View Full Version : Generation III Internal Engine
  1. Pics of engine carnage:
  2. i need to get this cam...
  3. Cam Choice
  4. C5-R block prices
  5. Help w/ building first forged bottom end
  6. Preferred So Cal LS 6 Engine Builder
  7. Head/cam combo
  8. Boring the Stock Bore Question
  9. Dropping K-Member for rod bolt install, what am I missing?
  10. Roughly 6500 shiftpoints, would I be ok to set the limter at 7000?
  11. REV Limiter with Patriot Heads?
  12. TSP 231/237 become popular
  13. Any one running the new magic stick (TSP)
  14. Edelbrock LSx Heads ?
  15. How big of a difference is a solid cam on a LS1
  16. best cam for 395cid
  17. Smog Legal CA Road Racing H/C Recommendation
  18. Looking for HD connecting rods for TT project
  19. Swapped to CC978 per TEAs recomendation
  20. 3rd failed lifter in 3 months, help
  21. wrecked 02 ta! engine removal im having frame repair, do i take it out top or bottom
  22. Changing rings
  23. Another heads question.
  24. Do Heads=Louder Exhaust??
  25. 427s and Emissions?
  26. TSP 231/237 Sounds awesome
  27. ls1 speeds full engine packages..looking new block
  28. If you install a cam on an early LS1, consider removing EGR.
  29. spark plugs with H/C?
  30. What could this be?
  31. valve seals bad
  32. Nervous about TR "Old Man" cam
  33. What should a forged 408 long block cost?
  34. What the diff. btw stock head and MTI 5.7 head?
  35. ASP PULLYS and double roll timing chains
  36. AFR/Tony - Minor Head Problem
  37. Cam Install??
  38. 2001 LS6 Block??
  39. O-ring with MLS gasket and copper oring??
  40. Is this a LS6 oil pump?
  41. Need some Help and Ideas
  42. LS6 oil pump part #?
  43. which heads to get
  44. what hp?
  45. 225cc AFR Mongoose heads. Too much for stock displacement?
  46. dominator package
  47. Anyone using SD LS1 performance springs come in?
  48. Cooling
  49. Quick and painless spring advice needed.
  50. Was the head swap worth it.
  51. Fm13 vs. TSP custom Torquer
  52. possible blown rocker
  53. Guys with Patriot 5.7 S2 heads come on in.
  54. Getting H/C in October, have some questions...
  55. Eagle or Callies LS1 Rotating Assembly sale - ONE WEEK ONLY!
  56. How much noise with aftermarket pistons?
  57. G5X3 is IN!!!!!!!
  58. TSP 228R alive and kicking!
  59. crane rockers and schubek lifters?'s
  60. 232/240 593/603 112 cam... what pushrods?
  61. tr220 cam/ stock manifolds
  62. Is there an advantage with ported 5.3L heads?
  63. Have heads and cam, want to swap cam, what do I need?
  64. dilemma, need some opinions
  65. What application would this cam be best for?
  66. KD tools valve spring compressor
  67. 918s on stock cam ala pop hotrod?
  68. lowest idle with 224 cam?
  69. whats my CR???
  70. Sandy Sound @ WOT
  71. High CR Iron Block Nitrous Motor (What Iternals)
  72. omg expensive!!! do i even have everything?
  73. Big bore/short stroke, anyone try it?
  74. Trying To Find A Good Combo
  75. Help me plan for my cam..
  76. camshafts
  77. TSP231/237 vs. G5X-2 cams
  78. Oil pump porting DIY
  79. Main cap side bolts
  80. COMP 978 SPRINGS. Machining required?
  81. 1.85 Rockers, Do they increase the power range
  82. LUNATI 237/242 .595"/.595"?
  83. CROWER,cranks and rockerarms for ls1!!
  84. Why isnt the G5X1 cam more popular?
  85. Valve Float
  86. Can you port the Combustion Chambers on LS1 heads?
  87. MORE vs. vinci valve spring tool
  88. is the LS6 block better for buildup?
  89. Excessive valvetrain noise checklist
  90. Very good article.
  91. How much valvetrain noise is normal?
  92. too big?
  93. My chosen H/C combo.... Opinions Plz & HP/Tq guesses?
  94. 6.0/5.3 Block Questions
  95. ASAP!!!HS rockers and G5X3 cam
  96. What length pushrods?
  97. High CR 347 question
  98. sewing machine top end sounds
  99. H/C vs S/C.. Gains?
  100. Narrowed down to 4 cams Help
  101. Cam Specs - How big of an acceptable tolerance is there?
  102. Is there a direct fit 1.4 or 1.5 ratio rocker arm for the LS1?
  103. Need heads for my set up
  104. Serious head/cam combo...
  105. Compressor fitting f/spring swap
  106. eagle I beam rods
  107. FMS f5 vs f11, differences while on nitrous?
  108. F1 Cam?
  109. Will 99 heads go on a 98 block??
  110. Comp 918's and .571 lift?
  111. what do u guys think of my new setup??
  112. Lingenfelter runner volumes!
  113. Compression Ratio
  114. Tapping noise
  115. Building a nitrous motor:
  116. Patriot heads
  117. What pistons and rods for a 400-500 shot?
  118. 3.908 can I use these with a late 98 block
  119. ported heads
  120. Did GM fix the piston slap and ring issues by '02
  121. Change Heads or Heads and Cam?
  122. Red line motor oil
  123. Rod
  124. Knockin Noises
  125. Will I be able to drive the car after cam install?
  126. TREX-GTP combo coming soon
  127. locks/ retainer locks?
  128. G5X2 users come in
  129. Help...what cam???
  130. Some cam questions
  131. Heads/Cam/Intake Supercharged
  132. Found out where my oil was going
  133. Cam GURU'S inside ("old grinds" vs "new grinds")
  134. Need step by step for engine removal
  135. Any daily driven 408's? come on in..got some ?'s..
  136. Which cam...231/237 or 231/231 both 112lsa
  137. Anyone running stage 3 LS1 heads on 4" bore or larger?
  138. trex cam questions
  139. How do hydraulic lifters work?
  140. TSP225 cam What should I set the rev limiter at?
  141. New cam from Absolute Speed on the way..
  142. The wait is over...Stage 3 AFR Details inside
  143. comp cams XR269HR question
  144. 228/228 114
  145. Difference in C5 and F-Body LS1
  146. Well you guys were right!
  147. TSP 231/237, is this a street cam
  148. LPE Cams
  149. What is this strange noise?
  150. Rocker ratio, springs and Cam lift
  151. comp cam base circle
  152. MTI sent us the wrong cam??? Please MTI respond!!
  153. Hard driving and oil consumption
  154. old cars and duration...
  155. HP increase or not????
  156. New LS1
  157. Castrol "Gtx Startup"? Anyone use this yet?
  158. why can't my motor control a TR 230????
  159. Which cam is this?
  160. Callies crank users
  161. Oil Leak from Rear Main Seal - advice???
  162. Comp Cams shaft mounted roller rockers???
  163. buy new sensors???
  164. Cam Help!?
  165. Another car wont start w/ cam install
  166. Knock sensor cover
  167. PP LS6 style heads
  168. patriot rockers
  169. What cam to go with?
  170. weights of valvetrain parts
  171. Another tapping LS1 (did search)
  172. Etheads
  173. Trex cam is in.Its Alive.
  174. What effects valve spring life?
  175. Looking to find out the best overall Head and Cam Package??
  176. springs/retainers for 224/228 cam
  177. cam install from hell!! Pulley problems
  178. Help with comp R's!
  179. lifter question
  180. What kind of spring are you running with TR224?
  181. Engine Performance before and after dyno tuning
  182. Diff between 918's and 915's
  183. 01 ls6 cam vs. 02 ls6 cam
  184. Vaccum pump / breathers?
  185. LQ-9 heads
  186. Pushrod question need help!
  187. Any one ever do heads without cam?
  188. Patriot Golds installed (pics) and the "BuckeyeROC" install tool
  189. Patman: Motor Flush Question
  190. New Dyno numbers
  191. Ultimate Stage 3 LS Series Head.
  192. what's the best compression for a max effort n2o motor?
  193. 6.0 heads good or bad?
  194. Patriot Gold users, quick question
  195. *** I Need Help!!!***
  196. Rocker Arm Help
  197. LS6 Head Question ?
  198. Low Coolant
  199. Best Cams w/3.42s?
  200. need help with oil pump/timing chain installation
  201. ARP rod bolts on stock engine? Good/bad? help.
  202. Texas Speed "Magic Stick" Camshaft R3 Specs & Results ---->
  203. Thank You..AGOSTINO RACING ENGINES...Thank You....
  204. guys with heads and big cams,what lifters are you using?
  205. TR220/.553 @ 112+4 Who's runnin it?
  206. installed a 6.0 long block what.....
  207. LS1 f-body oil pump pickup in a 6.0 iron block?
  208. Why is everyone selling their TSP 231/237?
  209. SLP Cam worth anything?
  210. car/engine shaking after cam install and tune...HELP!!!!
  211. what is this the difference in size? LOU @LG
  212. how hot does your motor run on the highway?
  213. TSP Custom Torquer Camshaft
  214. Rocker arms
  215. Too late for ARP main studs?
  216. 232/240 inside
  217. PP LS6 style heads
  218. SLP Roll Master Timing Chain
  219. Those with a 383 stroker
  220. help with heads and cam for my 98 ls1 in a 69 camaro ?
  221. TSP 231/237 on a 395ci
  222. SDPC spring kit, stock Pushrods?
  223. Cam Installation Question
  224. Can i make 400rwhp with this set up.
  225. lifter stuck in block
  226. piston to valve
  227. WANTED 450+ HP will i get it???
  228. P/V Clearance ? with this head/cam combo
  229. A4's and 112's. Trying to clear things up.
  230. gasket set
  231. rod bearings
  232. cam bearings
  233. Milled 62 cc AFR's,Compression & Deck Height
  234. engine installation prices
  235. What do 5.3l heads need to run on a 408ci?
  236. Cam Help for my 408.Please!
  237. Who rents a fly cutting tool?
  238. whats needed for the cam install
  239. Do 6.0 truck heads flow better than 5.7 LS1 heads?
  240. Head question
  241. Changing springs (golds) should I change anything else?
  242. Wanted to share this cam!!
  243. 5.3 Heads and Gaskets...
  244. Va emmissions?
  245. which cam to use?
  246. ticking sound(drag racing)...lifters????
  247. main bearings
  248. piston rings
  249. Valvespring swap in half the time (Install tips)
  250. PA Emissions on a TSP 225
