- torque specs on ARP rod bolts and rest of shortblock?
- Gapping rings for Diamond nitrous pistons?
- Bearings
- some cam help please , i am all stock !!! need to change
- quick response please
- Just installed cam only and have results posted
- what should the rev limit be
- torqey cam
- CNC'd LT4 flow numbers..
- What springs are being used for these bigger cams on stock heads?
- Stock '00 LS1 cam specs
- Question about valvetrain noise
- Double REV 1116 Springs
- flycutting stock pistons
- F13 Installed
- Rollmaster Adjustable timing set install help?
- added a 231/237 cam and 4400 vig got a question
- Jay at Absolulte??
- G5X2 Cam question
- How much power can stock internals handle?
- advertised duration
- were to go from here?????
- AFR heads WHEN?
- Heads- 6.0 or ls6
- What Valve Springs have a.........
- Oil
- All Texas Speed & Performance Camshafts Now Cam Doctored!
- installing heads, do I use old manifold gaskets?
- can I install heads without a tune?
- Ultimate drag cam for stock heads?
- Turbo Cam....
- TSP "Magic Stick" Camshaft
- Update on my car - bigger and better things!
- Replace 1 lifter or all 16? Best brand?
- Where do i get Valve spring shimms
- How much did you spend on cam setup?
- engine shaking...normal???
- Its alive!!!
- Powdercoating the block....
- Cylinder Bore Wear, how's this look, pic inside
- what is oil pan drain plug thread size?
- Can I just change springs?
- do i need new seats when i buy Springs...
- cam and spring install.. springs 1st??
- valves hit pistons?
- ?were to get lt1 heads that will flow over 300cfm???
- how do i get to a 10.7:1 CR?
- MTI Stage 2R Ls1 Heads
- Cam or Converter?
- 2004 LS1 & 2001 LS6 Heads, which gaskets?
- Valve Stem Help Please
- If I decide to do a 2nd cam, should I replace my factory timing chain?
- Milled heads with LS6 intake?
- oil pressure?
- click/tick....diagnose??? help??
- Im confused
- how much to forge my bottom end
- any dual spring install tips???
- Help with CAM plz
- 2000 SS with 231/237 cam only?
- Heads and exhaust tone ?
- Short duration, Tight LSA Cams
- TRex Cam
- Best way to Determine if you've got a miss without a diagonostic tool
- Texas Speed 5.3L Race Heads Pics
- porting heads
- 225/225 Camshaft Sound Clips FINALLY!!
- valve laper
- DON'T use pen magnets while doing a cam swap!!
- How much power?
- Mismatched Heads
- What makes a car NOT streetable?
- Harland Sharp install with pics :)
- engine specs
- Differences in these cams...224 228 232
- Is this a good CAM for a stock head?
- C6 Vette engine - what is it?
- Engine out of balance question?
- LS1 long block 10,000 miles, Price???
- LT1 block ???
- What Mods with $500
- Do i need a new oil pan gasket for cam swap?
- Motor Rebuild Questions - Sleeve Type, Heads, Cam ???
- TCS is acting weird lately...
- Good shortblock... questions
- 241 Heads vs. 317 castings
- Ape 408 Engine Dyno Results, Link!
- How much oil do you run with?
- Say I wanted to buy the Lunati 408CI rotating assembly kit...
- Raw oil out exhaust !!
- REV double-valve springs...
- Symptons of spun rod bearing??..??
- If you were gonna buy a new set of heads..
- Valve lash adjustment
- Help! Should I do H/C or wait?
- Use F/R O2 sensors with long tubes
- Do I have to modify anything for Double row timing set?
- G5 cam.. What kind of lobes does it have.
- Engine to Bellhousing Bolt Pattern
- Ring Gap on a forged 346 with small shot
- what kind of power do you thinkd my 383 LT1 will make?
- does anyone have vid clip of TR224?
- TR 220 or TR 224????
- What Year Is My Motor???
- LS1 head *
- G5X-2 Cam going in, what else should I do?
- Any running TSP 232/228?
- 98' T/A "Low Oil" On, then off? New here, TIA
- Best Stock Heads For Blower Motor
- What does it take to turn my LS1 into a 422ci?
- ticking under valve covers
- What is needed for Jesel SS's on PP 5.3 S2's??
- Help me decide...408+200shot vs. 370+turbo
- newbie cam question
- Looking for ultimate drag cam for stock heads, but will compliment future heads?
- Aight wtf is this about?
- engine build up questions...
- Crankcase evac, from valvecovers to header collector?
- Do I need a converter right away?
- Filing oil control rings....?
- Going from stock to forged.Will you lose HP?
- Help Please
- shifting at 7000 RPM's
- does chrisARE360 answer PM's??
- Should I get my heads milled?
- Decided on a setup. What do you guys think..
- car acting funny, help
- callies crank requires grinding block, lunati doesn't?
- Wanna Get New Cam But Have a Few Questions?
- How much will the stock bottem end take?
- Keep A4 or go with t56 m16 out of a gto?
- Flycutting opinions?
- (sponsers)- Any of you guys sell good, used stock 5.7l valves?
- How to get 400RWHP from A4????
- Longer crank bolt with new crank pulley??
- Question about installing my rockers.
- Double roller question
- The best street cam with big numbers
- where to buy an EASY OUT???
- Need input on this combo...
- Cam Guys Inside Plzzzz
- Update on the new engine, driving to VA and oil consumption
- new o-ring problem
- Patriot heads yes or no?
- Quick cam question
- Locked up my engine today, need idea's (sponsors inside please)...
- Installed my cam yestderday
- Thunder Motorsports Reverse Split cam
- lunati 408 stroker notch block/#8 piston?
- ? About Comp Cam
- Texas-speed 408 stroker
- How are cam bearings installed?
- Cam/Headers Install Complete
- Head & Cam Question
- Want to order head s2 how?
- I'm upset with my mods/performance... What should I do?
- The teardown begins....and already finding and handful of problems...
- ATAP/LS1-edit whats the advantages?
- Cylinder Head Choices??? Please Help
- Lucas oil?
- Oil starvation under high G loading - opinions and solutions?
- Explain timing to me........
- my stupid camswap mistake
- Cam?
- Spinning to 7500
- HEADS...stg I, II, III....whats the difference?
- Just did my first oil change and have a few questions
- FM13 is in!
- 54CC heads and STOCK short block (COMPRESSION???)
- Started the car this morning after letting the seafoam
- FMS F13 ok to use stock seats/seals? HELP QUICK
- patriot heads and 224
- Part # for Valve spring seats seals
- PP Stage ll LS1 heads $999.99!?!?!?
- Little diagonosis help please(off idle hesitation)
- New motor ready to assemble
- LS1/LS6 rod question
- LS1 Hot Cam and Stage 1 Heads Question
- oil presure
- stock rod langth
- FM 11=awesum
- Curiosity
- Engine builders come in, have some q's
- Questions about stock ls1 blocks
- CI Displacement Forumla????
- Why does high rpm cause an engine to "let go"???
- Squeaking Noise from Engine?
- It is safe to put rev limiter at 7000 rpm w/stock bottom end?
- My JPR HVLD Head flow numbers
- Yes, Another TSP 231/237 Thread...
- LS6 swap
- Am I being ripped off?!
- Well I am down to PP 5.3 Race heads or Forcefed HP 5.3 or/5.7 heads.
- Audible Knock coming from Water Pump area?
- Throttle Sticking?
- width of ported intake ports, please(stg 2,3)
- please help me figure out why I am pinging, going insane here
- WTF, GM guy says they don't sell injector o-rings!!!
- are these the pushrods i need??
- afr headed 427 in hotrod mag.
- PV clearance with this big of a cam???
- clicking sound, help...
- As long as we're asking, what does it take for 10's with...
- g5x2 vs. tr224
- Best cam for this combo ?????
- Which Cam
- quick timing chain question
- Help!!! Needle Bearings In Oil!!!
- Anyone running 11s with 224 224?
- Is it worht using the sea foam?
- Stroke Me!
- TEA Stage III LS6 Head Flow #s
- how streatable is this cam
- My Heads and Cam are finally in.....
- L-19 studs ready for shipment
- How Many Cams
- California Cam
- Balanced/Blueprinted LS1
- F T&D
- dished piston
- Head and Cam questions
- "Bolt on" cam with best power from 4500-7000?
- Motor or Tune
- Pre-load Adjustment
- Stock block
- Felpro 9284 head gasket
- Head Gasket
- How to build an Ls1 ?
- Roller rockers??
- 241 castings to 317's
- Drivetrain Loss
- Opinions on thunder racing's T-rex cam...
- Compressed head gasket thickness?
- how much valve train noise is normal?
- F5 cam install Q?
- g5x2 and other parts going in this weekend.
- spark plug gap
- I need a lil help getting started in the right direction.
- 5.3L TEA 1.5's going on soon...gaskets, tuning questions.
- Tips needed for Comp Check and leak down
- What cam are you guys running with PPstgII LS6 heads
- need cam suggestions, lightweight and 4.10 geared
- cam 224 street/strip
- Stock gaskets in a superstroker at SPEED INC. ?
- Input on Valve seal replacement.
- cam question?????
- can i drive my car untuned after heads, cam, headers, lid?
- all bore engines
- Clearance??
- I have a mrable noise coming from inside my intake...
