- power with this cam and these heads??
- Help! About to install 921's
- Swapping heads, cam...pushrod length question
- Can someone please help!!!!!!
- LS6 intake, cam, and heads.?
- 383 Questions...........
- TSP motors whos got one
- Ported TB vs. Vararam Velocity Stack
- Differnce in TB sensors ?
- 500 Cid Ls1
- Gains with Heads?
- Forged Rods vs. Stock?
- Trans AM w/ Borla Exhaust *VID*
- Comp Shaft Mount Rockers
- misfire under load/bad gas mileage?
- To anyone running the t-rex camshaft
- Bottom End Knocking... What Next???
- Looking for Cam Doctor for '01-'02 Stock Cam
- Compression ratio ?
- Cold Start
- anybody ever hear about?
- Do I Need Lunati Pushrods?
- any difference in GMPP and LS6 wires?
- ls1 to 6.0 crank
- How did get your H/C in there?
- Opinions please
- LQ9's on a Stock 2001 LS1
- RPM redline for my combo.
- springs
- Rollmaster double roller
- i heard word about a 500ci lsx:)
- Getting an N/A 370 into the 10's?
- What springs on afr's?
- Help with C/R
- Cam?? g5x3
- friends piston slap....
- AFR 205s enough for 7k+RPM 383?
- ?'s about 383 stroker LS1 help needed
- Heads on backwards?
- s-cam ?'s
- Shipping on a shortblock...
- Lower Price on The Original Patriot Gold Springs
- About the extra tube when removing A.I.R.
- Stock LS1 Shim
- Oil pump debacle
- lifter oil holes ?
- 383 LT1 vs 383 Ls1 ?
- If you are running stock lifters and high spring loads, please step in
- comp 228 236 588 578 114 help
- Anyone using over 4.00" stroke cranks???
- Patriot 226/226 camshaft...couple quick questions...
- Afr 225 Small Chamber
- T-Rex
- Ticking
- Need Mod advice fora Newbie
- Vented GM Oil Cap...?
- 04 Gto Ls1/6?
- installing a LS6 oil pump
- Piston rock and deck height (Mahle forged)
- WTF is with these head gaskets?
- Edelbrock LS1 CNC Cylinder Heads
- Do I need new pushrods with a new cam?
- Cam Bearing Clearance ? Motor needs help!
- Where to buy new lifters?
- loud tic from engine!!
- Perimiter bolt heads for 02 SS?
- Gains to expect
- Head differential?
- Comp "R" coming apart?
- anyone with a g5x4 cam m6 or a4 come in.
- Weird oil pressure
- about to install tr224.....
- oil still leaking from bell housing after replacing main seal
- Help!!!how The Hell Do I Reuse These Cometics?
- cam?
- engine rebuild, avoid piston slap
- What's the better blower cam?
- problem after installing ported throttle body
- What transmission cooler to use?
- Where to get ARP heads stud kit for best price?
- Performance mods on high mileage cars
- oil pump.
- Bleeding comp. on FI engines
- lingenfelter gt2-3 cam??????
- Is this cam too big!
- can i put a 98 camaro engine into my c5 if i...
- tools to mildly touch up heads
- TB coolant bypass ?
- LS6 Lightweight Valve Wear Issue???
- Specs on LS1 stock cam?
- 243 heads and springs
- MS3 Daily drivable?
- installing LS6 intake and ported TB
- head gasket???
- ls1 - bad ticking
- 2001 Stock Heads Adequate For Comp 212/218 .522/.529 Cam
- 97 - 98 Block Boring & Honing Limits
- Torquer 2 cam vid
- New Crate 6.0, NO oil pressure.
- Problem since I put the LQ4 in.
- ls1 cam and heads package
- GM Performance LS1/LS6 upgrade
- cams and emmissions how big can i go?
- very sad day.....
- Biggest Cam
- ARP head bolts vs GM head bolts
- Oil dripping from head bolts????
- Vinci 062 cam
- So what you think would cause this to happen?
- New Engine Now Hear Click Click (Valvetrain noise VIDEO!!)
- H/C with 2.73 gears?
- FM13 or FM14
- Gear drive for LS1?
- PN? for unlisted
- LS1-LS2 CHAIN many Pn`s
- cam choice
- Installing H/C motor????
- differences between these 2 cams
- Dart Heads...Lots of questions please>>
- Would you use this cam-pics inside
- head porting
- What # To Expect W/ Head/cam Swap?
- 5.3 Max overbore.......
- 3 quarts of oil in 2500 miles
- are these DOTS lined up...need HELP fast!!!
- Porous Block, can it get worse?
- HElP ASAP!!!
- Ssr?
- how much is enough?
- Diagnostic help.. Plugs pulled.. not good
- Can anyone help with a shut off problem?
- Cam?
- LS7 Exhaust Rockers
- Prices for machine work.
- can you check for bent valves this way?
- Is this a bad lobe?
- Timing chain..
- will this get me 450 rwhp?
- Can you reuse cometic gaskets?
- Please help a Newbie Build His LS1-Truck 6.0
- 1st Look Brand new TrickFlow LS-1 Head
- ? How to apply SEAFOAM ?
- TSP magic stick 3
- Help me build my LS1!!
- Disappointed with German Castrol (gold)
- god hates me, need cam advice!
- rwhp record stock bottom end
- Headgaskets? 97-01 style or 02+ style?
- What power will the LS6 cam make me?
- OIl pressure
- is it safe to use AR472 on LS1
- Diamond 11 degree pistons
- Rev'ing then Ticking.....
- Cam question
- Does LS1 300 hp equal to LT1 300hp?
- Question about big hp with only cam added?
- How to measure rod bolt stretch
- Thinking about doing a stroker
- What to expect wih this cam??
- Heads/cam mods and fuel economy.
- cheatercam
- P0341 - CMP sensor performance
- desensitizing knock sensors
- 98 motor with 52 k miles ?
- fear of wrong ARP studs.
- double "nutting" on ARP studs
- Tightening the hex-nut on adj.rockers...
- Pulling valve covers...
- Ready for Cam install, Now I am having second thoughts on my stick.
- Need help on CR and piston choice
- lift on stock springs????
- buying pushrods
- Key upgrades?
- Key upgrades?
- Patriot Gold Spring Installed Height ???
- why would someone sell a 2002 anv trans am for $6200 with only 44k miles?
- What do you think about this setup??
- couple of questions
- Cam help please
- Bad Compression or Seals.......or am i just paranoid?
- 98 Model year LS1 vs. other years
- this a good deal for rods and pistons?
- Will LS1 parts work in bored 5.3?
- Compression lost- how much HP does it cost?
- should I change my valve springs???
- Cam only autos...
- Advance question for the cam gurus, specs included
- Part number 25318411 for which maf??
- It is finished:
- short deck
- over heating ! ? help !
- Windage tray wont fit
- What are the stock head #'s ?
- f13 w/ 5.3
- what bore for aftermarket pistons?
- stock `98 head gaskets
- Magic Stick v.3 ("MS3") Camshaft
- Head CC chart
- off car valvespring swap
- Complete Edelbrock CNC ported heads $1149.95 ea. @SDPC
- cam bushing with new cam?
- oil pump costs??
- 2nd time around...setting up dowl pins for Katech Main Caps
- Head Install Questions
- How many rpms with new Cam?
- Anyone bought this 402
- ET Performance 11 degree heads, any dyno numbers?
- 5.7 vs. 6.0l crankshaft?????
- Help me get my shopping list together
- major problem
- Which AFR heads to use
- Need help...new to LS1's...oil in intake and black suit in heads???
- Jesel Sportsman Series SS shaftmounts??
- oil pressure frustration
- broke down
- Bullet cams?
- jrp can you help me plz
- running race gas N/A..ie- c114
- Patriots with F14
- My exhaust valve hitting piston!
- Exhaust Port on Heads
- gas mileage
- combo idea's, inside if interested
- Looking at getting a new Cam. I'm a n00b and need help
- New forum for Advanced Topics!
- Amsoil > *
- used cam, need opinions
- 427??
- Matching cylinder bore to combustion chamber bore...
- 98z cam swap for 02 z06...any gains?
- '98-'00 SS had LS1 intake manifold, '01-'02 had LS6 ?
- MPG with Cheatr Cam
- Quest to over 460 rwhp, Pretty close, what else?
- cookie cutter or build myself
- Jesel + Morel solid, pushrod length
- Comp "R" Lifters
- cam swap ????'s
- Cracked the Crankbolt Inside the crank.
- rattling sound?
- 00 cam swap for 02 cam
- Help Please Question bout buying cams
- sound clip of a comp224
- Which roller rockers?
- Engine Advise?
- Well I really did it this time! Stripped cyl 1 header bolt
- how much will it cost.....
- Switching back to dino oil?
- deck height
- Is there stock air injection 98' Z28?
- Valve Cleaning Tricks
