View Full Version : Generation III Internal Engine
  1. car will not idle anymore input please!
  2. Need a big cam for 408
  3. 402ci, 408ci, and rocking pistons
  4. Will 4.010" pistons work for a 408ci motor?
  5. Quick question about retainers
  6. Milled Heads to .050". What cam size can be ran?
  7. GT2-3 with LS6 springs question
  8. head gasket size
  9. what adj. timing kit to get ?
  10. 383 H/c?
  11. LQ9 heads ?
  12. Who has or can ind. test coil bind on 918s?
  13. Removing heads, idea/??
  14. COMP Cam owners come in...
  15. Help with valve clearence!
  16. 112 or 114 LSA (not the typical question)
  17. PEOPLE WHO KNOW valve springs
  18. Cam: How big for ~430-450rwhp?
  19. Look at my springs.
  20. Milled 5.3's with TSP 228R?
  21. How difficult is to Advanced a Cam
  22. FAST and AFR225s
  23. Best bore & stroke under 400inch?
  24. Anyone know GTP's website or phone number?
  25. ARP main studs guys inside please
  26. Who offers the best pricing now on Heads/Cam package for LS6 motor?
  27. How the F did my engine blow?
  28. Who sells rings for factory 3.898 pistons
  29. What's a LS1 worth?
  30. Piston problem
  31. Why is my LS1 getting horrible gas mileage?
  32. Will these heads work for my car???
  33. Looking for a Chopy Cam
  34. machine shop cost and recommendations in the SF bay area
  35. how often should the timing set be replaced on LS1
  36. Head Gaskets
  37. Motor Thoughts.
  38. Internal Engine Coatings
  39. aluminum connecting rods
  40. Got my PRC's 5.3/2.5, overall impression
  41. For those considering the CheaTR cam
  42. ASAP: G5X2 + SLIGHTLY milled heads = OK?
  43. when u go above 7000 rpm !! check the PIX
  44. Question about LSA
  45. oil change
  46. Leakdown Test results, no sign of where burning oil is coming from
  47. Blue exhaust smoke, help troubleshoot please
  48. Are Compression Tests neccessary?
  49. Rumor Mill - 465ci LS1.. Anyone know of it?
  50. where to get the T25 tool for the MAF
  51. What is it worth???
  52. AFR heads installed
  53. Front cover alignment
  54. NON LS1 Question about my Oil Change today
  55. Gains after cam install?
  56. Whaich cam?
  57. Internal Magic
  58. Perimeter Heads To Center Bolt
  59. Patriot LS6 Stage2 heads+Patriot 226/226 .585"/.585" LSA 112, RWHP ?
  60. Externals to enhanced internals
  61. Help Please!!!!!!........
  62. rocker arm upgrade/ tips wanted
  63. 383!
  64. 160 t-stat for 04/05 water pump?
  65. new engine build up
  66. 62k miles
  67. Link to C5R Block Prep by GMPP?
  68. 98 Corvette leaking gas under engine.
  69. Dual Spring Question.....
  70. Installed ARP rodbolts.
  71. Heads...?
  72. Turnkey motor project
  73. need help on specs for the ls1
  74. Ok a long story..
  75. Stock Short Block.. Cam recomendations
  76. Figured I would ask the experts
  77. Cam + Daily Driver : ? (all input welcome)
  78. overheating after H/C install?
  79. trying to suprise my boyfriend
  80. How much German Castrol do you have?
  81. Does anyone know of a PATRIOT GOLD DUAL SPRING that has broken?
  82. How much and where for Heads and Cam
  83. Sky-High Oil Pressure - Head Gasket?
  84. FMS F13 Owners: How's it drive down low???
  85. What cam???
  86. Broke a value Spring
  87. 02+ LS6 spring max valve lift
  88. How likely is it for the rocker bolts to loosen if you forget the loctite?
  89. Evans Coolant
  90. Pinned Damper
  91. Should I be concerned with P to V clearance?
  92. Has anyone broken the comp dual 921 springs yet!
  93. Damn Check Engine Light keeps coming on.
  94. Got 16 BROWN Valve Seals with my Patriot Duals... What to do!?!??!
  95. How much RWHP do the big Cammed australian cars make?
  96. If I tune for a cam, will I need to drill a hole in TB?
  97. Next Upgrades
  98. Need Advise on Cam and setup
  99. Warping an LS1 Aluminum Head
  100. Has anyone heard of the 100 % full throttle mod?
  101. Where to buy Katech Rod studs & urethane engine mount inserts???
  102. ATTN: Patman A Few Questions on 0 w40
  103. Why not just go 427?
  104. main bearings???CAM FU#KED!!!!
  105. Stalling after cam install.. HELP?
  106. Extended Pintle Valve Stuck Open
  107. 36 lb Injectors big enough??
  108. Which springs for F13??
  109. stock pushrods are not 7.380
  110. How to disconnect fuel line
  111. How much to swap a cam? (Tucson, AZ)
  112. ok to take rod caps off???????
  113. Rock On
  114. Whats the hot new cam out there that will get me 425 at the wheels on bolt on Z06!
  115. I need some help
  116. idle sux
  117. free mod??
  118. help with harland sharp rocker preload
  119. Pushrod Length?
  120. Finally figured out that nasty ticking...
  121. Is this too much to pay?
  122. FTI Custom Camshaft
  123. slp 402
  124. stock LS6 pushrod length? LS1 to LS6
  125. stroker cam suggestions
  126. ligenfelter head ??? for 01 z28, need help!
  127. How much HP gain w/ custom pistons???
  128. Is the MAF for the '04 GTO the same as other LS1 powered cars?
  129. 2000 z28 m6 wont run...HELP PLEASE
  130. C5 with headers gains 42 rwhp with CheaTR cam.
  131. a strange new question for cam heads...
  132. ls6 cam conversion... do i need spring retainers
  133. Compression Calculator
  134. nos on a motor setup for na
  135. 918 springs with stock cam.
  136. FMS 408, 410, or 414?
  137. Is this the right Crank Bolt? (Pic)
  138. Which bearings??
  139. Do I have an oil pressure problem?
  140. Has anyone heard of the Crane Cams Z-Cam kit?
  141. how effective do you think the aftermarket pulleys are as DAMPENERS?
  142. is there a downside to stiffer springs? more resistance or wear?
  143. Thinking about getting the T-Rex v2 w/150 shot n2o
  144. Need ring compressor and filing tool
  145. Real world benefit of Ti valves?
  146. early (weird numbers) cam
  147. ASP pulley. Run both belts?
  148. 90/90 install
  149. What all valvetrain parts are ...
  150. LS1 rods...?
  151. Darton East 427 block went Kaboom!!!*$*$*$
  152. MTI B1 vrs. TR 224 114lsa
  153. Difficulty of rebuiliding an LS1?
  154. what does valve float feel like?
  155. Lifter Question?
  156. Attention all California people. Advise on biggest cam I can go and pass smog.
  157. Comp Lifter users???
  158. Bogging a bit from a stop...
  159. looking for ls1 or ls2 engine
  160. Boring the stock block
  161. How much do most shops charge for R & R engine?
  162. valve springs
  163. Does Anyone Know?
  164. Stock WS6 Detonation
  165. Bitten the bullet
  166. Is the Crank bolt coarse or fine thread?
  167. Cut off at 2500 RPM
  168. What type of exhaust?
  169. trex in!!!!
  170. changing pushrods..1st time
  171. cam install
  172. Pre-lube
  173. Want to convert to ls6 cam... advice?
  174. P to V? X1 vs. R1
  175. Help, have 2 sets of heads, which should I use.
  176. lifter death AGAIN
  177. need help
  178. Rebuliding LS1-Fire damage to a v6 body
  179. Starting Issues
  180. which catch can?
  181. In Desperate need of a helicoil Kit for Crank
  182. Comp 26918 springs VS. Crane 144832 springs
  183. Pushrod length... need some help
  184. SDPC 408 startup video
  185. PRC stage 2.5 heads
  186. Finally fired up the 408 Stroker
  187. info on compstar ls1 rods
  188. What's up with my oil pressure? [VIDEO]
  189. Cams??????????
  190. What length pushrods?
  191. MTI Stealth I & II vs. LPE GT2-3.....Power vs. Idle
  192. Stock LS1 chamber size
  193. G5X3 on 112 sound clips?
  194. got Z06 cam do I really need longer pushrods
  195. Running hot, did search, please help
  196. z06 cam
  197. MTI Stealth II Cam Come In
  198. AFR 205's > stock bottom > please post info
  199. Broken Timing chains...i'm curious..
  200. Check Engine Light Help ASAP Please!!!!....
  201. 403 vs 408
  202. SLP Double-Roller timing chain vs Ls2 Chain???
  203. How much hp will stock '02 injectors support?
  204. LS2 chain with stock sprocket
  205. piston/valve interference
  206. Hello from down under need advice on heads
  207. Buzzing Noise In The Engine...help!
  208. Ferrea Valve source
  209. cheaTR CAM
  210. High miles on LS1 motor is it worth switching to synethic
  211. Gaskets and part numbers, are these correct?
  212. Can someone post their cam card on the Torquer II w/ 113 LSA please, need quick!>
  213. Got my Patriot Gold Duals... Quick Question
  214. Help Fast!!! Don't think I received the correct Torquer II cam!! tuning help>
  215. Little coolant gasket on top of head?
  216. Would this work?
  217. son of a bitch..another bearing
  218. Longer Crank Bolt?
  219. What are the true benefits of a higher LSA?
  220. Flycutting affecting Compression Ratio?
  221. help ARP Main Stud Problem LS6
  222. some vinci/crane rocker spy photos
  223. Should I be concerned with oil....
  224. Oil Accumulators
  225. which route for A4
  226. 6.0L with a G5X2?
  227. Changing a head gasket?
  228. Coolant cross over thingy under intake...
  229. Still need some help after cam install...
  230. Need cam and head help......
  231. Discovered very low price for Gen III Lifters
  232. G5X3 Cam Is In
  233. Just a few questions before I order a CheaTR cam
  234. lpe gt2-3
  235. type of coolant
  236. Fantasy Football Anyone?
  237. HP estamates? (sorry I can't help it)
  238. weight of ls1 with 4l60e and acessories?
  239. C5R Top End Components For Sale
  240. Crankshaft Reluctor wheel?
  241. mild corrosion on used cam, bad thing?
  242. LS6 or LS2
  243. 1.8 Harland Sharp Rockers
  244. Don't hate... Cam ?
  245. Coolant in the intake runner??
  246. Should I port stock ls1 heads?
  247. Tony Mamo where are the 225 small chambers at?
  248. 6.0 swap help?
  249. Trying to get some power
  250. Driving A4 w/ G5X2 on stock tune?
