View Full Version : Generation III Internal Engine
  1. What cam with Stage 2 heads and stall to get me in 10's?
  2. Guide for ring gap ???
  3. What is the correct configuration CAM SENSOR FOR LS2
  4. where can i find a t rex cam?
  5. what cam for emissions and power?
  6. saving up for engine
  7. LS1 lifter the same found in other motors?
  8. headgaskets, advantage??
  9. I just got my pistons and rods...is this right???
  10. 5.3 pistons
  11. Where to get aluminum u-bends: 4" vendors
  12. gto to t/a - camaro
  13. 4 Tech Questions
  14. car wont start after cam installl
  15. Any special prep work needed when installing 3.9" crank?
  16. LPE GT2-3 cam card
  17. Block work...How much
  18. Why use a reverse split Cam?
  19. oil consumption
  20. valve-train power gains?
  21. PInging??
  22. Another Cam Question For The Newb
  23. How much did you pay for your rebuild? (labor only)
  24. LS1 newbee question
  25. Lifters f'ed? could my cam be f'ed to?
  26. You have $10,000 to spend on a longblock...
  27. What All Do I Need For A 383 Stroker? (budget383)
  28. Head Gasket question for 6.0l Head
  29. what cam on stock manifolds
  30. Holes in solid lifters
  31. will i need stock lenght pushrods
  32. WOT noise, How bad is it?
  33. Cam swap for a 5.3 truck?
  34. thinking about a cam...have some questions
  35. Oil Pressure Saga
  36. Best heads for torquer 2 cam
  37. 11.1CR w/ 44 Quench VS 38 Quench?
  38. fm14 cam on a ?????
  39. Horse Power estimate needed, smart people apply
  40. Dynatech headers with LS6 heads
  41. how much $ for heads and cam installed
  42. Forged 370 for torque and boost
  43. cam
  44. help with setup decision!!!
  45. NE1 using the Lokar ED-5008 LS1 Oil Dipstick?
  46. Best for Custom Grind Cam???
  47. Install Cam bearings
  48. where can i get inconel valves?
  49. how much $ do i need?
  50. highest lift with PRC St 2.5 ?
  51. Lifter stuck in block. HELP!
  52. mti z1 cam ?
  53. Octane ans rpm
  54. 383 or 408????????
  55. Intermittent tapping / ticking.
  56. ARP head bolts reusable?
  57. Trickflow vs AFR on 3.90 bore flow numbers
  58. A Few Build ?'s
  59. Quench deck....
  60. Help me out on engine build-up?
  61. Cam and rocker install questions
  62. Installing G5X3 on 114
  63. Building a Motor need some advice
  64. LS7 cam in ls1??
  65. oil question
  66. Need help with heads, what to get!!!!!
  67. cam assistance
  68. Solid Roller and Lunati Lifters
  69. Reading a Valve Spring Height Micrometer
  70. 6L block guys, what year is my block....have all # listed, please help
  71. Whats the Record
  72. Oil for startup
  73. car stalls out...
  74. HELP !!!! broken head bolt
  75. should i still run ngk tr6 plugs?
  76. Cam bearings
  77. average life of CC 918s@ .58-ish lift?
  78. Rear engine cover part number please
  79. Will shaft mount rockers gain power
  80. recommends on a non daily driver heads and cam
  81. CLEVITE 77 rod bearing PROBLEM!!!!
  82. magic stick and patriot ls6 stage 3's
  83. Tr224 Vs Comp Xe-r 224
  84. What To expect "New Cam"
  85. What ca mcould this car have?
  86. Pics/Info: Edelbrocks new Heads/Intakes SEMA 05
  87. Warhawk Alum Race Block Pictures - SEMA 05
  88. SEMA 05 - 500 cube LS2 Shortblock Unveiled
  89. what are the SLP options?
  90. What exactly is bad about 99 oil pumps?
  91. cam and no2 questions!!
  92. ET Phone home...
  93. Engine Diagrams
  94. no oil pressure HELP new block
  95. SEMA Picts
  96. LS6 Valley cover
  97. Anyone Running A226 230 112lsa Cam??
  98. ls1 carbon fiber intake manifold
  99. question please on retainers
  100. Patriot 232/230 cam...just received..
  101. finishing heads/cam install--need help ID'ing a few things to connect
  102. GMPP Heads
  103. cam instalation help
  104. Question
  105. Question about pushrod length
  106. TTY bolts
  107. valve clearance??
  108. will it work
  109. Help me decide: Return failed mailorder shortblock or fix it myself?
  110. LS2 Heads on LS1 block
  111. Installing CAM (TR224/224 112) Do I need titanium retainers & double valve springs?
  112. GMPP LS-6 heads and a LPE GT2-3 cam
  113. 800 RWHP goal??
  114. Best springs for an fm13?
  115. My new setup
  116. Oil pump change w/o dropping the pan?
  117. who is running 5w40 amsoil
  118. Need a cam for stalled A4, perfect DD, track numbers important
  119. 580 Lift
  120. pretty nasty tick....
  121. Who's car is this on LS1Sounds?
  122. Anyone know where to pick up Single REV valve?
  123. ls6 oil pump and timing chain question
  124. Oil Pan help!!!
  125. valve spring height question
  126. Thicker Head Gasket, Lower Compression?
  127. What cam to go with ?
  128. another what would you do thread but please look
  129. Hotcam not good for F/I?
  130. Cam Selection
  131. A Look at Oil Consumption vs Driver Habits
  132. change oil light on?
  133. best lifters and rockers?
  134. Which heads to chose?
  135. Spark plug not threading
  136. Check Engine Light?
  137. 7K RPM, Harlan Sharp, Yella Terra, or stock?
  138. DD with a TSP 233/239 Cam?
  139. How much power would you guess?
  140. which heads with my 231/231?
  141. Found out why my motor developed..
  142. need opinions on cam...
  143. Best T/C to install during a cam change.
  144. LS1 vs. LS6
  145. Next Mod, Heads Or Rear End?
  146. Valve float
  147. Good DD blower cam?
  148. Good TSP Cam
  149. F15 Ron Jeremy Cam will it work with my combo? **I Searched**
  150. how well will this combination work for me?....408,...
  151. Domed Pistons
  152. Idle?
  153. Forged Pistons and KR
  154. Strongest, best designed pistons for 15+ psi?
  155. stroked guys please help........
  156. Clanking Noise After WOT??????!
  157. H/C install, Codes and valvetrain noise
  158. cams install
  159. TR236 on stalled A4?
  160. Part # For Arp Stud Kit For 2004 Z06
  161. Choosing a Cam?
  162. TR224/224-114 Cam with little else.
  163. Cam for 400 rwtq on stock heads?
  164. how can i tell if i have a bad valve seal?
  165. MTI Z1 Cam Package?
  166. one dirty spark plug
  167. Noob questions :)
  168. Help Needed Asap!
  169. Please explain this card to me
  170. Need Help With A Q on My Engine!
  171. 00 Zcamaro goverd??
  172. 224 and NOS?
  173. Just replaced valve seals, replaced plugs and saw this..
  174. Recommended 5.7 heads......and a good cam to go with?
  175. cam
  176. Torquer 2 on a 112+2 or 114
  177. ** ETP 215 Dyno Results - 498/467 **
  178. ticking after head install
  179. Engine Stumble & Backfire At 4000rpm
  180. please help to spec a new cam
  181. dual roller?
  182. Best price for a C5R block?
  183. part # for felpro, intake manifold gaskets
  184. Who sells hell fire rings?
  185. H/C -Problem?
  186. F13 vs. F14
  187. Newbie Question
  188. Tips on cutting SS hose
  189. Joe Overton "T-Rex Killer"
  190. No oil pressure at guage...
  191. heads for a 402 0r 408? cam?
  192. What will my compression be (estimated)
  193. pull key wait 10 sec. after K harness install
  194. GTO Cam Specs/Suggestions??
  195. Who in here has a 408 stroker?
  196. Low Oil Pressure
  197. Neep Help!
  198. Does a truly "Stealth" cam exist?
  199. senario question: what if it still happens after install?
  200. Too much oil?
  201. JAZ Mini Breather Tank (catch can)
  202. What gaskets do I need for H/C install?
  203. Will ls6 cam fit stock ls1?
  204. Intake valve flow comparison? 2.08 vs. 2.055
  205. timing chain dampner LS1
  206. Changing pan types - Oil pickup tube?
  207. Manley Rods anyone???
  208. Pic of Burned Piston - Why??
  209. Will this work...
  210. barbell restrictor?
  211. Latest List of Aftermarket LSx Heads
  212. Looking for cam card pics, and dyno sheets.....
  213. Tr 224/224 114?
  214. A few custom cam profiles I'm thinking about...opinions?
  215. quite cams
  216. cam only HP numbers
  217. Heads/cam swap question
  218. Is there a better H/C setup out there?
  219. replacing rods bolt and main bolts
  220. Dart heads on ebay?
  221. Some help please!!!
  222. what do you guys think?
  223. Header Torque Ratio's (please help, must install on Friday!)
  224. TR 224 Experiance:
  225. Engine Drop Mods
  226. Valley Cover with breather....
  227. HP difference between LSA
  228. More engine parts...56k beware
  229. top dead center question
  230. Why is my car idling up to speed when it's in gear?
  231. crank bolt LorR
  232. Anyone have an educated guess?
  233. Scat crank and rods?
  234. Anyone else have this problem?
  235. dual timing chain help
  236. Titanium retainers
  237. best stock cam?
  238. Best way to achieve ~550rwhp NA
  239. Looking for bore thickness (ls6 / ls1)
  240. Thinking of changing cam already
  241. Simple oil question here
  242. Deciding factor(s) between LS6/243 & 5.3L heads?
  243. engine sounds smoother after the timing chain
  244. What Mods For...
  245. NE1 Have Problems with Comp R lifters?
  246. Matching cam to heads.
  247. how does this set up sound
  248. Which Lunati Cam?
  249. cam help
  250. Lifter Tick?
