View Full Version : Generation III Internal Engine
  1. Meziere Water Pump, any good??
  2. Arp Pro series Ls1 head studs (12 point)-Missing washers?!?
  3. Good mild cam for a DD
  4. ls6 specs
  5. Spun a bearing looking for new engine
  6. 400rwhp with stock manifolds and a cam?
  7. plug wire heat shields
  8. valve seat difference
  9. Installing front oil plug
  10. Hesitation at fixed speed (46MPH)
  11. how will 382 run with t-rex?????
  12. Help Ls6 intake
  13. Help!!!!
  14. Building another 346...
  15. Power with my Current Mods!
  16. The BEST Cam/setup
  17. Some PRC Questions?
  18. IF you bought PRC heads or are considering it.. CHECK THIS OUT!
  19. Need advice.
  20. something is wrong with my engine
  21. More questions about valvespring swap..
  22. HELP !!! -- blow-by and leak-down q?
  23. Redline Oil
  24. oil pump removal
  25. Dry sleeve guys
  26. What else should I get with the TSP TQ2 Cam?>
  27. i could use some advice
  28. 1st H/C swap
  29. another guess my HP
  30. mild cam w/stock stall doable?
  31. Heads And Cam ?
  32. Idle surge
  33. Cam expert needed for my set up
  34. Any tricks to installing Crane 99893's?
  35. Looking for input on Cam & Nitrious setup
  36. 99 TA + all bolt-on's + F11 cam = need bigger injectors??
  37. Lookin For A Cam
  38. 6.0L head.....yeah only one????
  39. good or bad cam
  40. Highway cruising, slight throttle makes oil pressure dip just a little
  41. oil and trans sending units
  42. Oil Pump O Ring...what am I doing wrong
  43. Suggested HP/TQ numbers
  44. 02 LS1 & LS6 Stock Timing Chain
  45. new motor car make low oil psi
  46. do 98 cars have paper water pump gasket?
  47. Timing chain question
  48. pistons and rods...please help
  49. tell me what you know or think about this kit
  50. Futral Cams....
  51. downsides of '98 LS1 longblock
  52. Funny Story....
  53. Who's pushing .650" lift on their Crane duals?
  54. ls1 bore/hone
  55. Thermostates
  56. 230/224 .575/.563 111 LSA opinions
  57. Max bore on 6L Iron Block?
  58. Please help me build forged 348 short block
  59. ? about Cam
  60. how much oil
  61. TR 224/227 Pros and Cons
  62. oil pan/bottom end
  63. gear drive
  64. installed heads......problem
  65. Estimated hp numbers anyone???
  66. Non-green German Castrol???
  67. HP and Torque - What to expect
  68. What Oil Do You Use?
  69. AFR 225 on stock bottom LS1?
  70. Question about tuning new motor before break in?
  71. How Many Miles in On Your Original LS1 Engine?
  72. Time?
  73. wanna get rid of my f10 and go bigger, but
  74. Those with the F13 cam what valvesprings are you using?
  75. 717rwhp 03 Zo6 N/a
  76. '02-'04 LS6 Valve Springs Vs. Comp Cams 26918 Springs
  77. Flycutting pistons... how much is safe?
  78. Need help changing out valvesprings..
  79. Done some CAM homework; now need help putting it togther
  80. HELP!!!Double Roller Clearance Issues!!!
  81. MS3 vs.TREX vs. GX3 &4
  82. Aussie LS1 = US LS1 ?
  83. Advies: Everyone that purchased the PRC 2.5 heads from TSP what did you think of them
  84. Vavles, Pushrods, Rockers, Timing..
  85. Which 5.3 heads are the best for the money??
  86. wheres my hp?
  87. LS1 rebuild
  88. Setup feedback
  89. Cam and extras ordered. LS2 chain ?
  90. Engine pull: From Top or Bottom?
  91. Which heads work best with MTI's Stealth II cam?
  92. Cam guys, where will this cam peak?
  93. Name this part found in oil?
  94. Just blew my Z06 engine up.. need opinions on new setup
  95. double roller timing chain
  96. Ported Heads and Rocker Bolts
  97. lightest internals for a FI motor
  98. comp r lifters
  99. Best price for a LS6 Intake
  100. Heads on ebay?
  101. Part Number needed
  102. Guys with F14, whats your idle rpm set at?
  103. How much are these worth?? Heads
  104. Patriot Performance parts
  105. Cam help!!!!!!
  106. ls1 heads
  107. What am I looking at for HP/TQ?
  108. What am I looking at for HP/TQ?
  109. Has Anyone Ever Heard Of?
  110. valve cover swap help
  111. Refreshing an engine ?
  112. Question about cam install...
  113. You Guessed It, Cams?
  114. Took the plunge:
  115. Main cap question
  116. Motor going back to stock
  117. Help with LS1 build up...
  118. pan off, should i replace rod bolts in my 00 c5?
  119. Paging Tony Mamo at AFR, question about your 6016 cam
  120. AFR 225 too much for 382 stroker
  121. Help with cam and stall.
  122. Thinking of going solid lifter!
  123. emmissions 402, and cam choice
  124. confused over oil
  125. first oil change with GC
  126. F13 and expected power
  127. Titanium Retainer Fit?
  128. Still Misfiring What Next
  129. Estimated Dyno Numbers anyone???
  130. Rod bolts - what year were they upgraded?
  131. Cam install extras?
  132. Oil pressure after rebuild...
  133. Comp Cam numbers question...
  134. tsp 231/231
  135. This should be fun. Put these in order
  136. heat cycling new springs
  137. Anybody ever tryed putting 2 O rings on the pick up tube?
  138. Cam suggestions for a 408 W/ AFR225
  139. Input on 408 Iron Block(HPE)
  140. Estimate the time
  141. will 233/239 work with partiot heads
  142. I might change my TSP torquer cam. Help!
  143. Best Heads with F15?
  144. No idea What You Are On About !
  145. Can i use Crane Dual valvespring with stock retainers ?
  146. gear drive
  147. Comp 218/224 .527/.534 114 vs. Hotcam
  148. 4.8l heads on 6.0l
  149. Cam selection!!!
  150. pushrods
  151. Little help after motor rebuild.
  152. Used block for FI has nicks at bottom of cylinder
  153. Will block distort if head studs are added after machine work?
  154. It just looks so good - SDPC 408
  155. Any one have a spare rocker arm?
  156. F15 vs MS3
  157. Cracked Block
  158. Help Motor not making power!!
  159. Question on high idleing
  160. F11 vs. F14?
  161. Dependability (high mileage?) with LS6 cam in LS1?
  162. Yet another Cam question
  163. reputable ls1 shops?
  164. Should i buck out 4 some Rockers??
  165. Wats broke?
  166. Engine running hotter than normal
  167. Stealth 2
  168. How much lift can stock springs handle?
  169. Problems after cam install...
  170. Cam Swap on 02 LS1
  171. Which parts necessary for a big cam?
  172. warped valves??
  173. Help With Rear Main Oil Seal Leak
  174. 317 6.0 valve seals
  175. valvetrain issues!!!need help
  176. Advies: All H/C and also cam only guys please come in have a question???
  177. LS6 Cam questions
  178. Patriot or AFR heads on 402 block
  179. Unmilled AFR heads with Crane rockers
  180. Oil leak
  181. Need help.....Please
  182. SCAT rods?
  183. CAM Question Got a 224/228 112
  184. oil windage plate
  185. cam swap
  186. Maching involved in strokeing an LS1?
  187. Torquer 2 = Valve Breaker?
  188. Main cap bolts
  189. gear drive timing chain replacement
  190. Newbie Compression Question
  191. Noob Get'n Greasey... little help please!
  192. LS2 based 408 or Iron Block 408 ???
  193. head gaskets oem or cometic
  194. Tstat
  195. Rocker bolt. says 22lbs tq. 25lbs okay?
  196. Has anyone heard of this cam?
  197. 98 oil pan gasket?
  198. AFR heads & reverse split cam?
  199. re-occuring Lifter Ownage
  200. 97-01 and 02-04 head gaskets are different??
  201. Service Engine Light on after first track pass with Cam
  202. Tonights Carnage!
  203. ls1 to 6.0
  204. NEED HELP PLEASE 346 rebuild or buy 402???
  205. change oil before dyno tune?
  206. PRC, 233/239 guys come in...
  207. Tach problem HELP!!!!
  208. bad luck with a forged 346
  209. Small water leak after cam install...
  210. Need help asap!
  211. Any Body want to make a small fortune!!!
  212. Any advice/tips for a cam install newbie?
  213. patriot 224/585 CAM-thought/dyno results
  214. Pushrods or not
  215. WooHoo my TEA 1.5's 5.3's just came,flow sheet attached!
  216. Mod my car: Internet reality show at LS1tech.com
  217. My T/a's Running Hot?
  218. Part number of camshaft sprocket??
  219. Cam Intake Exhaust Combo
  220. Swap LS6 out, LS2 in?
  221. Which cam please
  222. Need carfax report, someone help!!
  223. Belt noise, Overheating, then Noise from Within! Help!
  224. Input needed......head swap?
  225. Need some info on Jager composite rods
  226. Were to get repalcement rocker arm bolt?
  227. Degree Kits
  228. help with cam
  229. Springs for a 250-260 cam?
  230. harland sharp heavier than stock rockers?
  231. How much power do u think ?
  232. 5.3 heads
  233. Will later LS2 oil pan make adifference?
  234. New GM heads...
  235. Guys Cammed with 4L60E's Come In...
  236. dry head gaskets
  237. anyone know anything about the mammajamma cam from LG??
  238. Need help Ordering A cam
  239. Attn Engine Builders & Racers!! Aug 6th is near...
  240. Oil change after Heads, intake, LS6 PCV conv.
  241. weird idling problem (not LSx) while in gear
  242. stock rockers
  243. how can i tell the difference between LS6 and LS1 intakes?
  244. terrible banging sound from motor
  245. Burning Anti-freeze whats the cause
  246. Dip on dyno graph then burning oil to redline
  247. 400 hp
  248. Center Bolt Valve Covers????
  249. I Want Heads and Cam, But There's A Catch
  250. Removing crank reluctor wheel
