View Full Version : Generation III Internal Engine
  1. storing car??
  2. newbie question..
  3. Crank Sensor Wiring
  4. 408 stroker parts
  5. I just got the magic stick but
  6. oil change = louder valvetrain?
  7. Stock Engine Pinging @ 4K!!!
  8. cam kit choices...I need opinions MS3/G5X3/F14
  9. need help with a miss or something. PLEASE come in and help
  10. TR CheaTR cam hits 401/375 with stock heads!! 12.53@ 114 1.96
  11. spun bearing???opinons please!
  12. ARP--Head Bolts or Studs which is better?
  13. After replacing valve seals....
  14. Anybody in the Houston area have a set of rocker arms?
  15. HELP....metal shavings on oil drain plug!!
  16. How strong is the stock crank?
  17. symptoms of a collapsed lifter or bent valve?
  18. Initial results on cheaTR cam dyno
  19. do Patriot ls6 heads w/ 2.02 int 59cc chambers fit on 6.0L?
  20. A few questions about the 5.3L block...
  21. Crank clearance
  22. help ! easy question
  23. Comp LSK lobes... any info?
  24. Ls1 6.0L Iron block
  25. CP Pistons for LS1?
  26. Spinning crankshaft by hand on Vette
  27. patriot heads
  28. Trick Flow....
  29. PRC Stg 2.5 5.3l Heads?
  30. quick question about 6in. rods...
  31. Correct way to install rear main seal
  32. Mechanical Over Rev!?!
  33. 224/224 114 in 346ci = ? in 427ci Motor?
  34. 408 Shortblock what do i do to clean the rust?
  35. 42lb injectors ok for 402 NA
  36. JWIS Timing Chain
  37. Valve seals - using exhaust seal on intake
  38. More valve lift equal more power?
  39. opinion
  40. 106 Lsa?
  41. JE #3814F pistons????
  42. Valvespring locater???
  43. Fresh heads on high mileage engine
  44. Turn car off, engine sounds like crap when sutting off after cam??
  45. 224/228 144lSA??
  46. Oil change = leak? (newb)
  47. What would cause this smell ?
  48. Is my combination good or not
  49. good info on n20 cams...
  50. Crankshaft drawings and measurements
  51. Lifters?
  52. Installing forged rods after motor break-in.......
  53. stroke vs bore
  54. G5X3 and Patriot Heads
  55. Is it worth fixing ?
  56. slp 402 into a c5 z06
  57. Rods?
  58. about to order cam, does this all look right?
  59. Looking for a Kit.
  60. My Ls1 Eats 5w30 like she burns gas
  61. Need some head info please.
  62. callies crankshaft
  63. Hollow or solid cam?
  64. Any experience with Lunati cams..
  65. f13 owners come in. Got some questions.
  66. about to make a cam change and....
  67. which cam for more hp
  68. Main Bearings
  69. Jesel rockers and Patriot heads
  70. Should i run 0W-40 yr round??
  71. H/C on a 130,000 mile engine
  72. New Heads, But Which Cam/Valvetrain?
  73. Tuned F14 soundclips??
  74. Changing head gaskets with head studs?
  75. TR Cheater Cam Question
  76. proper way to clean rust of cam????
  77. LS1-->Z06 Conversion Questions???
  78. Are hardened pushrods necessary with h/c setup.
  79. What Rods and Crank for a Darton Sleeved 4.125" Block?
  80. CAm IDLE RPM
  81. Cam change....how much of a diff?
  82. Piston to Valve Issues on 402
  83. what might i have messed up if the cam dots...
  84. Power and TQ difference between TR224 & F11
  85. HELP, need a few pics and specs plz!
  86. Plugs for 11.2:1 compression
  87. LS6 Spring Color
  88. Oil pressure sendfing unit
  89. 408 stroker what lifters and head gasket size
  90. For those who want a dry sump and A/C
  91. Is this beautiful or what?
  92. what would happen if cometics were backwards?
  93. JWIS Timing Chain
  94. Just curious....cam for 9k rpm?
  95. AFR 205 or 225 for Forced induction??? HEY TONY
  96. New to cams. Can someone tell me if this cam will work good on my setup?
  97. can someone help me
  98. Waiting on heads?? Give us 2 days!!
  99. Brand new block down the drain?
  100. TSP cam arrived today...
  101. Installed Cometic .040 gaskets with AFR205, now leaking...
  102. opinions
  103. TDC w/ heads still on??
  104. F13 and emissions in TX
  105. Cam only
  106. Question on Top Dead Center?
  107. Knockoff Valve Spring Tool
  108. Name that sound!!! Need help!
  109. new forged motor
  110. Tr224, Tr230, F13
  111. Help with DCR
  112. More f13 cam sound clips?
  113. Cam Swap - Loctite Use
  114. Head Gaskets????? Need quick answer
  115. Where else can i get a custom cam cut?
  116. Is this engine worth it?
  117. What Shift Points and Rev Limiter For Cam?
  118. Patriot 232/230@.050,110lsa $279.50
  119. RR's ?
  120. Mix Parts or Kits- Stroker Assemblies
  121. Trex and 310cfm heads which headers?
  122. 98 LS1's?
  123. help with stall and cam issue
  124. What else w/HC swap on 85K-mile LS1?
  125. AFR 205's Comp Cam dyno results inside.
  126. Jessel vs Harland sharps??
  127. valvetrain geomtry ????
  128. Looking for L-19 head studs!
  129. LS6 heads on a stock LS1
  130. Anyone have flow numbers on their AllPro heads?
  131. 5.3 stroker question
  132. Oil preasure sensor
  133. so what kind of power will i be making
  134. 5.3 heads question
  135. want to put a 427 kit in my ls1 need help
  136. air pump hose unplugged
  137. double roller chain - squeeling fan belts?
  138. Texas Speed
  139. Testing Compression Ratio - Engine Complete
  140. What Cam For My Setup???
  141. Too many bad cam sensors - reluctor issue?
  142. Gettin Hot on the Highway
  143. filters
  144. Engine Bearing Explanation Needed...
  145. oil pressure
  146. which cam???
  147. Piston slap explaination by GM Engineer
  148. Anyone have a link to Comp Cams XE XER lobes
  149. Need help. car surging like almost
  150. ls1tech...i really need your help
  151. Air/fuel issues on Dyno after heads and intake install
  152. New Patriot Prices Now In Effect
  153. My self ported stock heads
  154. How does the intake manifold restrict head airflow?
  155. rebuilding an LS1 with good heads etc.
  156. What's the most anyone has made using an eagle 4" crank?
  157. Coolant leak after head/cam swap
  158. 4000 stall, Which cam?
  159. 4.8 liter heads
  160. TR224 and Comp Cams 1.85 compatability
  161. swapping cam wat to get
  162. Crankshaft streching???
  163. Started backfiring 1k after cam install-possible causes?
  164. Cam-Newbie Question
  165. Need a New Motor!!!!!
  166. new to this stuff, need some buying guides
  167. need some opnions
  168. Couple questions about new motor...
  169. car wont crank
  170. New Motor not starting...Ideas???
  171. CheaTR Cam & A4?
  172. Ls1 Head gaskets on backward?
  173. tr224/110
  174. Lining up timing dots help.....
  175. SLP Heads and Cam package
  176. Lifter retainers
  177. LS1 bolts
  178. Rear Cover seal/oil galley plug
  179. <<<BEST LS1 CAM PT.2>>>
  180. Buying an F13 Cam need help on head
  181. Help indentifying this cam
  182. (PIC)oil p/u difference bolt location, c5 vs. f-body
  183. K&N Oil Filter
  184. ls1 cam swap guide?
  185. Too late to ask but
  186. misfires on 2 cylinders after swap to stock cam
  187. HELP!!! oil everywhere!!!!
  188. why overlook asa cam?
  189. Is a 427ci. worth the extra $$$ over let's say a 402-LS2?
  190. HP limit for stock ls6 oil pump
  191. quick Intake/exhaust seal ?
  192. what are the best and highest hp handling rods on the market
  193. new cam in!
  194. how big is your A4 CAM???
  195. How to turn crank when degreeing cam...???
  196. Yet another oil pump question
  197. *****New FFHP Spring Tool*****
  198. If I buy the block and rotating assembly, can I put it together?
  199. Thinner or thicker oil
  200. Any numbers w/PP stg2 per. bolt
  201. Patriot Stage III heads question
  202. Pilot Bearing for Eagle Crank
  203. AFR 205 heads & lifters install Questions ?
  204. HELP. diagnose problem from this noise
  205. a cam for my needs?????
  206. Tick, Tick, Tick...HELP!!!
  207. Just a thought...
  208. fm14 owners inside
  209. ane wan can help
  210. Rod bearing question
  211. good head and cam setup!!
  212. 350 to 383
  213. Will this cam work with stock heads? Speed Inc. S15
  214. Stock main caps
  215. TSP Texas Giant Cam
  216. what cam???
  217. loud humming noise after wire and plug change
  218. 402 with stock ls6 heads and fast90
  219. patriot 232 cam
  220. cam size
  221. custom EDC FI cam sound clip
  222. asa cam with more lift
  223. Many Questions About Strokers/Forged Motors...
  224. Anyone used the GM Performance LS1 TO LS6 Conversion
  225. Cranks-Lunati,eagle,callies....why the huge price difference?
  226. hp gains with a 228 cam
  227. Guys with cams....what's your "start up" procedure?
  228. AFR 205's are in....pics inside.
  229. HELP! 4.8 to 5.3 piston swap problems
  230. 5.3 stage 2+ and stock or cheatr cam results
  231. Preferred method for high compression?
  232. Final torque spec for factory head bolts?
  233. Anyone have a cam card for the C2" Hammer cam"
  234. Just installed MTI S2 cam - no dyno yet
  235. What way should i go to reach my goals????
  236. 402 Cam
  237. What would be better for me as my next mod?
  238. Wow, new heads everywhere
  239. your rpm rev limits ?
  240. Help PLEASE......... do i have a bad ring??
  241. 114 or 112lsa??
  242. Trouble starting
  243. Number at the end of cam??
  244. Piston to Valve Clearance ?
  245. 317 casting
  246. PPL w/ TSP Torquer II, where do you feel your car start to kick in?? mines weird>
  247. 64cc heads AFR, Z06
  248. LS1 vs LS6 valley covers
  249. Anyone running a Futral F13 cam on a 114 LSA in Virginia?
  250. Who's gunna be first?
