View Full Version : Generation III Internal Engine
  1. rocker arms with my h/c setup???
  2. Knock retard
  3. can someone walk me thru this top end cleaner method???
  4. Precision Porting Heads
  5. Question about cam timing with hydralic lifters
  6. Camshaft parts question..
  7. With all these porn star cam names, what would the peter north cam be?
  8. stock head gaskets
  9. Pick a cam
  10. Need info on gasket/bolt parts for replacing cam and heads
  11. Opinions on Hot Cam...
  12. 160 thermostat
  13. Need part # for oil spout and cap
  14. Trans cooler lines
  15. reverse split pros and cons?
  16. What Cam For Stock Ls1
  17. Thickness of the spacers that come w/ Yella Terras?
  18. AFR 205's?
  19. is this pushrod bent? *pic*
  20. Deck height?
  21. i have an LS6 block!!!
  22. Will Crane Have Its New Shaft Mount Rocker For LS1 Heads
  23. new toys going in the week
  24. Mystery Cam ..... Questions????
  25. Cam and supporting mods
  26. Need help ASAP
  27. Nitrous LS1?
  28. Damn. I can't believe I'm askin you guys If I have to worry about a NEON? GRRR
  29. 98' block...3.903" possible?
  30. 5.3 bored to 5.7??
  31. Patriot Heads?
  32. Short and sweet > what heads/
  33. Have we really gone from the race track to the dyno now to flow bench comparisons?
  34. If you installed Comp Cams 'R' lifters, please post here.
  35. Hot Cam Cam Pro Data
  36. 98 heads ?
  37. Stock rockers w/ big cubes
  38. what is the compression ratio with AFR's
  39. Cammed Stalled cars, what cams do yall run?
  40. "862" cast in head..is this 5.3 or 4.8??
  41. will 7.45 pushrods work on a stock engine?
  42. Comp cams question....
  43. flow numbers for tsp 5.3 2.5
  44. What therm R U running?
  45. machine shop around buffalo, NY
  46. Here is another "advice on cam" thread!
  47. valve springs
  48. rocker arms
  49. Cam gurus help me choose a cam...
  50. oil press sensor question
  51. Tranny fluid in the motor.
  52. warming up the car with new springs
  53. Dyno numbers or track times for Hotcam without longtubes?
  54. A little help here!!
  55. Year-vs-Heads
  56. Safest Bore?
  57. lost a keeper HELP
  58. LS1 and LQ4 Compatibility
  59. LSX or LS6
  60. Valve to Piston Clearence Question?
  61. Yes, Another cam advice needed thread
  62. XER cam lobes and lifters
  63. What makes Comp "R" lifters necessary?
  64. Saw this On Ebay
  65. neone running the tsp magic stick with spray in a A4?
  66. Diamond Forged Pistons
  67. TR 224 Cam, what parts to go with?
  68. Yet ANOTHER head thread (5.3's)
  69. Head casting numbers
  70. machine shop head issue. valve seat?
  71. Comp 228 Cam
  72. How long do aftermarket springs last? on avg?
  73. How much can I get a LS6 engine for???
  74. Need Evap Control Valve part #
  75. FM13 or MS3 for a daily driver
  76. Heads and cam removal ???
  77. lifter ?
  78. Head & Cam setup... Will it work????
  79. Valve Springs and Specs List
  80. magic or not
  81. Anything you ever wanted to know about your ls1 fbody
  82. Where to get oil pump spacer for Roll Master chain?
  83. putting in a 402
  84. LS6 Cam Question?...
  85. easiest way to make 500hp on a '02 Z06
  86. I Need Help! Installing Hs 1.8 Roller Rockers
  87. Need a good "How To" for LSX engine building.
  88. Anyone Tried a TSP 235/240?
  89. What heads with my 224 cam?
  90. do I need a retune?
  91. TR224 + MTI 2R LS6 = Overkill?
  92. Not a "what cam thread", but help me with the extras please
  93. Patriot Lock Fitment Issues, Maybe There is Another Reason.
  94. Are these Patriot "gold" springs?
  95. Cylinder head airflow question
  96. G5X2: What heads, pistons?
  97. .042 stock bore affordable head gaskets
  98. ls6 cam
  99. LS1 Oil issue.
  100. question about stroker cranks
  101. newbie heads/cam install
  102. quick cam question
  103. Q/A After Hot cam install
  104. How the hell do you get ahold of Terry/Racetech for PRC springs?
  105. longer rods for 224/224 .581 cam?
  106. iron block main clearance
  107. any help much appreciated!!!
  108. Coolant leaking
  109. What Mod should I do next?
  110. J-Rod, JRP, 93Pony.... others who know cams
  111. Is the Comp or Cloyes timing gear
  112. Rattling Sound
  113. Who have a 382 stroker?
  114. Any difference between LS6 parts in 04 Z06 v.s. 02 or 03?
  115. Guys that have F4 and F10 Cams come inside
  116. 3 valves per cylinder
  117. CNC Inc. heads
  118. Cam-how big with stock pistons
  119. Compression question
  120. Dual-Springs Kit?
  121. Cam question
  122. I have 2 similar cams, which one should I use?
  123. Comp R lifters??
  124. Adj. rockers
  125. New Phone Number!
  126. A4 guys with a cam come in
  127. F13 Cam in and fired up!
  128. Ring Placement
  129. What puller and where to get cam lube???
  130. So who's done a motor swap on a Vette?
  131. how hard is it to take off heads and pull cam on stock LS1 engine
  132. TR220 cam specs
  133. I've got a bad tick, need help guys.
  134. 228/232 cam, anyone making good power?
  135. HPE S Cam, MS3, TSP 233/239?
  136. LS1 wouldn't run after a WOT run
  137. Importance of correct head gasket on sleeved motor
  138. 226/228 or 230/227?
  139. Fuel additive/octane boost question
  140. Got my heads flowed today
  141. Any new AFR results/track times
  142. Biggest Cams in a 346ci A4
  143. I just ordered my new cam (TSP 233/239)
  144. alternator problem found! need help
  145. ms3 lifter question
  146. Intake Questions
  147. what is the best ls1 street cam ? not to radical
  148. Anybody lookin at the LPE 350 block?
  149. 98-00 Cam Pro Data
  150. timing advance questions
  151. alternator problems after cam install...
  152. I need some used Roller Rockers for a Ls6
  153. air fuel ratio with a cam?
  154. NLP 2002 Z06 AFR Heads/Cam Results w/ Minimal Mods
  155. Balancing question
  156. 242/252 .595 cam question
  157. Are 4.8, 5.3, 5.7, and 6.0 rockers the same and interchangable?
  158. After head swap, oil pressure gauge shows ZERO HELP
  159. spun a bearing?
  160. What can I rev to NOW?
  161. WSJ article - New C6 ZO6 now 500HP???
  162. Calling MTI, FI cam question
  163. stroker vs all bore - what is the difference
  164. should I wait until after the power tour for the cam swap
  165. MTI stage 2E heads and G1 cam....good match???
  166. 346 CID swap to the 427 CID C5R
  167. Which Rod Bearings?
  168. cam install pics
  169. Metalic Rattling Noise? What is it?
  170. 224/228 114 cam
  171. 427 build...advice and where to get the pieces?
  172. tea 1.5 Tr 224 dyno results
  173. Please, Help me make a decision
  174. Upgrading lifter/Magnum
  175. Big difference between TSP Torquer (233/233) and TSP 233/239?
  176. With this cam which gears?
  177. Motor Locked, Need Serious ASAP help
  178. cam tuning
  179. Gear Drive
  180. EMERGENCY!! Fuel System help!
  181. Cranked It Over First Time - NO OIL PRESSURE!!
  182. Anyone running an LS1 intake in a cam only car???
  183. Ticking noise...?
  184. Help: Cylinder 1 Rocker Keeps Breaking?
  185. Anybody ever put a cam in with stock manifolds?
  186. What's needed for a LS2 chain upgrade?
  187. Solid Lifter Oval Track Lobes for the Street?
  188. is it worth it to install a bigger cam?
  189. Anybody use timesert?
  190. Reluctor ring.. Who can install??
  191. Anyone running sheet metal valve cover??
  192. Any Shops In Tulsa Ok Area?
  193. firing up my new cam for the first time tomarrow...
  194. Front Seal?
  195. Are heads worht it??
  196. Z06 Cast #?
  197. Ticking from passenger side
  198. AS Stage II 5.3 head pics
  199. stg 2 or stg3 big bore 4.125
  200. picked up 35 rwhp with GT2-3
  201. i NEED help choosing my new heads.
  202. MTI Y1 cam, what springs?
  203. bore and stroke combinations sbc bbc vs. gen III
  204. what year 6.0 do i want to buy?
  205. ATI hub install
  206. Jesel SS Series install?
  207. stock lifter preload.
  208. Can you cut a valve relief .060 deep in a stock piston and not cause problems?
  209. yes another Vinci head test
  210. Spring Question
  211. What should I get? 382 stroker or 388 all bore?
  212. patriot LS6 stage 2 heads.....is my piston to valve clearance ok?
  213. 6.0L crank Question
  214. some interesting differences i found between LS1s and 6.0L
  215. valve clearence question
  216. stock head volume cc's
  217. Which timing chain works with ASP Pulley?
  218. How long to ....
  219. Higher Compression cheap??
  220. High Horse Power strokers and ARP studs
  221. so i have an ls6 block
  222. Cam and Gears question
  223. AFR Springs, How do they handle cold?
  224. At what point are different length pushrods necessary?
  225. TSP MS3 dyno results, kinda dissapointed (kinda long)
  226. valve spring locks
  227. Cam Question
  228. **mrr23, bigdsz and tech related info**
  229. Ok Cam guys
  230. 408 and complete drivetrain - est cost?
  231. who uses a Comp 222/224 112 come in....
  232. SES Light
  233. Should I get Patriot Stage 2's or should I get my stock heads p&p'd?
  234. Paging Total Engine Airflow!!!
  235. Block casting of LS6 versus LS1
  236. Flow # questions
  237. Stall and cam help?
  238. Has anyone put together a stroker motor faq?
  239. Advanced Pre-Load Question, T&D Shaft Mount Rockers?
  240. How about an AFR TECH THREAD...
  241. Proper valve spring/camshaft break in?
  242. Help - crank reluctor wheel contacts the block
  243. just my luck
  244. Antifreeze?
  245. oil soaked spark plug
  246. MTI G1 cam
  247. 04gto owner. and i am a retard when it comes to heads/camshaft
  248. how do you determine your compression ratio
  249. Having a 402 built, how do I know it's really a 402?
  250. APE 408/ET Perf Stage 3 6.0 Heads
