View Full Version : Generation III Internal Engine
  1. Local guy claiming 487 through an A4. Is this BS?
  2. Afr 225 Heads In Stock @ Slp
  3. What Cam?
  4. I did a bad thing...
  5. how about the tsp magic stick?
  6. Oil pressure sitting at 20lbs when warmed up.
  7. Torquing ARP head bolts...
  8. cam question
  9. Engine builder Questions
  10. need help asap
  11. Head and cam question
  12. keying the crank?
  13. Stealth Thread
  14. Thermostat Question
  15. New to the Game.
  16. Comp. 918s w/stock retainers?
  17. Amsoil helped the piston slap
  18. Ses Light On And Off
  19. My upcoming heads/cam setup and install
  20. SCE titan ICS gaskets
  21. Coolant leaking from Hean Bolt
  22. What is wrong with my car?
  23. How to calculate quench
  24. wanting 400 to the wheels....3.42 gears
  25. LS6 cam???
  26. 918 Springs with 233/239 Cam?
  27. Anyone torque there ARP head studs more than 80 ft lbs?
  28. should i change my springs again?
  29. Valve upgrade
  30. Need Help?????
  31. Simple valvetrain question.....????
  32. Please clarify this for me ... (degreeing cam)
  33. Highest RPM on stock 02 Short?
  34. Looking for LSX head porting templates?
  35. Does GTP (Gallant Technical) stamp their cylinder heads???
  36. Engine Cleanrces speces needed
  37. Valve seals
  38. I want a cam for my Vette..
  39. Trex? Bearings?
  40. TR6 Plugs actual part number
  41. Advice on H/C Set Up for Vette
  42. gm oil life monitoring system
  43. Tighten rocker arms question
  44. Patroit performance local flow bench numbers
  45. video clip of my piston slap..your comments
  46. Pick My Cam For Me!
  47. burnt valve and bottom end chatter.
  48. largest duration/lsa on milled 62cc 243 w/o flycutting?
  49. Eagle Crank Problems?
  50. TSP 228/228 114 Dyno
  51. Windage Tray difference??
  52. Cam timing advance
  53. How close would P to V be with this cam?
  54. Canton oil pan users
  55. Who has used GRP SB1000s?
  56. 6.5 quarts?
  57. Valve Adjustment???
  58. whats this? pic
  59. Heads + cam = smoke!!
  60. Tr230/236 112 Dyno
  61. I always hear about the F13 but....
  62. GT2-3 vs LS6 cam, is GT2-3 really better?
  63. Crane Valve Locks
  64. Sewing Machine Noise???????? Help
  65. what do u think of this cam for
  66. Why high compression?
  67. Stock Heads????
  68. best piston rings for stock size bore
  69. SLP and AFR team up !!!
  70. heads! which r best? ur opinion. Pat/AFR
  71. is this worht it for me
  72. 87 Octane!
  73. New LS1 for a 98 z28
  74. Rod Bolt Contreversy!
  75. MS3 or SI5 or suggestions?
  76. Best cam/lifters/spring combo?
  77. What bolts need to be removed to lower the oil pan?
  78. <<<BEST LS1 CAM?>>>
  79. Will my stock springs handle my cam?
  80. .040 Cometic.... .033 quench too tight?
  81. MTI 347 breaking point?
  82. 918 Hype Survey
  83. Broken valvespring???
  84. Can't use MLS Gaskets on 1998 LS1 Heads???
  85. Practice makes Perfect
  86. High oil consumption - what mods can I do?
  87. Question about putting LS1 oil pan on 04 LS6?
  88. TEA 5.3 Stage 1.5, F13, ASP, QTP install pics here
  89. Need advice on engine building...
  90. LS6 Main Bearing Clearance ?
  91. LS6 cnc'd heads stock cam
  92. Need honest opinions ... quickly
  93. vlavesprings for .630 lift?
  94. Pics & flow #'s for my Patriot Stage II LS6 Heads
  95. Crank and piston question
  96. new locks for dual valve springs?
  97. Cam Install problems, please help.
  98. if i were to have left out 3 coil pack bolts.. could that cause false knock?
  99. best deal on tea 5.3 1.5.....some hp numbers
  100. help look at my plugs
  101. Tr224 A4 Ppl Insinde!
  102. Has NE1 tryed the ISKY "Beehive" springs?
  103. I know I know
  104. Little help on bad case of piston slap
  105. Iron block alternator bracket
  106. super tiny metal shavings on the engine oil dipstick?
  107. Major problems
  108. what to do with 3 grand
  109. Loud clicking noise after wot? Wont shift to second?
  110. Hydraulic cam guys spinning over 6500: Questions for ya!
  111. Heads/Cam question
  112. what size nuts for ARP main studs windage tray
  113. air leak help!!!!
  114. Need rocker manufacturers
  115. opinion's on final cam choice wanted!!
  116. AFR dual springs only good to .600 lift??
  117. Which PP heads will flow best w/ 231 cam?
  118. Head/Engine Combination help!
  119. Stock Push Rods OK with milling?
  120. Valve Spring Stripe Color?!
  121. What's the most likely cause??
  122. 2002 ls1. 346ci or 348 ci
  123. Need to go through an Oil Pump, have ???
  124. Helicoil lifter tray bolt hole?????
  125. Need to helicoil lifter tray bolt hole???
  126. Pushrod length sanity check
  127. ET and TEA AFR Heads
  128. Rod ? here help please
  129. 98Z28 stock to New LS1/w LS6 heads AND CAM
  130. what cam with afr 205
  131. Engine Wont Start
  132. Pushrod length OK? Take a look at the pic
  133. Help!!! Flycutting?
  134. Afr ??
  135. Can bad rocker arm adjustment cost me 100rwhp?
  136. WHAT?!@? chain rattling noises from my engine bay
  137. 04 ZO6 Intake, possibly heads & Cam in my 00 Firehawk
  138. Need Cam suggestion...
  139. Cracked or bad tool mark on heads?
  140. German Castrol 0W-30
  141. Rod knock or Really bad case of piston slap???????
  142. What springs with asa cam
  143. oil pan leak, slightly different questions
  144. How deep to flycut?
  145. Rebuild Kit
  146. Traditional split, 2 , 4, 6 Degrees between intake and exhaust
  147. car wont idle, gauges go all wonky..
  148. Help!!! Car keeps blowing fuses!
  149. Ford guy with Ls1 dentonation issues, please help.
  150. My engine might be shot
  151. patriot springs
  152. Decided to go 402
  153. who has the best deal
  154. What springs for possible setup?
  155. What next? - I need a plan
  156. piston slap? .... fix? ....
  157. think of going with Mobil 1 or Amsoil
  158. shimmed 918's Max Lift !
  159. So which would you use then? 918 vs Golds...
  160. new forged block from Racetech is ticking bad
  161. Valve Spring Swap
  162. WFT not another cam question. Need some quick advice.
  163. Pistons
  164. Cam TDC alignment and startup question?
  165. Are 600lift lifters Ok with .634 exaust lift on a cam?
  166. what size motor will it take
  167. Custom Cam for Low-End Torque?
  168. help with starter
  169. Who has blown their built motor and what did it take?
  170. mobil one....
  171. Low Cam Dyno Numbers?
  172. Oil filter question
  173. Yet another Cam Question...
  174. wats the stock compression ratio?????
  175. Reuse cometic head gaskets???
  176. Flywheel Bolts?
  177. oily intake runners
  178. Cam suggestions please
  179. Ported head question?????
  180. new cam...what kind of numbers to expect?
  181. PTV with TRak cam
  182. Who on this website do i talk to abotu gettign soem TEA heads?!
  183. Gold .650s vs Comp 918s....
  184. Engine is whining
  185. Pulley help
  186. Stock connecting rod durability?
  187. setup ?
  188. SCAT Rods
  189. A cam question not asked every day...
  190. Another oil pressure thread
  191. LS6 short block with LS1 heads?
  192. Compression ratio?
  193. LME 408 Underway!!
  194. Best motor oil
  195. SH*T! Did I bend a rod?
  196. Will 918 Springs Work with G5X4 Cam Thanks
  197. Texas Speed Magic Stick - OPINIONS?
  198. LS7 Valve Springs
  199. Should i upgrade to a 427 LS2 engine from LS1?
  200. Help please!! Valve clearence issues
  201. cam decision
  202. Main Bolts TTY???
  203. AFR 76cc head questions
  204. What Cam???
  205. Really need help - cylinder won't build compression
  206. Recieved wrong cam,keep it or wiat for new one?
  207. hardened stock rods + NOS = ???
  208. were'd all my oil go????
  209. Valve Spring Installation/Measurement
  210. Timing cover install. did it wrong? Help
  211. multiple misfire problem!!!
  212. Rocker Arm off
  213. Temperature reduction plan
  214. Stock rocker arms
  215. H/C exhaust question ? back pressure?
  216. Best Shortblock
  217. Trying to figure out which one
  218. 408 guys inside please.
  219. Gained 32 rwhp with PRC 2.5/5.3L
  220. engine oil
  221. Help FAST!! Rocker Arm Bolt Rounding off
  222. FAST Intake and 90 TB
  223. Comp LSK Lobes
  224. Stock Injector flow rate
  225. Possibly buying this shortblock for spray ... how does it look?
  226. 427 & 225 AFR heads with FAST 90 intake?
  227. Lifters and Pushrods
  228. cam questions
  229. Hollow Crankshaft- Rear oil plug too far in??
  230. lifter boxes
  231. BrentB.....clean out your pm box!!!
  232. Slp lid problems?
  233. Edelbrock/Lingenfelter Heads
  234. Question on combustion chamber variance
  235. complete setup for my ls1 some advice
  236. Are my lifters ok to use? ....pics...
  237. LS1 to LS6 swap
  238. Valve locks....
  239. oil level sensor resistance
  240. Choice between Heads, MTI 2E's or TEA 5.3L Stage 1.5
  241. So What's Going On with Precison Race Components?
  242. F10 cam installed ! - videos
  243. SLP MAF? does it really work
  244. Which head for which side?
  245. To High of a compression A bad thing?
  246. Main Bearing Bolts?
  247. Spun bearing?
  248. Good sense or waste of $ to change springs on stock LS6 motor getting ATI D1SC SC
  249. When should this be done?
  250. GM Part Lookup
