replacing one piston and rod?
  50. how long can an ls1 sit without running?
  51. Which pistons, rods, lifters, & rocker arms for a 402 LS2 solid roller?
  52. best turbo? sorry for question haha
  53. Is it worth reworking head c.chambers when installing on 4.00" bore?
  54. Need some step by step help from you guys
  55. HELP For those of you who have had a motor built
  56. HP Tuner Program
  57. 1020 Flow bench differences(includes Patriot)
  58. MTI 2e heads/cam or cam only?
  59. How much RWHP will it make?
  60. rough idle
  61. Pushrod length question
  62. 6.0L heads on a 3.900" bore engine?
  63. ms3 vs. t-rex
  64. '98 and up LS1 differences....
  65. Where to get 30Lb injector for LS6 motor?
  66. Hessitation......stumbling problem
  67. Okay so I have these 2003 Z06 heads............
  68. Comp Extreme Energy Street Rollers and 1.95 Rockers
  69. really confused!! on a head and cam setup
  70. what to do w/ $4K??
  71. A4 + Ms3
  72. Patriots with F14??????help
  73. Noob LS2 heads questions....
  74. Which H/C combo to go with?
  75. Bearing failure.. cause?
  76. If you are a vendor/builder and want to build me a Short Block...
  77. Grinds numbers in english?
  78. 253 castings???
  79. LS-6 346 Stroker Expectations?
  80. Patrick G's CheaTR cam back in action!!!
  81. Cam questions
  82. Head gasket??
  83. what does it take to beat a cobra?
  84. Car Shut down on Missed shift
  85. LS6 Heads vs LS1 Heads
  86. Cartek 3X H/C package?
  87. valve float
  88. How much $$ to CNC heads?
  89. Bent pushrod and compression
  90. Help with cam choice
  91. quick need help... oilpump and timing chain question
  92. LS1 specific Rod width .945 vs SBC .940
  93. Has anyone ever tried to weld..
  94. Larger cam / Cold weather??
  95. Valve Cover spacer pic
  96. Patriot Flow data
  97. SLP dual chain or Comp 3153T or other?
  98. Sealed Power Pistons
  99. Stock heads
  100. rebuild
  101. question about my cam
  102. After 3 months she lives!!!
  103. MAGNAFLUX a set of assembled heads
  104. ls6 cam in a 5.3l
  105. Pushrods
  106. ? on clay method of checking p to v
  107. Low MPH need help w/ prognosis
  108. F15 vs. MS3 Debate
  109. What cam would be a good choice.
  110. My Ls1 is apart, spun rod bearing...help pls.
  111. Retorquing head studs
  112. LS2 aluminum 6.0 ?
  113. Milled LS6 heads questions!
  114. Hydralic Roller Lifter Ranking
  115. Biggest cam on stock heads?
  116. knocking ?
  117. hey got a knocking in my ls1 ?
  118. Thunder Cams
  119. Speed Inc cam?
  120. porting and polishing
  121. G5X3 cam with beehive springs?
  122. Pushrod rubbing ??
  123. Few questions
  124. 98-99 oil starvation problems
  125. Change cams or stay with current??
  126. JE vs. Mahle
  127. How will 1.75RR's affect my specs?
  128. GM Grand -am cup cam
  129. Cam swap complete. How much more drivetrain noise is normal?
  130. K&N FIPK
  131. Rotating assembly weights
  132. Bad Noises on my way to work today....
  133. Part numbers for engine gaskets
  134. biggest stroker
  135. Who to buy AFR 205's from!!!!!!
  136. Aftermarket roller rockers??
  137. APE Engine problems? Please post in the link
  138. Warm the engine up! and avoid internal problems!!!
  139. Stock rods ok?
  140. Vote on best shortblock builder
  141. Can u run 11.4 to 11.5 CR????
  142. Crank Bolt
  143. 346 vs 408
  144. Ls1 to Ls2 Block okay to do?
  145. Question for PatrickG or JZ or other H/C guys...
  146. F11 Cam only performance question
  147. What CID to go for...consider these parts.
  148. are comp 918 springs any good?
  149. whats the difference in the castings 241 243 853?
  150. taking heads off need help part 2
  151. installing ARP studs anything i should know
  152. 3600 enough stall for MS3?
  153. Which HPE Cam to get?
  154. Will it go 650 RWHP N/A
  155. 5000 Bucks!! What to do?
  156. Ported LS6 Oil Pumps: What causes them to fail?
  157. Help with 5.3 Heads.... Anyone using 5.3 heads come IN...
  158. Increasing valve lift
  159. Piston #7 died check out these pix!
  160. Difference in C5 and F-bod windage tray?? interchangable?
  161. Crane Valve Springs
  162. ET performance head questions
  163. 6.0 rebuild kits
  164. Who is running Comp 918's with 1.8 rockers?
  165. 408 bore and stroke?
  166. stage II patriat heads or t rex
  167. Lunati lifters, how much preload?
  168. Engine Squeaking ???
  169. 215cc heads Vs 205cc heads, where is the cc measured?
  170. Absolute Speed Stage 2.5 Heads
  171. How many big n/a motors are in the 9's with an a4
  172. 231/237 or 232/230 Will this cam work without the matching heads?
  173. Which solid roller lifters?
  174. need some help form ls1 pros
  175. Cam questions?
  176. Is this a blown head gasket?
  177. Suggestions on Head gasket and bolts?
  178. Grand Am camshaft- Is notching pistons required on all install
  179. 226/226 cam
  180. LQ9 Seats
  181. Double roller chain and underdrive pulley?
  182. help!, car studdering, knocking, low on power...
  183. Cam Plans
  184. minimum piston to head clearance?
  185. Which heads for a naturally aspirated 402 LS2?
  186. Cam Question
  187. how much was your cam intall?
  188. 700RWHP Cam Help
  189. Compression??
  190. Winter Project...okay?
  191. Wiseco PIstons
  192. Mini AFC 2.2 Air fuel controller ...
  193. ET Performance Heads on a C5
  194. $2000.00 What next to the car ?
  195. AFR 205's or 225's
  196. basic valvetrain upgrade
  197. Lifter Retainers
  198. Performance Racing Industry 2005 Photos!
  199. ls1 in a GM A body?
  200. top end tick on stock motor
  201. Double Roller Question
  202. Race car oiling system
  203. Bo White and other DIY porters???
  204. residue and moisture found under oil cap... HELP PLEASE!!!
  205. peak point
  206. LS1 F-Body Oil Pan ?
  207. EGR Block off plates
  208. 226/226 585/585 112 cam for m6
  209. cam/rocker/spring question
  210. MS3 Cam
  211. patriot performance cam questin on m6 car
  212. Head gasket material question.
  213. How can I tell if my motor is on its way out?
  214. Getting ET Heads..need help picking out the right one's..
  215. fm13 cam
  216. T-rex cam questions??
  217. What's the going rate to have a block machined, assembled, & balanced?
  218. ETP Heads
  219. Big Bore head gaskets??
  220. MS3 or heads cam pkg?
  221. ET Heads Pic.
  222. Dexcool is cool
  223. Valve spring change
  224. CheaTR cam package gas mileage
  225. heads for this cam
  226. manditory ticker after springs??
  227. 1.8rr on a stock ls1 good idea? and gains?
  228. Mystery solved
  229. Guys that measured PR's with Dial Calipers?
  230. What's better, H or I beam connecting rods?
  231. Qoute to build 408?
  232. Did a search... still need advice on the 875-16 Comp R Lifters
  233. Changing Pushrods
  234. What do you think of this cam?
  235. LS1 Rebuild kits?
  236. Estimating Install Cost..H/C...What did you guys pay?
  237. Anyone out there modify their LS1 pan/pickup to prevent from oil starvation?
  238. quick ? regarding pp ls6 heads and tr cam
  239. Need to stop sewing machine sound. Which rockers?
  240. need help with ls6 and cam
  241. Vinci 079 Cam Question
  242. 235+ duration/.600" lift cam people!!!!
  243. Any Dart 205 dyno results yet????
  244. Thought you all might like to see this!
  245. f14\15 vs g5x4 vs ms3 vs trex
  246. cam suggestions for A4 car
  247. taking heads off need help!
  248. Priming the oil pump
  249. cam size
  250. Head porters I have a question.....
