View Full Version : Generation III Internal Engine
  1. Looking at getting a new Cam. I'm a n00b and need help
  2. New forum for Advanced Topics!
  3. Amsoil > *
  4. used cam, need opinions
  5. 427??
  6. Matching cylinder bore to combustion chamber bore...
  7. 98z cam swap for 02 z06...any gains?
  8. '98-'00 SS had LS1 intake manifold, '01-'02 had LS6 ?
  9. MPG with Cheatr Cam
  10. Quest to over 460 rwhp, Pretty close, what else?
  11. cookie cutter or build myself
  12. Jesel + Morel solid, pushrod length
  13. Comp "R" Lifters
  14. cam swap ????'s
  15. Cracked the Crankbolt Inside the crank.
  16. rattling sound?
  17. 00 cam swap for 02 cam
  18. Help Please Question bout buying cams
  19. sound clip of a comp224
  20. Which roller rockers?
  21. Engine Advise?
  22. Well I really did it this time! Stripped cyl 1 header bolt
  23. how much will it cost.....
  24. Switching back to dino oil?
  25. deck height
  26. Is there stock air injection 98' Z28?
  27. Valve Cleaning Tricks
  28. Please Help With Stock 01 Cam Specs
  29. TSP Magic Stick
  30. Heres the combo I came up with, whatcha think?
  31. Valve size question
  32. progress!!!
  33. AFR 205s + Thunder TRak Cam = 487rwhp/436rwtq
  34. Valve Cleaning Tricks
  35. Qtp Hv Oil Pump
  36. Added cam and lost peak torque?
  37. Cam on the way! Questions.....
  38. Good engine building book.....
  39. Which heads? Which cam?
  40. Engine Identification help
  41. Who has a 402
  42. cam with no headers?
  43. Z06 heads on my LS1
  44. Milling vs. thinnner gasket
  45. stock crank or eagle?
  46. Is this cam big enough?
  47. if im changing lifters what else should i look at and change?
  48. Who has the F11 on a Stock Headed Car?
  49. F14 install? Question on degree!
  50. here's my setup
  51. 232'' 234'' .599'' .601'' 112+2 Questions Help Please
  52. ls-1 ls-6 whats the numbers?
  53. Cam Size Question and Motor Question???
  54. Comp Custom Grind Cam???
  55. LS6 Heads / Cam on a LS1
  56. Futural Cam
  57. LS1 doesn't want to stay running
  58. Which head gasket to use
  59. how much $$$ to mill heads
  60. piston to valve clearance and head gasket?
  61. 427 C5R tt....pics inside
  62. noise on decel / low rpm
  63. Morel/Lunati Lifters
  64. Futral ?
  65. Zo6 heads on stock 5.3L a factory option?
  66. Lets see those Vette Doctors numbers
  67. APE sore subject
  68. Cam and spring?
  69. cam price / requirement ?'s
  70. help
  71. Hey, Name that cam....
  72. taking off the heads
  73. Oil Pump #
  74. 6.0 Stroker Kit
  75. Dex-cool coolant causing damage to engine?
  76. Head bolts for LQ9
  77. Want to goto 1/2" Head studs, how much cost/method?
  78. cam for my 408 build
  79. Anyine know what cam is in the Nickey Camaro?
  80. Who makes the best custom cams?
  81. Best heads for Z06 block
  82. Heads and Cam install ?
  83. Cam for me?
  84. at what point should you go forged internals?
  85. 97 corvette need some help
  86. How often should I change my oil on a weekend warrior?
  87. Will this setup work?
  88. Engine coatings...
  89. Patriot Shaftmounts???
  90. 8.1 Wiring ??
  91. Another which cam thread
  92. how much should i mill to 11.0?
  93. rocker arm hitting head?
  94. misfires when slamming 2nd gear cyl#4 cly#5
  95. can you reuse
  96. cam selections.
  97. dual spring question..
  98. prime the oil system
  99. Cleaning O2 sims
  100. 402 people inside
  101. Valve Spring Life
  102. crank question...
  103. LS2 Timing Chain identification/ dimensions
  104. How long did you wait before rumping on your car after a cam swap?
  105. XR281HR Comp Cam....
  106. 00' oil consumers?
  107. New parts now low oil pressure
  108. Cam
  109. crane 832 and trex
  110. stock displacement rebuild w/ h/c swap
  111. valvetrain noise
  112. timing chain
  113. FM-11 CAM and Valvespring question
  114. PRC 2.5 flowsheet
  115. G2 G5x2 Vs Magic stick MS3
  116. Good stock replacement lifter
  117. Over 1/2" slack in SLP double roller chain ok?
  118. magic number of 400 ft-lbs??
  119. Cam ??'s
  120. new short block
  121. what stage ls6 heads for this cam. inside you guru's
  122. A few questions about the FM F13 cam.
  123. Now whats the Problem?!?!?!
  124. solid roller???
  125. Studs - VS - Bolts
  126. Any issues w/ Vinci tool and AFR225s or PP golds?
  127. 5.3 Pistons
  128. Comp. ratio consufion..
  129. PRC 6.0 stage 3 head ?
  130. Causes of oil pump failures?
  131. dart VS patriot
  132. NEW lingenfelter 346 Break In & when can I spray Nitrous?
  133. how much power on stock alum. block
  134. 450rwhp?
  135. Cam Question
  136. problem with timing
  137. How Much are...
  138. How do you guys break in your motors?
  139. Heads + CheaTR cam vs Heads+custom grind cam
  140. 370 vs 408 PLEASE ONLY READ IF YOU KNOW WHAT YOUR TALKING ABOUT.
  141. Should I build or do a PA
  142. MISS FIRES AT idel
  143. Another adjusting the rocker arms question
  144. Anyone built the 8.1 truck engine?
  145. Cam specific questions
  146. Thinking about the T-rex.....
  147. what now?
  148. Cylinder timing question
  149. State Inspection ROAR and FLUIDS! imput please
  150. TR 224 112 LSA sound clips?
  151. Need some answers verified
  152. Best heads for torquer 2 cam??
  153. torquer 2 cam sounds inside
  154. TR227 + Tea 5.3 stage 1.5?
  155. Billet timing cover pics
  156. Head/cam package for LQ4 6.0L-Help!
  157. Patriot Heads with stock Cam
  158. Question about head bolts.
  159. XER 224 cam LS6 heads and Headers only 378 rwhp WTF????
  160. Serious problems...car will barely run
  161. how do you determine lobe base circle?
  162. f13 vs. g5x2 and maybe tr224
  163. Oil gallery plugs...installing
  164. Rear main seal.. Trick to get t on?
  165. 224
  166. help me diagnose a problem? (oil pres./bearing?) $#!+
  167. 01 LS1 1500RPM vibration??
  168. y-pipe glowing red after cam swap
  169. Begun the Head/Cam swap......a few pics
  170. cam ?'s
  171. TR6's or TR7's Help me!
  172. How do you know if its piston slap?
  173. How much power will i gain from these heads?
  174. New Thunder Racing TRak Cam?
  175. Head/Cam usage for a shorty header?
  176. car didn't want to start right away
  177. Does valvesprings really make that much of a difference?
  178. LS1 Question.
  179. PP Stage 2 6.0L LS6 heads vs stock OEM LS6 heads?
  180. PRC Stage 2.5 5.3 or Patriot LS6 Style Heads???
  181. G5X2 in a 370?
  182. AFR 63cc PR Length?
  183. Cam Opinion
  184. large combustion chamber heads for FI?
  185. Oil on Plugs...
  186. LSK Lobes: Are they making more power?
  187. Comp ratio?
  188. pushrod ? for Patriot head/cam 8402
  189. Comparing heads - Need Some Help
  190. P0305 broken valve spring?
  191. Guys with F13/F14, what heads are you using?
  192. how to tell if...
  193. Crane 832 shims
  194. Installed torquer 2c cam past weekend VID!!!!
  195. MS3 Guys w/ Aftermarket Heads Step Inside
  196. Torquer II is in!
  197. Free LS6 heads from an '04 GTO...Worth the swap?
  198. low oil pressure in 436 solid roller
  199. TEA Stage 3 6.0 heads. Local flow numbers
  200. Biggest cam for a stock motor??
  201. Need Help with combination
  202. Where to get the longer crank bolt for pully install?
  203. What all does the car do in fail safe mode?
  204. Crankshafts & head gaskets
  205. Rain IN the engine?!
  206. Anyone have 4.030 Cometic head gaskets in stock?
  207. What Cam Are you Running with Patriot Stage II Heads?
  208. connecting rods
  209. Cheater vs other stock sounding cams.
  210. Cylinder missfire question
  211. ls6 built put in a 4th gen possible?
  212. G5x4 Cam
  213. R&R left cyl head C5
  214. Texas Race = might be cancelled soon...
  215. trying to pick a cam and having a hard time...
  216. a bit of concern
  217. power problem?
  218. LS1 to LS6
  219. high revs, shorter engine life?
  220. Potential new owner, very curious about potential E.T.
  221. Oil pressure issue
  222. Sputtering under WOT
  223. Stroker block change?!?
  224. Stealth setup options: LT's+cam vs H/C+stock exhaust
  225. 408 Head choice
  226. keep breaking the same spring...any ideas?
  227. HELP PLEASE....engine making bad noise after cam
  228. What's that noise....!!!!!
  229. PRC LS6 heads?
  230. Gas ports
  231. looking for a new cam
  232. what kind o Rwhp to expect.
  233. Advanced Indepth Trex Cam Questions
  234. 224/224 vs. 224/228?
  235. Engine Temp?
  236. B1 cam 385rwhp?
  237. Tr220
  238. LQ9 users, does the bottom end hold together well?
  239. New motor, TCS wont work???
  240. cam install: might have nicked a cam bearing? help pls
  241. specs
  242. reverse lock out
  243. Custom tune.....
  244. 208/214 high lift cam
  245. Oil Pressure
  246. 402 & BIGGER owners inside please (simple head question)
  247. Question about main caps
  248. How strong is the ls2 block?
  249. Catch can, how does it work with nothing inside?
  250. Buying Used Longblock
