View Full Version : Generation III Internal Engine
  1. complementing/choosing parts for 224?
  2. Pulling crank timing gear: What tool/method to use?
  3. complementing/choosing parts for 224?
  4. Which cometic gaskets have the water leaking issues, HD or MLS?
  5. Help me please! Install Cam or go nitrous?
  6. questions about oil pumps
  7. Grand am Cup cam information needed
  8. Cam Question
  9. Removal of cam bearing
  10. ATI dampener install different?
  11. 231 231 at 2 degrees adv or ret or straight up?
  12. bottom end access
  13. trex cam on stock ported heads.
  14. are the Eagle Crank issues worked out?
  15. 5.7 compression increase questions/comments
  16. Engine noise now taking bets
  17. rollmaster installation
  18. Help Opinions On Setup
  19. Will the T-Rex make significant power gains on heads?
  20. Good cam for gmpp cnc ls6 heads?
  21. cam help
  22. *** Paging Big Mike ***
  23. will exhaust improve driveability after a cam swap?
  24. 228R camshaft is in
  25. accessories for head install?
  26. do i need new springs with stock cam and 1.85 RR??
  27. MTI Stage 2E HEADS/ TR224 114LSA
  28. Help me pleeeease
  29. Patriot dual springs and Ti retainers
  30. It lives!
  31. Hank the Crank LS1 cranks....
  32. New Springs needed for 1.8 HS Rockers?
  33. Help with an LS6 problem
  34. Harland Sharpe Rocker install tips
  35. ?? on part #'s for 6.0 head swap
  36. When should you use titanium retainers?
  37. Bare or assembled
  38. Honing with a deck plate?
  39. Thinkin bout buildin a motor
  40. need some QUICK advice... any help appreciated
  41. Forged pistons with stock bottom end.
  42. ARP head studs
  43. TSP 231/237, PP II LS6 and PT4400
  44. oil pressure gauge
  45. Should I go Heads and Cam?
  46. What size socket for oil pressure sending unit?
  47. CAM for A4?
  48. rocker arms and set up
  49. Its Alive!!!.....
  50. Oil Pump O ring pn
  51. Cam split pattern logic and results?
  52. How much does it cost to change the seats in a set of heads?
  53. AFR heads = need different piston design?
  54. did I mess up my shortblock??
  55. Are comp 987 springs any good?
  56. Good cam to go with an ATI D1SC?
  57. Oh no, knocking noise from drive train.
  58. Do I have to change the stock retainers with the GM Hotcam
  59. Mti Stage 2e
  60. Can I use this cam on a stock engine?
  61. Patriot 228/224 112LSA cam?
  62. Knock-Out Boxes
  63. 7.4 or7.35 pushrods?
  64. 231-237 and bigger,, owners come in!!!
  65. New S2 Heads and X1 cam on Order should I Go to 90 mm LSX Fast Intake?
  66. Cam acc.
  67. help with oil pump issue!
  68. fms f13 peaks at ?
  69. Short block questions.
  70. Think I toasted a bearing?
  71. knocking after intake removal
  72. HEADS what kind ???
  73. engine stall after cam
  74. A head question (cfm) not asked everyday
  75. 6.0 block
  76. Anyone ever sleeve an iron 6.0 block? Details?
  77. F1 cam (.591/569) questions...`
  78. Need some SERIOUS help!!!!!
  79. JPR HVLD S2 flow #'s 2nd opinion and PCM info
  80. New timing set, crank gear wont go on all the way
  81. TRex Cam ?'s
  82. zero oil pressure...
  83. Might Be a Stupid Question: Can I Swap Cams W/O Uninstalling Springs?
  84. another 231/237 pp ls6
  85. ok guys, here is the TRex sound clip you all wanted
  86. Idiot dealer sent me wrong oil pump o-ring, can i reuse?
  87. HELP!! TR cam stamp - is it right?
  88. Valve Springs ?
  89. #799 casting aluminum LS6 head
  90. what allows a motor to rev high?
  91. smell oil burning
  92. pp stg 2 5.7 heads-224r cam dyno results
  93. Bring out your dead!
  94. Timing Chain Question........
  95. just installed a 224 cam......
  96. Got my HS rockers..**pics**
  97. Trying to keeep her idling after H/C, any tips?
  98. a4 guys (( heads and cam ))
  99. ported/polished LS1 heads
  100. ported or unported LS6 intake?
  101. WTF? Installed cam dot to dot...#1 at TDC???
  102. Is a 98 balancer the same as a 99 balancer?
  103. Need engine advice - Cam, and more
  104. Help! I Broke My Balancer During Cam Swap!!
  105. new used CAM, need some help
  106. Why use 5.3 heads?
  107. GEN-III cam base circle??
  108. 918 Springs???
  109. Gm Hotcam
  110. which block to use
  111. Cam Experts Please!
  112. Question about milling
  113. Whats the biggest cam i can run in a A4?
  114. Cam Experts Please
  115. East Side Performance Forged LS1 (Video)
  116. using 5.3L heads on a 408 .
  117. Lunati stroker kit problems
  118. Anyone else have a hard time ordering a big custom cam from Comp cams?
  119. What springs/retainers for G5X2
  120. 408 guys...what heads/cam???
  121. did I get the wrong springs
  122. Heads and cam are going on this weekend
  123. Heads and a Cam, what would you order?
  124. is 10% leakdown acceptable?
  125. stroker 6.0 - offset ground crank
  126. i want a BIGGER cam, need help!
  127. 427 Stroker If You Got One Whats Your Et?
  128. cam
  129. 99 f-body cam in Z71 5.3?
  130. Experts: How much do you know about dynamic cmpression ratio?
  131. What cam?
  132. 408 iron block info wanted
  133. Cost of Cam swap?
  134. Please tell me there is a way!!
  135. AFR UPDATE (Now Accepting Deposits!)
  136. Thicker head gaskets to for use with a TREX?
  137. Thinking about Absolute speed's STG 2.5's?
  138. Setting the Record STRAIGHT
  139. Whats the best lt1
  140. CC 978 springs overkill?
  141. Do heads need to be taken apart to be milled?
  142. Need Water Pump Help!
  143. Rods from Home Depot for cam swap
  144. Help! Have pin hole in one head!!
  145. Paging Pro Stock John
  146. What Head Casting #s Are The Best
  147. remove heads to remove lifters?
  148. what PSI is 10:1 compression?
  149. AFR Heads
  150. Angle Milling cylinder heads and radial P/V clearance
  151. GEN III Heads?
  152. which pushrods?
  153. Cam Suggestions
  154. Engine kocking/tapping
  155. Magic Stick R.2 Open Header Sound Clips Inside!!
  156. Stock Valves vs. Aftermarket
  157. Patriot Performance heads
  158. DIY hand finishing a cnc head?
  159. t1 cam in an a4
  160. MLS gasket??? reusable?? head bolted down for only two hours
  161. 799 head castings
  162. Would bouncing off the rev limiter with an A4 cause a valve spring to break?
  163. Blue SPrings lift numbers
  164. Started my Cam and Header install
  165. AP-Engineering 6.0 liter race head
  166. Patriot Heads
  167. AP-Engineering LS6 Race head
  168. valve spring tool
  169. Things they dont tell you about building a stroker..
  170. Any Problems with LS6 Valves & Aftermarket Cams
  171. H/C 405/385 Rwhp?
  172. What's she gonna do?
  173. Z06 Cam Specs vs 99 C5 Cam Specs... question>>
  174. Anyone mind calculating my CR?
  175. Help! I need more power, but cheap
  176. 427 Stroker Help
  177. If Money Was No Object
  178. Whats the Highest Rocker Ratio You Can Use??
  179. pcv valve fix question
  180. Got a good one for ya...
  181. Is a 112 lsa cam harder on springs than a 114 lsa
  182. DinoSim
  183. Cam Installation?
  184. LQ9 upgrades to 450-550 fwhp/fwtq
  185. Cam Guide
  186. TSP 231/237 & Patriot S2 Head Owners Come IN
  187. What else do I need?
  188. Can a person make a 400ci LS1 with just all bore?
  189. Valve hitting piston...?
  190. "Professionally Spec'd cams" where are they?
  191. Oil pan?
  192. What's the best oil to use?
  193. 77CC LS6 Heads from WCCH.
  194. Does NE1 have Sound Clips of Comp Cam 230/230 .592/.592 XER Cam?
  195. Ported vs. Regular Oil Pump
  196. Who's running a 108LSA cam?
  197. New Oil Pump From GM
  198. New race cam - 415RWHP on stock heads and stock exhaust-help with Atap & other stuff
  199. low compression cylinder #5
  200. LS6 intake flow
  201. Cam suggestions.
  202. What Cam is this?
  203. hollow ticking sound at idle, what do you think it is?
  204. what cam would you recommend for me?
  205. What spark plugs should i run????
  206. Engine noise(please help)
  207. MTI Stealth Cam
  208. cam choice :)
  209. 222/222 66/566 112,
  210. will boring cure piston slap?
  211. what cam for a 414
  212. Thermostat Temp
  213. Where to buy the GM Hotcam?
  214. Has Anyone Had Problems with Patriot's Dual Spring?
  215. I might be buying some heads....
  216. Which stock heads for LS6 cam? 5.3 or 5.7(241)
  217. good shops
  218. 5.7 S2 Heads
  219. Why does my 2000 T/A run like a 2000 GT?
  220. Wanted LS1 & LS6 Head Specs
  221. Cam swap completed!
  222. boaring the 5.3l block........
  223. balanceing rotating assembly ?????????
  224. Any ideas on what to look for?
  225. Cam question
  226. lt1 set up
  227. At what point do lifters need to be upgraded
  228. Help with cam choice
  229. PP ls6 stg2 Tsp 231/237 install
  230. a Duramax diesel sounding Z-28
  231. dropped valve seat
  232. Rebuild + Break In
  233. Eagle Cranks and Pilot Bearing??
  234. Hardened Pushrods Worth $100?
  235. Am I setting myself up for failure?
  236. everyone running FMS 30# injectors in thier big cube/stroke motors?
  237. What's the Choices For Taller Valve Covers??
  238. Pics from Australia
  239. Where to get heliCoil kits online? Size & lenght of Rocker bolt?
  240. Guesstimates on how much I'm gonna have to notch my pistons?
  241. Heads are off, what's best method for cleaning carbon off tops of pistons?
  242. Anyone have an ARE 228/228 575/575 cam?
  243. OK, crossthreaded rocker stud....
  244. Hmmm....Patriot Performance
  245. what valve seals are these (pics inside)?
  246. Anyone do a ls6 engine swap
  247. 3 failed lifters
  248. WTF!!! Car fouled out spark plugs right after H/C install
  249. Clean stage when swapping heads ??
  250. Cam talk...specifically the TR224-114...
