View Full Version : Generation III Internal Engine
  1. Cam install $$$
  2. Does anybody else have these cam specs or cam?
  3. Top End cleaner Ok for cleaning AL Heads?
  4. G5X3 what timing with 93 octan?
  5. Help with possible future set-up
  6. cam bearings, retainers, seats???
  7. oil pressure,wtf!
  8. Closed/Open Valve Spring Pressure for .510/.521
  9. Cam Motion selection help please
  10. Hotcam?
  11. hypethetically, if a car made 525rwhp on a 11:1 comp. ratio,how would it do on a 9:1?
  12. g5x3?
  13. What is the correct way to ajust RR
  14. How much is a 3 angle worth on a stock head
  15. Flow numbers for GM Perfrmance parts LS6 CNC heads????
  16. 317 Heads, Worth it?
  17. Need help.. dropped a lifter.. arrgghhhh
  18. P2V clearance with TREX on the stock bottom end?
  19. what is the biggest cam u can run with a 5.3 liter head
  20. what lock for Dual Gold Springs?
  21. So Im walking around autozone.....
  22. Cylinder Pressure Observation On 2 T/R Cams
  23. newbie question
  24. TEA heads are back
  25. How many needles in an OEM LS1 rocker arm?
  26. How much rpms can the stock rods handle?
  27. cam for 408 N/a??
  28. (pic) What's are these stuck to the oil drain magnet?
  29. Big cam in Stage III heads..
  30. Just curious...H/C question?
  31. Head Polishing?
  32. How much can you retard cam to increase Pto V clearance?
  33. i am new , i need some cam help ! PLEASE
  34. LS1 will be part of the Engine Masters Challenge. .
  35. What Cam?
  36. LS1 with truck internals?
  37. Whats a safe DCR for running pump gas with no problems (including in summer heat)
  38. Looking for Grand Am cam sound clip
  39. Rebuilding- which piston rings (GM or ??)
  40. MTI Y1, LG G5X3, TSP MS3 or which other cam?
  41. Cylinder heads should be rated...
  42. Gaskets
  43. would this work ?
  44. TSP Torquer ok on stock 3.42 m6?
  45. screw it... im ordering it!!! side note: cam gurus ever fig. out lobes on 233/239?
  46. worthwhile swap?
  47. AFR head question
  48. please help ls6 question
  49. TSP 233/239 Info?
  50. Heads From 346 Going On 402
  51. TR224 installed in a C5
  52. Anyone heard anything about the new ThunderRacing 230/236 cam?
  53. Oil Pan Removal
  54. why dont we see more 228 cams????
  55. Eagle H-Beam Failures?
  56. Head Milling ?
  57. Need a resolution guys...
  58. home port job on heads?
  59. ticking valvetrain
  60. 981-16/GM Hotcam?
  61. Throw away NEW Comp 850 lifters?
  62. Spun rod bearing. How much to repair?
  63. Stock size ring recommendation
  64. Valvetrain Geometry
  65. Switching cam is it Worth it?
  66. Well here is the final list, I think.
  67. Decking of aluminum block, deck height or iron liner etc
  68. ls1 knocking?
  69. G5x3 ??
  70. East Side Performance heads!!!
  71. Anyone need some Lunati dished Pistons????
  72. comp oe lifters 850-16
  73. Track times?
  74. Happy Valentines from HPE
  75. Who's happy with their LS1 setup?
  76. cam card for TR 224
  77. are all 4340 parts considered "forged" ?
  78. Any Ideas On Cr ?
  79. 2.4Litres diesel engine camshaft, valvetrain & timing
  80. TR224 valvesprings , pushrods, lucks, retainers !!
  81. comp rockers keep coming loose ?? HELP PLease !!!
  82. 500fwhp stock heads.
  83. reverse split?
  84. Will LS1/6 pass for 95 GMC truck standards?
  85. Electric water pump and underdrive pulleys?
  86. how to vids on head porting
  87. who has used mahle pistons?
  88. OH NO!!! gasket on front of timing cover ruined
  89. just ordered TSP 235/240 on 112 anybody have a sound clip
  90. Which is a better cam?
  91. 6.0 use 2 diff. length cranks?
  92. Look what I found on LS2......lol
  93. Backfiring on the dyno ... too much smoke ...
  94. 668.3 HP From Chev 377"!!!
  95. new engine..trying to get oil pressure by cranking
  96. **H/C setup, missing anything?**
  97. OEM LS1 main bearing clearance - some very general q's
  98. cam questions?
  99. higher ratio rockers ?
  100. Which valve seals to get for head rebuild?
  101. Trouble shooting help please.....
  102. cam question.....
  103. Help with my new 383 storker.
  104. Cam for a stock A4?? Which one?
  105. What heads for a stock cam?
  106. How many DIY'ers degree cam?
  107. castrol syntec
  108. gasket difference?
  109. agostino stage III heads too big??
  110. Mti 236/236
  111. vavle seat pressure
  112. hand porting 5.3 heads
  113. Cam swap
  114. Engine theory and flame travel
  115. C5r or Ls2 block
  116. When on the AFR 225 small chamber heads?
  117. Broken Valve spring, dinged pistons, rings okay???
  118. Where to buy Ferera valve springs for LS1??
  119. TRex cam owners inside...anyone probs???
  120. What kind of power would you guys forcast for my 408?
  121. should I change my springs and pushods
  122. LS6 346 to 382 Forged
  123. What heads for cars runnign nitrous?
  124. How are you guys pulling the motors?
  125. High pressure oil spring
  126. Um yea....really need some help!
  127. anyone tried these?
  128. True cam specs of stock '04 GTO? I don't believe it
  129. Better daily Driver Cam… TSP Torquer or 233/239 or HPE “S” Cam or what?
  130. My quote from Patriot I have some concerns and questions. You guys know your sh!t....
  131. Cometic head gaskets and GM head bolts?
  132. So whats the opinion on Rockers & Lifters now...
  133. To "383," or not to "383"... that is the question
  134. okay what am i leaving out
  135. 6.0 and LS1
  136. Tsp231/237 Hp???
  137. Need head advice
  138. TSP 347 w/ MS3 and AFR's up and running
  139. Any A4 heads and cam guys on stock 10 bolt?
  140. Help Fast Ls1 Or Not
  141. Rocker lift calculation 1.7 vs 1.79 vs 1.89
  142. warmup time for patriot gold duals?
  143. Is this normal? (Gunk on cylinder walls)
  144. Max lift on LS6 springs >.600"?!?
  145. Camshaft Swap Complete!!! Thoughts inside!
  146. Im Going To Lose It Please Help
  147. how do i do this
  148. timing chain guide???
  149. So what exactly causes cam surge?
  150. install today or tomorrow
  151. what length pushrod?
  152. 5.3 heads
  153. Where can I find a 1994 3.4L Olds engine?
  154. PSYCHED! TR224/224 & 918's on the way!
  155. oil pressure question
  156. simple question
  157. Found the Problem
  158. So whats the secret to lining up the front and rear covers/main seals on LS1 motor?
  159. Internal Gurus I need help!
  160. 2004 ls6 valves strong?
  161. Shimming the rockers w/ AFR's cut .030....gotta do something
  162. o ringed 6.0 iron block
  163. oil pump
  164. Requesting a TUNED FM13 sound clip. Anyone have one?
  165. Y-pipe set up?
  166. will manley 2.02 1.6 valves fit on a stock ls1 head?
  167. O-ringed heads: Gasket alignment
  168. rocker arm question
  169. How to tell if head has been milled?
  170. Dyno Results- AFR Heads + Mild Cam
  171. Do you need to have the rods resized after ARP bolt install?
  172. stock head gaskets
  173. header gaskets, which ones
  174. Do these heads look like they have less than 100 miles on them? [PICS INSIDE]
  175. stock replacements????
  176. When to run dual springs?
  177. does it take any "special tools" to do a cam swap?
  178. Dirt in cylinders
  179. Asp Pulley Problem Need Advice
  180. Idle and running Problems - Update
  181. Question about intake
  182. another cam question...
  183. just got some heads now a cam?
  184. rocket scientists' baffled..no oil pressure 1 min. then full the next!!
  185. Highest N/A RWHP?
  186. Quick cam question.
  187. Can somebody explain to me why engines perform worse at high altitude?
  188. Advertised duration for F13, F14 and TSP 233/239
  189. All APE engines now using........
  190. Problems after cam install. Please help
  191. Cam selection
  192. AFR Install
  193. wasn't sure where to put this so here goes..
  194. porting intake
  195. Do FMS cams use XE or XER lobes?
  196. 987 springs??
  197. How many?
  198. thermostate temperatures
  199. LS1 to LS6 block swap
  200. Identifying camshaft
  201. Anyone kno "elgin"
  202. Slimming down the beast
  203. torque specs.????
  204. another cam question...
  205. which head gasket to go with for AFR
  206. biggest spring dia. for ls1
  207. Cam..EMISSIONS?
  208. what to do?
  209. Cometics and leaking....
  210. Questions about comp 978's
  211. New LSX series crate motors from Busch Builder
  212. Took heads off car, need advice on possible problem...
  213. LS6 / LS1 Valve Spring Questions
  214. Comp XER 232/234 .595/.598 112LSA?
  215. Which heads to go with FM13 Cam to get close to 450rwhp?
  216. Need advice on heads
  217. Checking P to V clearance
  218. Help with heads, SCR, and DCR in truck application.
  219. EGR question???`
  220. Looking to buy a manual SS 70k mileage..scared?
  221. rusted slevees
  222. 5.3 heads on 6.0 liter engine?
  223. Cometic thickness questions....
  224. Patriot Head question: does the stock valvetrain fit?
  225. LQ9 heads on an LS1
  226. f13 choppy ?
  227. Another game of "guess my power."
  228. Oil Pressure Problem
  229. strange tick from motor
  230. LS7 heads on LS1?
  231. service engine light
  232. 01-z and other g5x4 guys...
  233. Timming Chain???
  234. Patriot Dual Valve springs
  235. Sanity check - MLS head gasket p/n?
  236. car wont start..help
  237. 918's or dual springs for TR 224/224 .563???
  238. Y1 Cam power ratings
  239. My Eagle 383 stroker story told...
  240. change in cam choice
  241. Am I Right?
  242. Maximum cylinder pressure of LS1?
  243. beefing up bottom end while adding more hp?
  244. If 100 octane gas was available.......
  245. New Motor Smoking for 5-10 minutes after each cold start
  246. Breaking in new cam
  247. Ordered my Cam :)
  248. need a head and cam package for my gto
  249. eagle stroker kit in summit racing
  250. Block Thermal Expansion
