- Patroit Performance Heads Specs & Lingfinger Head Specs
- Help with a Cam? Drivability with heads and this cam? Need some input.
- MISSING bearings?!
- First drive: 383 Stroker - I LIKE IT!
- 4 Degrees advance ?
- Looking at the Futral RJ cam.
- Solid motor mount plate, shaving water pump
- When putting a motor back together what bolts can be reused and how..
- Anyone Done This.....
- What size hole? TB blade (G5X3/114 cam)
- help please!
- P0342 and P0343 codes since new engine installed
- quick question about double roller timing chains and asp pulley (search is down)
- will this work?
- Question about ATI super damper..
- 10/11 sec. cam ONLY cars come in...a thread 4 those looking 4 the ultimate drag cam.
- SES Light, P0404, P0153, P0155 ... and low dyno #'s
- Taking out the LS1....a few Qs
- new cam installed, when can I run it?
- How much will my idle quality change with this new cam????
- Cam dilemma?
- timing chain damper
- whats the sensor on back of the intake thats black and round?
- So...I think it's time for another cam discussion...and heads...
- 402/408 can choice revisited..
- Dumb cam question... :)
- Morel Lifter Test...
- Couple of new engine parts!!
- Parts list ...........
- cause of collapsed lifters
- Cam Degree and PTV Measurment Question
- head id
- Does the Torquer cam need 410's?
- Degreeing the cam...
- HELP!! ready for heads and cam, need advice!!!!
- how does my new setup sound
- ready for heads and cam, need advice!
- Found Sludge!!!!
- whats wrong with this setup?
- What should i use to clean Camshaft?
- Cam bearing question
- cam tuning
- Where's the HP?
- torquer vs 10 bolt?
- Anyone have cam in Daily Driver?
- milled 5.3 heads?
- Russian roulette cam swap?
- removing engine where to mount chains
- tapping noise when cold start
- Short runner manifold
- LS-1 Heads 853 vs 241 castings
- STock valve springs? Good safely to what rpm?
- 252/260 .600/.615 112 would this came be a good 408ci choice?
- anyone using a tr236 cam
- TR 220 kit ... what rockers?
- solid vs hydralic rollers
- 5.3 Flow Numbers Are In.
- Any one o ring there block?
- paging TEA!!!
- Need to change pushrod length going from YT to stock?
- Spring question related to breakage.
- Anybody ever heard of Corteco Gaskets ??
- 2.08" INtake valves on a stock bore?
- Heads/Cam going in...It's an odd combo so I've got a few questions
- latch and preload??
- zq4??
- T-rex on a stock 02' SS????
- Newbie Looking for some technical writeups
- Bigger Cam or LS6 Heads?
- Escalade engine
- FM13 vs. TSP Torquer
- I need serious help!!! What should I do???
- LSX question
- Morel lifters from 7.40 to 7.20 push rod
- comp pro magnum rockers
- headers?????????
- High-Mileage block, okay for re-build?
- Katech Vs. ARP Rod Bolts?
- AFR 205's with .024 mill questions
- New cam is in, but very very loud clicking
- Why use larger cams on larger motors?
- Someone help, need carfax report!!
- New York Emissions ideas
- Stroker guys inside - post your cam specs and opinions
- Cost to build a homebuilt 429...
- Received my nasty perf. valve covers yesterday.
- optimal cam for 408
- Any oil pressure issues w/ Morel solid lifters?
- where now?
- The Best Cam Choice!!!!
- Compression ratio ?
- Need HELLLLPPP
- 85 Throttle body
- SLP head & cam packge??
- Cam install parts
- Help with lifters
- another cam question :(
- what pushrod length you guys think i should use
- cam help
- Aluminum 402ci build questions...
- Which rods and pistons?
- Spring Pressures vs Lifters, head milling vs. Pushrod length??
- heads cam combo what injectors to run
- How much power out of a 408?
- LS1/ZO6 cranks vs Forged cranks
- Partiot Shaft Mount Rocker Arms
- Performance Plus in Ft. Myers Florida?
- TR 230/224 Cam Question
- Gulp..metal in oil!
- Best Ported Heads???
- Help
- Pistons and rings being replaced, dealer doesn't want to hone.
- Eagle Stroker cranks..
- AS 5.3 Stg 2's and HS rockers inside please....
- Check out my new combo.. does this sound right?
- Another piston slap thread -repost
- Harland Sharp Rockers and Comp R's
- Crank Pulley
- Heads/Cam swap start-up issue help needed
- LH6 oil pump
- heads/cam specs
- PRC spring questions
- I Got A Question Maybe You Guys Could Help
- I'm confusing myself here which is leaner?
- Stock or Not
- hmmmm which of these cams to get...
- which heads to upgrade to
- Possible stupid question
- piston trouble
- First heads/cam buildup what will I need?
- got a bearing question
- Valvespring Compressors ???
- Is there a trick to remove the lifters
- cam ques???
- 978 vs 987 spring
- Will TSP 231/237 clear with milled heads?
- 383 (382) LS1 short blocks?
- Cam.. Stall.. a little help please
- Am I missing Anything?
- F5 futral cam
- normal rpm range @ idle? (botched Spark plug installation)
- "Interesting" Flow Comparison...
- Looking for a cam...
- what kind of gain should I expect
- dry sleeve
- GM LS6 Cam Card
- MTI Introduces the "R5D4 John Holmes Voodoo Shaft" Cam!
- Engine Break-in
- Need Help and Advice
- burning oil at idle, what can slow this down a little?
- Is it possible?
- picked out a h/c package.. wondering what ya'll think?
- dumb ass question...
- Harland Sharp rockers...
- 233/233 tsp cam with LS6 S2 patriots.
- Will 5.3 Heads Raise Compression?
- quick head question
- cam woes
- What's the best cam for these heads???
- Cool preload stuff, now a question...
- Who has destroyed a 383 or 395
- 6.0L in F-body question??
- Will this setup get me close to the 10's n/a?
- Motor problems again, please help me figure this out
- Whos running Comp cam hi-tech roller timing set,Qs
- fm14 question
- I'M LOST! Best Mods for improving low-end torque?
- comp 224/228
- Help me find the best cam for my car
- Stroker guys inside..... Oil consumption Q+A within
- Cam, lifters, pushrods, springs
- Gas on plugs
- T-Rex Cam Question.
- Custom Grind with High LSA??
- Shaft Mounted Rockers
- MONEY TO SPEND! afr 205's tsp 231/237 sounds good???
- Clean Slate - 750 HP LS1
- Oil Pressure Problems
- Lq4 6.0 Stock Cam Specs????
- how thick are the stock ls1 piston domes?
- i need help
- Which Oil is better . . .?
- how to fix collapesed lifters
- What kind of heads are these
- pushrods
- 383 question
- Bad lifter I think?? Loud ticking noise. Need help!!!
- valve clearance?
- Lifter Help!!!!
- Does this deck height sound right (427)?
- ok i put the welded lifters in but
- Carfax Request.......
- 706 Casting 5.3L heads from '04 SSR
- Timing chain for cam install?
- stock ls-6 heads, comp springs, headers...what cam?
- Heads And Cam??
- How long do the factory valvesprings last?
- 231/237
- After Heads install issues, need some help
- What to consider when picking cam?
- How do the 2001 ls-6 valves hold up under..
- best oil to use?? ATTN: Patman
- Stock vs titanium retainers.
- Recommend me a cam...on a budget.
- What Is Needed In Cam Swap?
- 85mm lid?
- 388 all bore = fun....
- Cams and FI?
- Codes P0410, P0412, and P0418?
- Ever done your own P2V clearancing? I am going to do it...
- Need Valvetrain Advice, Asap!
- Wheres everyone getting fresh stock shortblocks from?
- Simple question about head bore size.
- how to stop the oil burning when backing off???
- Car won’t idle after changing intake, PLZ HELP!
- Oil Pressure Sender
- AFR's Patriot performace "gold" springs
- What's the difference in pushrods?
- patriot heads...
- Mystery Cam Results Unmasked
- ls1 eagle rotating assemblys? any info?
- SVO 30 lb. injectors good for 420 rwhp?
- Car bucking/surging, coolant gauge dying, jumping, etc.
- ZL-402.. HP gainss??
- Some help...new to theLSx and about to buy a LQ9...
- PnP TEAs on a 402
- what all is envolved with going solid lifter?
- Crazy Idea.
- Verify collapsed lifters?
- Question about Patriot Performance Stage 3 heads.
- Is it worth going solid roller with a cam this small?
- Rocker arm question
- Cranking Pressure....who's a genius here?
- what cam does Agostino use or how to find out?
- Need cam, but MANY restrictions...
- Stock Verter and Manifolds which Cam??
- Morel lifter preload
- Stay 382 or go bigger?
- Please pick my cam for me. Is this one ok?
- Lunati Stealth Cam/LS1 heads/6.0 motor....
- Anybody know anthing about these rockers?
- TR8xi plugs
- Do you have a 3200 stall and a cam? Please help!
- Got a question PRC springs and Shims for my TEA heads
- ok, decided to upgrade my cam
- 402,408,414,422...
- Comp Cams now owns Pro Action Cylinder. .
- can anyone confirm stock cam VE?
- I guess even the cam companies are using. . .
