View Full Version : Generation III Internal Engine
  1. If a block is bored 2 or 3 thousands too much ...
  2. flow numbers for afr 205cc
  3. Milling AFR Heads
  4. Preload question/valve train geometry question
  5. Currently have a 224/224, but want bigger! Sorry another cam thread.
  6. Comp Cams 918 spring broke
  7. Edelbrock & Lingenfelter to partner on LS_ head
  8. Need a valve train diagnosis.
  9. GTP/TReX combo up and running...soundclip inside
  10. Large cams.....stock 3.42's?
  11. Best low-maintenace (road course) cam?
  12. cam size?
  13. pushrods
  14. Ok this isgetting on my nerves. 408 keeps sputtering and backfiring.
  15. TSP 231/237 & Patriot 5.3 Stage II Combo
  16. what would cause this
  17. ? about casting #
  18. LS1 or LS6 ??
  19. What's the difference betwenn the TSP 224R & 225?
  20. What do you think about this cam
  21. Installing Crane Dual 832's, how much shim for .612 lift?
  22. Patriot Performance
  23. torque down procedure for revised block?
  24. "detonation" ugh!!! #$%@! HELP
  25. Installing a stroker kit
  26. Leakdown and HP loss
  27. largest cam that works well with stock gear
  28. Comp R and lifter collapse
  29. Sheet metal intake manifolds.
  30. C-motorsports
  31. Any info on the new MTI G1 cam?
  32. How much power should this combo make?
  33. 4.100" Bore Head Gaskets?
  34. do i need tune if i get convertor plz help!!!
  35. What do you think of this Cam w/a Stoker Motor?
  36. TSP race heads and Magic stic.
  37. when i reseal my 383 ls1 will i need oversize head gaskets? what kit?
  38. cam????
  39. Zo6 cam
  40. New Sponsor - Racetechspeed & Performance
  41. vacuum leak ONLY in open loop?
  42. repairing a damaged block
  43. 6.0L Cam
  44. Do I need to rebalance my rotating assembley?
  45. lg motorsports package on my car but which one?!
  46. running 224-224 on stock verter
  47. So much for killer heads: JPR S2 flow numbers
  48. Valve leakage when CCing heads
  49. Effects of no PCV system?
  50. Stock pushrods ok?
  51. MAF acting weird....
  52. For those that have pulled the crankshaft sprocket
  53. Cam swap 101.....
  54. head studs don't fit on new iron block?
  55. Anyone with ARE 346 short block
  56. F10 or F12 cam for stree/strip car?
  57. 224/581 cam, stg. 2 heads do i need tune!!
  58. Oil Decision
  59. bad rocker??
  60. Labor estimate....
  61. low oil pressure
  62. Anyone Crower Rods?
  63. Somebody,Anybody,Please Help!!!
  64. Oil change question....
  65. Comp 918 broke with few miles
  66. Bad driving with TR6?
  67. Wtf...
  68. Starter enganging with out key in ignition
  69. Crank Position Locator Wheel Movement
  70. Stock cam with a pic(quick question)
  71. How much power can stock injector feed?
  72. Thinking of swapping cams
  73. g5x3 tunning
  74. Possible bad lifter?
  75. HELP! Oil shooting out of breather!
  76. Short block redline
  77. Need help ls6 cam
  78. A few valv spring questions
  79. biggest cube daily driver?
  80. Yet another T-Rex Question
  81. Okay, bet you've never seen/heard of this shit...
  82. I need a cam
  83. What a good lightweight valve?
  84. Just ordered cam and springs gotta a few ?'s
  85. need some nuts,ARP
  86. where to buy valve guides??
  87. keep stock lifters?
  88. Anybody see a loss in hp because of leaking Patriot valve seals?
  89. Compression ratio?
  90. engine guru's! could this cause a lean condition???
  91. mild solid roller set up
  92. Knock retard... It won't go away...
  93. where to get cheap arp head bolts?
  94. Best Stroker Short Block?
  95. Mti Stg2 R Heads
  96. Finished my cam instal!! got another question
  97. OIL and engine break in ???
  98. 02 LS6 in 99 SS
  99. G5x2????
  100. Differences in LS1 block years?
  101. 6.0L C/R with stock LS1 heads
  102. Which Stroker to go with?
  103. Power loss? 422 heads on a 408?
  104. update on HPE new ( S ) cam
  105. How to mod an ASP pulley for a double roller timing chain?
  106. LS1 Valve Spring Issues. . ..
  107. Just snapped a Crane dual on my way to work
  108. Info regarding the revised 144832 Crane dual spring
  109. Intake Manifold Porting?
  110. Factory Ls1 valve vs spring pressure??
  111. Good compromising Cam
  112. What do you think would flow better?? 'pic'
  113. Is 108k miles too many for a cam install??
  114. what's a good cam w/TQ & HP
  115. Which spring# and installed height with solid cam.
  116. WOT Blast and car idles high afterwords?
  117. C5R block and C5R heads, fully built 427....daily driver....
  118. chevy high performance magazine
  119. Which size main and rod bearings for a 427?
  120. whats the best cam for a stock 93 LT1
  121. Cam Question???
  122. piston to valve clearance with 5.3 heads, T-Rex cam???
  123. should I port my stock heads?
  124. Question for those that have replaced the stock rod bolts.
  125. need some q's answered
  126. another oil pressure question???
  127. What cam to go with??????????
  128. Aluminum or iron?
  129. Pistons notched?
  130. Cam and tuning questions
  131. Who sells Harlan Sharp rockers?
  132. can to many choices be a bad thing...
  133. big cam with arp rod bolts and high rpms
  134. Thoughts on this cam? (specs inside)
  135. throttle body passenger side top???
  136. Anyone know .200 or .400 lft duration figures of TRex?
  137. h/c question
  138. How much machining should I have to do to this block?
  139. I am looking for a rotating assebley
  140. buy new rockers??
  141. Port my 98ls1 heads?
  142. Ran into a snag with cam and now have a question
  143. how much shaving to get 6.0Ls to 67ccs
  144. What cam, horespower per dollar??
  145. Patriot Gold Spec's
  146. Broken ISKY 295D
  147. What do you guys think
  148. front cylinder on passenger side??
  149. Anyone have a FMS cam with a blower?
  150. is there a link somewhere w/ all the head casting #s and their info?
  151. tr230/224 111 cam questions?
  152. Which cam do I have??
  153. New Sponsor - LME
  154. New HPE "S" cam!
  155. aftermarket cam w/ stock heads
  156. Has anyone resleaved a iron block?
  157. driving impressions with afr's,90mm TB and fast
  158. cam sound clips?
  159. About how many miles can I get off of my dual springs?
  160. Shim the oil pump?
  161. Are the problems with the Eagle cranks fixed yet?
  162. AnyoNE KNOW where i can find directions for deleting EGR and A.I.R??
  163. best place for short block?
  164. Double timing chain NEEDED????
  165. will stage 2 heads change my sound???
  166. Need input on a cam
  167. My final cam question
  168. driving characteristics
  169. Engine running! Thanks for help.
  170. what need to switch cam?
  171. getting closer to the end
  172. what else do i need for my cam swap??checklist
  173. what head gaskets to use???
  174. LSx torque plates
  175. Tips on pulling my motor
  176. How much HP is 1 point of compression worth..
  177. Who grinds MTI's cams?
  178. Head Install
  179. Anyone used Jackson auto machine lifters?
  180. 03 #12560965 Camshaft specs?
  181. Who has bored a 98' LS1 block?
  182. Oil consumption before new motor; Same consumption with new motor
  183. Help, need shop suggestion in South Cal
  184. Do I need to do anything to put Z06 valves in stock LS1 heads?
  185. Stock heads with what cam and headers?
  186. Absolute Speed heads on the way!!!!!!!!!!
  187. Pen Magnets Blow
  188. any update on the TSP magic stick???
  189. G5x3& heads???
  190. Help Please! Oil on intake manifold after heads install...
  191. Pinging at part throttle?
  192. Futral F13 cam specs?
  193. Fired up the T-rex for the 1st time tonight!!!
  194. exhaust fumes kill??? :)
  195. I think I've decided on the new set up
  196. Are 2.055 valves to big for a stock bore 346?
  197. How Many RPM's are Possible ?
  198. Cam & Heads advice! help!
  199. Engine tapping at idle
  200. Which Cam for 383 LS1 in a truck?
  201. Need Help TR227 or TSP228r ?
  202. Any difference in bearings??
  203. Oil Leak Questions
  204. LS6 valves vs. LS1 valves? Any difference?
  205. Rwhp?
  206. GTP stage one heads/w 224 cam vs. no heads and larger cam
  207. Got my G5X3
  208. Will TSP 231/237 work weel with Stg 2 LS6 heads
  209. Short block arrived today
  210. Can someone help me out please. Need to get a Cam for these heads. What cam?
  211. I Have a Problem ! Please Help !
  212. absolute speed port volumes theory 101
  213. Manley Spring takes a dump w/ less than 19k miles...
  214. C5R purchase?
  215. Upgrade cam what else should I do?
  216. Cam w/Stock Clutch & Rearend
  217. larged chamber volume you can hit with a 6L head?
  218. Heads & Cam vs another set-up
  219. gain from heads only
  220. Cam ?
  221. Do I need to mess with my distributor or timing?
  222. Best LT headers?
  223. time to go faster, cam&stall choices
  224. cam change
  225. Enough room for ARP head studs?
  226. T-Rex and Ported Heads
  227. AFRs+T-Rex
  228. Should I buy new head bolts?
  229. Engine fired, got a problem
  230. Cartech Books
  231. Those who didnt swap timing chain with cam
  232. Crane 1.85 rockers???
  233. Too much Oil Pressure?
  234. GM Hot cam
  235. How much power can the LS1 handle?
  236. LS6 price?
  237. How far should the balancer be seated?
  238. New Problem: Exhaust Pops between shifts and hard decel
  239. fulral f11 and....
  240. afr's arrived today
  241. Cam swap checklist
  242. Stealth II with TEA stage 1.5 5.3 heads.
  243. RWHP estimate with AFR 205's and TSP magic stick
  244. G-Force 205CC AFR Head Flow #'s Inside!
  245. Should I get AS S2.5 5.3ltr heads?
  246. Spring Seats
  247. She's ALIVE!!!
  248. cam help
  249. decisions, decisions
  250. help!!! need advise on head/cam install prices
