- nuetral balance flywheel? boost plastic intake?
- Need some buidl advice... LQ9 vs LS6 with 243 heads...
- Possibly oiling issue?
- are both head gaskets the same on 98 LS1
- 2.5 5.3 heads for my goat. What cam???
- Rod bolt torque
- Timing Suggestions
- countersunk cam door bolt size
- Lifter Preload
- 400 rwhp?????
- 63cc to 72cc how much compression will it dump
- LS2 Timing Chain Install
- Which lifters for SILENT valve-train???
- Rate my setup that i have in mind for an LQ9
- Plugs?
- Any guesses what these dual springs might be?
- Cam choices!!! Need opinions
- Possible PCM Failure?
- Most gentle lobe from comp?? LSL, XE, LSK?? Need help
- Turning crank by hand?
- Condensation in motor (LS6) were is it coming from?
- Which cam is this?
- Decided to make some: Oil pump pickup tube "girdle"
- Rebuild kit
- how much is 243 & ls6 intake worth
- Stock LS6 cam
- Compression vs bigger cam
- Best performance from a ported factory casting
- Prc 215
- engine question
- 1999 Z/28 Terrible Engine Noise! Please Help
- valve questions
- Would more lift help??
- LQ4 with milled heads Compression?
- lq9 with 243 heads and ls6 cam question
- connecting rod bolt removal without a vice
- PTV with new heads
- Torquer V2 or V3
- are the stock cranks heat treated?
- Anyone else speed-pro pistons not coming out of hole
- oil ring support rail gaps?
- piston question
- remove cruise control module?
- I want some good head..s
- 5.3 torque specs
- Starting LQ4 Build
- Catch Can or LS6 Valley Cover?
- 5.3l heads
- How to make a poor cam
- cam swap timing chain question tr224
- Patriot Preditor heads?
- Whats up with this cam
- Ls1 power?
- Titanium vs. Steel Retainers
- ticking and clacking sound
- Rotating Assembly questions? Can you buy cast rotating assembly?
- Newschool Torque Cam?
- who are some of the reputible ls engine builders
- Water Pump?
- 243 cnc heads whats a good cam
- lq4 243 hp
- Question about a cam.
- Throttle Body Problems - please help
- Oil psi please help
- Hows this LQ9 look?
- Building a 5.3L L33 - What would you do?
- 650 lift valve spring installed height question
- Ls6 noise problem
- VVT effect on DCR. (question)
- is this ok?
- Throttle Body question on LM7
- HELP oil pressure issues
- cam bearings out of its place...
- 243 heads N tbss/nnbs intake??
- C5 Corvette making AFTER WOT pull! Video & pics inside
- Oil pan gasket ?s
- what rings to use?
- Looking for cam bearing pics....
- Would you run this?
- Piston to Valve clearance ?
- I like what I've got just want more of it.
- Big cubes to stock cubes FI opinion
- cam advice
- Lq4/317 cam only recommendations
- ls1 with ls6 heads what to do
- raising cranking compression
- 243 milling n comp ?'s
- Never Seen a head like this before what is it???
- Getting ready for a cam swap
- Is this block ok?
- maybe a stupid question....
- how to retorque rod/main bolts
- lq9 cam only rec
- Those with, or with information, on PI heads, please come in
- LS6 vs LM7 block differences?
- EPS 222/226 Vs TR224
- 243 head experts please
- Clearance questions
- LS7 lifters or what?
- parts ordered for build
- New Motor ??
- Cam and stall Matching advise
- Best oil for older bottom end
- 243's shaved .020 ballpark cc?
- Need more eyes to look at the heads i just received...
- 99' Z28 Head/Cam Install 2012
- Shortblock & Rust.?
- would you run a chipped main bearing?
- Reslevee a 6.0 iron block ????
- need opinions (cam/head)!
- I have a ? about a high mileage ls1
- ls1 starting build 500rwhp
- Gasket set.
- cam advance or retard
- 6.0 heads
- This is what I am thinking....
- spring question would ls7 springs be better
- Oil pump, big cam questions
- Another Lq9 Question thread, awww here it goes
- rocker arm studs
- Can a 2.00 intake valve be used on a 5.3 cylinder head?
- Buying ls1 block... What to look for?
- Looking to buy a stroker kit for my LS6
- car seems to have no power at all
- Ms3 and 4 question
- 6.0 LQ4 Question
- Which Oil Pump to use?
- Educate me on how valve angles effect air flow
- 383 Aluminum block or 408 Iron? How will it affect handling?
- Patriot 8501 .660" Valve Spring Ruined multiple valve seals
- Slp rocker arm
- 383 rotating assembly vs short block
- Anyone with cam experience tech in
- PTV clearance
- After ported heads and other changes will I be able to drive to my tuner?
- rebuild
- SLP double row chain and pump
- If you've swapped multiple cams..come inside
- Need Peoples Advice
- head studs
- Compression question
- Rockers hitting valve covers, still.
- *video* bad engine shudder and movement
- head question
- LS1 block and part swap to LM7
- Procharger concerns
- Pushrod wear
- 806 cnc ported slp heads good or bad?
- Yella Terra Installation
- Replacing #4 piston@63k
- 13k lq9 stock or forged?
- Anyone with HEMI heads on their LS?
- 5.3 question 's
- Would you reuse this cam? See pic.
- AI 226cc 243's and TV3.
- Do I have the wrong head gaskets on my LQ4 with LS3 heads?
- Best place to get AFR 210 heads / cam combo ?
- Difference in cam selection between M6 and A4?
- LQ4/9 vs LS2 rods
- MS3 cam
- porting 799 head questions
- LY5 AFM Delete
- Custom Cam People Come Inside!
- Rod Bolts Reusable?
- 853 heads to ported 706 heads?
- ls3 l92 swap >>>what am i missing<<<
- Engine VIN identification
- safe power gen 3 lq4 press fit rods
- Highest possible compression
- Texas speed cam kits?
- Understanding an engine
- What springs are this
- Patriot to AFR heads ?
- Streetsweeper with Terminator heads?
- Low compression test numbers
- slack in timing chain
- 5.3 Questions for Texas-Speed
- LQ4 oil cooler gasket
- floating rods
- Valve Spring Identification
- question bout port and polish stock ls1 heads
- Ultimate 6.0 street head?
- To port or not to port... This is my question...853's :(
- Head mill question?
- Stock roller rockers and valve spring kit with trex cam
- Just bought ls6 intake from a 2002 corvette
- ARP headbolts
- LS1 vs LS2 position sensors info
- Compression on 91 Octane.
- ARP bolts
- Which valve lap?
- curiosity again
- want a streetable cam that pounds the ground
- Replacing lifters, have some questions
- is this a good set up for my 98T/A
- Resize H-Beam Rod
- Typhoon vs ls6 Looking at a cam package
- Cammed.... Is this normal?
- if ur running a6.0 cammed plz chime in
- 347 ci ???
- Need help identifying this Cam!!!
- Just flex honed my block, let me know what you all think
- Local machine shop
- PRC 237cc or LS3 small port heads for 408
- building a iron block 6.2
- What turbo cam for me...
- Pick me out a cam!
- 10.2:1 dcr?
- LS1 CAD Drawings?
- Lq9 Conversion
- how to tell difference between a 5.3 and 4.8?
- Polluter camshaft any good?
- 243 valve job
- lq4 rod upgrade?
- Compression ratio
- HEADS/CAM, Probably asked before Need advice
- 5.3 w/ built ls1 internals
- LS7 lifter identification??
- Cam size ? for 243 heads milled .030
- need help....
- Help getting cam and parts
- what is going to take to swap out an ls1 from an f-body to a 2004 corvette?
- 6.0 h/c combo
- Milling 317's
- 5.3 heads vs ls1 heads
- Crank Question
- 370 or 408
- I need More power !
- Trunion upgrade need help! Making sure I did this right.
- what's happening in this pic?
- Bearing Location?
- lq9, 6.0L lsx questions
- LQ4 as my base where should i go from here?
- Balance an LQ4 crank with LY6 Rods and LS2 Pistons?
- Picked up an lq with extended crank, help
- Best cam for 373
- Scored an LQ4 block.... and now the bad news.
- stock 241 heads?
- 5.3L Swap into 98 Sierra
- head notch and gasket questions
- ls1 with blown bottom end
- Stock pushrods?
- LQ9 bottom end question
- stock reman. engines
- Torquer 2, 241s, how much should I mill?
- Cam pitting - Would you run this?
- Ls376/525
- 4.8 with ms3 or????
- getting ready for the build...
- how do i know which engine is in my car
