View Full Version : Generation III Internal Engine
  1. Could this be?? Help Me
  2. DAPSUPRSLO Inside Please!!
  3. cam finally done!
  4. Help!!!! Stock LS1 hydrolic lifters?????
  5. How to remove the oil filler cap from valve cover?
  6. Oil pump pick up tube?
  7. difference in power levels....
  8. Does anyone make a graphite head
  9. hyd cam on solid lifter
  10. Please Help Asap
  11. Stock LS1(for now)..help me with a game plan !!
  12. Blew head gasket?? Why? Pictures inside
  13. Anyone use the 3.9" stroke Eagle forged crank?
  14. Oil all over the top of engine!! Help!
  15. Whats The Best Bang For Your Buck?
  16. Oil addictives
  17. New timming chain install.
  18. Cams dissected...
  19. cam question
  20. looking towards the trex...but still some questions
  21. GM Valve Spring Shim Size 99-01???
  22. new cap bearings, new block....loose!!!!
  23. Who makes the best spring pressure testing Tool?
  24. Innovate Wide Band With Gauge --- $249!!!!!
  25. Oil Sprayers in Valve Covers, to use or not to use?
  26. whats my rwhp 408CI 244/248-613/615-112
  27. Valve Spring- How often to do I change???
  28. prc valve seals????
  29. Eagle crank w/ pilot bearing problems HELP
  30. Patriot Gold Dual spring pressures?
  31. So what makes it an LS1...
  32. would it be safe to say
  33. Critique my combo please
  34. Anyone have the GM Part Number for the LS6 Oil Pump
  35. how can I tell if cam is too big?
  36. ET Performance LS1 265 heads......anyone have them?
  37. Guys that Copper sprayed Cometics......
  38. LG4 vs LS6 heads
  39. Cam question
  40. Quick Simple Question
  41. Why did my Jesel's do this?
  42. requesting pics of the vertical pcv mod
  43. solid roller motor questions
  44. solid roller lifters
  45. Cam questions
  46. oil pump numbers
  47. should i go back to regular oil
  48. best street use cam?? NO track
  49. Which cam do I need
  50. ? about LS2 timing chain
  51. custom piston options for 13/1 346?
  52. a bit confused about valve lash...
  53. oil compression
  54. How big a cam can I go?
  55. my custom pistons are finally in!!!!!!!
  56. 918's or not?
  57. oil pressure problem/I have NONE
  58. Cam research still Questions....
  59. cammed car losing to a non cammed?
  60. LS1 Engine, adding LS6 heads... gasket options?
  61. camshaft on stock heads !?
  62. LS2 Timing chain only vs. set
  63. MTI Stealth 2 cam?
  64. Bad water-related misfire need ideas please..
  65. Proper lifter preload?
  66. Loud Ticking When Start And Run
  67. AFR 224/228 Cam Installed
  68. cam question for 98 trans am
  69. zl 402 block
  70. cam questions
  71. Changin injectors in 6.0, need help
  72. difference in z06 valve spring colors...
  73. Opinions on this bumpstick
  74. Ls1 knock
  75. Anyone use Snap on Balancer installer?
  76. about to buy a 408 Where to buy from?
  77. 6 litre stroker kit
  78. what cam to run with 150 shot
  79. Engine Noise!! Help
  80. What are some big #'s for cam only cars?
  81. valve spring questions?
  82. Hey Mamo. . .I see you. . . ..
  83. Help on Checking Pushrods or other valvetrain parts
  84. Rocker Arm Round-up
  85. Will I need to upgrade my fuel system for an F13?
  86. New Block and Heads from World Products !!!
  87. question about 383
  88. Pleas Help!
  89. What temp/gap plug for 12:1 CR?
  90. After tearing into my 422 this is what we found
  91. any downsides to offset ground cranks?
  92. how should i raise my compression?
  93. Precision Race Components 1.5S Head Now Available!
  94. extrude honing heads?
  95. Cam numbers not jiving
  96. Stock lifter limits
  97. Burning oil on decel after rebuild
  98. LS2 Questions
  99. HP Gains
  100. Got it back after MS3 install!!
  101. Thunder Racing CheaTR package??
  102. Who's running a 106lsa cam? Need info
  103. Cam install
  104. California Smog Legal Blower Cam idea...
  105. Katech Main Caps
  106. Roller Rockers
  107. Are the cam install kits all the same?
  108. what all needed for cam only install?
  109. stock trans cooler in radiator plugged, need new radiator?
  110. need some help
  111. Good parts suppliers?
  112. block for 700hp ls1?
  113. LQ9 heads on a 5.3L
  114. engine sounds like a diesel untill full opersting temp.
  115. 402 LS1 & AFR 205 ?
  116. R1 vs. Y1 cam poll
  117. DYNO Black Smoke out exhaust when let off gas after WOT
  118. Dumb question: What does it mean when heads are sold "bare?"
  119. Best Stealth or small(ish) cam for 01 Z06?
  120. resizing rods
  121. getting a 224/228, pulley & ported TB, questions??
  122. Help!!! I swap intakes and get 0 oil pressure!!
  123. PRC Heads What Cam?
  124. AFR 205cc HEADS VS Patriot Stage 2 & 3 Heads
  125. New Cam/Header Dyno #'s Today
  126. Head work/Bo White?
  127. Main Cap removal
  128. Oil pump issue
  129. What heads and Cam should i get?
  130. dart ls1 heads
  131. Will the truck intake work on the LS1 5.7L heads?
  132. Heads came in yesterday, a few pics
  133. should i raise my rev limiter while i can?
  134. ? about Comp-R's
  135. Can you build a 427 w/out sleeving?
  136. GTO more prone to heat soak,TR55 ot TR6?
  137. Adjustable Harland Sharp 1.7's
  138. long blocks!!!!
  139. 3rd gen LS1 swap
  140. what gains to expect...
  141. H/C install, no tune, runs great
  142. Pushrods
  143. Anyone using NGK Iidium IX
  144. Help hissing noise in throttle body
  145. has anyone used this to clean bolt holes??
  146. what can we expect?
  147. comp cam stealth 2 *need advice*
  148. 400 RWHP LS1 w/o heads & cam?
  149. When you built your motor what were your goals?
  150. few questions on building up my motor
  151. ? About valve springs?
  152. whats the best cam for TEA 2.5 heads
  153. Valve Springs?
  154. A quick question?
  155. dart head gurus inside!
  156. T-rex and Patriot LS6 stg. III heads
  157. Head porting -
  158. Some irritating things going on!
  159. Pistons To Coat or Not To Coat
  160. Morel Lifters/Performance Information?
  161. lq9 vs ls1?
  162. Reliable daily-driveable 402/408?
  163. Push rod length with Trex?
  164. help :'(
  165. Help ticking noise
  166. p0300 missfire
  167. What do heads do to drivability?
  168. oil coming out of the exhaust tips?
  169. Ls1 with cam only E.T. question?
  170. How to prelube LSX engines
  171. 4.185 bore forged pistons
  172. Do I have the right head gasket?
  173. Assembly lube which one?
  174. F12 cam installed!
  175. Can I reuse fuel injector o-rings?
  176. Quick Alternator pully install question
  177. Help: what are these?
  178. Head flows and Power ?
  179. bogging at 2500 rpm's
  180. What gap for 11.6+ compression?
  181. Is The Plug On The Back Of The Ls6 Intake The Same On Ls1?
  182. Lifter Trays????
  183. Help with holding lifters up during cam install please?
  184. Who has used ARP head BOLTS?
  185. Head gaskets
  186. Accusump needed?
  187. AFR 205's question
  188. is there a problem????
  189. Heads Info
  190. what gains going with stock 243's?
  191. Cam newbie...need help picking out a cam...
  192. heads and cam only gave 8 rwhp wtf
  193. Quick - Name That Lifter
  194. Need Some Help?????
  195. Power falling off above 5400 rpms
  196. F13 owner's come in
  197. Stealth II Cam - Not too good
  198. quick misfire tech help please...
  199. Do i need a rebuild? *PICS*
  200. Ordering 1 push rod
  201. ARP Mains.....Windage Tray.....nut size?
  202. anybody got a part# for this fitting
  203. Another ticking sound question
  204. How much can stock crank and block take??
  205. What kind of oil filters do you run?
  206. Anyone broke 918's with F-13 or similar cam?
  207. Rocker Arm side to side movement
  208. tune before cam
  209. Eagle Crank Shaft... Knife-Edging or Lightening?
  210. head/cam install
  211. Anybody w/ an F13 113+4?
  212. 5.3L in a '99 Camaro???
  213. head\cam vs. FI
  214. what do I do with...?
  215. Max Rev Limit ?
  216. H/C driveability.....no problem!!
  217. ARP Head Bolts????
  218. these are signs of? (blown head gasket?)
  219. is there a how to on changing valvesprings with heads in car?
  220. Experienced Machiners Needed: Typical crankshaft balance requirements?
  221. Plugs/Wires/Coil?
  222. Crankshaft ?????
  223. Which Cam to use
  224. Arp Molly-Lube
  225. Can I reuse the gasket under the valley cover?
  226. 6.0L Motor?
  227. CAM for my set up?
  228. Did i break a rod or spin a bearing?
  229. Car won't start after H/C swap!! :(
  230. Can a LS6 make 425 RWHP with the stock cam?
  231. Bent push rod also means bent valve?
  232. Who Makes Lightest Haydraulic Roller Lifters
  233. 408 build
  234. Help!! Just got motor running in RX7 but oil pressure is weird
  235. Low compression bad cylinder
  236. Check List
  237. Hesitation in my C5...
  238. getting a LS6 oil pump this weekend
  239. 408 question
  240. storing heads...
  241. still misfiring cont.... What to do now??
  242. Head&cam install
  243. Strange ticking noise, any ideas?
  244. T-rex cam
  245. Casting Numbers
  246. Critique my Flow numbers please
  247. more problems- need help!
  248. cam and fuel system for 408CI down under OZ
  249. Compression Help with 6.0 Heads
  250. p0134 o2 sensor no activity
