View Full Version : Generation III Internal Engine
  1. Tony@AFR: G5x3 & AFR 205 *LONG*
  2. headers
  3. Can Futral F4 cam pass dyno-emissions test?
  4. opinions on TR230/224
  5. performance shop needed?
  6. I'm thinking about getting a cam for my car but I dont know which one for my setup.
  7. What to do with an LS1 while the motor is out
  8. Need stroker engine, what to get.
  9. Low Oil PSI
  10. redline for FM15?
  11. Opinions on this setup
  12. G5X2 or TSP 233/239 R2? Please help me choose
  13. new disk
  14. whats the diff with the casting #'s
  15. Do Cams wear out?
  16. What gap plug for this combo?
  17. Please Help! Cam Selection
  18. what springs to run on XER lobes?
  19. dyno oil vs synthetic after H/C swap
  20. weight of stock piston from a 6.0 ???
  21. Small Combustion Chamber Dished Piston N/A Motor Discussion
  22. Where did you mount your remote oil filter?
  23. Does anyone use Oil additive such as Lucus, slick 50 etc..
  24. lobe intensity on T-rex(advertise duration)
  25. A.R.E a tour
  26. am i robbing myself of power??
  27. selling mti stealth 1 cam if anyone's interested
  28. 5.3l heads on a 5.7l
  29. cam gurus in here please
  30. Best place/shop for custom ground cam?
  31. Oil Change?
  32. What are my options now?
  33. I thought AFR were the only ones with a new LSX head(guess not)
  34. Carbon on the pistons
  35. Cam Suggestions for WS6 w/LS6
  36. 233/239 Track Results
  37. cam choice in a month
  38. bumpstick question?
  39. standard or reverse split?
  40. Water pump gasket question?
  41. Any More info on All pro heads ?
  42. This is what the knocking was...
  43. recommended gap for 10.5:1 milled heads
  44. Ignition module
  45. is this street-able
  46. Differance between a 114 lsa and a 112 lsa on a 224 cam
  47. What years did the 6.0L come in the trucks...
  48. forged internals- How much can you do yourself?
  49. Any All-Pro head results yet?
  50. Tony/AFR
  51. Question on cleaning heads...
  52. missing at idle
  53. P to V clearance? ease my mind...
  54. BIG question on AFR's
  55. should I RTV bottom of timing cover (99 frc)
  56. Bad valve seals or Mac's?
  57. Aiming for 500rwhp
  58. Help me with parts please!?
  59. H/C/I install (Pics) Nothing special
  60. Damn ARP..
  61. So whats the best small budget thing I can to for Heads?
  62. port match 90mm LSX intake for 205 AFR heads
  63. New rollmaster timing chain is loose
  64. Low mileage 409 piston skirt damage
  65. Sorry, another preload question
  66. Heard it a couple times now...(timing chain)..
  67. MTI X1 cam and flycutting
  68. Aloha Gang Cam Question
  69. P&P HEADS
  70. Removing Valve springs & retainers?
  71. Guesstimate- How many HP?
  72. 5w30 or 10w30
  73. Wiseco Pistons?
  74. Best way to build a 427?
  75. Why don't LS1's use BIG cams?
  76. Replacing cam bearings
  77. Water Pump
  78. Compression Ratio
  79. stroker or not?
  80. Mti Info
  81. power increase
  82. oil presure problem after h/c swap
  83. stock reground crank?
  84. MTI stage 2E head E/I port ratio....
  85. Anyone have the P/N for lifter cups?
  86. the new mobil1
  87. PP heads cam rail mounted rockers package?
  88. 455 c.i. LS1
  89. gm hot cam
  90. 90mm throttle body
  91. swapping cam and valve springs soon
  92. PISTON & boreing question
  93. What year of LS6 springs are these(Orange Striped)?
  94. Does Absolute Speed etch numbers on their heads?
  95. new engine with low oil pressure swaped oil pumps still happening
  96. rattling sounds.....
  97. whats ARE's website?
  98. tap for head bolt holes
  99. Knock Sensors
  100. Got my TSP 225 today...
  101. New TSP ported LS6 oil pump
  102. 00z to v6 swap, long list of parts.....
  103. My understanding of exhaust flow w/ a pipe
  104. Cam Install.. I'm freaking out... PLEASE HELP!
  105. cam on the way! WAHOO
  106. best way to bleed air outa the system
  107. AFR 225 Flow on 4.030 Bore....
  108. LS1 to LS6 parts??
  109. Lock-tite on cam bolts?
  110. Cam discussion: Exhaust Valve Opening Points
  111. ? for those with decent size cam
  112. Got the cam, help me make a list of everything else
  113. Stock shortblock cost
  114. Lower End Knock
  115. Compression????
  116. what are the best factory heads to port for my application?
  117. SLP PerformacePac: Bad News
  118. will i have to get my lq9 heads machiened
  119. G5X2 cam is in!!!
  120. G-Tech pros on Ebay
  121. ANOTHER head and cam question
  122. opinions on stroked 427? 4.030 bore, 4.125 stroke
  123. How much can I mill my heads?
  124. ZO6 H/C numbers, What do you guys think?
  125. small block and long block
  126. TR224 cam, opinions?
  127. Jesel 1.8's and a Lunati cam
  128. Need some LS6 engine advise
  129. cam decisions, I am torn on what to buy!
  130. Crane Accelerated ramp rockers???
  131. ? about power
  132. Where is the best place to get pushrods.
  133. Racetech customer service
  134. read this!!!!
  135. Carb. on an Ls6
  136. Cam Sensor
  137. Diagnosing a bad lifter (Comp R)....need advice
  138. Will this H/C combo work?
  139. 799 casting???
  140. Install new oil pump on '02 SS, yay or nay?
  141. Cam Specs
  142. ls1 crank
  143. opinions on mobils new oils
  144. New LS1 owner needs help
  145. Budget cam only need titanium retainers??
  146. Precision Race Components Cylinder Head Specs & Pics!!
  147. First mod to my Truck
  148. valve springs
  149. Anyone using the COMP 941 valvesprings?
  150. ls2 chain, gaskets, 85-90mm bellows?
  151. Actual LS1 stock thermostat reading inside!
  152. Good set of heads for my cam?
  153. Engine vibration
  154. 160 Thermostat Too Cold?
  155. Is this healthy
  156. new heads, now searching for new cam
  157. Heads compression help
  158. LS1 vs LS2
  159. thinkin of changing cam
  160. LS1 crank > should I lighten or modify it?
  161. most accurate way to check P-V clearance
  162. Your method of break in after cam
  163. Got it running!
  164. easy dumb question
  165. Eagle 4.10 vs Callies 4.125
  166. 224R cam...thinking of maybe 110LSA
  167. fm 13
  168. installing 6.0 block
  169. Cam install problem
  170. Help w/ choosing a cam
  171. WCCH Heads arrived ! Pics inside !
  172. Question on 78mm throttle bodies
  173. new cam in my 01 Zo6
  174. Oil Pump Pickup tube: optimal clearance from oil pan?
  175. Ls6 Cam? Too Mild?
  176. gtp heads milled question
  177. Lost Plug!
  178. I'm new to ls1's and help on picking oil
  179. engine shaking
  180. Swap heads, keep cam.
  181. need help with heads and cam decision.
  182. need fm13 soundclip
  183. what causes bent valves and how do you know if they are bent?
  184. LSA and ICL of new LS7 cam?
  185. LS1 , Cubic inch question
  186. So my valves and pistons must've fell in love
  187. 5 bent valves? help needed
  188. H/C Upgrade - Are we happy yet?
  189. When should i change my springs?
  190. What's the biggest cam with a stock converter?
  191. measuring cam lift?
  192. Exhaust port question
  193. Ok I wantto go to a bigger cam in my 408. Will I have tunining issues???
  194. AFR head only swap. questions inside
  195. What oil to use for break in period? Nondetergant?
  196. What Would Be The Difference W/ These 408 Setups?
  197. how much lift
  198. 02+ ZO6 head gaskets on a 99 LS1
  199. Edelbrock's carb+intake for Ls motors. Any comments?
  200. Recommended shop in Fl. for flowing heads?
  201. what lsa would you recommend for a 408??
  202. question with oil
  203. cam?
  204. Need help, stumbling badly after sitting all winter
  205. 20k mile fluid changes...any recommendations?
  206. Trex/MS3 and 6.0 heads
  207. math gurus, ptv question
  208. LS7 GM crate motor part# = 1782397
  209. gm top engine cleaner
  210. TEA heads to match an FM13...
  211. How To Determine Cam Specifications of an Unknown Cam
  212. Intake Manifold Flow Test
  213. Timing Chain Question?
  214. H/C Upgrade - Driver's side very lean
  215. added AFR205s to my 230 cam
  216. 99ls1 in 98z
  217. ppls6 style heads came in today and ...
  218. What do stock LS1 heads flow?
  219. cam
  220. Guys might wanna check out TSP, some prices are $0 dollars! haha
  221. Flow CFM on Stock LQ4 Cast Iron Heads
  222. anybody have PP adj. rockers?
  223. Cam specs
  224. Compression Ratio ?'s
  225. Hot Cam installed, what else needs to be done?!?
  226. Stock LQ4 Cam Specs
  227. quick oil pump question.
  228. How important are head studs?
  229. dont know the specs on cam
  230. Patriot heads
  231. big cam statement
  232. ATTN: patman Syntec 5W40
  233. Does new Oil Pan from GM come with the gasket?
  234. Opinions on my Setup
  235. machine work for a 4" stroke LS6
  236. Installing TR224 .563 112 LSA & 918 Springs
  237. Cylinder Head Help!!!
  238. cam install? timing?
  239. Ive seen it all.....need HELP
  240. super seven locks?
  241. Engine Misfire, top end noise problem. PLEASE help!!
  242. Timing chain....sprockets?
  243. Head choice, couple questions
  244. Reusing Stock Retainers
  245. Curing piston slap?
  246. After revving I get popping noises... normal or not?
  247. After revving I get popping noises... normal or not?
  248. Can someone explain "Squench" to me?
  249. Wrist Pin Noise Questions
  250. Patriot Performance Recall
