View Full Version : Generation III Internal Engine
  1. Valve Spring Shim
  2. what springs n pushrods for torquer v3 111 lsa in a 2001 5.3?
  3. valve springs
  4. pushrods and valve springs for MS4??
  5. Sonic testing in Missouri??
  6. Crank replacement or Tapp the Snout
  7. give me your opinions and suggestions on cam choice.
  8. Help identifying unknown cam
  9. oil trays
  10. Stock Head Gasket wit ARP bolts?
  11. is it worth it?
  12. LG G6X3 cam
  13. Internal Tune-Up
  14. engine issues or am i buggin out cam and questions to
  15. Oil dipstick bolt size
  16. Casting Numbers on Z06 Cam?
  17. Lunati LS1-LS6 OE Hydrolic Lifters
  18. How much head milling??
  19. Edelbrock 90mm TB
  20. green o-ring too tight?
  21. fast 90/90 oplnions
  22. Rocker arm torque
  23. Which rocker arms are which???
  24. HMM what to do?
  25. torquer v2 and PAC1218s
  26. 5.3 heads and ls6 cam
  27. running Ls6 springs on stock cam.....
  28. underdrive or overdrive pulley
  29. Cam...best ICL
  30. Patriot 2033 & Fast 90
  31. Milling PRC ls6 stage 1 heads????
  32. need help
  33. Machine work cost?
  34. need advice on mods
  35. 408 stroker big cam surging at idle
  36. Actual physical non-variable differences between 241s and 243s
  37. My EPS 226/234 Cam just cam in. How much HP more will it make
  38. Question on cam lift???
  39. TSP 233/239. Anyone running this on 111lsa?
  40. Head Recommendations..
  41. What's some good choices?
  42. Build my ws6
  43. Firehawk Blown engine....new 383 or stock LS1?
  44. Some fly cutting info
  45. sleeving lq4?????????????
  46. Yet another cam thread...
  47. will i need 2 fly cut my pistons?
  48. Ported 243/799 vs. as cast ls2 220
  49. Ls6 Main girdle options?
  50. torquing mains?
  51. Best Cam Setup???
  52. What could it be if my car keeps smoking after cam install.
  53. Help newbie, id this tb and intake 90mm
  54. 5.3 LM7 w/ 00' LS1 Cam?
  55. Cam Advise
  56. Oil pressure goes down coming to a stop
  57. What spark plugs should I use for my 1998 cammed Z28?
  58. Zero Oil Pressure & metal flakes
  59. new ls1 6 speed stock "for now"
  60. cam chain dampener ?
  61. 317 or ported 241's?
  62. how much cam for 853 heads is to much?
  63. 98 ls1 engine harness question for an 89 firebird swap
  64. Anybody porting Melling high volume oil pumps?
  65. LQ4, ported 241 heads, TR224/230 111. Head milling questions.
  66. g5x3 cam
  67. ls1!
  68. 1.85 rockers?
  69. Heads/Cam Build
  70. AI 241s vs PRC 5.3
  71. stock LQ4 heads...
  72. Boltons and 04+ Z06 cam only dyno?
  73. lq9 build suggestions
  74. Thunder Racing 219/236 cam
  75. Build? 'S
  76. GM LS6 shortblock?
  77. PRC Heads
  78. Oil PSI goes up off throttle
  79. Good DD friendly Cam.. 5.3L
  80. factory new rod bearing clearance .002" book says .001-.002
  81. Part sizes and questions... HELP!
  82. Torquer V2 Cam... now to finish her off.
  83. 6.0 install...Help!
  84. Bottom end rebuild
  85. Advice Needed on Engine Package
  86. Has ANYONE tried the Patriot Predator Heads??
  87. lm7 5.3l to ls6 cam
  88. piece missing from oil pump o ring
  89. Stock PTV clearance?
  90. stock pushrods.
  91. Valve seals for dual springs...where to get them?
  92. some Lifters wont accept pre-load, frozen at top
  93. Misfire under load
  94. Trying to identify oil pump, part #12556436
  95. Heads / Cam Project - Input Needed! :)
  96. motor build
  97. best cam for stage 2.5 heads
  98. Lucas Synthetic Oil Stabilizer
  99. Getting ready to do my first engine swap/build advise please.
  100. Texas Speed cam identify
  101. What can you tell me about ERSON cams?
  102. Trouble Codes
  103. LQ4 build...L92 or 243 heads?
  104. Connecting rod position
  105. Dynamic Compression
  106. LQ4 replacement pistons? What are options?
  107. lq4
  108. cam ID
  109. low boost budget build
  110. Head gasket ? Need help
  111. Can anyone ID these valve springs?
  112. What are the differences between the "old" and "new" oil pumps?
  113. Need help identifying these oil pumps *LS noob*
  114. should i be hearing the valves hit the seat?
  115. no start coils not firing or the injectors changed the ckp sensor still have nethier
  116. Interesting Cam specs. What do the folks in the know think?
  117. which cam to choose
  118. ptv issue with ms4
  119. Finding TDC Compression stroke
  120. LS1 vs. LY6...need to buy this weekend.
  121. Cam Questions
  122. Did I make a mistake and Pay Too Much?
  123. Valve spring changing procedure recommendations?
  124. symptoms of broke spring??
  125. Whose Running Dart Heads?
  126. Assembly questions
  127. Compression Ratio
  128. cam/oil pump torque specs?
  129. question for those who have installed comp trunnion upgrade
  130. cams
  131. loose chain??
  132. New Cam or Not?
  133. Pushrod length?
  134. Cracked Starter Bolt
  135. crank case ventilation.. will this work
  136. She blew!!!!
  137. Help with Set up and Pistons for 370?
  138. Putting $3k into the LS1... need some collaboration here!
  139. How do i remove 12 point ARP head bolts?
  140. Anybody ever done this?
  141. increasing oil pressure
  142. NO MAS ls1howto.com ?
  143. head swap question
  144. Is it Rod knock?
  145. Spark knock??
  146. Wiring question: Gen III 5.3L vs LS1
  147. Tsp 231/237 cam and 799 heads ok?
  148. Cam/Head install. Got everything?
  149. Ported 241 or Stock 243
  150. need cam advice for 5.3 with ls6 243 and ls6 intake
  151. LY6/L92/LS3 head question...
  152. HELP!!! Stripped a rocker bolt
  153. New set-up
  154. advice on heads 7 intakes
  155. where to buy
  156. LS1HOWTO.COM down?
  157. 383 stroker ls1 build questions.
  158. Exhaust help
  159. 6.0 carb'd build...which heads?
  160. cam swap coming soon i need advice for my trex cam swap
  161. Heads Cam Question Unknown Cam
  162. can someone ID this timing setup please?
  163. Low oil pressure
  164. New set-up coming soon 402 stoker
  165. help with cam
  166. roughly how much is a BBk intake with the throttle body
  167. LQ4 + LS3 heads + ZR1 cam
  168. Help me pick some internals for my build
  169. Need yall's opinions
  170. Factory warranty procedures if replacing LS1 (or any) rod brgs - what else gets done?
  171. harmonic balancer
  172. Take a guess
  173. cylinder head questions
  174. Was suppose to go for a tune Mon. but.....
  175. Broke Pushrod after Cam install
  176. Another Oil Pressure Thread
  177. Ms3 cam degreeing?
  178. SLP Oil pump
  179. PRW, PQ series Aluminum Shaft Mount Rocker Arm System-3334611, who's running it?
  180. ls1 head bolt thread taps
  181. Need help with comp with these pistons
  182. Rebuild or New Short/Long block
  183. Stroking an ls1 using a 3.90 stroke crank
  184. Good Stall? and some other things.
  185. Offset valve locks?
  186. Another 370 LQ4 Question Thread*
  187. GTP 420 cam
  188. Few questions bout heads and cam that i have picked out
  189. Valvetrain tick???
  190. texas speed iron block question?
  191. What is wrong with my car???
  192. what year lq4 for 99 camaro ss swap
  193. Piston rings gone bad, shop to blame, or cars age??
  194. which exhaust for built ls1????
  195. Need advice cam selection
  196. Went to check my pushrods... is this a bad sign??
  197. which cam would be better?
  198. melling 10295 clear a double roller chain?
  199. LQ4 at home short block tear down, hone & reassemble
  200. Heads
  201. 468ci (7.6L) LS1 possible?
  202. How badly is if u dont installed dual springs in there proper pressure
  203. Running like crap
  204. 408 won't start
  205. Guys with PRC stage 2.5, 5.3 heads and T V2
  206. rod bolt torque on arp 8740?
  207. Think I am Going to need a new shortblock.
  208. Dart Pro1 225cc Heads... need advice guys
  209. Anyone have FAST 90/92 install instructions sitting around?
  210. Getting Cam Install
  211. crankshaft questions????
  212. limits of a arp rod bolt
  213. Futral cam users come in
  214. Need a little guidance on a cam swap
  215. LS3/L92 heads or "as cast" 220 Trick Flows?
  216. Dumb knock sensor question
  217. oil pressure issue
  218. Where do you connect mechanical oi pressure gauge?
  219. Lost oil pressure after oil change??? Help?
  220. Any issues with cutting down a truck windage tray to use with an f-body pan?
  221. MS4 cam. What heads?
  222. Oil pump spacers?
  223. anybody running a 228r combo with a 102
  224. Rocker Arms to replace YT Ultra Lites?
  225. DSS Racing Forged Pistons
  226. Rockers to work with PAC 1205s
  227. 228r cam/Head Combo questions
  228. Any difference in the bearings for Harland and Comp trunion upgrade?
  229. Post-Deployment Projects
  230. Valve Float
  231. oil pressure is low at idle
  232. Finally going to start building a motor
  233. Help with my top end build!
  234. old cam
  235. g5x3 with milled and ported 5.3 heads BUDGET BUILD questions
  236. need your help before taking engine out it smokes on hard accel did a lot of checking
  237. Best Recommended Cam For LS6 Heads
  238. Build help
  239. Early head studs on a 2006
  240. new cam help
  241. Reluctor Ring
  242. Should I install connecting rods
  243. 3-2 Shift, people with experience come in!
  244. Heads
  245. cylinder head moding
  246. Best Cam for my setup?
  247. Valve seat/cup locator question
  248. Cam gurus, I need some advice.
  249. Idle issues after LT/ory and ported fast 92/95 mil TB install...
  250. LS1 running diesel rich when hot
