View Full Version : Generation III Internal Engine
  1. HELP! Looking for qualified mechanic
  2. Time for my 60K Maintenance--what do I need to do?
  3. MTI X1 cam???
  4. Would TR6 plugs help...
  5. cam install
  6. Quick Prob Stupid Question
  7. What kind of head gaskets are these?
  8. ummmm
  9. Some porting photos for your DIYers
  10. HPE cams.. Anyone using them? How ya like?
  11. leak down test
  12. ls1 ported heads vs ls6 heads
  13. Cam comparisons...
  14. Head And Cam Question??
  15. Cam?
  16. intake install on milled heads
  17. intake installation with milled heads
  18. ticking after get down
  19. cam swap ???
  20. Patriot Heads?
  21. A squeek type noise when I turn the motor over by hand
  22. 236/242 .602/.610 XR-E 112 LSA (Piston/Valve clearance)?
  23. I have Heads/cam Questons????
  24. Daily driving on this cam...
  25. Anyone here done a LS1 swap into a LT1 4th gen?
  26. Is this an LS6 intake?
  27. looking for bottom end..... looking to go forced induction..
  28. 6.0 iron block 370 + 244/248 cam up and running... VID!
  29. Do cams ever go bad?
  30. CAm help
  31. Can u run Comp 772 Ti retainers w/02 LS6 springs?
  32. serdi 4903 valve job??
  33. Best shift points for a Bone Stock M6 98 T/A
  34. Gaskets?
  35. Cam Swap, Need Some Help...
  36. What's the difference
  37. help! oil problem
  38. f-13 vs f-14
  39. normal for new cam to comsume oil?
  40. Radiator hose sucked close....
  41. ls6 cam help
  42. est:LS1 power
  43. The TRex is in!
  44. LS6 cam in LS1
  45. Help!@#$
  46. So who all has the famous piston slap?
  47. 4" Crank recomendations
  48. A New Noise
  49. Lunati Cam Question
  50. Loud Clunk then nothing
  51. Need Headgaskets in a hurry.
  52. Does Anyone Use Gapless Rings with FI? Would there be a problem with them?
  53. Drivability?
  54. Good Set up???
  55. When should I change the stock time chin?
  56. LS6 heads/cam - any dyno #s?
  57. Honing
  58. How much will cam effect gas milage?
  59. best shift point calculator?
  60. How much $
  61. How to determine shim thickness for preload?
  62. solid roller cams
  63. wtf? oil pressure question
  64. installed heads/cam/intake/headers. now car is stumbling and throwing codes.
  65. Absolute Speed LS1 (5.7) Head Questions
  66. Options on winter buildup
  67. G5X3 on a 112 with millled heads..P/V clearance?
  68. what has to be changed for a solid roller cam
  69. just took my heads off ??? (techs help)
  70. Heads, Cam, Exhaust, Intake, all installed in ~ 13 hrs.
  71. arp head stud kit vs. stock head bolts
  72. Torquer camshaft and obligatory crap installed!
  73. cam install
  74. installing heads, got a tuning?
  75. what the main difference in these heads
  76. what would make the pistions get lots of buildup?
  77. question about timing chain slack
  78. Piston to Valve Clearance ??? for T-Rex
  79. MPP2 Power Plates
  80. WCCH heads are on !
  81. just ordered gmpp ls6 heads for my asa cam
  82. Cam combo question
  83. Did I hurt something?
  84. ported/polished oil pump
  85. What are the best heads for my LS1?
  86. TSP heads and cam package question!!
  87. LS1 - LS6 swap
  88. hi compression with FI
  89. Edelbrock LS1 Heads are listed.....
  90. What cam to get? With my set-up?
  91. Comp 921 duals or PRC gold duals?
  92. Well since this is LS1tech, then I need some tech advice.
  93. lunati internals
  94. stock ported heads?
  95. anybody run crane cam
  96. What amount of total timing do the AFR heads like?
  97. Firebird stock internals question
  98. LSx engine building literature
  99. can a 5.3 block be safely bore to 3.905??
  100. Approx. Cost and build order
  101. Heads, 10 CFM difference equals how much rwhp?
  102. 228/230/571/573 Xer
  103. When is it no longer an LS1?
  104. Which Cam to get???
  105. LS! to LS6 PCV conversion question
  106. rocker arm question
  107. Need Comp Pro-Magnum help
  108. TSP cam
  109. TSP Majic Stick 3 and idle.
  110. Bogging, Stalling, All of the above...Help!!!
  111. Stock Cats from a 2000 to a 2001
  112. 2003 Z06
  113. help!! car starts to stumble!!!
  114. which cam
  115. HELP with Valvespring install!!!
  116. Need help installing Manley springs
  117. 422 ci start up, no oil pressure. How long to wait till the gauge moves?
  118. Holding up Comp "R" lifters
  119. Nut size....
  120. Lingenfelter GT2-3 Sleeper Cam
  121. AFR 225's flowed by TPIS in June issue of Hot Rod
  122. cam?
  123. Valve Train noise
  124. Magic Stick V3 power
  125. Need some compression check please...jrp or someone../
  126. Porting and polishing stock heads worth it?
  127. C5R port vs. LS catherdal port
  128. Need help on cam choice for 370?
  129. Changing Cam's. how big can i go??
  130. AFR's, F13, and LG's on their way.
  131. Help!!! Oil leak
  132. Too much oil pressure?
  133. Complete list to build forged 347
  134. What type of head gaskets come with Patriot heads??
  135. Oil pressure problem
  136. Is this cam to big??????????
  137. No difference after can/intake swap
  138. Things to check that could cause low trapspeed.
  139. few LS1 motor build questions...
  140. Oil pressure
  141. 427 Ls1
  142. Question Regarding Heads/Compression...
  143. ARP Mainstud Toque Specifications
  144. Best conventional oil for high mileage?
  145. Ferrea Valve Springs?
  146. Is my oil pump bad
  147. need advice
  148. Tight lobe, Advance cam? Tuning issues?
  149. cam w/d-1sc
  150. Independent TEA Stg 3 LQ9 head flow
  151. Cam Going In, Valvetrain Questions...
  152. cost of a UOA?
  153. Cam installed. Now some problems.
  154. Rod material, diffrences.
  155. Will i have any kind of clearance issues with this setup?
  156. Lifter Tool??
  157. Who is good for custom cams?
  158. Changed oil today... strange finding! Motor Oil gurus pls step in..
  159. Valve sizes...
  160. What else can you use with the BGRA?
  161. Need Help....Crankshaft oil deflector...
  162. cam question
  163. Any A4 running Comp Cam 216/220...what rpm is your idle set at?
  164. when i turned the heat on the car started to bog and act funny. help!!
  165. Anyone got a ballpark estimate of the RWHP/RWTQ i will have??
  166. Which cam?
  167. Cam Package Install prices???
  168. Roller Rockers??????????
  169. Texas Speed 408 - 256/266 .640"+ Hydr. Sound Clips & Specs
  170. Found the reason for my misfiring
  171. 232/228 .595 .588 112????
  172. TR220 passed CA emissions...barely
  173. I Just Want My Cam :*(
  174. Cam questoins,Best power with no headers.....
  175. Where to get the Tony Mamo AFR 224/228 cam?
  176. A Factory Chevrolet Ls6 Z06 Camshaft
  177. anyone runing the TSP Tourqer Cam??
  178. Do I need titanium retainers?
  179. what kind of power...
  180. 1.8 rockers
  181. Sdsp 2005 Cat.
  182. official numbers
  183. oil pressure and German Syntec
  184. preload question
  185. MTI R1 vs F13
  186. bigger valves in afr 205
  187. Anyone ever heard of a 4,7, timing swap?
  188. CFM is CFM right?
  189. Heads - 300cfm.. is it possible?
  190. Lunati rotating assemblies
  191. Fm13 Just installed TODAY...
  192. Who's got the Free Ram Air mod?
  193. Lets make my car fast!
  194. First Track Trip W/New Car Okay Times + Major Leak, Please Help!
  195. Precision Race Components CNC Machine At Work!! #2
  196. X1 Cam question do I still need a stall on 114lsa.
  197. Oil Pressure 60 to 30 to 60 after start
  198. O2 sensors
  199. Help!!!
  200. Where to take an oil pressure reading?
  201. what pushrods for g5x3 cam?
  202. Cam Question
  203. can running too rich harm anything??
  204. f14 cam too much??
  205. biggest cam with 59 cc ls6 'style' PP's
  206. big cam question guys
  207. Where to buy eagle rotating assembly..
  208. 205cc or 225cc?
  209. which cam?
  210. Looking for someone to port my pp ls6 style heads
  211. What cam?
  212. ARP head bolt broke in block, whole thing trashed?
  213. best small cam?
  214. Bigger Injectors?
  215. Replace Valve seals.. what's involved?
  216. Pros and Cons of +4 On A Cam
  217. Comp 921's
  218. damage to the crank?
  219. What can cause a roller lifter to turn during operation?
  220. ? for PRC
  221. Help, Big Cam Need Advice!!!!!!!!
  222. How much would i gain??
  223. What Gas for 14-13.5 to 1 Compression?
  224. Cam Question
  225. list all the "Free Mods"
  226. Pushrods, anybody using Trick Flows?
  227. going from lunati 224/224 to lunati 232/232???opinions needed!
  228. Need opinions... Should I get the HS rockers?
  229. My cam results
  230. Noobish question about "tunes"
  231. Possible knocking close redline(already searched)
  232. what spring kit????
  233. F13 shift points/rev limiter
  234. porting heads
  235. where to get these valves??
  236. QUICK which place gives best deal on.
  237. F14, LSX, Boltons = ?
  238. z06 cam & heads on ls1 engine?
  239. Engine guys inside please... Weird smoke...
  240. cost of tear down, hone, and build
  241. When Fly-cutting pistons...
  242. quick question
  243. RPM Gauge doesn't work right away?
  244. Who has the best price on Comp Cams parts?
  245. Missing some Horsepower need help* sponsors
  246. what happened to my motor?
  247. Cam only???
  248. F15 Pvc ?????
  249. Calling Out the LSx Tech Gods
  250. Crank Bolt
