View Full Version : Generation III Internal Engine
  1. LS6 Cam and Valve Springs
  2. idle speed after cam install
  3. Valve spring shims (.015)
  4. What does a collapsed lifter or lifter going bad sound like?
  5. why do people put1.5RR on the intake and 1.6on the exhaut
  6. Valve Spring How-To Discussion
  7. 228/234 Xe-r
  8. Where can I order a set of LS1 expansion plugs?
  9. Cam and spring selection?
  10. Getting Heads Milled
  11. wiseco pistons
  12. all bore limits
  13. stroker or all bore iron block??
  14. valve train recommendations...
  15. Best lifters
  16. HP limit of Eagle Rods?
  17. Help inside....cam gear is hitting bolts behind it!!!!
  18. Crank Pulley Install Help..ASAP!
  19. What would cause This - help please?
  20. Any problem with stock head gaskets?
  21. 228/232 .581/.581 on 114 cam whats your opinion
  22. Bench flowing heads ??
  23. Legal Camshaft?
  24. oil to use on a fresh 427 with forged internals
  25. Need help determining compression ratio
  26. Piston to valve clearance whats safe?
  27. And another GM Grand Am Cup cam setup, this one from Down Under.
  28. Anyone have the GM CNCed LS6 heads?
  29. H/C Swap Day 1!
  30. 1 quart of auto tranny fluid in a full tank of gas.....
  31. Flow numbers for 59cc PP LS6 style heads
  32. My compressin ratio???
  33. 5.3L heads...from a 2001...work on a 2000???
  34. 12.0:1 VS. 11.0:1 and the TREX!! :)
  35. Do Vettes still come with LS1 blocks?
  36. Stupid Question
  37. TREX in a daily driver??? and how much HP gain??
  38. Rollmaster questions...
  39. Guesses on how much my 347 will pump out?
  40. Fuel Injecter Cleaner??
  41. Where to find torque specs
  42. Typical flow numbers for Stage 1 heads?
  43. New guy needs help with cam/heads
  44. Slp head\cam kit?
  45. new code with heads and cam install
  46. Milling heads vs. Bigger cam
  47. what are the best springs to use
  48. Help on cam choice with my current bolt ons? I am lost
  49. Swapping from a milled head to a non milled head.
  50. New Pistons....
  51. oil galley plugs and camshaft end plug
  52. FREE ARP head bolts........
  53. ******TVWilkes******
  54. Patriot Springs
  55. JESEL JKR Rocker Arm Users!
  56. asa cam?
  57. Oil
  58. HELP|rocker arm bolts stuck!!!
  59. 231/237 or G5X-3
  60. Shims Safe for Lifter PreLoad?
  61. Help with Cam, Exhaust, Tuning?? New Times! (Long)
  62. Which Heads from PP?
  63. want to change to synthetic
  64. Crane 144832 spring rate data here.
  65. 5.3 heads
  66. oil in the intake
  67. Cam Gurus, help for choice
  68. How To Remove Knock Sensor's
  69. Help: TSP cam install
  70. Balancer Removal Question
  71. Valvetrain problem??
  72. Worried fuel tank might ignite
  73. Anyone heard of Mellings lifters? Are they good enought for a stroker?
  74. Cam For 2002 Chevy Truck
  75. Got a free hydrolocked LS1...need opinions
  76. Is 112mph low for my mods?
  77. Coolant LEAK at head
  78. most compression with 93 octane
  79. Comp 'R' Problem Thread
  80. Another what will my HP be? I'd like to know where I stand..
  81. Whine coming from the engine when started.
  82. What is a better rod design
  83. New motor or build up old motor???
  84. Head Cam combinations ??
  85. Required Head Flow?
  86. Need some help quick about head gaskets!
  87. Supercharger vs Head/Cam Package
  88. need help! poppin
  89. Cam and 347cid
  90. Please help. Stripped threads
  91. camshaft questions
  92. I think I'm goin overboard w/ my cam on my 347 but what the hell. G5X-3 is too small!
  93. hole im my Lifters
  94. H\C first impressions!
  95. anyone port their own oil pump?
  96. New 347. What do you guys think?
  97. Camshaft Discussion Part III
  98. 230/232 114 + 4 questions....
  99. Adjustable Rockers
  100. New Cam thread?
  101. High-end cam question
  102. Conflicting infrormation from our sponsors on Crane 832 dual springs; need help!
  103. Head Gasket part #?
  104. engine swap
  105. 224 228 on a 112-2
  106. Installing Heads
  107. Is there an LS-1 Cam Database? (Shopping)
  108. Best SMOG legal cam
  109. what the heck did i do wrong?(leaking head gaskets)
  110. a few questions from a newbie: iron block????
  111. Anyone else's HS rockers do this?
  112. Cam Change. HP est..
  113. Hotcam quality issue from GM?
  114. Problem with my new h/c car...help!
  115. Opinions needed for heads
  116. Do big cams=bad lifters?
  117. spring life question
  118. 427 home built
  119. V-8 S-10
  120. head gaskets???
  121. how driveable is the trex cam
  122. rwhp estimate on a 231/237
  123. Cam install question
  124. head/cam install question
  125. quick!! oil pump removal help!!
  126. first startup a4 2.73's patriot 5.7's tsp 231/237
  127. Such a thing as a cam thats "to" big?
  128. APE and Absolute speed
  129. S/C vs. stroker kit
  130. comp 224 .561 lift 110lsa cam and S2 LS1 heads, which ICL do I install cam on?
  131. Where yo get Tella Terras
  132. Need correct part # for Comp R lifters!
  133. New cam! What will be my estimated RWHP????
  134. Aboslute Speed 5.3L stg 2 vs 2.5
  135. Is this cam any good?
  136. Help! My new crank bolt slides into the crank of my used built block
  137. wont idle for sh##t
  138. Measuring a LS6 cylinder
  139. LS6 crate engine storage?
  140. 98 LS1 to a 03 LS6 swap - what hurdles are there?
  141. AFR's=$2600=.550 lift springs,wtf!
  142. need few horses
  143. A-4 guy's come in side i need help
  144. Advantages of head studs
  145. paging 007SS
  146. Low oil pressure and metalic noise coming from under ds valve cover..
  147. Jesel SS Rockers, Make then adjustable?
  148. What is the most reliable and quietest springs?
  149. Future F-body Products?
  150. Another 977 / CompR question
  151. Valve float??? What to do.
  152. material for 4" cranks
  153. MTI Stage 2E heads...
  154. Stage 2 head, how much can they be milled?
  155. Wrong waterpump?
  156. Engine Knocking! WTF???
  157. 228/230 comp cam
  158. revving to the moon?
  159. Need part # for ARP crank bolt!
  160. Finaly Grand Am Cup Cam In And Running
  161. Help, blown motor
  162. Tired of the preload crap. What lifters can i use?
  163. Rocker tightening sequence for adjustables?
  164. Rocker Arm Quick Question
  165. Problems after H\C install :(
  166. How much vacuum at idle?
  167. Cam / convertor matching
  168. is 25-30 oil pressure too low??
  169. ls6 intake ID ??
  170. Do Patriot dual springs require Comp r lifters?
  171. on a stock motor...how much does 1.8R's really help it??
  172. Opinions Please
  173. Titanium Retainers
  174. pp 5.7 stage 2 heads with 231/237 (( a4 ))
  175. Fly Cutting Tool
  176. could it be ANOTHER spun bearing???
  177. Weight off on rod bolt-Will it matter?
  178. how does this combanation sound for rwhp and track times?
  179. Cam Questions??????
  180. Lunati Stroker kit
  181. No spark on #2,4,6, and 8
  182. Cam install questions
  183. 112 vs 114 - Need a little help please
  184. Clacking sound...lifter??
  185. ISKY 295D springs
  186. bad knocking sound?? lifter??
  187. Replace Oil Pressure sender without removing intake?
  188. Comp Cam?
  189. what big cams fit with PP LS6 heads 59cc
  190. Need help dropping oil pan on 3rd gen
  191. I need a few part #'s
  192. How much power loss?
  193. Almost There....Thxs ESP...
  194. Thanks APE, looking good
  195. low to mid range cam that works on zo6 springs??
  196. Which cam should i go with ?
  197. Wrong Patriot Heads?????
  198. good price on heads and cam install?
  199. In Progress.......Head and Cam Install
  200. Cost of polishing crankshaft?
  201. LS1 Cylinder Head info
  202. 224/224 .525 110LSA w/stock tuning?
  203. Help with CAM Install
  204. Most lift i can put on the comp 978 springs
  205. ONE QUESTIOn after TREX
  206. Could have picked up GM preformance 5.3's
  207. milled ls1 heads and 224 cam?
  208. Rocker Install Problems
  209. LSA and advance questions...
  210. Magnetic oil drain plug & Synthetic oil...??
  211. Milled Heads
  212. oil pressure sender/switch part # from gm?
  213. Help to choose heads
  214. Starting head bolt torquing finishing later?
  215. Too much oil pressure?
  216. Newbie help w/ installing rockers
  217. oil
  218. Gas mileage on Heads/Cam package?
  219. 3/4 of an inch lift
  220. whats next?
  221. stage 2 PP 5.3 heads and TR224 114LSA cam ?????
  222. Finely fix..
  223. HS Rockers
  224. Doing cam install got a question
  225. Cam suggestions for a 408
  226. comp cams 54-000-11
  227. Just finished Trex install SLIGHT PROBLEM
  228. Marine Vortec 6000 Intake Manifold
  229. Cam assistance
  230. Priming Oil Pump?
  231. will 4L60E out of my 96 blazer work bolt up to LS1?
  232. Lifter Question
  233. Who sells adjustable 1.7 ratio rockers?
  234. ok what is this i broke while taking off the intake last night?
  235. Help need info on what mods to do.
  236. need more info.
  237. strokers?
  238. Rod and main clearance's for 410 stroker and other info?
  239. MTI R1 Cam with Spray
  240. Anybody have any sound clips of Futural's F13 112
  241. Head Flow vs. Velocity
  242. Head and Cam install begins tonight!!
  243. Cam swap and Air/Fuel Ratio....
  244. Need some advice
  245. T Rex vs racenet's 238/240
  246. valve float? motor breaking up
  247. Hotcam plus 918s Big NONO???
  248. your thoughts on the 216/220 cam?
  249. Started my heads/cam tonight
  250. Cleaning cylinders of debris?
